TL;DR I have a Radeon 6770 and I'm using the free driers. Is my GPU really too old to work properly as mentioned here and here? Blender shows interesting graphical glitches like this when I render (for a second or two):
Longer version: I'm dual-booting. On Windows, I'm using a proprietary Windows driver. Blender works fine; on Manjaro, it crashed whenever I save/export (after some work, it now saves/exports fine, but shows weird GPU glitches like the screenshot above, for a few seconds.)
I am a noob, and I tried several things, so here's an information dump.
- On Windows, Blender reports that I have OpenCL 1.2; on Linux, it reports Open CL 1.1
- I ran
sudo mhwd -a pci free 0300
and it saidSkipping already installed config 'video-linux' for device: 0000:01:00.0 (0300:1002:68ba) Display controller ATI Technologies Inc Juniper XT [Radeon HD 6770]
, which means the right driver is installed - A friend suggested I install several packages; notably:
radeontool
,lib32-opencl-mesa
,lib32-vulkan-radeon
. I had previously installedopencl-mesa
andvulkan-radeon
- After installing those packages, I reached the current problem, albeit Blender now mentions OpenCL (previously, it said OpenCL isn't supported)
Here's a partial dump from system-info
from Blender:
OpenGL:
renderer: 'AMD JUNIPER (DRM 2.50.0 / 5.4.43-1-MANJARO, LLVM 10.0.0)'
vendor: 'X.Org'
version: '3.3 (Core Profile) Mesa 20.0.7'
extensions:
OpenCL device capabilities:
Number of platforms: 1
Platform #0
Platform Name: Clover
Platform Vendor: Mesa
Platform Version: OpenCL 1.1 Mesa 20.0.7
Platform Profile: FULL_PROFILE
Platform Extensions: cl_khr_icd
Number of devices: 1
Device: #0
Device Name: AMD JUNIPER (DRM 2.50.0 / 5.4.43-1-MANJARO, LLVM 10.0.0)
Device Vendor: AMD
Device OpenCL C Version: OpenCL C 1.1
Device Profile: FULL_PROFILE
Device Version: OpenCL 1.1 Mesa 20.0.7
Device Extensions: cl_khr_byte_addressable_store cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics
Device Max clock frequency (MHz): 850
Device Max compute units: 10
Device Max work group size: 256
The same thing on Windows reports OpenGL 4.5.
sudo dmesg | grep radeon
shows:
[ 10.491359] [drm] radeon kernel modesetting enabled.
[ 10.491403] radeon 0000:01:00.0: remove_conflicting_pci_framebuffers: bar 0: 0xd0000000 -> 0xdfffffff
[ 10.491405] radeon 0000:01:00.0: remove_conflicting_pci_framebuffers: bar 2: 0xe1420000 -> 0xe143ffff
[ 10.491407] fb0: switching to radeondrmfb from VESA VGA
[ 10.491466] radeon 0000:01:00.0: vgaarb: deactivate vga console
[ 10.491762] radeon 0000:01:00.0: VRAM: 1024M 0x0000000000000000 - 0x000000003FFFFFFF (1024M used)
[ 10.491763] radeon 0000:01:00.0: GTT: 1024M 0x0000000040000000 - 0x000000007FFFFFFF
[ 10.492098] [drm] radeon: 1024M of VRAM memory ready
[ 10.492098] [drm] radeon: 1024M of GTT memory ready.
[ 10.768606] [drm] radeon: dpm initialized
[ 10.827973] [drm] enabling PCIE gen 2 link speeds, disable with radeon.pcie_gen2=0
[ 10.854525] radeon 0000:01:00.0: WB enabled
[ 10.854527] radeon 0000:01:00.0: fence driver on ring 0 use gpu addr 0x0000000040000c00 and cpu addr 0x000000006861a7c9
[ 10.854528] radeon 0000:01:00.0: fence driver on ring 3 use gpu addr 0x0000000040000c0c and cpu addr 0x00000000b1571102
[ 10.854894] radeon 0000:01:00.0: fence driver on ring 5 use gpu addr 0x000000000005c418 and cpu addr 0x0000000033b9c1ea
[ 10.854897] radeon 0000:01:00.0: radeon: MSI limited to 32-bit
[ 10.854935] radeon 0000:01:00.0: radeon: using MSI.
[ 10.854954] [drm] radeon: irq initialized.
[ 11.818703] fbcon: radeondrmfb (fb0) is primary device
[ 11.818707] radeon 0000:01:00.0: fb0: radeondrmfb frame buffer device
[ 11.850852] [drm] Initialized radeon 2.50.0 20080528 for 0000:01:00.0 on minor 0
Perhaps most importantly, ixni -Fxxxz
now shows a driver failure?:
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Juniper XT [Radeon HD 6770] vendor: ASUSTeK driver: radeon v: kernel
bus ID: 01:00.0 chip ID: 1002:68ba
Display: x11 server: X.Org 1.20.8 driver: radeon FAILED: ati unloaded: modesetting alternate: fbdev,vesa
compositor: kwin_x11 resolution: 1280x1024_60.00~60Hz, 1440x900~75Hz
OpenGL: renderer: AMD JUNIPER (DRM 2.50.0 / 5.4.43-1-MANJARO LLVM 10.0.0) v: 3.3 Mesa 20.0.7 compat-v: 3.1
direct render: Yes
Is there any thing I can do now to improve my GPU situation, other than buying a newer card?
