Random System Hanging on Gnome Desktop
Hi everyone!
I have been using Linux since a year and a half now. I first had been used Windows, then installed Ubuntu and kept it for a year and then tried Arch. I wasn't convinced about all the complexity it required so I decided to switch to Manjaro and have been using it for about 3/4 months.
The problem I have is that I experience random freezes from time to time. I have experienced them while playing Starcraft (on Lutris with Wine) or while using python, for example. I had not experienced any similar issues neither on Windows nor on Ubuntu.
Most of the time I have not been able to respond to a freeze because the system barely responded to me, and . Fortunately, today I was able to switch to tty4. It first was very slow but then it let me run journalctl -b and save the output to a log file. And then my system unfreezed for some reason.
Next, I analyzed the logfile and found that the error was an Out Of Memory error. I was running python on a jupyter notebook, and the unfrozing seemingly was triggered by ending the python process (that apparently was consuming a lot of memory). I don't know if that's what has been happening the other times my system froze, but it seems like it.
The error happened at around 15:56. I'll leave here the output of some commands, please help!
inxi -Fxxxz
  Host: julianss Kernel: 5.6.16-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 10.1.0 Desktop: Gnome 3.36.3 wm: gnome-shell dm: GDM 3.34.1
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Laptop 14-cf0xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: HP model: 84B3 v: KBC Version 74.30 serial: <filter> UEFI: Insyde
  v: F.42 date: 06/20/2019
  ID-1: BAT0 charge: 36.4 Wh condition: 36.4/36.4 Wh (100%) volts: 13.0/11.6
  model: HP Primary type: Li-ion serial: <filter> status: Full
  Topology: Dual Core model: Intel Core i3-7020U bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 3072 KiB
  bogomips: 18406
  Speed: 800 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 799 2: 797
  3: 800 4: 798
  Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:5916
  Display: x11 server: X.Org 1.20.8 driver: i915 compositor: gnome-shell
  resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.0.7
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
  Sound Server: ALSA v: k5.6.16-1-MANJARO
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000 bus ID: 02:00.0
  chip ID: 10ec:8168
  Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
  vendor: Hewlett-Packard driver: rtl8723de v: kernel port: 3000
  bus ID: 03:00.0 chip ID: 10ec:d723
  Device-3: Realtek 802.11n WLAN Adapter type: USB driver: btusb
  bus ID: 1-8:3 chip ID: 0bda:b009 serial: <filter>
  Local Storage: total: 931.51 GiB used: 34.09 GiB (3.7%)
  ID-1: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
  speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: RSM7 scheme: GPT
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 6060 bus ID: 00:17.0 chip ID: 8086.282a rev: 21
  ID-1: / size: 28.71 GiB used: 13.90 GiB (48.4%) fs: ext4 dev: /dev/sda2
  ID-2: /home size: 790.44 GiB used: 20.19 GiB (2.6%) fs: ext4
  dev: /dev/sda4
  System Temperatures: cpu: 36.0 C mobo: 35.0 C gpu: amdgpu temp: 31 C
  Processes: 233 Uptime: 2h 19m Memory: 3.73 GiB used: 2.00 GiB (53.6%)
  Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: zsh v: 5.8
  running in: gnome-terminal inxi: 3.0.37
journalctl -p err -b
-- Logs begin at Sat 2020-05-23 14:18:52 -04, end at Sun 2020-06-28 16:42:38 -04. --
Jun 28 14:22:36 julianss kernel: ACPI BIOS Error (bug): Failure creating named object [\_GPE._L72], AE_ALREADY_EXISTS (20200110/dswload2-326)
Jun 28 14:22:36 julianss kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20200110/psobject-220)
Jun 28 14:22:36 julianss kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.AWAC], AE_ALREADY_EXISTS (20200110/dswload2-326)
Jun 28 14:22:41 julianss kernel: kfd kfd: TOPAZ  not supported in kfd
Jun 28 14:23:12 julianss wpa_supplicant[976]: bgscan simple: Failed to enable signal strength monitoring
Jun 28 14:23:14 julianss gdm-password][1248]: gkr-pam: unable to locate daemon control file
Jun 28 14:43:05 julianss kernel: rtlwifi: AP off, try to reconnect now
Jun 28 14:43:14 julianss wpa_supplicant[976]: bgscan simple: Failed to enable signal strength monitoring
Jun 28 15:59:26 julianss kernel: Out of memory: Killed process 2918 (python) total-vm:4481504kB, anon-rss:2149056kB, file-rss:0kB, shmem-rss:0kB, UID:1000 pgtables:4980kB oom_score_adj:0
Jun 28 16:08:43 julianss gdm[729]: GLib: Source ID 77 was not found when attempting to remove it
journalctl -b
Jun 28 14:44:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 14:44:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 14:44:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 14:44:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 14:45:14 julianss tracker-store[2962]: OK
Jun 28 14:45:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 14:46:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 14:46:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 14:46:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 14:46:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 14:47:14 julianss tracker-store[2978]: OK
Jun 28 14:47:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 14:48:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 14:48:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 14:48:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 14:48:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 14:49:14 julianss tracker-store[2998]: OK
Jun 28 14:49:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 14:52:38 julianss wpa_supplicant[976]: wlp3s0: WPA: Group rekeying completed with 9c:97:26:eb:6f:bb [GTK=TKIP]
Jun 28 14:53:39 julianss caffeine.desktop[1660]: INFO:caffeine.core:Fullscreen app detected. Inhibiting.
Jun 28 14:53:39 julianss caffeine.desktop[1660]: INFO:caffeine.core:GnomeInhibitor is applicable, running it.
Jun 28 14:53:39 julianss caffeine.desktop[1660]: INFO:caffeine.core:XdgScreenSaverInhibitor is applicable, running it.
Jun 28 14:53:39 julianss caffeine.desktop[1660]: INFO:caffeine.core:DpmsInhibitor is applicable, running it.
Jun 28 14:53:39 julianss caffeine.desktop[1660]: INFO:caffeine.core:XorgInhibitor is applicable, running it.
Jun 28 14:53:49 julianss caffeine.desktop[1660]: INFO:caffeine.core:Was auto-inhibited, but there's no fullscreen or whitelisted process now. De-activating.
Jun 28 14:53:49 julianss caffeine.desktop[1660]: INFO:caffeine.core:Caffeine is now dormant; powersaving is re-enabled.
Jun 28 14:53:49 julianss caffeine.desktop[1660]: INFO:caffeine.core:GnomeInhibitor is applicable, running it.
Jun 28 14:53:49 julianss caffeine.desktop[1660]: INFO:caffeine.core:XdgScreenSaverInhibitor is applicable, running it.
