Hi,
Since i installed manjaro I3 two weeks ago, everything works except when i boot i got a blank screen, and i need to reboot 5 times or more to get the login screen and do my stuff. i tried with i915.modeset=1 and i got the same result. I also tried to set nvidia.modeset=0, maybe because of a mismatch with the drivers, or with another login manager but nothing changed.
So i checked the logs, and it seems (from lightdm logs) that the X server didn't start successfully, but i doesn't see where it fails, maybe someone can tell me for what reasons the server didn't start.
journalct -b -1
sept. 02 02:29:26 isos-pc kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=003dc175-12db-4b19-b9c1-469ed7def564 rw quiet resume=UUID=eb12fb71-fba9-4509-ba11-41cf191c84d7 nvidia.modeset=0
sept. 02 02:29:26 isos-pc kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
sept. 02 02:29:26 isos-pc kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
sept. 02 02:29:26 isos-pc kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
sept. 02 02:29:26 isos-pc kernel: x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
sept. 02 02:29:26 isos-pc kernel: x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
sept. 02 02:29:26 isos-pc kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
sept. 02 02:29:26 isos-pc kernel: x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
sept. 02 02:29:26 isos-pc kernel: x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
sept. 02 02:29:26 isos-pc kernel: x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
sept. 02 02:29:26 isos-pc kernel: e820: BIOS-provided physical RAM map:
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x000000000009e000-0x000000000009efff] reserved
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] usable
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000c70fafff] usable
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000c70fb000-0x00000000c75fafff] type 20
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000c75fb000-0x00000000c7c7efff] reserved
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000c7c7f000-0x00000000c7e7efff] ACPI NVS
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000c7e7f000-0x00000000c7efefff] ACPI data
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000c7eff000-0x00000000c7efffff] usable
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000c7f00000-0x00000000cc7fffff] reserved
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000f80fa000-0x00000000f80fafff] reserved
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000f80fd000-0x00000000f80fdfff] reserved
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
sept. 02 02:29:26 isos-pc kernel: BIOS-e820: [mem 0x0000000100000000-0x00000002317fffff] usable
sept. 02 02:29:26 isos-pc kernel: NX (Execute Disable) protection: active
sept. 02 02:29:26 isos-pc kernel: efi: EFI v2.40 by HP
sept. 02 02:29:26 isos-pc kernel: efi: ACPI=0xc7efe000 ACPI 2.0=0xc7efe014 SMBIOS=0xc78db000 MPS=0xc794b000 ESRT=0xc7073660
sept. 02 02:29:26 isos-pc kernel: SMBIOS 2.7 present.
sept. 02 02:29:26 isos-pc kernel: DMI: HP HP EliteBook 840 G3/8079, BIOS N75 Ver. 01.10 07/31/2016
sept. 02 02:29:26 isos-pc kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
sept. 02 02:29:26 isos-pc kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
sept. 02 02:29:26 isos-pc kernel: e820: last_pfn = 0x231800 max_arch_pfn = 0x400000000
sept. 02 02:29:26 isos-pc kernel: MTRR default type: write-back
sept. 02 02:29:26 isos-pc kernel: MTRR fixed ranges enabled:
sept. 02 02:29:26 isos-pc kernel: 00000-9FFFF write-back
sept. 02 02:29:26 isos-pc kernel: A0000-BFFFF uncachable
sept. 02 02:29:26 isos-pc kernel: C0000-FFFFF write-protect
sept. 02 02:29:26 isos-pc kernel: MTRR variable ranges enabled:
sept. 02 02:29:26 isos-pc kernel: 0 base 00E0000000 mask 7FE0000000 uncachable
sept. 02 02:29:26 isos-pc kernel: 1 base 00D0000000 mask 7FF0000000 uncachable
sept. 02 02:29:26 isos-pc kernel: 2 base 00CC000000 mask 7FFC000000 uncachable
sept. 02 02:29:26 isos-pc kernel: 3 base 00CA000000 mask 7FFE000000 uncachable
sept. 02 02:29:26 isos-pc kernel: 4 disabled
sept. 02 02:29:26 isos-pc kernel: 5 disabled
sept. 02 02:29:26 isos-pc kernel: 6 disabled
sept. 02 02:29:26 isos-pc kernel: 7 disabled
sept. 02 02:29:26 isos-pc kernel: 8 disabled
sept. 02 02:29:26 isos-pc kernel: 9 disabled
sept. 02 02:29:26 isos-pc kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
sept. 02 02:29:26 isos-pc kernel: e820: last_pfn = 0xc7f00 max_arch_pfn = 0x400000000
sept. 02 02:29:26 isos-pc kernel: esrt: ESRT header is not in the memory map.
