--after installing and updating my system yesterday i have problem to boot to my session normally today i have just black screen with root session ( look pictures). help me to know problem. i reinstall my system twice .Sorry about the long topics
$ inxi -Fx
Kernel: 4.8.17-1-MANJARO x86_64 (64 bit gcc: 6.2.1)
Desktop: JWM 2.3.6 Distro: Manjaro Linux
Machine: Device: laptop System: ASUSTeK product: K53E v: 1.0
Mobo: ASUSTeK model: K53E v: 1.0
BIOS: American Megatrends v: K53E.219 date: 03/06/2012
CPU: Dual core Intel Core i5-2450M (-HT-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9983
clock speeds: max: 3100 MHz 1: 799 MHz 2: 799 MHz 3: 800 MHz
4: 801 MHz
Graphics: Card: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
bus-ID: 00:02.0
Display Server: X.Org 1.19.1 driver: intel
Resolution: 1366x768@60.00hz
GLX Renderer: Mesa DRI Intel Sandybridge Mobile
GLX Version: 3.0 Mesa 13.0.3 Direct Rendering: Yes
Audio: Card Intel 6 Series/C200 Series Family High Definition Audio Controll
Drives: HDD Total Size: 750.2GB (2.9% used)
ID-1: /dev/sda model: ST9750420AS size: 750.2GB
Partition: ID-1: / size: 118G used: 9.8G (9%) fs: ext4 dev: /dev/sda2
ID-2: /boot size: 477M used: 46M (11%) fs: ext4 dev: /dev/sda1
ID-3: /home size: 265G used: 2.5G (1%) fs: ext4 dev: /dev/sda3
ID-4: swap-1 size: 8.70GB used: 0.00GB (0%) fs: swap dev: /dev/sda4
Sensors: System Temperatures: cpu: 36.0C mobo: N/A
Fan Speeds (in rpm): cpu: 2300
Info: Processes: 153 Uptime: 13 min Memory: 774.6/5749.5MB
Init: systemd Gcc sys: 6.3.1
Client: Shell (bash 4.4.51) inxi: 2.3.5
Manjaro still doesn't play nice with other Distro's, ..., not sure about Win10 either. ?
no sir just manjaro in drive
in error i view manjaro cant mount disk uuid x2d7....
yeah I'm in manjaro but i want understand why i have this error
When you can enter your system, AFTER update BUT BEFORE restart, please do this:
sudo mkinitcpio -P
sudo update-grub
I dont know why but in some rare cases the linux hook dont work and it'll not run mkinitcpio after kernel upgrade by itself and you're not able to boot successfull
ok thanks man
i faced this problem too but i installed manjaro again to solve it. does this solution will help me if i decided to update my system now . i afraid to update system after this problem .
Does updateing manjaro will break the system?!