Jun 28 14:53:49 julianss caffeine.desktop[1660]: INFO:caffeine.core:DpmsInhibitor is applicable, running it.
Jun 28 14:53:49 julianss caffeine.desktop[1660]: INFO:caffeine.core:XorgInhibitor is applicable, running it.
Jun 28 14:54:27 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 14:56:30 julianss gnome-shell[1940]: [Child 1940, MediaDecoderStateMachine #1] WARNING: Decoder=7f4dbde74800 Decode error: NS_ERROR_DOM_MEDIA_FATAL_ERR (0x806e0005) - RefPtr<MediaSourceTrackDemuxer::SamplesPromise> mozilla::MediaSourceTrackDemuxer::DoGetSamples(int32_t): manager is detached.: file /build/firefox/src/firefox-77.0.1/dom/media/MediaDecoderStateMachine.cpp, line 3370
Jun 28 14:56:52 julianss gnome-shell[1940]: [Child 1940, MediaDecoderStateMachine #1] WARNING: Decoder=7f4dbf74b800 Decode error: NS_ERROR_DOM_MEDIA_FATAL_ERR (0x806e0005) - RefPtr<MediaSourceTrackDemuxer::SamplesPromise> mozilla::MediaSourceTrackDemuxer::DoGetSamples(int32_t): manager is detached.: file /build/firefox/src/firefox-77.0.1/dom/media/MediaDecoderStateMachine.cpp, line 3370
Jun 28 14:57:18 julianss gnome-shell[1385]: Ignoring excess values in shadow definition
Jun 28 14:57:20 julianss upowerd[1084]: energy 36.232350 bigger than full 35.839650
Jun 28 15:01:01 julianss CROND[3293]: (root) CMD (run-parts /etc/cron.hourly)
Jun 28 15:02:38 julianss wpa_supplicant[976]: wlp3s0: WPA: Group rekeying completed with 9c:97:26:eb:6f:bb [GTK=TKIP]
Jun 28 15:02:57 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:03:41 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:08:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:08:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:08:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:08:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:09:15 julianss tracker-store[3462]: OK
Jun 28 15:09:15 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:09:46 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:10:03 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:10:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:10:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:10:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:10:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:11:14 julianss tracker-store[3574]: OK
Jun 28 15:11:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:12:38 julianss wpa_supplicant[976]: wlp3s0: WPA: Group rekeying completed with 9c:97:26:eb:6f:bb [GTK=TKIP]
Jun 28 15:12:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:12:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:12:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:12:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:13:14 julianss tracker-store[3597]: OK
Jun 28 15:13:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:13:18 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:14:38 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:14:40 julianss gnome-shell[3619]: ###!!! [Child][RunMessage] Error: Channel closing: too late to send/recv, messages will be lost
Jun 28 15:14:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:14:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:14:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:14:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:15:03 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:15:14 julianss tracker-store[3710]: OK
Jun 28 15:15:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:16:46 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:18:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:18:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:18:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:18:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:19:14 julianss tracker-store[3830]: OK
Jun 28 15:19:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:19:39 julianss rtkit-daemon[1104]: Supervising 5 threads of 3 processes of 1 users.
Jun 28 15:20:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:20:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:20:45 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:20:45 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:21:15 julianss tracker-store[3905]: OK
Jun 28 15:21:15 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:22:38 julianss wpa_supplicant[976]: wlp3s0: WPA: Group rekeying completed with 9c:97:26:eb:6f:bb [GTK=TKIP]
Jun 28 15:22:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:22:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:22:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:22:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:23:14 julianss tracker-store[3926]: OK
Jun 28 15:23:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:23:44 julianss gnome-shell[1940]: [Child 1940, MediaDecoderStateMachine #1] WARNING: Decoder=7f4dbd4dd000 Decode error: NS_ERROR_DOM_MEDIA_FATAL_ERR (0x806e0005) - RefPtr<MediaSourceTrackDemuxer::SamplesPromise> mozilla::MediaSourceTrackDemuxer::DoGetSamples(int32_t): manager is detached.: file /build/firefox/src/firefox-77.0.1/dom/media/MediaDecoderStateMachine.cpp, line 3370
Jun 28 15:24:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:24:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:24:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:24:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:25:14 julianss tracker-store[3997]: OK
Jun 28 15:25:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:26:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:26:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:26:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:26:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:27:14 julianss tracker-store[4024]: OK
Jun 28 15:27:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:32:38 julianss wpa_supplicant[976]: wlp3s0: WPA: Group rekeying completed with 9c:97:26:eb:6f:bb [GTK=TKIP]
Jun 28 15:34:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:34:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:34:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:34:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:35:14 julianss tracker-store[4095]: OK
Jun 28 15:35:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:36:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:36:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:36:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:36:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:37:14 julianss tracker-store[4136]: OK
Jun 28 15:37:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:38:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:38:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:38:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:38:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:39:15 julianss tracker-store[4177]: OK
Jun 28 15:39:15 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:40:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:40:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:40:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:40:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:41:15 julianss tracker-store[4215]: OK
Jun 28 15:41:15 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:42:38 julianss wpa_supplicant[976]: wlp3s0: WPA: Group rekeying completed with 9c:97:26:eb:6f:bb [GTK=TKIP]
Jun 28 15:42:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:42:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:42:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:42:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:43:15 julianss tracker-store[4273]: OK
Jun 28 15:43:15 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:44:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:44:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:44:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:44:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:45:14 julianss tracker-store[4305]: OK
Jun 28 15:45:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:46:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:46:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:46:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:46:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:47:15 julianss tracker-store[4334]: OK
Jun 28 15:47:15 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:48:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:48:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:48:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:48:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:49:14 julianss tracker-store[4354]: OK
Jun 28 15:49:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:50:21 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:50:21 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:50:21 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:50:21 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:50:51 julianss tracker-store[4377]: OK
Jun 28 15:50:51 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:52:38 julianss wpa_supplicant[976]: wlp3s0: WPA: Group rekeying completed with 9c:97:26:eb:6f:bb [GTK=TKIP]
Jun 28 15:52:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:52:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:52:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:52:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:53:14 julianss tracker-store[4409]: OK
Jun 28 15:53:14 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:54:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:54:44 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:54:44 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:54:44 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:55:15 julianss tracker-store[4431]: OK
Jun 28 15:55:15 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:56:45 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:56:45 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:56:45 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:56:45 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:57:15 julianss tracker-store[4467]: OK
Jun 28 15:57:15 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 15:58:34 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 gestures: scheduled expiry is in the past (-111ms), your system is too slow
Jun 28 15:58:44 julianss /usr/lib/gdm-x-session[1308]: (II) event15 - CUST0000:00 04F3:30A0 Touchpad: SYN_DROPPED event - some input events have been lost.