sept. 02 02:29:26 isos-pc kernel: Scanning 1 areas for low memory corruption
sept. 02 02:29:26 isos-pc kernel: Base memory trampoline at [ffff8816c0097000] 97000 size 24576
sept. 02 02:29:26 isos-pc kernel: Using GB pages for direct mapping
sept. 02 02:29:26 isos-pc kernel: BRK [0x0c63a000, 0x0c63afff] PGTABLE
sept. 02 02:29:26 isos-pc kernel: BRK [0x0c63b000, 0x0c63bfff] PGTABLE
sept. 02 02:29:26 isos-pc kernel: BRK [0x0c63c000, 0x0c63cfff] PGTABLE
sept. 02 02:29:26 isos-pc kernel: BRK [0x0c63d000, 0x0c63dfff] PGTABLE
sept. 02 02:29:26 isos-pc kernel: BRK [0x0c63e000, 0x0c63efff] PGTABLE
sept. 02 02:29:26 isos-pc kernel: BRK [0x0c63f000, 0x0c63ffff] PGTABLE
sept. 02 02:29:26 isos-pc kernel: Secure boot could not be determined
sept. 02 02:29:26 isos-pc kernel: RAMDISK: [mem 0x36e0d000-0x376fdfff]
sept. 02 02:29:26 isos-pc kernel: ACPI: Early table checksum verification disabled
sept. 02 02:29:26 isos-pc kernel: ACPI: RSDP 0x00000000C7EFE014 000024 (v02 HPQOEM)
sept. 02 02:29:26 isos-pc kernel: ACPI: XSDT 0x00000000C7EBC188 0000CC (v01 HPQOEM SLIC-BPC 00000000 01000013)
sept. 02 02:29:26 isos-pc kernel: ACPI: FACP 0x00000000C7EF1000 0000F4 (v05 HPQOEM SLIC-BPC 00000000 HP 00000001)
sept. 02 02:29:26 isos-pc kernel: ACPI: DSDT 0x00000000C7EC8000 025F16 (v02 HPQOEM 8079 00000000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: FACS 0x00000000C7E6B000 000040
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EFC000 000108 (v02 HP ShmTable 00000001 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: TCPA 0x00000000C7EFA000 000032 (v02 HPQOEM EDK2 00000002 01000013)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EF9000 0003B8 (v02 HPQOEM TcgTable 00001000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: UEFI 0x00000000C7E7A000 000042 (v01 HPQOEM EDK2 00000002 01000013)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EF3000 0051FA (v02 SaSsdt SaSsdt 00003000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EF2000 0005B1 (v01 Intel PerfTune 00001000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: HPET 0x00000000C7EF0000 000038 (v01 HPQOEM 8079 00000001 HP 00000001)
sept. 02 02:29:26 isos-pc kernel: ACPI: APIC 0x00000000C7EEF000 0000BC (v01 HPQOEM 8079 00000001 HP 00000001)
sept. 02 02:29:26 isos-pc kernel: ACPI: MCFG 0x00000000C7EEE000 00003C (v01 HPQOEM 8079 00000001 HP 00000001)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EC7000 00019A (v02 HPQOEM Sata0Ide 00001000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EC6000 000729 (v01 HPQOEM PtidDevc 00001000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EC5000 0003DC (v02 HPQOEM SDS_RTD3 00001000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EC4000 000E73 (v02 CpuRef CpuSsdt 00003000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EC2000 001B5C (v01 HP LAPTOPPC 00001000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: DMAR 0x00000000C7EC1000 0000CC (v01 INTEL SKL 00000001 INTL 00000001)
sept. 02 02:29:26 isos-pc kernel: ACPI: NHLT 0x00000000C7EC0000 00002D (v00 INTEL EDK2 00000002 01000013)
sept. 02 02:29:26 isos-pc kernel: ACPI: ASF! 0x00000000C7EBF000 0000A5 (v32 HPQOEM UYA 00000001 TFSM 000F4240)
sept. 02 02:29:26 isos-pc kernel: ACPI: FPDT 0x00000000C7EBE000 000044 (v01 HPQOEM EDK2 00000002 01000013)
sept. 02 02:29:26 isos-pc kernel: ACPI: BGRT 0x00000000C7EBD000 000038 (v01 HPQOEM EDK2 00000002 01000013)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0x00000000C7EFD000 000260 (v02 HP PwrCtlEv 00000001 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: Local APIC address 0xfee00000
sept. 02 02:29:26 isos-pc kernel: No NUMA configuration found
sept. 02 02:29:26 isos-pc kernel: Faking a node at [mem 0x0000000000000000-0x00000002317fffff]
sept. 02 02:29:26 isos-pc kernel: NODE_DATA(0) allocated [mem 0x2317fa000-0x2317fdfff]
sept. 02 02:29:26 isos-pc kernel: Zone ranges:
sept. 02 02:29:26 isos-pc kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff]
sept. 02 02:29:26 isos-pc kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
sept. 02 02:29:26 isos-pc kernel: Normal [mem 0x0000000100000000-0x00000002317fffff]
sept. 02 02:29:26 isos-pc kernel: Device empty
sept. 02 02:29:26 isos-pc kernel: Movable zone start for each node
sept. 02 02:29:26 isos-pc kernel: Early memory node ranges
sept. 02 02:29:26 isos-pc kernel: node 0: [mem 0x0000000000001000-0x0000000000057fff]
sept. 02 02:29:26 isos-pc kernel: node 0: [mem 0x0000000000059000-0x000000000009dfff]
sept. 02 02:29:26 isos-pc kernel: node 0: [mem 0x000000000009f000-0x000000000009ffff]
sept. 02 02:29:26 isos-pc kernel: node 0: [mem 0x0000000000100000-0x00000000c70fafff]
sept. 02 02:29:26 isos-pc kernel: node 0: [mem 0x00000000c7eff000-0x00000000c7efffff]
sept. 02 02:29:26 isos-pc kernel: node 0: [mem 0x0000000100000000-0x00000002317fffff]
sept. 02 02:29:26 isos-pc kernel: Initmem setup node 0 [mem 0x0000000000001000-0x00000002317fffff]
sept. 02 02:29:26 isos-pc kernel: On node 0 totalpages: 2066585
sept. 02 02:29:26 isos-pc kernel: DMA zone: 64 pages used for memmap
sept. 02 02:29:26 isos-pc kernel: DMA zone: 89 pages reserved
sept. 02 02:29:26 isos-pc kernel: DMA zone: 3997 pages, LIFO batch:0
sept. 02 02:29:26 isos-pc kernel: DMA32 zone: 12676 pages used for memmap
sept. 02 02:29:26 isos-pc kernel: DMA32 zone: 811260 pages, LIFO batch:31
sept. 02 02:29:26 isos-pc kernel: Normal zone: 19552 pages used for memmap
sept. 02 02:29:26 isos-pc kernel: Normal zone: 1251328 pages, LIFO batch:31
sept. 02 02:29:26 isos-pc kernel: Reserving Intel graphics memory at 0x00000000ca800000-0x00000000cc7fffff
sept. 02 02:29:26 isos-pc kernel: ACPI: PM-Timer IO Port: 0x1808
sept. 02 02:29:26 isos-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
sept. 02 02:29:26 isos-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
sept. 02 02:29:26 isos-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
sept. 02 02:29:26 isos-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
sept. 02 02:29:26 isos-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
sept. 02 02:29:26 isos-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
sept. 02 02:29:26 isos-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
sept. 02 02:29:26 isos-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
sept. 02 02:29:26 isos-pc kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
sept. 02 02:29:26 isos-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
sept. 02 02:29:26 isos-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
sept. 02 02:29:26 isos-pc kernel: ACPI: IRQ0 used by override.
