Hi, I am experiencing an issue where my computer is going to sleep earlier than what I have set in the Power Management settings.
System Info:
System: Kernel: 5.6.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64 root=UUID=6a1b4ac3-d886-4a59-9195-2d4a8147274c rw quiet apparmor=1
Desktop: KDE Plasma 5.18.4 tk: Qt 5.14.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0 serial: <filter> UEFI: American Megatrends
v: 1.80 date: 01/16/2020
CPU: Topology: 16-Core (2-Die) model: AMD Ryzen 9 3950X bits: 64 type: MT MCP MCM arch: Zen family: 17 (23)
model-id: 71 (113) stepping: N/A microcode: 8701013 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 224086
Speed: 3689 MHz min/max: 2200/3500 MHz boost: enabled Core speeds (MHz): 1: 3689 2: 3522 3: 3735 4: 3721 5: 3002
6: 3712 7: 3721 8: 3723 9: 3722 10: 3181 11: 3253 12: 3723 13: 3688 14: 2910 15: 3583 16: 3398 17: 2360 18: 3724
19: 3721 20: 3721 21: 3734 22: 3715 23: 3123 24: 3244 25: 3720 26: 3723 27: 3566 28: 3262 29: 3295 30: 2896
31: 3721 32: 3741
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] driver: amdgpu
v: kernel bus ID: 2f:00.0 chip ID: 1002:731f
Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: modesetting,radeon alternate: fbdev,vesa
compositor: kwin_x11 resolution: 3840x2160~120Hz
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.36.0 5.6.8-1-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.0.6
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 2f:00.1
chip ID: 1002:ab38
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 31:00.4 chip ID: 1022:1487
Device-3: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus ID: 5-1.3:4 chip ID: 046d:082d
serial: <filter>
Device-4: N/A type: USB driver: cdc_acm,hid-generic,snd-usb-audio,usbhid bus ID: 5-3.2:5 chip ID: 2833:0051
serial: <filter>
Sound Server: ALSA v: k5.6.8-1-MANJARO
Network: Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb v: 5.6.0-k port: e000 bus ID: 26:00.0
chip ID: 8086:1539
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 27:00.0
chip ID: 10ec:8125
IF: enp39s0 state: down mac: <filter>
Drives: Local Storage: total: 1.34 TiB used: 262.48 GiB (19.1%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP600 size: 953.87 GiB block size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 serial: <filter> rev: EGFM11.3 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-3: /dev/nvme2n1 vendor: Corsair model: Force MP510 size: 894.25 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: ECFM12.3 scheme: GPT
ID-4: /dev/sda vendor: SanDisk model: SDSSDH3 512G size: 476.94 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 1000 scheme: GPT
Partition: ID-1: / raw size: 893.96 GiB size: 878.92 GiB (98.32%) used: 80.53 GiB (9.2%) fs: ext4 dev: /dev/nvme2n1p2
Sensors: System Temperatures: cpu: 54.2 C mobo: N/A gpu: amdgpu temp: 44 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 65535
Info: Processes: 557 Uptime: 1d 56m Memory: 31.38 GiB used: 22.16 GiB (70.6%) Init: systemd v: 244 Compilers: gcc: 9.3.0
clang: 10.0.0 Shell: bash v: 5.0.16 running in: konsole inxi: 3.0.37
I have my Power Management settings set up to sleep after 4 hours (240 min):
However, I am finding that my system is going to sleep mode after about 30 minutes. Here is a snippet of the journalctl from last night. I walked away from my machine at around 11pm, and it went to sleep at around 11:30pm.
May 04 22:58:21 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: Enforcing inhibition from ":1.328" "/usr/bin/discord" with cookie 200 and reason "Playing audio"
May 04 22:58:21 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
May 04 22:59:27 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: Scheduling inhibition from ":1.334" "/usr/bin/discord" with cookie 201 and reason "Playing audio"
May 04 22:59:30 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: Releasing inhibition with cookie 201
May 04 22:59:30 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: It was only scheduled for inhibition but not enforced yet, just discarding it
May 04 22:59:32 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: Enforcing inhibition from ":1.334" "/usr/bin/discord" with cookie 201 and reason "Playing audio"
May 04 22:59:32 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: By the time we wanted to enforce the inhibition it was already gone; discarding it
May 04 23:09:30 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: Kbd backlight brightness value: 0
May 04 23:30:16 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Can't contact systemd
May 04 23:30:16 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Can't contact ck
May 04 23:30:16 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Suspend session triggered with QMap(("GraceFade", QVariant(bool, true))("Type", QVariant(uint, 1)))
May 04 23:30:16 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Suspend session triggered with QMap(("GraceFade", QVariant(bool, true))("SkipFade", QVariant(bool, true))("Type", QVariant(uint, 1)))
May 04 23:30:21 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Can't contact systemd
May 04 23:30:21 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Can't contact ck
May 04 23:30:21 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Suspend session triggered with QMap(("SkipFade", QVariant(bool, true))("Type", QVariant(uint, 1)))
May 04 23:30:21 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Starting Login1 suspend job
May 04 23:30:21 Manjaro-PC org_kde_powerdevil[4298]: powerdevil: Pausing all media players before sleep
May 04 23:30:21 Manjaro-PC org_kde_powerdevil[2057]: powerdevil: Pausing all media players before sleep