Jun 28 15:58:44 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 tap: scheduled expiry is in the past (-345ms), your system is too slow
Jun 28 15:58:44 julianss /usr/lib/gdm-x-session[1308]: (EE) libevdev: BUG: Device "CUST0000:00 04F3:30A0 Touchpad" received a double tracking ID 2535 in slot 0.
Jun 28 15:58:44 julianss /usr/lib/gdm-x-session[1308]: (EE) libevdev: BUG: Device "CUST0000:00 04F3:30A0 Touchpad" received a double tracking ID 2536 in slot 1.
Jun 28 15:58:44 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 tap: scheduled expiry is in the past (-737ms), your system is too slow
Jun 28 15:58:51 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 tap: scheduled expiry is in the past (-67ms), your system is too slow
Jun 28 15:58:51 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 tap: scheduled expiry is in the past (-32ms), your system is too slow
Jun 28 15:58:55 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Activating via systemd: service name='org.freedesktop.Tracker1' unit='tracker-store.service' requested by ':1.68' (uid=1000 pid=1667 comm="/usr/lib/tracker-miner-fs ")
Jun 28 15:59:00 julianss systemd[1286]: Starting Tracker metadata database store and lookup manager...
Jun 28 15:59:10 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 middlebutton: scheduled expiry is in the past (-112ms), your system is too slow
Jun 28 15:59:19 julianss kernel: c invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
Jun 28 15:59:23 julianss kernel: CPU: 0 PID: 1660 Comm: c Tainted: G           OE     5.6.16-1-MANJARO #1
Jun 28 15:59:23 julianss kernel: Hardware name: HP HP Laptop 14-cf0xxx/84B3, BIOS F.42 06/20/2019
Jun 28 15:59:23 julianss kernel: Call Trace:
Jun 28 15:59:24 julianss kernel:  dump_stack+0x64/0x88
Jun 28 15:59:24 julianss kernel:  dump_header+0x4a/0x1f7
Jun 28 15:59:24 julianss kernel:  oom_kill_process.cold+0xb/0x10
Jun 28 15:59:24 julianss kernel:  out_of_memory+0x197/0x490
Jun 28 15:59:24 julianss kernel:  __alloc_pages_slowpath+0xb3c/0xd90
Jun 28 15:59:24 julianss kernel:  __alloc_pages_nodemask+0x2ee/0x320
Jun 28 15:59:24 julianss kernel:  pagecache_get_page+0x14a/0x360
Jun 28 15:59:24 julianss kernel:  filemap_fault+0x65d/0x8c0
Jun 28 15:59:24 julianss kernel:  ext4_filemap_fault+0x2d/0x40 [ext4]
Jun 28 15:59:24 julianss kernel:  __do_fault+0x38/0xd0
Jun 28 15:59:24 julianss kernel:  __handle_mm_fault+0xe49/0x1620
Jun 28 15:59:24 julianss kernel:  ? retint_kernel+0x1b/0x1b
Jun 28 15:59:24 julianss kernel:  handle_mm_fault+0xca/0x1f0
Jun 28 15:59:24 julianss kernel:  do_user_addr_fault+0x1ef/0x470
Jun 28 15:59:24 julianss kernel:  page_fault+0x34/0x40
Jun 28 15:59:24 julianss kernel: RIP: 0033:0x7f2bdfdbacef
Jun 28 15:59:24 julianss kernel: Code: Bad RIP value.
Jun 28 15:59:25 julianss kernel: RSP: 002b:00007ffe9e3afc20 EFLAGS: 00010246
Jun 28 15:59:25 julianss kernel: RAX: 000000000000002e RBX: 000000000000002e RCX: 0000000000000027
Jun 28 15:59:25 julianss kernel: RDX: 0000000000000001 RSI: 00007f2bdff31460 RDI: 00007f2bdcd4fd20
Jun 28 15:59:25 julianss kernel: RBP: 00007f2bdfedb14a R08: 00007f2bdffebe20 R09: 0000000000000000
Jun 28 15:59:25 julianss kernel: R10: 7fffffffffffffce R11: 0000000000000088 R12: 00007f2bdfef372c
Jun 28 15:59:25 julianss kernel: R13: 00007ffe9e3afc30 R14: 00007f2bdfedb149 R15: 0000000000000001
Jun 28 15:59:25 julianss kernel: Mem-Info:
Jun 28 15:59:25 julianss kernel: active_anon:736224 inactive_anon:152093 isolated_anon:0
                                  active_file:88 inactive_file:77 isolated_file:0
                                  unevictable:1313 dirty:0 writeback:0 unstable:0
                                  slab_reclaimable:12266 slab_unreclaimable:26347
                                  mapped:33269 shmem:41891 pagetables:7178 bounce:0
                                  free:22239 free_pcp:236 free_cma:0
Jun 28 15:59:25 julianss kernel: Node 0 active_anon:2944896kB inactive_anon:608372kB active_file:352kB inactive_file:308kB unevictable:5252kB isolated(anon):0kB isolated(file):0kB mapped:133076kB dirty:0kB writeback:0kB shmem:167564kB shmem_thp: 0kB shmem_pmdmapped: 0kB anon_thp: 1138688kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
Jun 28 15:59:25 julianss kernel: Node 0 DMA free:15396kB min:272kB low:340kB high:408kB reserved_highatomic:0KB active_anon:268kB inactive_anon:148kB active_file:0kB inactive_file:0kB unevictable:0kB writepending:0kB present:15896kB managed:15816kB mlocked:0kB kernel_stack:0kB pagetables:4kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
Jun 28 15:59:25 julianss kernel: lowmem_reserve[]: 0 2108 3782 3782 3782
Jun 28 15:59:25 julianss kernel: Node 0 DMA32 free:44144kB min:37512kB low:46888kB high:56264kB reserved_highatomic:0KB active_anon:1543272kB inactive_anon:541328kB active_file:12kB inactive_file:488kB unevictable:0kB writepending:0kB present:2236212kB managed:2170632kB mlocked:0kB kernel_stack:4220kB pagetables:10496kB bounce:0kB free_pcp:8kB local_pcp:0kB free_cma:0kB
Jun 28 15:59:25 julianss kernel: lowmem_reserve[]: 0 0 1674 1674 1674
Jun 28 15:59:25 julianss kernel: Node 0 Normal free:29416kB min:29796kB low:37244kB high:44692kB reserved_highatomic:0KB active_anon:1401356kB inactive_anon:66896kB active_file:528kB inactive_file:212kB unevictable:5252kB writepending:0kB present:1818624kB managed:1722144kB mlocked:0kB kernel_stack:9684kB pagetables:18212kB bounce:0kB free_pcp:936kB local_pcp:260kB free_cma:0kB
Jun 28 15:59:25 julianss kernel: lowmem_reserve[]: 0 0 0 0 0
Jun 28 15:59:25 julianss kernel: Node 0 DMA: 1*4kB (U) 4*8kB (U) 2*16kB (U) 5*32kB (UM) 3*64kB (UM) 1*128kB (U) 0*256kB 1*512kB (M) 2*1024kB (UM) 0*2048kB 3*4096kB (ME) = 15396kB
Jun 28 15:59:25 julianss kernel: Node 0 DMA32: 1061*4kB (UME) 548*8kB (UME) 528*16kB (UME) 272*32kB (UME) 135*64kB (UME) 44*128kB (UE) 16*256kB (UME) 2*512kB (E) 0*1024kB 0*2048kB 0*4096kB = 45172kB
Jun 28 15:59:25 julianss kernel: Node 0 Normal: 963*4kB (UME) 920*8kB (UME) 347*16kB (UME) 211*32kB (UME) 99*64kB (UME) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 29852kB
Jun 28 15:59:25 julianss kernel: Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=1048576kB
