Randomly and Continuous reboot on manjaro 20.0.3
Hi friends
My system randomly and continuous reboots. This happened recently without hardware changing or installing a new software.
my system information:
System:    Kernel: 5.7.0-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=a68d8232-2268-4c22-a875-d7f2e2201e8b rw quiet apparmor=1
           Console: tty 1 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop System: Micro-Star product: MS-7A39 v: 1.0 serial: N/A
           Mobo: MSI model: A320M GAMING PRO (MS-7A39) v: 1.0 serial: <filter> UEFI: American Megatrends v: 1.KP
           date: 12/02/2019
CPU:       Topology: Quad Core model: AMD Ryzen 3 1200 bits: 64 type: MCP arch: Zen family: 17 (23) model-id: 1 stepping: 1
           microcode: 8001138 L1 cache: 384 KiB L2 cache: 2048 KiB L3 cache: 8192 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 24805
           Speed: 1836 MHz min/max: 1550/3100 MHz boost: enabled Core speeds (MHz): 1: 1375 2: 1718 3: 1376 4: 1378
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: AMD Baffin [Radeon RX 460/560D / Pro 450/455/460/555/555X/560/560X] vendor: ASUSTeK driver: amdgpu
           v: kernel bus ID: 29:00.0 chip ID: 1002:67ef
           Display: server: X.org 1.20.8 driver: amdgpu FAILED: ati unloaded: modesetting alternate: fbdev,vesa
           compositor: kwin_x11 tty: 184x30
           Message: Advanced graphics data unavailable in console for root.
Audio:     Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK driver: snd_hda_intel
           v: kernel bus ID: 29:00.1 chip ID: 1002:aae0
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus ID: 2b:00.3 chip ID: 1022:1457
           Sound Server: ALSA v: k5.7.0-3-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
           port: f000 bus ID: 25:00.0 chip ID: 10ec:8168
           IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 417.10 GiB used: 58.47 GiB (14.0%)
           ID-1: /dev/sda vendor: Silicon Power model: SPCC Solid State Disk size: 111.79 GiB block size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 7A0 scheme: GPT
           ID-2: /dev/sdb vendor: Samsung model: HM321HX size: 298.09 GiB block size: physical: 512 B logical: 512 B
           speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
           ID-3: /dev/sdc type: USB model: USB FLASH DRIVE size: 7.21 GiB block size: physical: 512 B logical: 512 B
           serial: <filter> rev: PMAP scheme: MBR
Partition: ID-1: / raw size: 111.49 GiB size: 109.24 GiB (97.98%) used: 58.47 GiB (53.5%) fs: ext4 block size: 4096 B
           dev: /dev/sda2
Sensors:   System Temperatures: cpu: 40.0 C mobo: 40.5 C gpu: amdgpu temp: 44 C
           Fan Speeds (RPM): fan-1: 0 fan-2: 1311 fan-3: 1785 fan-4: 0 fan-5: 0 gpu: amdgpu fan: 1466
           Voltages: 12v: N/A 5v: N/A 3.3v: 3.42 vbat: 3.36
Info:      Processes: 292 Uptime: 15m Memory: 11.71 GiB used: 2.32 GiB (19.8%) Init: systemd v: 245 Compilers: gcc: 10.1.0
           Shell: bash v: 5.0.17 running in: tty 1 inxi: 3.0.37
and log information with journalctl -b -p err|less command:
-- Logs begin at Fri 2020-04-17 14:02:25 +0430, end at Tue 2020-06-23 16:57:13 +0430. --
Jun 23 16:40:52 ali-desktop kernel: mce: [Hardware Error]: CPU 1: Machine Check: 0 Bank 5: bea0000000000108
Jun 23 16:40:52 ali-desktop kernel: mce: [Hardware Error]: TSC 0 ADDR 1ffffba9f1b3e MISC d012000100000000 SYND 4d000000 IPID 500b000000000
Jun 23 16:40:52 ali-desktop kernel: mce: [Hardware Error]: PROCESSOR 2:800f11 TIME 1592914249 SOCKET 0 APIC 1 microcode 8001138
Jun 23 16:40:53 ali-desktop kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Jun 23 16:40:53 ali-desktop kernel: kvm: disabled by bios
Jun 23 16:40:55 ali-desktop kernel: sd 9:0:0:0: [sdc] No Caching mode page found
Jun 23 16:40:55 ali-desktop kernel: sd 9:0:0:0: [sdc] Assuming drive cache: write through
Jun 23 16:40:56 ali-desktop nmbd[828]: [2020/06/23 16:40:56.662721,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 16:40:56 ali-desktop nmbd[828]:   daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Jun 23 16:40:56 ali-desktop smbd[832]: [2020/06/23 16:40:56.771166,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 16:40:56 ali-desktop smbd[832]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Jun 23 16:41:00 ali-desktop sddm-helper[1076]: gkr-pam: unable to locate daemon control file
Jun 23 16:41:03 ali-desktop KMailApplet[1648]: /usr/bin/KMailApplet : no Maildirs provided
Jun 23 16:41:19 ali-desktop nmbd[828]: [2020/06/23 16:41:19.811488,  0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Jun 23 16:41:19 ali-desktop nmbd[828]:   *****
Jun 23 16:41:19 ali-desktop nmbd[828]:   Samba name server ALI-DESKTOP is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.102
(END)
my BIOS version is the latest one.
thanks in advanced
First thing to do is to try a different kernel. New kernels often introduce inconsistencies.
thanks body
also I have tried some kernels like 5.6, 5.4 and 4.19 without any success.