sept. 02 02:29:26 isos-pc kernel: ACPI: IRQ9 used by override.
sept. 02 02:29:26 isos-pc kernel: Using ACPI (MADT) for SMP configuration information
sept. 02 02:29:26 isos-pc kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
sept. 02 02:29:26 isos-pc kernel: smpboot: Allowing 4 CPUs, 0 hotplug CPUs
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0x0009e000-0x0009efff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xc70fb000-0xc75fafff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xc75fb000-0xc7c7efff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xc7c7f000-0xc7e7efff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xc7e7f000-0xc7efefff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xc7f00000-0xcc7fffff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xcc800000-0xf80f9fff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xf80fa000-0xf80fafff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xf80fb000-0xf80fcfff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xf80fd000-0xf80fdfff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xf80fe000-0xfdffffff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
sept. 02 02:29:26 isos-pc kernel: PM: Registered nosave memory: [mem 0xfe011000-0xffffffff]
sept. 02 02:29:26 isos-pc kernel: e820: [mem 0xcc800000-0xf80f9fff] available for PCI devices
sept. 02 02:29:26 isos-pc kernel: Booting paravirtualized kernel on bare hardware
sept. 02 02:29:26 isos-pc kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
sept. 02 02:29:26 isos-pc kernel: random: get_random_bytes called from start_kernel+0x93/0x4d3 with crng_init=0
sept. 02 02:29:26 isos-pc kernel: setup_percpu: NR_CPUS:128 nr_cpumask_bits:128 nr_cpu_ids:4 nr_node_ids:1
sept. 02 02:29:26 isos-pc kernel: percpu: Embedded 42 pages/cpu @ffff8818f1400000 s134360 r8192 d29480 u524288
sept. 02 02:29:26 isos-pc kernel: pcpu-alloc: s134360 r8192 d29480 u524288 alloc=1*2097152
sept. 02 02:29:26 isos-pc kernel: pcpu-alloc: [0] 0 1 2 3
sept. 02 02:29:26 isos-pc kernel: Built 1 zonelists, mobility grouping on. Total pages: 2034204
sept. 02 02:29:26 isos-pc kernel: Policy zone: Normal
sept. 02 02:29:26 isos-pc kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=003dc175-12db-4b19-b9c1-469ed7def564 rw quiet resume=UUID=eb12fb71-fba9-4509-ba11-41cf191c84d7 nvidia.modeset=0
sept. 02 02:29:26 isos-pc kernel: PID hash table entries: 4096 (order: 3, 32768 bytes)
sept. 02 02:29:26 isos-pc kernel: Calgary: detecting Calgary via BIOS EBDA area
sept. 02 02:29:26 isos-pc kernel: Calgary: Unable to locate Rio Grande table in EBDA - bailing!
sept. 02 02:29:26 isos-pc kernel: Memory: 7803624K/8266340K available (10252K kernel code, 1162K rwdata, 2864K rodata, 1360K init, 988K bss, 462716K reserved, 0K cma-reserved)
sept. 02 02:29:26 isos-pc kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
sept. 02 02:29:26 isos-pc kernel: Kernel/User page tables isolation: enabled
sept. 02 02:29:26 isos-pc kernel: ftrace: allocating 29490 entries in 116 pages
sept. 02 02:29:26 isos-pc kernel: Preemptible hierarchical RCU implementation.
sept. 02 02:29:26 isos-pc kernel: RCU restricting CPUs from NR_CPUS=128 to nr_cpu_ids=4.
sept. 02 02:29:26 isos-pc kernel: Tasks RCU enabled.
sept. 02 02:29:26 isos-pc kernel: RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
sept. 02 02:29:26 isos-pc kernel: NR_IRQS: 8448, nr_irqs: 1024, preallocated irqs: 16
sept. 02 02:29:26 isos-pc kernel: Console: colour dummy device 80x25
sept. 02 02:29:26 isos-pc kernel: console [tty0] enabled
sept. 02 02:29:26 isos-pc kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
sept. 02 02:29:26 isos-pc kernel: hpet clockevent registered
sept. 02 02:29:26 isos-pc kernel: tsc: Detected 2600.000 MHz processor
sept. 02 02:29:26 isos-pc kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5186.00 BogoMIPS (lpj=8640000)
sept. 02 02:29:26 isos-pc kernel: pid_max: default: 32768 minimum: 301
sept. 02 02:29:26 isos-pc kernel: ACPI: Core revision 20170728
sept. 02 02:29:26 isos-pc kernel: ACPI: 11 ACPI AML tables successfully acquired and loaded
sept. 02 02:29:26 isos-pc kernel: Security Framework initialized
sept. 02 02:29:26 isos-pc kernel: Yama: becoming mindful.