Jun 28 15:59:25 julianss kernel: Node 0 hugepages_total=0 hugepages_free=0 hugepages_surp=0 hugepages_size=2048kB
Jun 28 15:59:25 julianss kernel: 47339 total pagecache pages
Jun 28 15:59:25 julianss kernel: 5257 pages in swap cache
Jun 28 15:59:25 julianss kernel: Swap cache stats: add 276466, delete 271220, find 6533/8920
Jun 28 15:59:25 julianss kernel: Free swap  = 0kB
Jun 28 15:59:25 julianss kernel: Total swap = 1048572kB
Jun 28 15:59:25 julianss kernel: 1017683 pages RAM
Jun 28 15:59:25 julianss kernel: 0 pages HighMem/MovableOnly
Jun 28 15:59:25 julianss kernel: 40535 pages reserved
Jun 28 15:59:25 julianss kernel: 0 pages hwpoisoned
Jun 28 15:59:25 julianss kernel: Tasks state (memory values in pages):
Jun 28 15:59:25 julianss kernel: [  pid  ]   uid  tgid total_vm      rss pgtables_bytes swapents oom_score_adj name
Jun 28 15:59:25 julianss kernel: [    271]     0   271    25251      140   204800      260          -250 systemd-journal
Jun 28 15:59:25 julianss kernel: [    292]     0   292     8560       22    94208     1199         -1000 systemd-udevd
Jun 28 15:59:25 julianss kernel: [    296]     0   296    19515        2    53248       31             0 lvmetad
Jun 28 15:59:25 julianss kernel: [    693]   979   693    22811        0    77824      265             0 systemd-timesyn
Jun 28 15:59:25 julianss kernel: [    701]     0   701     2567        4    57344      140             0 bluetoothd
Jun 28 15:59:25 julianss kernel: [    703]     0   703     2281       13    49152       71             0 crond
Jun 28 15:59:25 julianss kernel: [    704]    81   704     1989       70    57344      404          -900 dbus-daemon
Jun 28 15:59:25 julianss kernel: [    705]     0   705    82998      202   151552      544             0 NetworkManager
Jun 28 15:59:25 julianss kernel: [    707]   102   707   414861        0   192512     1733             0 polkitd
Jun 28 15:59:25 julianss kernel: [    708]     0   708   348487      471   241664     2915          -900 snapd
Jun 28 15:59:25 julianss kernel: [    709]     0   709     4294        0    69632      292             0 systemd-logind
Jun 28 15:59:25 julianss kernel: [    724]   967   724    14672       85    94208      303             0 redis-server
Jun 28 15:59:25 julianss kernel: [    729]     0   729    59512        1    94208      266             0 gdm
Jun 28 15:59:25 julianss kernel: [    748]   968   748    51983      127   147456      329          -200 postgres
Jun 28 15:59:25 julianss kernel: [    758]     0   758    59244        0    94208      244             0 accounts-daemon
Jun 28 15:59:25 julianss kernel: [    764]     0   764    78104        0   106496      391             0 ModemManager
Jun 28 15:59:25 julianss kernel: [    784]   968   784    52011       62   122880      335          -200 postgres
Jun 28 15:59:25 julianss kernel: [    785]   968   785    51983       40   122880      330          -200 postgres
Jun 28 15:59:25 julianss kernel: [    786]   968   786    51983       31   118784      332          -200 postgres
Jun 28 15:59:25 julianss kernel: [    787]   968   787    52125       81   131072      363          -200 postgres
Jun 28 15:59:25 julianss kernel: [    788]   968   788    15578       31    98304      317          -200 postgres
Jun 28 15:59:25 julianss kernel: [    789]   968   789    52089       57   122880      371          -200 postgres
Jun 28 15:59:25 julianss kernel: [    976]     0   976     3448       53    61440      198             0 wpa_supplicant
Jun 28 15:59:25 julianss kernel: [   1084]     0  1084    62799        1   106496      372             0 upowerd
Jun 28 15:59:25 julianss kernel: [   1104]   133  1104    38182        2    65536       59             0 rtkit-daemon
Jun 28 15:59:25 julianss kernel: [   1210]   974  1210    61203        1   110592     1252             0 colord
Jun 28 15:59:25 julianss kernel: [   1248]     0  1248    41898        1    98304      415             0 gdm-session-wor
Jun 28 15:59:25 julianss kernel: [   1275]     0  1275     7262        0    86016      428             0 cupsd
Jun 28 15:59:25 julianss kernel: [   1286]  1000  1286     4750      230    81920      301             0 systemd
Jun 28 15:59:25 julianss kernel: [   1287]  1000  1287     7489        6    90112      819             0 (sd-pam)
Jun 28 15:59:25 julianss kernel: [   1299]  1000  1299    59715        1    90112      288             0 gnome-keyring-d
Jun 28 15:59:25 julianss kernel: [   1306]  1000  1306    40689        1    77824      161             0 gdm-x-session
Jun 28 15:59:25 julianss kernel: [   1308]  1000  1308   364891     5548   626688     6223             0 Xorg
Jun 28 15:59:25 julianss kernel: [   1311]  1000  1311      579        0    36864       19             0 xf86-video-inte
Jun 28 15:59:25 julianss kernel: [   1329]  1000  1329     1839      251    49152      110             0 dbus-daemon
Jun 28 15:59:25 julianss kernel: [   1331]  1000  1331    64642        0   126976      459             0 gnome-session-b
Jun 28 15:59:25 julianss kernel: [   1352]  1000  1352    76069        0    90112      226             0 at-spi-bus-laun
Jun 28 15:59:25 julianss kernel: [   1358]  1000  1358     1600       36    49152       72             0 dbus-daemon
Jun 28 15:59:25 julianss kernel: [   1367]  1000  1367    22199        0    73728      103             0 gnome-session-c
Jun 28 15:59:25 julianss kernel: [   1368]  1000  1368   387031      641   147456      461             0 pulseaudio
Jun 28 15:59:25 julianss kernel: [   1370]  1000  1370   138525      124   167936      533             0 gnome-session-b
Jun 28 15:59:25 julianss kernel: [   1385]  1000  1385  1060539    14089  1056768    12047             0 gnome-shell
Jun 28 15:59:25 julianss kernel: [   1402]  1000  1402    58844        0    94208      269             0 gsettings-helpe
Jun 28 15:59:25 julianss kernel: [   1408]  1000  1408    77537      285    98304      204             0 ibus-daemon
Jun 28 15:59:25 julianss kernel: [   1411]  1000  1411    59603      133    90112      103             0 gvfsd
Jun 28 15:59:25 julianss kernel: [   1416]  1000  1416    94731       44    94208      152             0 gvfsd-fuse
