Problem with Windows 10 ISO on USB
Hi,
so I wanted to switch back to Windows 10 because I'm having tons of problems using any Linux distro for some reason, so I'm trying to put the installation ISO of Windows 10 on my USB (a 15 GB one) but there's always a problem, even while following the post suggested by the Manjaro Wiki itself ([HowTo] Use Manjaro to create a bootable Windows USB).
While using the WoeUSB software I receive a message stating that the ISO exceeds the maximum single file size of 4 GB (the windows 10 ISO is 4.9 GB), so I tried to use the CLI procedure but with that when I try to boot from the USB nothing happens and Manjaro starts instead.
Here the complete procedure I did on both the attempts:
Istantanea_2019-11-01_16-55-05
CLI procedure terminal:
[david@manjaro ~]$ lsblk -la
NAME  MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0   7:0    0         1 loop
loop1   7:1    0         0 loop
loop2   7:2    0         0 loop
loop3   7:3    0         0 loop
loop4   7:4    0         0 loop
loop5   7:5    0         0 loop
loop6   7:6    0         0 loop
loop7   7:7    0         0 loop
sda     8:0    0 931,5G  0 disk
sda1    8:1    0 931,5G  0 part
sdb     8:16   0 931,5G  0 disk
sdb1    8:17   0 931,5G  0 part /
sdc     8:32   0 931,5G  0 disk
sdc1    8:33   0 931,5G  0 part
loop0   7:0    0         1 loop
loop1   7:1    0         0 loop
loop2   7:2    0         0 loop
loop3   7:3    0         0 loop
loop4   7:4    0         0 loop
loop5   7:5    0         0 loop
loop6   7:6    0         0 loop
loop7   7:7    0         0 loop
sdd     8:48   1  14,4G  0 disk
sdd1    8:49   1  14,4G  0 part
[david@manjaro ~]$ sudo dd if=/dev/zero of=/dev/sdd bs=1M count=10 oflag=sync
[sudo] password di david:
10+0 record dentro
10+0 record fuori
10485760 bytes (10 MB, 10 MiB) copied, 0,660068 s, 15,9 MB/s
[david@manjaro ~]$ sudo fdisk /dev/sdd
Welcome to fdisk (util-linux 2.34).
Changes will remain in memory only, until you decide to write them.
Be careful before using the write command.
Device does not contain a recognized partition table.
Created a new DOS disklabel with disk identifier 0x7f3ce906.
Comando (m per richiamare la guida): o
Created a new DOS disklabel with disk identifier 0x78a86c37.
Comando (m per richiamare la guida): n
Partition type
   p   primary (0 primary, 0 extended, 4 free)
   e   extended (container for logical partitions)
Select (default p):
Using default response p.
Numero della partizione (1-4, default 1):
First sector (2048-30218841, default 2048):
Last sector, +/-sectors or +/-size{K,M,G,T,P} (2048-30218841, default 30218841):
Created a new partition 1 of type 'Linux' and of size 14,4 GiB.
Comando (m per richiamare la guida): t
Selected partition 1
Hex code (type L to list all codes): c
Changed type of partition 'Linux' to 'W95 FAT32 (LBA)'.
Comando (m per richiamare la guida): a
The bootable flag on partition 1 is enabled now.
Comando (m per richiamare la guida): w
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
[david@manjaro ~]$ sudo mkfs.vfat -F 32 /dev/sdd1
mkfs.fat 4.1 (2017-01-24)
[david@manjaro ~]$ mkdir ~/winiso
[david@manjaro ~]$ sudo mount -o loop windows.iso ~/winiso
mount: /home/david/winiso: WARNING: device write-protected, mounted read-only.
[david@manjaro ~]$ mkdir ~/winusb
[david@manjaro ~]$ cd ~/winiso
[david@manjaro winiso]$ cp -r * ~/winusb
[david@manjaro winiso]$ sync
[david@manjaro winiso]$ cd ~
[david@manjaro ~]$ sudo umount ~/winiso ~/winusb
umount: /home/david/winusb: not mounted.
[david@manjaro ~]$ rm -f ~/winiso ~/winusb
rm: impossibile rimuovere '/home/david/winiso': È una directory
rm: impossibile rimuovere '/home/david/winusb': È una directory
Reading through your terminal output - it makes me reallize - you didn't mount your usb device to ~/winusb.
The cleanup command is missing the recursive flag on the rm command - I have fixed the guide
rm -rf ~/winiso ~/winusb
Yeah sorry I did a mistake, it was the third time I was trying to do this. Right now I get an error message that I got before, saying I don't permissions to copy the files:
[david@manjaro ~]$ sudo mount /dev/sde1 ~/winusb
cp: impossibile creare il file regolare '/home/david/winusb/autorun.inf': Permesso negato
cp: impossibile creare la directory '/home/david/winusb/boot': Permesso negato
cp: impossibile creare il file regolare '/home/david/winusb/bootmgr': Permesso negato
cp: impossibile creare il file regolare '/home/david/winusb/bootmgr.efi': Permesso negato
cp: impossibile creare la directory '/home/david/winusb/efi': Permesso negato
cp: impossibile creare il file regolare '/home/david/winusb/setup.exe': Permesso negato
cp: impossibile creare la directory '/home/david/winusb/sources': Permesso negato
cp: impossibile creare la directory '/home/david/winusb/support': Permesso negato
I thought this was caused by the "read-only" state that I got in every attempt but I can't find the right way to make it read and write.
EDIT:
I've tried with adding sudo too but using that it just gets stuck with no response, last time if I remember correctly it stated that the file was too large just like in WoeUSB, I'm running it again to generate again the error.
Try using WoeUSB and select NTFS for filesystem.
I will take another look at the guide - test the manual way with NTFS
Your permission issues is because you - forgot to mount the iso in a previous step.
You have copied all the files from the ISO to a folder in your home - and maybe you have mixed in sudo in the creation of the folders or the copying or you you have switched the folder mounts.
In any case - the solution is to unmount your device and use sudo to remove the folders.
sudo umount /dev/sde1
Remove the folders
sudo rm -rf /home/david/winusb /home/david/winiso
Then you have a clean state and can try again - if the NTFS selection in WoeUSB fails you.
It seems to be working fine now, thank you very much!
I hope to eventually fix all the performance problems I'm having with manjaro to come back on it one day.
Edit: grammar fix.