sept. 02 02:29:26 isos-pc kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
sept. 02 02:29:26 isos-pc kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
sept. 02 02:29:26 isos-pc kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
sept. 02 02:29:26 isos-pc kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
sept. 02 02:29:26 isos-pc kernel: CPU: Physical Processor ID: 0
sept. 02 02:29:26 isos-pc kernel: CPU: Processor Core ID: 0
sept. 02 02:29:26 isos-pc kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
sept. 02 02:29:26 isos-pc kernel: ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
sept. 02 02:29:26 isos-pc kernel: mce: CPU supports 8 MCE banks
sept. 02 02:29:26 isos-pc kernel: CPU0: Thermal monitoring enabled (TM1)
sept. 02 02:29:26 isos-pc kernel: process: using mwait in idle threads
sept. 02 02:29:26 isos-pc kernel: Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
sept. 02 02:29:26 isos-pc kernel: Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
sept. 02 02:29:26 isos-pc kernel: Spectre V2 : Mitigation: Full generic retpoline
sept. 02 02:29:26 isos-pc kernel: Spectre V2 : Spectre v2 mitigation: Filling RSB on context switch
sept. 02 02:29:26 isos-pc kernel: Spectre V2 : Spectre v2 mitigation: Enabling Indirect Branch Prediction Barrier
sept. 02 02:29:26 isos-pc kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls
sept. 02 02:29:26 isos-pc kernel: Speculative Store Bypass: Vulnerable
sept. 02 02:29:26 isos-pc kernel: Freeing SMP alternatives memory: 24K
sept. 02 02:29:26 isos-pc kernel: smpboot: Max logical packages: 2
sept. 02 02:29:26 isos-pc kernel: DMAR: Host address width 39
sept. 02 02:29:26 isos-pc kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0
sept. 02 02:29:26 isos-pc kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
sept. 02 02:29:26 isos-pc kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1
sept. 02 02:29:26 isos-pc kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
sept. 02 02:29:26 isos-pc kernel: DMAR: RMRR base: 0x000000c7c37000 end: 0x000000c7c56fff
sept. 02 02:29:26 isos-pc kernel: DMAR: RMRR base: 0x000000ca000000 end: 0x000000cc7fffff
sept. 02 02:29:26 isos-pc kernel: DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
sept. 02 02:29:26 isos-pc kernel: DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
sept. 02 02:29:26 isos-pc kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000
sept. 02 02:29:26 isos-pc kernel: DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
sept. 02 02:29:26 isos-pc kernel: DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
sept. 02 02:29:26 isos-pc kernel: DMAR-IR: Enabled IRQ remapping in xapic mode
sept. 02 02:29:26 isos-pc kernel: x2apic: IRQ remapping doesn't support X2APIC mode
sept. 02 02:29:26 isos-pc kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
sept. 02 02:29:26 isos-pc kernel: TSC deadline timer enabled
sept. 02 02:29:26 isos-pc kernel: smpboot: CPU0: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz (family: 0x6, model: 0x4e, stepping: 0x3)
sept. 02 02:29:26 isos-pc kernel: Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
sept. 02 02:29:26 isos-pc kernel: ... version: 4
sept. 02 02:29:26 isos-pc kernel: ... bit width: 48
sept. 02 02:29:26 isos-pc kernel: ... generic registers: 4
sept. 02 02:29:26 isos-pc kernel: ... value mask: 0000ffffffffffff
sept. 02 02:29:26 isos-pc kernel: ... max period: 00007fffffffffff
sept. 02 02:29:26 isos-pc kernel: ... fixed-purpose events: 3
sept. 02 02:29:26 isos-pc kernel: ... event mask: 000000070000000f
sept. 02 02:29:26 isos-pc kernel: Hierarchical SRCU implementation.
sept. 02 02:29:26 isos-pc kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
sept. 02 02:29:26 isos-pc kernel: smp: Bringing up secondary CPUs ...
sept. 02 02:29:26 isos-pc kernel: x86: Booting SMP configuration:
sept. 02 02:29:26 isos-pc kernel: .... node #0, CPUs: #1 #2 #3
sept. 02 02:29:26 isos-pc kernel: smp: Brought up 1 node, 4 CPUs
sept. 02 02:29:26 isos-pc kernel: smpboot: Total of 4 processors activated (20744.00 BogoMIPS)
sept. 02 02:29:26 isos-pc kernel: devtmpfs: initialized
sept. 02 02:29:26 isos-pc kernel: x86/mm: Memory block size: 128MB
sept. 02 02:29:26 isos-pc kernel: PM: Registering ACPI NVS region [mem 0xc7c7f000-0xc7e7efff] (2097152 bytes)
sept. 02 02:29:26 isos-pc kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
sept. 02 02:29:26 isos-pc kernel: futex hash table entries: 1024 (order: 4, 65536 bytes)
sept. 02 02:29:26 isos-pc kernel: pinctrl core: initialized pinctrl subsystem
sept. 02 02:29:26 isos-pc kernel: RTC time: 0:29:22, date: 09/02/18
sept. 02 02:29:26 isos-pc kernel: NET: Registered protocol family 16
sept. 02 02:29:26 isos-pc kernel: cpuidle: using governor ladder
sept. 02 02:29:26 isos-pc kernel: cpuidle: using governor menu
sept. 02 02:29:26 isos-pc kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
sept. 02 02:29:26 isos-pc kernel: ACPI: bus type PCI registered
sept. 02 02:29:26 isos-pc kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
sept. 02 02:29:26 isos-pc kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
sept. 02 02:29:26 isos-pc kernel: PCI: not using MMCONFIG
sept. 02 02:29:26 isos-pc kernel: PCI: Using configuration type 1 for base access
sept. 02 02:29:26 isos-pc kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
sept. 02 02:29:26 isos-pc kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
sept. 02 02:29:26 isos-pc kernel: ACPI: Added _OSI(Module Device)
sept. 02 02:29:26 isos-pc kernel: ACPI: Added _OSI(Processor Device)
sept. 02 02:29:26 isos-pc kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
sept. 02 02:29:26 isos-pc kernel: ACPI: Added _OSI(Processor Aggregator Device)
sept. 02 02:29:26 isos-pc kernel: ACPI: Executed 17 blocks of module-level executable AML code
sept. 02 02:29:26 isos-pc kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
sept. 02 02:29:26 isos-pc kernel: ACPI: Dynamic OEM Table Load:
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0xFFFF8818E76D3800 000660 (v02 PmRef Cpu0Ist 00003000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0xFFFF8818E7020800 00037F (v02 PmRef Cpu0Cst 00003001 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0xFFFF8818E76CC6C0 00008E (v02 PmRef Cpu0Hwp 00003000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0xFFFF8818E7025400 000130 (v02 PmRef HwpLvt 00003000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0xFFFF8818E76D7000 0005AA (v02 PmRef ApIst 00003000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0xFFFF8818E7024400 000119 (v02 PmRef ApHwp 00003000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: SSDT 0xFFFF8818E7024800 000119 (v02 PmRef ApCst 00003000 INTL 20121018)
sept. 02 02:29:26 isos-pc kernel: ACPI: EC: EC started
sept. 02 02:29:26 isos-pc kernel: ACPI: EC: interrupt blocked
sept. 02 02:29:26 isos-pc kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
sept. 02 02:29:26 isos-pc kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x6e, EC_CMD/EC_SC=0x66, EC_DATA=0x62
sept. 02 02:29:26 isos-pc kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
sept. 02 02:29:26 isos-pc kernel: ACPI: Interpreter enabled
sept. 02 02:29:26 isos-pc kernel: ACPI: (supports S0 S3 S4 S5)
sept. 02 02:29:26 isos-pc kernel: ACPI: Using IOAPIC for interrupt routing
sept. 02 02:29:26 isos-pc kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in ACPI motherboard resources
sept. 02 02:29:26 isos-pc kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
sept. 02 02:29:26 isos-pc kernel: ACPI: Enabled 8 GPEs in block 00 to 7F
sept. 02 02:29:26 isos-pc kernel: ACPI: Power Resource [PG01] (on)
sept. 02 02:29:26 isos-pc kernel: ACPI: Power Resource [PG02] (on)
sept. 02 02:29:26 isos-pc kernel: ACPI: Power Resource [PG00] (on)
sept. 02 02:29:26 isos-pc kernel: ACPI: Power Resource [WRST] (on)
sept. 02 02:29:26 isos-pc kernel: ACPI: Power Resource [PXP] (on)
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
sept. 02 02:29:26 isos-pc kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
sept. 02 02:29:26 isos-pc kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
sept. 02 02:29:26 isos-pc kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
sept. 02 02:29:26 isos-pc kernel: PCI host bridge to bus 0000:00
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: root bus resource [mem 0xcc800000-0xf7ffffff window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: root bus resource [bus 00-3e]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:00.0: [8086:1904] type 00 class 0x060000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: [8086:1916] type 00 class 0x030000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: reg 0x10: [mem 0xe0000000-0xe0ffffff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff 64bit pref]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: reg 0x20: [io 0x3000-0x303f]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: BAR 2: assigned to efifb
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:14.0: reg 0x10: [mem 0xe1220000-0xe122ffff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:14.2: reg 0x10: [mem 0xe124a000-0xe124afff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:15.0: reg 0x10: [mem 0xe124b000-0xe124bfff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:16.0: reg 0x10: [mem 0xe124c000-0xe124cfff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:16.0: PME# supported from D3hot
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:17.0: reg 0x10: [mem 0xe1248000-0xe1249fff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:17.0: reg 0x14: [mem 0xe124f000-0xe124f0ff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:17.0: reg 0x18: [io 0x3080-0x3087]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:17.0: reg 0x1c: [io 0x3088-0x308b]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:17.0: reg 0x20: [io 0x3040-0x305f]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:17.0: reg 0x24: [mem 0xe124d000-0xe124d7ff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:17.0: PME# supported from D3hot
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: [8086:9d11] type 01 class 0x060400
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.3: [8086:9d13] type 01 class 0x060400
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.0: [8086:9d48] type 00 class 0x060100
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.2: reg 0x10: [mem 0xe1240000-0xe1243fff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.3: [8086:9d70] type 00 class 0x040380
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xe1244000-0xe1247fff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.3: reg 0x20: [mem 0xe1230000-0xe123ffff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.3: PME# supported from D3hot D3cold
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.4: reg 0x10: [mem 0xe124e000-0xe124e0ff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.4: reg 0x20: [io 0xefa0-0xefbf]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.6: [8086:1570] type 00 class 0x020000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.6: reg 0x10: [mem 0xe1200000-0xe121ffff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
sept. 02 02:29:26 isos-pc kernel: pci 0000:01:00.0: [10ec:522a] type 00 class 0xff0000
sept. 02 02:29:26 isos-pc kernel: pci 0000:01:00.0: reg 0x10: [mem 0xe1000000-0xe1000fff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:01:00.0: supports D1 D2
sept. 02 02:29:26 isos-pc kernel: pci 0000:01:00.0: PME# supported from D1 D2 D3hot D3cold
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: PCI bridge to [bus 01]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: bridge window [mem 0xe1000000-0xe10fffff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:02:00.0: [8086:24f3] type 00 class 0x028000
sept. 02 02:29:26 isos-pc kernel: pci 0000:02:00.0: reg 0x10: [mem 0xe1100000-0xe1101fff 64bit]
sept. 02 02:29:26 isos-pc kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.3: PCI bridge to [bus 02]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.3: bridge window [mem 0xe1100000-0xe11fffff]
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
sept. 02 02:29:26 isos-pc kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