Jun 28 15:59:25 julianss kernel: [   1417]  1000  1417    58592        0    81920      147             0 xdg-permission-
Jun 28 15:59:25 julianss kernel: [   1423]  1000  1423    58822        0    86016      196             0 ibus-dconf
Jun 28 15:59:25 julianss kernel: [   1424]  1000  1424    67504      267   163840     2940             0 ibus-extension-
Jun 28 15:59:25 julianss kernel: [   1428]  1000  1428   126648        0   196608      948             0 gnome-shell-cal
Jun 28 15:59:25 julianss kernel: [   1437]  1000  1437    47924       34   147456     2100             0 ibus-x11
Jun 28 15:59:25 julianss kernel: [   1440]  1000  1440    58782       16    86016       94             0 ibus-portal
Jun 28 15:59:25 julianss kernel: [   1447]  1000  1447    39929       63    77824      147             0 at-spi2-registr
Jun 28 15:59:25 julianss kernel: [   1459]  1000  1459    87629      172   131072      251             0 gvfs-udisks2-vo
Jun 28 15:59:25 julianss kernel: [   1462]     0  1462    98030        1   126976      761             0 udisksd
Jun 28 15:59:25 julianss kernel: [   1466]  1000  1466   217444      225   245760      735             0 evolution-sourc
Jun 28 15:59:25 julianss kernel: [   1475]  1000  1475   135544        0   258048     1681             0 goa-daemon
Jun 28 15:59:25 julianss kernel: [   1488]  1000  1488    58663        0    90112      179             0 gvfs-goa-volume
Jun 28 15:59:25 julianss kernel: [   1499]  1000  1499    78355        0   110592      264             0 goa-identity-se
Jun 28 15:59:25 julianss kernel: [   1504]  1000  1504    78897        0   110592      262             0 gvfs-afc-volume
Jun 28 15:59:25 julianss kernel: [   1510]  1000  1510    58638        0    86016      207             0 gvfs-mtp-volume
Jun 28 15:59:25 julianss kernel: [   1518]  1000  1518    78125        0   106496      322             0 gvfsd-trash
Jun 28 15:59:25 julianss kernel: [   1524]  1000  1524   678577        1   229376     1312             0 gjs
Jun 28 15:59:25 julianss kernel: [   1533]  1000  1533    77110        0    98304      181             0 gsd-a11y-settin
Jun 28 15:59:25 julianss kernel: [   1534]  1000  1534   143103      219   196608     2065             0 gsd-color
Jun 28 15:59:25 julianss kernel: [   1535]  1000  1535    92500        1   159744      518             0 gsd-datetime
Jun 28 15:59:25 julianss kernel: [   1537]  1000  1537    77603       39    98304      164             0 gsd-housekeepin
Jun 28 15:59:25 julianss kernel: [   1539]  1000  1539    84755       30   159744     2124             0 gsd-keyboard
Jun 28 15:59:25 julianss kernel: [   1540]  1000  1540   288776       66   225280     2314             0 gsd-media-keys
Jun 28 15:59:25 julianss kernel: [   1542]  1000  1542   103519       57   172032     2231             0 gsd-power
Jun 28 15:59:25 julianss kernel: [   1551]  1000  1551    61820        1   118784      357             0 gsd-print-notif
Jun 28 15:59:26 julianss kernel: [   1553]  1000  1553    95527        0   102400      194             0 gsd-rfkill
Jun 28 15:59:26 julianss kernel: [   1554]  1000  1554    58574        0    81920      166             0 gsd-screensaver
Jun 28 15:59:26 julianss kernel: [   1558]  1000  1558   114855      161   118784      184             0 gsd-sharing
Jun 28 15:59:26 julianss kernel: [   1561]  1000  1561    96858        0   114688      262             0 gsd-smartcard
Jun 28 15:59:26 julianss kernel: [   1563]  1000  1563    78897        0   110592      286             0 gsd-sound
Jun 28 15:59:26 julianss kernel: [   1565]  1000  1565    95923        0   110592      205             0 gsd-usb-protect
Jun 28 15:59:26 julianss kernel: [   1572]  1000  1572    66419       47   155648     2139             0 gsd-wacom
Jun 28 15:59:26 julianss kernel: [   1574]  1000  1574    78174        1   106496      258             0 gsd-wwan
Jun 28 15:59:26 julianss kernel: [   1584]  1000  1584    85274       77   167936     2160             0 gsd-xsettings
Jun 28 15:59:26 julianss kernel: [   1621]  1000  1621    84723        0   143360      498             0 gsd-printer
Jun 28 15:59:26 julianss kernel: [   1623]  1000  1623   208566        0   258048     1147             0 evolution-calen
Jun 28 15:59:26 julianss kernel: [   1646]  1000  1646    40362       49    86016      102             0 ibus-engine-sim
Jun 28 15:59:26 julianss kernel: [   1656]  1000  1656   176410        0   335872     3614             0 evolution-alarm
Jun 28 15:59:26 julianss kernel: [   1659]  1000  1659     2424       38    61440       73             0 check-aur
Jun 28 15:59:26 julianss kernel: [   1660]  1000  1660   111258      451   237568     6150             0 c
Jun 28 15:59:26 julianss kernel: [   1665]  1000  1665    57716       77    81920      174             0 gsd-disk-utilit
Jun 28 15:59:26 julianss kernel: [   1667]  1000  1667   147470      645   204800     1609             0 tracker-miner-f
Jun 28 15:59:26 julianss kernel: [   1718]  1000  1718    38796        3    65536      190             0 dconf-service
Jun 28 15:59:26 julianss kernel: [   1722]  1000  1722   185815        0   241664      980             0 evolution-addre
Jun 28 15:59:26 julianss kernel: [   1817]  1000  1817    41656        1    90112      244             0 ibus-engine-sun
Jun 28 15:59:26 julianss kernel: [   1834]  1000  1834   927089    50067  2330624    22355             0 firefox
Jun 28 15:59:26 julianss kernel: [   1893]  1000  1893   614480     6088   794624     7098             0 Privileged Cont
Jun 28 15:59:26 julianss kernel: [   1940]  1000  1940   709914    46033  1978368    32035             0 Web Content
Jun 28 15:59:26 julianss kernel: [   1972]  1000  1972   608256     2601   671744     6298             0 WebExtensions
Jun 28 15:59:26 julianss kernel: [   2054]  1000  2054   165559     1801   344064     5836             0 nautilus
Jun 28 15:59:26 julianss kernel: [   2136]  1000  2136    48578      651   299008     1542             0 RDD Process
Jun 28 15:59:26 julianss kernel: [   2152]  1000  2152    40386       21    81920      253             0 gvfsd-metadata
