Qt5 issues after updating
Hi There,
so here i am a new manjaro user coming from Ubuntu and super happy with this distro :+1::+1:
I think this problem caused by an update of qt, because now all qt applications won't start ending with core dumped. It happens when starting vlc, kdenlive, clemntine, ...
[mickey@ph ~]$ vlc
VLC media player 3.0.7.1 Vetinari (revision 3.0.7.1-0-gf3940db4af)
[0000557c4196c630] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
qt5ct: using qt5ct plugin
Cannot mix incompatible Qt library (version 0x50c04) with this library (version 0x50d00)
Aborted (core dumped)
[mickey@ph ~]$ kdenlive
[mickey@ph ~]$
Any suggestions on how to solve this issue?
Running Manjaro MATE stable, 4.19.56-1-MANJARO x86_64
Greetings
Mickey
Which qt5-base and which qt5ct is used? We checked to update both as needed.
qt5-base 5.13.0-7.1
Qt5 Settings (qt5ct) 0.39-1
qt5ct 0.39-2 is the match. Please check why that is still revision 1.
Hi,
after some search, I need to upgrade qtct5 and qt5-styleplugins
sudo pacman -U http://archlinux.thaller.ws/community/os/x86_64/qt5ct-0.39-2-x86_64.pkg.tar.xz
pacman -U https://mex.mirror.pkgbuild.com/community/os/x86_64/qt5-styleplugins-5.0.0.20170311-15-x86_64.pkg.tar.xz
Hi,
Thanks for all your feedback. I have reinstalled Manjaro in primary of some partitions and disks issues anyway so everything is super fine now. Thank you @trimbode for this way of installing packages with pacman but where did you find these URLs? Thank you for a great and fast OS!
Best Regards
Mickey :slightly_smiling_face:
