dmesg
while running 4.10.
WARNING: CPU: 5 PID: 406 at kernel/workqueue.c:2424 check_flush_dependency+0x122/0x130
workqueue: WQ_MEM_RECLAIM hci0:hci_power_off [bluetooth] is flushing !WQ_MEM_RECLAIM events:btusb_work [btusb]
New bug reported upstream: https://bugzilla.redhat.com/show_bug.cgi?id=1417144
OMG
MSI made crappy Firmware (ACPI Errors) and using crappy sub chipsets
Kernel 4.10 only works with Nvidia 378.13 which isn't available yet to us.
When I boot into 4.10 currently, it crashes with traces:
Mar 12 11:20:47 xmg kernel: BUG: scheduling while atomic: kworker/u16:4/363/0x00000002
Mar 12 11:20:47 xmg kernel: Modules linked in: bnep fuse hid_generic usbhid 8812au(O) cfg80211 uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_core videodev media joydev mousedev ath3k btusb btrtl btbcm btintel bluetooth rfkill msr intel_rapl x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm irqbypass snd_hda_codec_realtek crct10dif_pclmul snd_hda_codec_hdmi crc32_pclmul snd_hda_codec_generic crc32c_intel iTCO_wdt ghash_clmulni_intel iTCO_vendor_support pcbc snd_hda_intel rtsx_pci_ms mxm_wmi r8168(O) memstick aesni_intel aes_x86_64 crypto_simd glue_helper cryptd snd_hda_codec snd_soc_rt5640 mei_me intel_cstate ie31200_edac snd_soc_rl6231 snd_hda_core intel_rapl_perf snd_hwdep mei shpchp psmouse edac_core lpc_ich i2c_i801 input_leds thermal snd_soc_core snd_compress snd_pcm_dmaengine
Mar 12 11:20:47 xmg kernel: snd_pcm snd_timer snd soundcore snd_soc_sst_acpi ac97_bus i2c_hid snd_soc_sst_match elan_i2c hid wmi fjes evdev i2c_designware_platform spi_pxa2xx_platform battery 8250_dw mac_hid i2c_designware_core tpm_crb ac tpm_tis tpm_tis_core tpm sch_fq_codel uinput ip_tables x_tables ext4 crc16 jbd2 fscrypto mbcache sd_mod serio_raw atkbd libps2 rtsx_pci_sdmmc xhci_pci ahci xhci_hcd libahci libata usbcore scsi_mod rtsx_pci usb_common i8042 sdhci_acpi serio sdhci led_class mmc_core nvidia_drm(PO) nvidia_uvm(PO) nvidia_modeset(PO) nvidia(PO) i915 video button intel_gtt i2c_algo_bit drm_kms_helper syscopyarea sysfillrect sysimgblt fb_sys_fops drm
Mar 12 11:20:47 xmg kernel: CPU: 2 PID: 363 Comm: kworker/u16:4 Tainted: P O 4.10.1-1-MANJARO #1
Mar 12 11:20:47 xmg kernel: Hardware name: Clevo P65_P67SG /powered by premamod.com, BIOS 1.03.07PM v2 07/09/2015
Mar 12 11:20:47 xmg kernel: Workqueue: events_unbound intel_mmio_flip_work_func [i915]
Mar 12 11:20:47 xmg kernel: Call Trace:
Mar 12 11:20:47 xmg kernel: dump_stack+0x63/0x83
Mar 12 11:20:47 xmg kernel: __schedule_bug+0x54/0x70
Mar 12 11:20:47 xmg kernel: __schedule+0x588/0x700
Mar 12 11:20:47 xmg kernel: schedule+0x3d/0x90
Mar 12 11:20:47 xmg kernel: schedule_preempt_disabled+0x15/0x20
Mar 12 11:20:47 xmg kernel: __mutex_lock_slowpath+0x19b/0x2d0
Mar 12 11:20:47 xmg kernel: mutex_lock+0x23/0x30
Mar 12 11:20:47 xmg kernel: nvidia_drm_gem_prime_fence_op_signaled+0x2f/0x80 [nvidia_drm]
Mar 12 11:20:47 xmg kernel: nvidia_drm_gem_prime_fence_op_enable_signaling+0x39/0x130 [nvidia_drm]
Mar 12 11:20:47 xmg kernel: dma_fence_default_wait+0xb3/0x260
Mar 12 11:20:47 xmg kernel: ? sched_clock_cpu+0xa9/0xc0
Mar 12 11:20:47 xmg kernel: nvidia_drm_gem_prime_fence_op_wait+0x28/0x30 [nvidia_drm]
Mar 12 11:20:47 xmg kernel: dma_fence_wait_timeout+0x39/0x120
Mar 12 11:20:47 xmg kernel: ? dma_fence_free+0x20/0x20
Mar 12 11:20:47 xmg kernel: i915_gem_object_wait_fence+0x3c/0x190 [i915]
Mar 12 11:20:47 xmg kernel: i915_gem_object_wait_reservation+0xc3/0x2d0 [i915]
Mar 12 11:20:47 xmg kernel: ? put_prev_entity+0x31/0xa10
Mar 12 11:20:47 xmg kernel: ? pick_next_task_fair+0x300/0x4c0
Mar 12 11:20:47 xmg kernel: i915_gem_object_wait+0x15/0x30 [i915]
Mar 12 11:20:47 xmg kernel: intel_mmio_flip_work_func+0x50/0x2a0 [i915]
Mar 12 11:20:47 xmg kernel: process_one_work+0x1e5/0x470
Mar 12 11:20:47 xmg kernel: worker_thread+0x48/0x4e0
Mar 12 11:20:47 xmg kernel: kthread+0x101/0x140
Mar 12 11:20:47 xmg kernel: ? process_one_work+0x470/0x470
Mar 12 11:20:47 xmg kernel: ? kthread_create_on_node+0x60/0x60
Mar 12 11:20:47 xmg kernel: ret_from_fork+0x2c/0x40
Sorry for the delay of this answer. I took the time to think and to step back about this issue.
