Problems with Kernel 5.7 and Nvidia hybrid
Hello everyone,
After the last stable update (I'm using Manjaro Gnome) I also upgraded my kernel to 5.7.9-1.
The problem is it seems there's some problem when loading the Nvidia drivers with this kernel.
I had this problem before, but I didn't bother fixing because it was with the RC kernel.
Everything works fine in kernels 5.6.19 and earlier.
The Xorg.0.log looks like this:
[     5.792] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     5.795] (II) Module modesetting: vendor="X.Org Foundation"
[     5.795]    compiled for 1.20.8, module version = 1.20.8
[     5.795]    Module class: X.Org Video Driver
[     5.795]    ABI class: X.Org Video Driver, version 24.1
[     5.795] (II) LoadModule: "fbdev"
[     5.796] (WW) Warning, couldn't open module fbdev
[     5.796] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     5.796] (II) LoadModule: "vesa"
[     5.797] (WW) Warning, couldn't open module vesa
[     5.797] (EE) Failed to load module "vesa" (module does not exist, 0)
[     5.798] (II) NVIDIA dlloader X Driver  440.100  Fri May 29 08:21:27 UTC 2020
[     5.798] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     5.799] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     5.799] (WW) Falling back to old probe method for modesetting
[     5.799] (II) systemd-logind: releasing fd for 226:0
[     5.802] (II) Loading sub module "fb"
[     5.802] (II) LoadModule: "fb"
[     5.802] (II) Loading /usr/lib/xorg/modules/libfb.so
[     5.804] (II) Module fb: vendor="X.Org Foundation"
[     5.804]    compiled for 1.20.8, module version = 1.0.0
[     5.804]    ABI class: X.Org ANSI C Emulation, version 0.4
[     5.804] (II) Loading sub module "wfb"
[     5.804] (II) LoadModule: "wfb"
[     5.804] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     5.807] (II) Module wfb: vendor="X.Org Foundation"
[     5.807]    compiled for 1.20.8, module version = 1.0.0
[     5.807]    ABI class: X.Org ANSI C Emulation, version 0.4
[     5.807] (II) Loading sub module "ramdac"
[     5.807] (II) LoadModule: "ramdac"
[     5.807] (II) Module "ramdac" already built-in
[     5.811] (EE) Screen 0 deleted because of no matching config section.
[     5.811] (II) UnloadModule: "modesetting"
[     5.811] (EE) Device(s) detected, but none match those in the config file.
[     5.811] (EE)
Fatal server error:
[     5.812] (EE) no screens found(EE)
[     5.812] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[     5.812] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     5.812] (EE)
[     5.814] (EE) Server terminated with error (1). Closing log file.
I'm using the video-hybrid-intel-nvidia-440x-prime in my Dell Inspiron 7560-A30S laptop.
The system specs are below.
Can anyone point me in the right direction to solve this problem?
System:    Host: bitz-dell Kernel: 5.6.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0 Desktop: Gnome 3.36.4
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Inspiron 7560 v: N/A serial: <filter>
           Mobo: Dell model: 09WC1G v: A01 serial: <filter> UEFI: Dell v: 1.1.6 date: 07/19/2017
Battery:   ID-1: BAT0 charge: 11.3 Wh condition: 11.3/42.0 Wh (27%) model: LGC-LGC3.553 DELL 8YPRW79 status: Full
           Device-1: hidpp_battery_0 model: Logitech M570 charge: 30% status: Discharging
CPU:       Topology: Dual Core model: Intel Core i7-7500U bits: 64 type: MT MCP arch: Amber Lake rev: 9 L2 cache: 4096 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 23209
           Speed: 700 MHz min/max: 400/3500 MHz Core speeds (MHz): 1: 700 2: 700 3: 700 4: 700
Graphics:  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Dell driver: nvidia v: 440.100 bus ID: 01:00.0
           Display: x11 server: X.org 1.20.8 driver: modesetting,nvidia resolution: <xdpyinfo missing>
           OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.1.3 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3
           Sound Server: ALSA v: k5.6.19-2-MANJARO
Network:   Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
           port: e000 bus ID: 02:00.0
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8168 v: 8.048.03-NAPI
           port: d000 bus ID: 03:00.0
           Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-8:9
Drives:    Local Storage: total: 1.03 TiB used: 263.36 GiB (25.1%)
           ID-1: /dev/sda vendor: Western Digital model: WD10SPZX-75Z10T0 size: 931.51 GiB
           ID-2: /dev/sdb vendor: LITE-ON model: CV3-8D128-11 SATA 128GB size: 119.24 GiB
Partition: ID-1: / size: 58.06 GiB used: 37.13 GiB (63.9%) fs: ext4 dev: /dev/sdb5
           ID-2: swap-1 size: 17.17 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
Sensors:   System Temperatures: cpu: 39.0 C mobo: 37.0 C sodimm: 36.0 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 266 Uptime: 43m Memory: 15.54 GiB used: 3.62 GiB (23.3%) Init: systemd Compilers: gcc: 10.1.0
           clang: 10.0.0 Shell: bash v: 5.0.18 inxi: 3.0.37
you should check in log
sudo journalctl -b0 -f drm
sudo journalctl -b0 -f nvidia
I have used the commands but they gave me an error.
hmcezar@bitz-dell ~]$ sudo journalctl -b0 -f drm
[sudo] senha para hmcezar:
Failed to add match 'drm': Argumento inválido
[hmcezar@bitz-dell ~]$ sudo journalctl -b0 -f nvidia
Failed to add match 'nvidia': Argumento inválido
I went to the journalctl manual and tried to fix them but I think I couldn't.
[hmcezar@bitz-dell ~]$ sudo journalctl -b -1 -f -u nvidia
-- Logs begin at Fri 2019-06-21 08:59:02 -03. --
^C
[hmcezar@bitz-dell ~]$ sudo journalctl -b -1 -f -u drm
^C
I'm using -b -1 because it was the last boot (when I tried kernel 5.7) that I had the problem. Now I'm in 5.6.19 and it's fine.