Jun 28 15:59:26 julianss kernel: [   2168]  1000  2168   155262      760   262144     2266             0 gnome-terminal-
Jun 28 15:59:26 julianss kernel: [   2177]  1000  2177     3349       41    69632      578             0 zsh
Jun 28 15:59:26 julianss kernel: [   2559]  1000  2559   133532     4163   274432     9364             0 jupyter-noteboo
Jun 28 15:59:26 julianss kernel: [   2564]  1000  2564   149697     2088   344064     9617             0 evince
Jun 28 15:59:26 julianss kernel: [   2569]  1000  2569    38721        0    65536      134             0 evinced
Jun 28 15:59:26 julianss kernel: [   2672]  1000  2672   643612    26604  1179648    10831             0 file:// Content
Jun 28 15:59:26 julianss kernel: [   2706]  1000  2706   659632    12866  1470464    12771             0 Web Content
Jun 28 15:59:26 julianss kernel: [   2918]  1000  2918  1120376   537264  5099520     7430             0 python
Jun 28 15:59:26 julianss kernel: [   3326]  1000  3326   672849    22232  1495040    13857             0 Web Content
Jun 28 15:59:26 julianss kernel: [   3367]  1000  3367   646245    35850  1388544     4308             0 Web Content
Jun 28 15:59:26 julianss kernel: [   3480]  1000  3480    69644      169   122880      154             0 gvfsd-http
Jun 28 15:59:26 julianss kernel: [   3542]  1000  3542   634042    31314  1183744        0             0 Web Content
Jun 28 15:59:26 julianss kernel: [   3720]  1000  3720   649835    17597  1069056        0             0 Web Content
Jun 28 15:59:26 julianss kernel: [   3771]  1000  3771   622026    18380   909312        0             0 Web Content
Jun 28 15:59:26 julianss kernel: [   3855]  1000  3855   629830    22926   864256        0             0 Web Content
Jun 28 15:59:26 julianss kernel: [   4225]  1000  4225   130207     9339   225280        0             0 python
Jun 28 15:59:26 julianss kernel: [   4241]  1000  4241   130207     9395   217088        0             0 python
Jun 28 15:59:26 julianss kernel: [   4487]  1000  4487     1958       16    53248        0             0 sleep
Jun 28 15:59:26 julianss kernel: [   4496]  1000  4496     3167       37    61440        0             0 tracker-store
Jun 28 15:59:26 julianss kernel: oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@1000.service,task=python,pid=2918,uid=1000
Jun 28 15:59:26 julianss kernel: oom_reaper: reaped process 2918 (python), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Jun 28 15:59:26 julianss /usr/lib/gdm-x-session[1308]: (II) event15 - CUST0000:00 04F3:30A0 Touchpad: SYN_DROPPED event - some input events have been lost.
Jun 28 15:59:26 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 tap: scheduled expiry is in the past (-722ms), your system is too slow
Jun 28 15:59:26 julianss dbus-daemon[1329]: [session uid=1000 pid=1329] Successfully activated service 'org.freedesktop.Tracker1'
Jun 28 15:59:26 julianss systemd[1286]: Started Tracker metadata database store and lookup manager.
Jun 28 15:59:32 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 tap: scheduled expiry is in the past (-546ms), your system is too slow
Jun 28 15:59:32 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 keyboard: scheduled expiry is in the past (-728ms), your system is too slow
Jun 28 15:59:32 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 keyboard: scheduled expiry is in the past (-512ms), your system is too slow
Jun 28 15:59:32 julianss /usr/lib/gdm-x-session[1308]: (EE) client bug: timer event15 keyboard: scheduled expiry is in the past (-62ms), your system is too slow
Jun 28 15:59:38 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "25"
Jun 28 15:59:38 julianss /usr/lib/gdm-x-session[1308]: (II) event2  - Power Button: device removed
Jun 28 15:59:38 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "29"
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (II) event6  - Video Bus: device removed
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "30"
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (II) event1  - Power Button: device removed
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "31"
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (II) event17 - HP TrueVision HD Camera: HP Tru: device removed
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "32"
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (II) event14 - CUST0000:00 04F3:30A0 Mouse: device removed
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "33"
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (II) event15 - CUST0000:00 04F3:30A0 Touchpad: device removed
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "34"
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (II) event3  - AT Translated Set 2 keyboard: device removed
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "35"
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (II) event16 - HP WMI hotkeys: device removed
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "36"
Jun 28 15:59:39 julianss /usr/lib/gdm-x-session[1308]: (II) event4  - HP Wireless hotkeys: device removed
Jun 28 15:59:40 julianss /usr/lib/gdm-x-session[1308]: (II) AIGLX: Suspending AIGLX clients for VT switch
Jun 28 15:59:42 julianss kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
Jun 28 15:59:42 julianss kernel: amdgpu: [powerplay] can't get the mac of 5
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:68
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:81
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 226:1
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 226:0
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:67
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:66
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:65
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:78
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:70
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:80
Jun 28 15:59:43 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:79
Jun 28 15:59:48 julianss kernel: rfkill: input handler enabled
Jun 28 15:59:48 julianss kernel: amdgpu: [powerplay] VI should always have 2 performance levels
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in First Boot Wizard being skipped.