That isn't good.
It is possible you have some failing hardware or something has become corrupt in your system.
Is there anything in journalctl -p err from a time when the issues were happening? Your above output is limited to the most recent boot which may not be showing the actual errors.
the output of "journalctl -p err" command is:
-- Logs begin at Fri 2020-04-17 14:02:25 +0430, end at Tue 2020-06-23 17:22:30 +0430. --
Apr 17 14:02:31 ali-desktop sddm-helper[1001]: gkr-pam: unable to locate daemon control file
Apr 17 14:02:35 ali-desktop KMailApplet[1498]: /usr/bin/KMailApplet : no Maildirs provided
Apr 17 17:41:05 ali-desktop kscreenlocker_greet[142988]: Could not create AF_NETLINK socket (Operation not permitted)
Apr 17 17:41:15 ali-desktop kscreenlocker_greet[142988]: Could not create AF_NETLINK socket (Operation not permitted)
Apr 17 17:41:25 ali-desktop kscreenlocker_greet[142988]: Could not create AF_NETLINK socket (Operation not permitted)
Apr 17 17:41:35 ali-desktop kscreenlocker_greet[142988]: Could not create AF_NETLINK socket (Operation not permitted)
Apr 17 17:41:45 ali-desktop kscreenlocker_greet[142988]: Could not create AF_NETLINK socket (Operation not permitted)
Apr 17 17:41:55 ali-desktop kscreenlocker_greet[142988]: Could not create AF_NETLINK socket (Operation not permitted)
Apr 17 17:42:05 ali-desktop kscreenlocker_greet[142988]: Could not crea
on and on
That is output from April. You need to find the output from when you last had the issue occur.
yeah I'm sorry
today logs are:
Jun 23 04:06:54 ali-desktop nmbd[822]:   Got SIGTERM: going down...
Jun 23 13:29:20 ali-desktop kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Jun 23 13:29:21 ali-desktop kernel: kvm: disabled by bios
Jun 23 13:29:22 ali-desktop kernel: sd 9:0:0:0: [sdc] No Caching mode page found
Jun 23 13:29:22 ali-desktop kernel: sd 9:0:0:0: [sdc] Assuming drive cache: write through
Jun 23 13:29:25 ali-desktop nmbd[827]: [2020/06/23 13:29:25.222406,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 13:29:25 ali-desktop nmbd[827]:   daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Jun 23 13:29:25 ali-desktop smbd[830]: [2020/06/23 13:29:25.348206,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 13:29:25 ali-desktop smbd[830]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Jun 23 13:29:28 ali-desktop sddm-helper[1073]: gkr-pam: unable to locate daemon control file
Jun 23 13:29:30 ali-desktop KMailApplet[1333]: /usr/bin/KMailApplet : no Maildirs provided
Jun 23 13:29:48 ali-desktop nmbd[827]: [2020/06/23 13:29:48.387172,  0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Jun 23 13:29:48 ali-desktop nmbd[827]:   *****
Jun 23 13:29:48 ali-desktop nmbd[827]:   Samba name server ALI-DESKTOP is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.102
Jun 23 15:14:02 ali-desktop nmbd[827]: [2020/06/23 15:14:02.184323,  0] ../../source3/nmbd/nmbd.c:59(terminate)
Jun 23 15:14:02 ali-desktop nmbd[827]:   Got SIGTERM: going down...
Jun 23 15:14:02 ali-desktop systemd-logind[704]: Failed to start session scope session-c2.scope: Transaction for session-c2.scope/start is destructive (systemd-reboot.service has 'start' job queued, but 'stop' is included in transaction).
Jun 23 15:14:02 ali-desktop sddm-helper[70666]: pam_systemd(sddm-greeter:session): Failed to create session: Transaction for session-c2.scope/start is destructive (systemd-reboot.service has 'start' job queued, but 'stop' is included in transaction).
