Problems with wifi in Linux 5.7 kernel
So.. that, with kernel 5.6 it worked well so.. What can be the problem?
Is it for the kernel itself or a manjaro bug?
With 5.4 and 5.6 it works, 5.7 not. I have the rt3090 wireless card
Hi!
try adding to module
sudo modprobe rt2800pci
Not working. The module is loaded already so.. no
Hi!
try this nmcli c up Wifi_name --ask
If it work, it should ask for your wifi passwd
It doesn't detect anything so.. this is not gonna work I think but I will try.
Anyways is not logical that Linux 57 don't work but Linux 54 and 56 yes, I think