sept. 02 02:29:26 isos-pc kernel: ACPI: EC: interrupt unblocked
sept. 02 02:29:26 isos-pc kernel: ACPI: EC: event unblocked
sept. 02 02:29:26 isos-pc kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: vgaarb: bridge control possible
sept. 02 02:29:26 isos-pc kernel: vgaarb: loaded
sept. 02 02:29:26 isos-pc kernel: EDAC MC: Ver: 3.0.0
sept. 02 02:29:26 isos-pc kernel: Registered efivars operations
sept. 02 02:29:26 isos-pc kernel: PCI: Using ACPI for IRQ routing
sept. 02 02:29:26 isos-pc kernel: PCI: pci_cache_line_size set to 64 bytes
sept. 02 02:29:26 isos-pc kernel: e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
sept. 02 02:29:26 isos-pc kernel: e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
sept. 02 02:29:26 isos-pc kernel: e820: reserve RAM buffer [mem 0xc70fb000-0xc7ffffff]
sept. 02 02:29:26 isos-pc kernel: e820: reserve RAM buffer [mem 0xc7f00000-0xc7ffffff]
sept. 02 02:29:26 isos-pc kernel: e820: reserve RAM buffer [mem 0x231800000-0x233ffffff]
sept. 02 02:29:26 isos-pc kernel: NetLabel: Initializing
sept. 02 02:29:26 isos-pc kernel: NetLabel: domain hash size = 128
sept. 02 02:29:26 isos-pc kernel: NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
sept. 02 02:29:26 isos-pc kernel: NetLabel: unlabeled traffic allowed by default
sept. 02 02:29:26 isos-pc kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
sept. 02 02:29:26 isos-pc kernel: hpet0: 8 comparators, 64-bit 24.000000 MHz counter
sept. 02 02:29:26 isos-pc kernel: clocksource: Switched to clocksource hpet
sept. 02 02:29:26 isos-pc kernel: VFS: Disk quotas dquot_6.6.0
sept. 02 02:29:26 isos-pc kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
sept. 02 02:29:26 isos-pc kernel: pnp: PnP ACPI init
sept. 02 02:29:26 isos-pc kernel: system 00:00: [mem 0xfd000000-0xfdabffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:00: [mem 0xfdad0000-0xfdadffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:00: [mem 0xfdb00000-0xfdffffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:00: [mem 0xfe000000-0xfe01ffff] could not be reserved
sept. 02 02:29:26 isos-pc kernel: system 00:00: [mem 0xfe03d000-0xfe3fffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
sept. 02 02:29:26 isos-pc kernel: system 00:01: [io 0x2000-0x20fe] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
sept. 02 02:29:26 isos-pc kernel: system 00:02: [io 0x0680-0x069f] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:02: [io 0xffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:02: [io 0x1800-0x18fe] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:02: [io 0x164e-0x164f] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
sept. 02 02:29:26 isos-pc kernel: pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
sept. 02 02:29:26 isos-pc kernel: system 00:04: [io 0x1854-0x1857] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
sept. 02 02:29:26 isos-pc kernel: pnp 00:05: Plug and Play ACPI device, IDs HPQ8002 PNP0303 (active)
sept. 02 02:29:26 isos-pc kernel: pnp 00:06: Plug and Play ACPI device, IDs SYN3037 SYN0100 SYN0002 PNP0f13 (active)
sept. 02 02:29:26 isos-pc kernel: system 00:07: [io 0x0200-0x023f] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:07: [mem 0xfedf0000-0xfedfffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
sept. 02 02:29:26 isos-pc kernel: system 00:08: [mem 0xfe031000-0xfe031fff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:08: [mem 0xfe030008-0xfe030fff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
sept. 02 02:29:26 isos-pc kernel: system 00:09: [mem 0xfe030000-0xfe030007] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xfed10000-0xfed17fff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xfed18000-0xfed18fff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xfed19000-0xfed19fff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xf8000000-0xfbffffff] could not be reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xfed20000-0xfed3ffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xfed90000-0xfed93fff] could not be reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xfed45000-0xfed8ffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xff000000-0xffffffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xfee00000-0xfeefffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: [mem 0xcc800000-0xcc81ffff] has been reserved
sept. 02 02:29:26 isos-pc kernel: system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
sept. 02 02:29:26 isos-pc kernel: pnp 00:0b: Plug and Play ACPI device, IDs IFX0102 PNP0c31 (active)
sept. 02 02:29:26 isos-pc kernel: pnp: PnP ACPI: found 12 devices
sept. 02 02:29:26 isos-pc kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01] add_size 1000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: BAR 15: assigned [mem 0xcc900000-0xccafffff 64bit pref]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: BAR 13: assigned [io 0x4000-0x4fff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:1c.0: bridge window [mem 0xcc900000-0xccafffff 64bit pref]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: resource 7 [mem 0xcc800000-0xf7ffffff window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:01: resource 1 [mem 0xe1000000-0xe10fffff]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:01: resource 2 [mem 0xcc900000-0xccafffff 64bit pref]
sept. 02 02:29:26 isos-pc kernel: pci_bus 0000:02: resource 1 [mem 0xe1100000-0xe11fffff]
sept. 02 02:29:26 isos-pc kernel: NET: Registered protocol family 2
sept. 02 02:29:26 isos-pc kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes)
sept. 02 02:29:26 isos-pc kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
sept. 02 02:29:26 isos-pc kernel: TCP: Hash tables configured (established 65536 bind 65536)
sept. 02 02:29:26 isos-pc kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes)
sept. 02 02:29:26 isos-pc kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
sept. 02 02:29:26 isos-pc kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
sept. 02 02:29:26 isos-pc kernel: PCI: CLS 0 bytes, default 64
sept. 02 02:29:26 isos-pc kernel: Unpacking initramfs...