I've done some work, and now it's quite better (I think), but not fully functional.
Here it's the report of those actions
- I booted on a Live environment to use
mhwd-chroot
. (I don't know why, but mhwd freezed while simply running manjaro) - After mounting the partition, I've fully uninstalled, and then reinstalled,
video-hybrid-intel-nvidia-bumblebee
, following the step 1 of the manjaro wiki. (You're right @ryanmusante, it has automatically installed Nvidia 375.39) - Following the logs, I ran the following command
mhwd-gpu --setgl nvidia
- Once more, following the logs, I have edited a new file :
/etc/X11/xorg.conf.d/20-intel.conf
; with the following content. (http://pastebin.com/8U0C053Y) -
/!\ IMPORTANT : I disabled bumblebeed with
sudo systemctl disable bumblebeed
, then exitedmhwd-chroot
console, and reboot on Manjaro with Kernel 4.4.
@FadeMind
Now I'm able to run
optirun nvidia-smi
And here it's the output
Unfortunatly, the final test hasn't been OK yet
Indeed, after running glxspheres64
I've got the following output :
Polygons in scene: 62464 (61 spheres * 1024 polys/spheres)
Xlib: extension "GLX" missing on display ":0.0".
ERROR in line 620:
Cheers.
Hi Yonulya, my laptop has a similar setup (mine is a GE62), and I'm having exactly the same issue like yours. I have updated the BIOS to the latest version (112 instead of 118 like yours) given by MSI but ACPI error persists... but nvm. How do you disable bumblebeed.service ? Is it doable through GRUB?
Thank you
To only stop the service
sudo systemctl stop bumblebeed
So what I should is that to boot in live environment, then chroot and put in these commands? Since I can't boot into system. Nice pic btw
Oh how I miss the GUI. Thank you for the help. I'm living with my DE now lol
@Yonulya and @Da_Toast , take a look at this thread.
Your problem could be a TLP bumblebee conflict, if so the fix is in the thread.
Hi back guys
Above all, a small point of my (unsuccessful) work :
I tried with
video-nvidia
==> Worst idea ever. I wasn't able to reach the GUI. -
I tried
video-hybrid-intel-nouveau-bumblebee
==> Not so bad, but only works with Kernel 4.9 and not compatible with GTX960. So it used only the intel graphics. (Enough to play some light games awaiting to find a better solution)
@sueridgepipe
Thanks for reminding me this.
@michaldybczak has suggested this solution above, and since, I haven't retried it.
I will go back to the '4 days ago' configuration and try again.
@Da_Toast
Indeed, when you enable bumblebeed.service
, it create a symlink.
I don't really know why, but I seems this symlink freezed our boot.
[quote="Da_Toast, post:27, topic:19211, full:true"]
So what I should is that to boot in live environment, then chroot and put in these commands? Since I can't boot into system. Nice pic btw[/quote]
That's it. If you have some difficulties to use mhwd-chroot
, this tutorial of Heart-of-Lion explains very well how to use it.
Note : By using this tool, you can only use the disable
option of systemctl
. Others options aren't usable while using mhwd-chroot
. (Fortunately, that's enough to remove the symlink and reboot without troubles)
I'm coming soon with fresh news about the TLP issue.
Cheers
Hi,
That's weird. Finally, I found a kind of workaround, but I don't really understand what's happening.
Execute glxgears
or primusrun glxgears
returns the following messages :
Error: couldn't get an RGB, Double-buffered visual
But execute optirun glxgears
works fine.
[ 4763.107218] [INFO]Configured driver: nvidia
[ 4763.108743] [INFO]Response: Yes. X is active.
[ 4763.108769] [INFO]Running application using virtualgl.
Downgrade bumblebee
package to version 3.2.1-16, doesn't seems to have any effect.
Same for setting RUNTIME_PM_BLACKLIST
to the value returns by lspci | grep "NVIDIA" | cut -b -8
What's the difference between optirun
and primusrun
man
says one is running program with the discrete video card and the other with the discrete NVIDIA video card.
So what card I'm using ?
Cheers.
