Problem with shortcuts and IntelliJ
I use IntelliJ on Manjaro and I need to run a program with an external jar (Gurobi).
The problem is this: if I launch IntelliJ from Application Launcher or Terminal and I run the Java program on IntelliJ, I get the error java.lang.UnsatisfiedLinkError: no gurobijni90 in java.build.path.
Then, (also in order to see the log outputs of the run) I try to launch IntelliJ navigating in its installation folder: cd /opt/idea-IC-201.7846.76/bin, I run ./idea.sh and everything works (no error and Gurobi works fine).
If I create a keyboard shortcut to run the commands cd /opt/idea-IC-201.7846.76/bin && ./idea.sh or /opt/idea-IC-201.7846.76/bin/idea.sh the program IntelliJ is launched, but no terminal windows is shown. If I run the java program that includes Gurobi (the external jar), I get the same error as above (like the first case I described).
If I run any java program that does not include external jars or libraries, everything works always fine.
I really do not know what to do, because I do not want to launch IntelliJ everytime by navigating in its folder and then launching the .sh file.
Thanks to everybody in advance!