sept. 02 02:29:26 isos-pc kernel: Freeing initrd memory: 9156K
sept. 02 02:29:26 isos-pc kernel: DMAR: ACPI device "device:6f" under DMAR at fed91000 as 00:15.0
sept. 02 02:29:26 isos-pc kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
sept. 02 02:29:26 isos-pc kernel: software IO TLB [mem 0xb40aa000-0xb80aa000] (64MB) mapped at [ffff8817740aa000-ffff8817780a9fff]
sept. 02 02:29:26 isos-pc kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x255cb6cc5db, max_idle_ns: 440795203504 ns
sept. 02 02:29:26 isos-pc kernel: Scanning for low memory corruption every 60 seconds
sept. 02 02:29:26 isos-pc kernel: Initialise system trusted keyrings
sept. 02 02:29:26 isos-pc kernel: Key type blacklist registered
sept. 02 02:29:26 isos-pc kernel: workingset: timestamp_bits=41 max_order=21 bucket_order=0
sept. 02 02:29:26 isos-pc kernel: zbud: loaded
sept. 02 02:29:26 isos-pc kernel: Key type asymmetric registered
sept. 02 02:29:26 isos-pc kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
sept. 02 02:29:26 isos-pc kernel: io scheduler noop registered
sept. 02 02:29:26 isos-pc kernel: io scheduler deadline registered
sept. 02 02:29:26 isos-pc kernel: io scheduler cfq registered
sept. 02 02:29:26 isos-pc kernel: io scheduler mq-deadline registered
sept. 02 02:29:26 isos-pc kernel: io scheduler kyber registered
sept. 02 02:29:26 isos-pc kernel: io scheduler bfq registered
sept. 02 02:29:26 isos-pc kernel: io scheduler bfq-sq registered (default)
sept. 02 02:29:26 isos-pc kernel: BFQ I/O-scheduler: v8r12 (with cgroups support)
sept. 02 02:29:26 isos-pc kernel: io scheduler bfq-mq registered
sept. 02 02:29:26 isos-pc kernel: pcieport 0000:00:1c.0: AER enabled with IRQ 122
sept. 02 02:29:26 isos-pc kernel: pcieport 0000:00:1c.3: AER enabled with IRQ 123
sept. 02 02:29:26 isos-pc kernel: pcieport 0000:00:1c.0: Signaling PME with IRQ 122
sept. 02 02:29:26 isos-pc kernel: pcieport 0000:00:1c.3: Signaling PME with IRQ 123
sept. 02 02:29:26 isos-pc kernel: pciehp 0000:00:1c.0:pcie004: Slot #1 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ LLActRep+
sept. 02 02:29:26 isos-pc kernel: efifb: probing for efifb
sept. 02 02:29:26 isos-pc kernel: efifb: framebuffer at 0xd0000000, using 3072k, total 3072k
sept. 02 02:29:26 isos-pc kernel: efifb: mode is 1024x768x32, linelength=4096, pages=1
sept. 02 02:29:26 isos-pc kernel: efifb: scrolling: redraw
sept. 02 02:29:26 isos-pc kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
sept. 02 02:29:26 isos-pc kernel: Console: switching to colour frame buffer device 128x48
sept. 02 02:29:26 isos-pc kernel: fb0: EFI VGA frame buffer device
sept. 02 02:29:26 isos-pc kernel: intel_idle: MWAIT substates: 0x11142120
sept. 02 02:29:26 isos-pc kernel: intel_idle: v0.4.1 model 0x4E
sept. 02 02:29:26 isos-pc kernel: intel_idle: lapic_timer_reliable_states 0xffffffff
sept. 02 02:29:26 isos-pc kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
sept. 02 02:29:26 isos-pc kernel: rtc_cmos 00:03: RTC can wake from S4
sept. 02 02:29:26 isos-pc kernel: rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
sept. 02 02:29:26 isos-pc kernel: rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
sept. 02 02:29:26 isos-pc kernel: intel_pstate: Intel P-state driver initializing
sept. 02 02:29:26 isos-pc kernel: intel_pstate: HWP enabled
sept. 02 02:29:26 isos-pc kernel: ledtrig-cpu: registered to indicate activity on CPUs
sept. 02 02:29:26 isos-pc kernel: vlv2_plat_clk vlv2_plat_clk: vlv2_plat_clk initialized
sept. 02 02:29:26 isos-pc kernel: intel_pmc_core 0000:00:1f.2: enabling device (0000 -> 0002)
sept. 02 02:29:26 isos-pc kernel: NET: Registered protocol family 10
sept. 02 02:29:26 isos-pc kernel: Segment Routing with IPv6
sept. 02 02:29:26 isos-pc kernel: NET: Registered protocol family 17
sept. 02 02:29:26 isos-pc kernel: RAS: Correctable Errors collector initialized.
sept. 02 02:29:26 isos-pc kernel: microcode: sig=0x406e3, pf=0x80, revision=0xc2
sept. 02 02:29:26 isos-pc kernel: microcode: Microcode Update Driver: v2.2.
sept. 02 02:29:26 isos-pc kernel: sched_clock: Marking stable (3854358162, 0)->(3863114985, -8756823)
sept. 02 02:29:26 isos-pc kernel: registered taskstats version 1
sept. 02 02:29:26 isos-pc kernel: Loading compiled-in X.509 certificates
sept. 02 02:29:26 isos-pc kernel: zswap: loaded using pool lzo/zbud
sept. 02 02:29:26 isos-pc kernel: Key type big_key registered
sept. 02 02:29:26 isos-pc kernel: Magic number: 2:91:455
sept. 02 02:29:26 isos-pc kernel: rtc_cmos 00:03: setting system clock to 2018-09-02 00:29:25 UTC (1535848165)
sept. 02 02:29:26 isos-pc kernel: Freeing unused kernel memory: 1360K
sept. 02 02:29:26 isos-pc kernel: Write protecting the kernel read-only data: 16384k
sept. 02 02:29:26 isos-pc kernel: Freeing unused kernel memory: 2016K
sept. 02 02:29:26 isos-pc kernel: Freeing unused kernel memory: 1232K
sept. 02 02:29:26 isos-pc kernel: i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
sept. 02 02:29:26 isos-pc kernel: i8042: Detected active multiplexing controller, rev 1.1
sept. 02 02:29:26 isos-pc kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
sept. 02 02:29:26 isos-pc kernel: serio: i8042 AUX0 port at 0x60,0x64 irq 12
sept. 02 02:29:26 isos-pc kernel: serio: i8042 AUX1 port at 0x60,0x64 irq 12
sept. 02 02:29:26 isos-pc kernel: serio: i8042 AUX2 port at 0x60,0x64 irq 12
sept. 02 02:29:26 isos-pc kernel: serio: i8042 AUX3 port at 0x60,0x64 irq 12
sept. 02 02:29:26 isos-pc kernel: rtsx_pci 0000:01:00.0: enabling device (0000 -> 0002)
sept. 02 02:29:26 isos-pc kernel: ACPI: bus type USB registered
sept. 02 02:29:26 isos-pc kernel: usbcore: registered new interface driver usbfs
sept. 02 02:29:26 isos-pc kernel: usbcore: registered new interface driver hub
sept. 02 02:29:26 isos-pc kernel: usbcore: registered new device driver usb
sept. 02 02:29:26 isos-pc kernel: SCSI subsystem initialized
sept. 02 02:29:26 isos-pc kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller
sept. 02 02:29:26 isos-pc kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
sept. 02 02:29:26 isos-pc kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00109810
sept. 02 02:29:26 isos-pc kernel: xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
sept. 02 02:29:26 isos-pc kernel: libata version 3.00 loaded.
