Currently in my settings I have my monitor set to switch off after 15 minutes of inactivity. After 15 minutes it appears to work, monitor goes blank for about a few seconds but then it comes back on and this repeats. Ive tried unplugging my mouse & keyboard thinking maybe they are waking it back up but that had no effect. I've done an online search and most of what turned up was resuming issues i.e. monitor stays off. I've also tried changing the times but no luck still the same. I've also tried the force off command and it does go blank for a few seconds but again monitor will come back on. This has been going on for months now. I was hoping an update would have fixed it but no luck there either. Any help is appreciated. Thanks.
System: Host: sammy-ms7c02 Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: KDE Plasma 5.19.3
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0 serial: <root required>
UEFI: American Megatrends v: 3.60 date: 04/22/2020
CPU: Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86424
Speed: 4125 MHz min/max: 2200/3600 MHz Core speeds (MHz): 1: 4125 2: 2062 3: 2200 4: 2200 5: 2062 6: 2200 7: 2200
8: 2200 9: 4125 10: 2062 11: 2062 12: 2201
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 28:00.0
Display: x11 server: X.Org 1.20.8 driver: amdgpu FAILED: ati unloaded: modesetting,radeon tty: N/A
OpenGL: renderer: AMD Radeon RX 5600 XT (NAVI10 DRM 3.36.0 5.6.19-2-MANJARO LLVM 10.0.0) v: 4.6 Mesa 20.1.3
direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 28:00.1
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 2a:00.4
Sound Server: ALSA v: k5.6.19-2-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: f000 bus ID: 22:00.0
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: 00:d8:61:ab:62:4f
Drives: Local Storage: total: 3.66 TiB used: 345.18 GiB (9.2%)
ID-1: /dev/nvme0n1 model: Sabrent size: 953.87 GiB
ID-2: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-3: /dev/sdb type: USB vendor: Western Digital model: WD My Passport 0820 size: 931.48 GiB
Partition: ID-1: / size: 937.60 GiB used: 345.18 GiB (36.8%) fs: ext4 dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 51.0 C mobo: N/A gpu: amdgpu temp: 54 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 305 Uptime: 2h 12m Memory: 15.65 GiB used: 3.81 GiB (24.3%) Init: systemd Compilers: gcc: 10.1.0
Shell: bash v: 5.0.18 inxi: 3.0.37