Jun 28 15:59:53 julianss kernel: audit: type=1130 audit(1593374393.897:106): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty4 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 28 15:59:53 julianss audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty4 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in Rebuild Dynamic Linker Cache being skipped.
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in Rebuild Journal Catalog being skipped.
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in Create System Users being skipped.
Jun 28 15:59:52 julianss systemd[1]: Condition check resulted in Update is Completed being skipped.
Jun 28 15:59:53 julianss systemd[1]: Started Getty on tty4.
Jun 28 15:59:54 julianss kernel: fbcon: Taking over console
Jun 28 15:59:54 julianss kernel: Console: switching to colour frame buffer device 170x48
Jun 28 16:00:03 julianss login[4506]: pam_unix(login:auth): authentication failure; logname=LOGIN uid=0 euid=0 tty=tty4 ruser= rhost=  user=julian
Jun 28 16:00:04 julianss kernel: audit: type=1100 audit(1593374403.958:107): pid=4506 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=? acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=failed'
Jun 28 16:00:03 julianss audit[4506]: USER_AUTH pid=4506 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=? acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=failed'
Jun 28 16:00:05 julianss login[4506]: FAILED LOGIN 1 FROM tty4 FOR julian, Authentication failure
Jun 28 16:00:13 julianss audit[4506]: USER_AUTH pid=4506 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_tally2,pam_shells,pam_unix,pam_permit acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:13 julianss kernel: audit: type=1100 audit(1593374413.171:108): pid=4506 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_tally2,pam_shells,pam_unix,pam_permit acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:14 julianss audit[4506]: USER_ACCT pid=4506 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:14 julianss kernel: audit: type=1101 audit(1593374414.121:109): pid=4506 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:15 julianss audit[4506]: CRED_ACQ pid=4506 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_tally2,pam_shells,pam_unix,pam_permit acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:15 julianss kernel: audit: type=1103 audit(1593374415.098:110): pid=4506 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_tally2,pam_shells,pam_unix,pam_permit acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:15 julianss kernel: audit: type=1006 audit(1593374415.098:111): pid=4506 uid=0 old-auid=4294967295 auid=1000 tty=tty4 old-ses=4294967295 ses=4 res=1
Jun 28 16:00:15 julianss login[4506]: pam_unix(login:session): session opened for user julian by LOGIN(uid=0)
Jun 28 16:00:16 julianss systemd-logind[709]: New session 4 of user julian.
Jun 28 16:00:16 julianss systemd[1]: Started Session 4 of user julian.
Jun 28 16:00:16 julianss audit[4506]: USER_START pid=4506 uid=0 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:16 julianss kernel: audit: type=1105 audit(1593374416.908:112): pid=4506 uid=0 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:16 julianss kernel: audit: type=1110 audit(1593374416.911:113): pid=4506 uid=0 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_securetty,pam_tally2,pam_shells,pam_unix,pam_permit acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:16 julianss audit[4506]: CRED_REFR pid=4506 uid=0 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_securetty,pam_tally2,pam_shells,pam_unix,pam_permit acct="julian" exe="/usr/bin/login" hostname=julianss addr=? terminal=tty4 res=success'
Jun 28 16:00:17 julianss login[4506]: LOGIN ON tty4 BY julian
Jun 28 16:00:49 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:68
Jun 28 16:00:49 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:81
Jun 28 16:00:50 julianss kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
Jun 28 16:00:50 julianss kernel: amdgpu: [powerplay] can't get the mac of 5
Jun 28 16:00:50 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 226:1
Jun 28 16:00:50 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 226:0
Jun 28 16:00:50 julianss /usr/lib/gdm-x-session[1308]: (II) AIGLX: Resuming AIGLX clients after VT switch
Jun 28 16:00:50 julianss /usr/lib/gdm-x-session[1308]: (II) intel(0): switch to mode 1366x768@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
Jun 28 16:00:50 julianss kernel: rfkill: input handler disabled
Jun 28 16:00:50 julianss /usr/lib/gdm-x-session[1308]: (II) event17 - HP TrueVision HD Camera: HP Tru: is tagged by udev as: Keyboard
Jun 28 16:00:50 julianss /usr/lib/gdm-x-session[1308]: (II) event17 - HP TrueVision HD Camera: HP Tru: device is a keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event4  - HP Wireless hotkeys: is tagged by udev as: Keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event4  - HP Wireless hotkeys: device is a keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:67
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event3  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event3  - AT Translated Set 2 keyboard: device is a keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:66
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event2  - Power Button: is tagged by udev as: Keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event2  - Power Button: device is a keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:65
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event1  - Power Button: is tagged by udev as: Keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event1  - Power Button: device is a keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:78
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event14 - CUST0000:00 04F3:30A0 Mouse: is tagged by udev as: Mouse Pointingstick
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event14 - CUST0000:00 04F3:30A0 Mouse: device is a pointer
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:70
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event6  - Video Bus: is tagged by udev as: Keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event6  - Video Bus: device is a keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:80
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event16 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event16 - HP WMI hotkeys: device is a keyboard
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got resume for 13:79
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event15 - CUST0000:00 04F3:30A0 Touchpad: is tagged by udev as: Touchpad
Jun 28 16:00:51 julianss /usr/lib/gdm-x-session[1308]: (II) event15 - CUST0000:00 04F3:30A0 Touchpad: device is a touchpad
Jun 28 16:00:51 julianss gnome-shell[1385]: pushModal: invocation of begin_modal failed
Jun 28 16:00:55 julianss /usr/lib/gdm-x-session[1308]: (II) event15 - CUST0000:00 04F3:30A0 Touchpad: SYN_DROPPED event - some input events have been lost.
Jun 28 16:00:56 julianss kernel: amdgpu: [powerplay] VI should always have 2 performance levels
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Jun 28 16:00:59 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
Jun 28 16:01:00 julianss gnome-shell[1385]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "25"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event2  - Power Button: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "35"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event6  - Video Bus: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "33"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event1  - Power Button: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "30"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event17 - HP TrueVision HD Camera: HP Tru: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "34"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event14 - CUST0000:00 04F3:30A0 Mouse: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "84"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event15 - CUST0000:00 04F3:30A0 Touchpad: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "86"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event3  - AT Translated Set 2 keyboard: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "36"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event16 - HP WMI hotkeys: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (**) Option "fd" "29"
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) event4  - HP Wireless hotkeys: device removed
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) AIGLX: Suspending AIGLX clients for VT switch
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:68
Jun 28 16:01:01 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:81
Jun 28 16:01:02 julianss kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
Jun 28 16:01:02 julianss kernel: amdgpu: [powerplay] can't get the mac of 5
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 226:1
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 226:0
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:67
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:66
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:65
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:78
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:70
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:80
Jun 28 16:01:02 julianss /usr/lib/gdm-x-session[1308]: (II) systemd-logind: got pause for 13:79
Jun 28 16:01:02 julianss kernel: rfkill: input handler enabled
Jun 28 16:01:02 julianss CROND[4858]: (root) CMD (run-parts /etc/cron.hourly)
Jun 28 16:01:08 julianss kernel: amdgpu: [powerplay] VI should always have 2 performance levels
Jun 28 16:01:16 julianss tracker-store[4496]: OK
Jun 28 16:01:16 julianss systemd[1286]: tracker-store.service: Succeeded.