sept. 02 02:29:26 isos-pc kernel: hub 1-0:1.0: USB hub found
sept. 02 02:29:26 isos-pc kernel: hub 1-0:1.0: 12 ports detected
sept. 02 02:29:26 isos-pc kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
sept. 02 02:29:26 isos-pc kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
sept. 02 02:29:26 isos-pc kernel: hub 2-0:1.0: USB hub found
sept. 02 02:29:26 isos-pc kernel: hub 2-0:1.0: 6 ports detected
sept. 02 02:29:26 isos-pc kernel: usb: port power management may be unreliable
sept. 02 02:29:26 isos-pc kernel: ahci 0000:00:17.0: version 3.0
sept. 02 02:29:26 isos-pc kernel: ahci 0000:00:17.0: SSS flag set, parallel bus scan disabled
sept. 02 02:29:26 isos-pc kernel: ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x5 impl SATA mode
sept. 02 02:29:26 isos-pc kernel: ahci 0000:00:17.0: flags: 64bit ncq stag pm led clo only pio slum part deso sadm sds apst
sept. 02 02:29:26 isos-pc kernel: scsi host0: ahci
sept. 02 02:29:26 isos-pc kernel: scsi host1: ahci
sept. 02 02:29:26 isos-pc kernel: scsi host2: ahci
sept. 02 02:29:26 isos-pc kernel: ata1: SATA max UDMA/133 abar m2048@0xe124d000 port 0xe124d100 irq 126
sept. 02 02:29:26 isos-pc kernel: ata2: DUMMY
sept. 02 02:29:26 isos-pc kernel: ata3: SATA max UDMA/133 abar m2048@0xe124d000 port 0xe124d200 irq 126
sept. 02 02:29:26 isos-pc kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
sept. 02 02:29:26 isos-pc kernel: ata1: SATA link down (SStatus 4 SControl 300)
sept. 02 02:29:26 isos-pc kernel: usb 1-7: new full-speed USB device number 2 using xhci_hcd
sept. 02 02:29:26 isos-pc kernel: usb 1-9: new high-speed USB device number 3 using xhci_hcd
sept. 02 02:29:26 isos-pc kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
sept. 02 02:29:26 isos-pc kernel: ata3.00: ACPI cmd f5/00:00:00:00:00:e0 (SECURITY FREEZE LOCK) filtered out
sept. 02 02:29:26 isos-pc kernel: ata3.00: ATA-9: SAMSUNG MZNLN512HCJH-000H1, EMT22H0Q, max UDMA/133
sept. 02 02:29:26 isos-pc kernel: ata3.00: 1000215216 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
sept. 02 02:29:26 isos-pc kernel: ata3.00: configured for UDMA/133
sept. 02 02:29:26 isos-pc kernel: scsi 2:0:0:0: Direct-Access ATA SAMSUNG MZNLN512 2H0Q PQ: 0 ANSI: 5
sept. 02 02:29:26 isos-pc kernel: sd 2:0:0:0: [sda] 1000215216 512-byte logical blocks: (512 GB/477 GiB)
sept. 02 02:29:26 isos-pc kernel: sd 2:0:0:0: [sda] Write Protect is off
sept. 02 02:29:26 isos-pc kernel: sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
sept. 02 02:29:26 isos-pc kernel: sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sept. 02 02:29:26 isos-pc kernel: sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8 sda9
sept. 02 02:29:26 isos-pc kernel: sd 2:0:0:0: [sda] Attached SCSI disk
sept. 02 02:29:26 isos-pc kernel: PM: Starting manual resume from disk
sept. 02 02:29:26 isos-pc kernel: PM: Image not found (code -22)
sept. 02 02:29:26 isos-pc kernel: random: fast init done
sept. 02 02:29:26 isos-pc kernel: EXT4-fs (sda7): mounted filesystem with ordered data mode. Opts: (null)
sept. 02 02:29:26 isos-pc kernel: clocksource: Switched to clocksource tsc
sept. 02 02:29:26 isos-pc kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
sept. 02 02:29:26 isos-pc systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN +PCRE2 default-hierarchy=hybrid)
sept. 02 02:29:26 isos-pc systemd[1]: Detected architecture x86-64.
sept. 02 02:29:26 isos-pc systemd[1]: Set hostname to <isos-pc>.
sept. 02 02:29:26 isos-pc kernel: random: systemd: uninitialized urandom read (16 bytes read)
sept. 02 02:29:26 isos-pc systemd[1]: Created slice system-mariadb.slice.
sept. 02 02:29:26 isos-pc systemd[1]: Created slice system-getty.slice.
sept. 02 02:29:26 isos-pc systemd[1]: Created slice system-maia\x2dconsole.slice.
sept. 02 02:29:26 isos-pc systemd[1]: Listening on udev Kernel Socket.
sept. 02 02:29:26 isos-pc systemd[1]: Listening on initctl Compatibility Named Pipe.
sept. 02 02:29:26 isos-pc systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
sept. 02 02:29:26 isos-pc systemd[1]: Reached target Login Prompts.
sept. 02 02:29:26 isos-pc kernel: EXT4-fs (sda7): re-mounted. Opts: discard
sept. 02 02:29:26 isos-pc systemd-journald[204]: Journal started
sept. 02 02:29:26 isos-pc systemd-journald[204]: Runtime journal (/run/log/journal/3c21884c5bcb4884bc8c0018e0b0706f) is 8.0M, max 393.0M, 385.0M free.
sept. 02 02:29:26 isos-pc systemd-modules-load[206]: Inserted module 'crypto_user'
sept. 02 02:29:26 isos-pc systemd[1]: Starting Flush Journal to Persistent Storage...
sept. 02 02:29:26 isos-pc ufw-init[218]: Skip starting firewall: ufw (not enabled)
sept. 02 02:29:26 isos-pc systemd-journald[204]: Time spent on flushing to /var is 6.380ms for 626 entries.
Ty for your help
