Python Tkinter execution issues
Hello Everyone,
I am very new to manjaro and pacman and I was unable to find anything about this.
I am trying to run some python-tkinter apps that I wrote earlier on ubuntu and I am getting this error when doing the tkinterr._test() command (similar error with my other programs):
[julius@Pinebook ~]$ python
Python 3.8.3 (default, May 19 2020, 23:51:58)
[GCC 9.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tkinter
>>> dir(tkinter)
['ACTIVE', 'ALL', 'ANCHOR', 'ARC', 'BASELINE', 'BEVEL', 'BOTH', 'BOTTOM', 'BROWSE', 'BUTT', 'BaseWidget', 'BitmapImage', 'BooleanVar', 'Button', 'CASCADE', 'CENTER', 'CHAR', 'CHECKBUTTON', 'CHORD', 'COMMAND', 'CURRENT', 'CallWrapper', 'Canvas', 'Checkbutton', 'DISABLED', 'DOTBOX', 'DoubleVar', 'E', 'END', 'EW', 'EXCEPTION', 'EXTENDED', 'Entry', 'Event', 'EventType', 'FALSE', 'FIRST', 'FLAT', 'Frame', 'GROOVE', 'Grid', 'HIDDEN', 'HORIZONTAL', 'INSERT', 'INSIDE', 'Image', 'IntVar', 'LAST', 'LEFT', 'Label', 'LabelFrame', 'Listbox', 'MITER', 'MOVETO', 'MULTIPLE', 'Menu', 'Menubutton', 'Message', 'Misc', 'N', 'NE', 'NO', 'NONE', 'NORMAL', 'NS', 'NSEW', 'NUMERIC', 'NW', 'NoDefaultRoot', 'OFF', 'ON', 'OUTSIDE', 'OptionMenu', 'PAGES', 'PIESLICE', 'PROJECTING', 'Pack', 'PanedWindow', 'PhotoImage', 'Place', 'RADIOBUTTON', 'RAISED', 'READABLE', 'RIDGE', 'RIGHT', 'ROUND', 'Radiobutton', 'S', 'SCROLL', 'SE', 'SEL', 'SEL_FIRST', 'SEL_LAST', 'SEPARATOR', 'SINGLE', 'SOLID', 'SUNKEN', 'SW', 'Scale', 'Scrollbar', 'Spinbox', 'StringVar', 'TOP', 'TRUE', 'Tcl', 'TclError', 'TclVersion', 'Text', 'Tk', 'TkVersion', 'Toplevel', 'UNDERLINE', 'UNITS', 'VERTICAL', 'Variable', 'W', 'WORD', 'WRITABLE', 'Widget', 'Wm', 'X', 'XView', 'Y', 'YES', 'YView', '__builtins__', '__cached__', '__doc__', '__file__', '__loader__', '__name__', '__package__', '__path__', '__spec__', '_cnfmerge', '_default_root', '_exit', '_flatten', '_join', '_magic_re', '_setit', '_space_re', '_splitdict', '_stringify', '_support_default_root', '_test', '_tkerror', '_tkinter', '_varnum', 'constants', 'enum', 'getboolean', 'getdouble', 'getint', 'image_names', 'image_types', 'mainloop', 're', 'sys', 'wantobjects']
>>> tkinter._test()
  File "<stdin>", line 1, in <module>
  File "/usr/lib/python3.8/tkinter/__init__.py", line 4552, in _test
    root = Tk()
  File "/usr/lib/python3.8/tkinter/__init__.py", line 2261, in __init__
    self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: unknown color name "BACKGROUND"
tldr: there is an issue with initialising tkinter.
I installed python tkinter with
sudo pacman -Syu tk
as it was suggested on the internet. I also tried with pip but it would not work.
some system information:
  • aarch64 cpu architecture
  • linux 5.7.0 manjaro arm
  • python 3.8.3
thank you in advance and please ask if you have further questions about the setup.
Best Regards, Julius
Hello antman,
thanks for the reply, I looked this error up already, but I wasn't finding any useful information. The problem is that the error is from tkinter/init.py which is not a file that I wrote. Instead, the error comes up when it executes the root = tk.Tk() function.
I looked up /usr/lib/python3.8/tkinter/__init__.py.
This error should not happen when tkinter is installed correctly and it seems like the instruction that I found on the internet don't work for me.
Please try this out to see if it solves your problem
xrdb -load /dev/null
xrdb -query
Hello Experimenter,
thanks for this reply, it worked!