Jun 28 16:02:39 julianss wpa_supplicant[976]: wlp3s0: WPA: Group rekeying completed with 9c:97:26:eb:6f:bb [GTK=TKIP]
swapon -s
Filename				Type		Size	Used	Priority
/swapfile                          file    	1048572	495048	-2
cat /sys/fs/cgroup/memory/memory.swappiness
60
Thanks! (and sorry for my bad english)
Install an OOM killer like nohang-git, it will at least give you warning.
 aur/nohang-git 0.1.r691.g22ac983-1 [installed] [4+] [1.25%] [28 Jun 2020]
    A sophisticated low memory handler
Am I reading it correctly - 4gb of memory?
Yes, i do have 4gb of memory on my laptop. I'll try nohang and then report the results. Thanks!
Do you have a /swap or a swapfile? swapfile is better imo.
I use a 1MiB swapfile
um... since you have 4GB of RAM, you should make a 8GB or 12GB swap file. I have 16GB of RAM on all of my computers, but I still run a 4GB or 8GB swapfile.
Whoa that's a lot. I was sure I read in archlinux wiki that I should make a swapfile 20% of the size of my ram memory, but perhaps I understood incorrectly
I think you misread it. Swapfile can be 20% the size of your RAM memory if you're already at 16GB RAM.
But if you have so little RAM to start with, you need a bigger swapfile to take place of your RAM. Else you'd run of memory, which you are.
Ok, i'll try that too, thanks!
Well, that did not fix the issue. I never got alerted by nohang (that was very weird), and the extra memory (I upgraded it to 8GB) couldn't do it either. My system hanged today, and the weird thing is that I had not a OOM error. I suppose it's another thing. I updated the title
There are some parts of the log output that really surprise me, like
Jul 18 13:03:16 julianss gnome-shell[1396]: Window manager warning: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x5600003
Jul 18 13:03:27 julianss kernel: amdgpu: [powerplay] VI should always have 2 performance levels
Jul 18 13:03:32 julianss kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
Jul 18 13:03:32 julianss kernel: amdgpu: [powerplay] can't get the mac of 5
Jul 18 13:03:42 julianss kernel: amdgpu: [powerplay] VI should always have 2 performance levels
Jul 18 13:03:47 julianss kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
Jul 18 13:03:47 julianss kernel: amdgpu: [powerplay] can't get the mac of 5
Jul 18 13:04:01 julianss /usr/lib/gdm-x-session[1316]: (II) intel(0): switch to mode 1366x768@60.1 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
Jul 18 13:04:07 julianss kernel: amdgpu: [powerplay] VI should always have 2 performance levels
Jul 18 13:04:15 julianss kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
Jul 18 13:04:15 julianss kernel: amdgpu: [powerplay] can't get the mac of 5
Jul 18 13:04:23 julianss kernel: amdgpu: [powerplay] VI should always have 2 performance levels
Jul 18 13:04:27 julianss kernel: [drm] PCIE GART of 256M enabled (table at 0x000000F400000000).
Jul 18 13:04:27 julianss kernel: amdgpu: [powerplay] can't get the mac of 5
Jul 18 13:04:27 julianss gnome-shell[1396]: Window manager warning: Treating resize request of legacy application 0x5600003 as a fullscreen request
Jul 18 13:04:29 julianss gnome-shell[1396]: clutter_actor_insert_child_at_index: assertion 'child->priv->parent == NULL' failed
Jul 18 13:04:31 julianss gnome-shell[1396]: clutter_actor_remove_child: assertion 'child->priv->parent == self' failed
Jul 18 13:04:32 julianss gnome-shell[1396]: Impossible to monitor trash: Gio.IOErrorEnum: Operation not supported
Jul 18 13:04:32 julianss gnome-shell[1396]: Impossible to enumerate trash children: Gio.IOErrorEnum: Operation not supported
Jul 18 13:04:35 julianss kernel: amdgpu: [powerplay] VI should always have 2 performance levels
or
Jul 18 13:22:30 julianss /usr/lib/gdm-x-session[1316]: (EE) client bug: timer event15 tap: scheduled expiry is in the past (-64ms), your system is too slow
Jul 18 13:22:31 julianss gnome-shell[1396]: clutter_actor_insert_child_at_index: assertion 'child->priv->parent == NULL' failed
Jul 18 13:22:31 julianss gnome-shell[1396]: clutter_actor_remove_child: assertion 'child->priv->parent == self' failed
Jul 18 13:22:32 julianss /usr/lib/gdm-x-session[1316]: (EE) client bug: timer event15 middlebutton: scheduled expiry is in the past (-140ms), your system is too slow
Jul 18 13:22:32 julianss gnome-shell[1396]: Impossible to monitor trash: Gio.IOErrorEnum: Operation not supported
Jul 18 13:22:32 julianss gnome-shell[1396]: Impossible to enumerate trash children: Gio.IOErrorEnum: Operation not supported
Jul 18 13:22:32 julianss systemd[1293]: Started VTE child process 3686 launched by gnome-terminal-server process 3659.
Jul 18 13:22:32 julianss systemd[1293]: Started VTE child process 3685 launched by gnome-terminal-server process 3659.
Jul 18 13:22:32 julianss systemd[1293]: gnome-launched-org.gnome.Terminal.desktop-3636.scope: Succeeded.
Jul 18 13:22:32 julianss systemd[1293]: gnome-launched-org.gnome.Terminal.desktop-3641.scope: Succeeded.
Any ideas?
Any ideas
May be the problem is small swap space. You would change some config keys to fix it:
Set
warning_threshold_min_swap = 500 M
soft_threshold_min_swap = 200 M
Default soft_threshold_min_swap = 10%. - it is 0.1 MiB if you used 1 M swap space.
Yet another suggestion: use swap on zram with disksize = 4 - 6 GiB, for example.
BTW, I'm nohang author. Welcome to https://github.com/hakavlad/nohang/issues if you have a question.