Jun 23 15:14:02 ali-desktop sddm-greeter[70668]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jun 23 15:14:34 ali-desktop kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Jun 23 15:14:35 ali-desktop kernel: kvm: disabled by bios
Jun 23 15:14:37 ali-desktop kernel: sd 9:0:0:0: [sdc] No Caching mode page found
Jun 23 15:14:37 ali-desktop kernel: sd 9:0:0:0: [sdc] Assuming drive cache: write through
Jun 23 15:14:38 ali-desktop nmbd[812]: [2020/06/23 15:14:38.297279,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 15:14:38 ali-desktop nmbd[812]:   daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Jun 23 15:14:38 ali-desktop smbd[814]: [2020/06/23 15:14:38.410822,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 15:14:38 ali-desktop smbd[814]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Jun 23 15:14:41 ali-desktop sddm-helper[1058]: gkr-pam: unable to locate daemon control file
Jun 23 15:14:45 ali-desktop KMailApplet[1646]: /usr/bin/KMailApplet : no Maildirs provided
Jun 23 15:15:01 ali-desktop nmbd[812]: [2020/06/23 15:15:01.457155,  0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Jun 23 15:15:01 ali-desktop nmbd[812]:   *****
Jun 23 15:15:01 ali-desktop nmbd[812]:   Samba name server ALI-DESKTOP is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.102
Jun 23 15:15:14 ali-desktop sudo[2383]: pam_unix(sudo:auth): conversation failed
Jun 23 15:15:14 ali-desktop sudo[2383]: pam_unix(sudo:auth): auth could not identify password for [ali]
Jun 23 16:14:31 ali-desktop kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 5: bea0000000000108
Jun 23 16:14:31 ali-desktop kernel: mce: [Hardware Error]: TSC 0 ADDR 1ffffb68f0bcc MISC d012000100000000 SYND 4d000000 IPID 500b000000000
Jun 23 16:14:31 ali-desktop kernel: mce: [Hardware Error]: PROCESSOR 2:800f11 TIME 1592912667 SOCKET 0 APIC 0 microcode 8001138
Jun 23 16:14:31 ali-desktop kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 22: baa000000000080b
Jun 23 16:14:31 ali-desktop kernel: mce: [Hardware Error]: TSC 0 MISC d012000100000000 SYND 5d000000 IPID 1002e00000002
Jun 23 16:14:31 ali-desktop kernel: sd 9:0:0:0: [sdc] No Caching mode page found
Jun 23 16:14:31 ali-desktop kernel: sd 9:0:0:0: [sdc] Assuming drive cache: write through
Jun 23 16:14:31 ali-desktop kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Jun 23 16:14:31 ali-desktop kernel: kvm: disabled by bios
Jun 23 16:14:32 ali-desktop kernel: kvm: disabled by bios
Jun 23 16:14:34 ali-desktop nmbd[816]: [2020/06/23 16:14:34.870063,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 16:14:34 ali-desktop nmbd[816]:   daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Jun 23 16:14:34 ali-desktop smbd[820]: [2020/06/23 16:14:34.981953,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 16:14:34 ali-desktop smbd[820]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Jun 23 16:14:58 ali-desktop nmbd[816]: [2020/06/23 16:14:58.022561,  0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Jun 23 16:14:58 ali-desktop nmbd[816]:   *****
Jun 23 16:14:58 ali-desktop nmbd[816]:   Samba name server ALI-DESKTOP is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.102
Jun 23 16:16:14 ali-desktop sddm-helper[1069]: gkr-pam: unable to locate daemon control file
Jun 23 16:16:17 ali-desktop KMailApplet[1681]: /usr/bin/KMailApplet : no Maildirs provided
Jun 23 16:22:09 ali-desktop nmbd[816]: [2020/06/23 16:22:09.151721,  0] ../../source3/nmbd/nmbd.c:59(terminate)
Jun 23 16:22:09 ali-desktop nmbd[816]:   Got SIGTERM: going down...
Jun 23 16:22:09 ali-desktop systemd-logind[683]: Failed to start session scope session-c2.scope: Transaction for session-c2.scope/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Jun 23 16:22:09 ali-desktop sddm-helper[7505]: pam_systemd(sddm-greeter:session): Failed to create session: Transaction for session-c2.scope/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
Jun 23 16:22:09 ali-desktop sddm-greeter[7507]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Jun 23 16:22:41 ali-desktop kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
Jun 23 16:22:42 ali-desktop kernel: kvm: disabled by bios
Jun 23 16:22:43 ali-desktop kernel: sd 9:0:0:0: [sdc] No Caching mode page found
Jun 23 16:22:43 ali-desktop kernel: sd 9:0:0:0: [sdc] Assuming drive cache: write through
Jun 23 16:22:46 ali-desktop nmbd[805]: [2020/06/23 16:22:46.003446,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 16:22:46 ali-desktop nmbd[805]:   daemon_ready: daemon 'nmbd' finished starting up and ready to serve connections
Jun 23 16:22:46 ali-desktop smbd[808]: [2020/06/23 16:22:46.124761,  0] ../../lib/util/become_daemon.c:135(daemon_ready)
Jun 23 16:22:46 ali-desktop smbd[808]:   daemon_ready: daemon 'smbd' finished starting up and ready to serve connections
Jun 23 16:22:56 ali-desktop sddm-helper[1053]: gkr-pam: unable to locate daemon control file
Jun 23 16:23:00 ali-desktop KMailApplet[1689]: /usr/bin/KMailApplet : no Maildirs provided
Jun 23 16:23:08 ali-desktop nmbd[805]: [2020/06/23 16:23:08.164706,  0] ../../source3/nmbd/nmbd_become_lmb.c:397(become_local_master_stage2)
Jun 23 16:23:08 ali-desktop nmbd[805]:   *****
Jun 23 16:23:08 ali-desktop nmbd[805]:   Samba name server ALI-DESKTOP is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.102
Combination of KDE Plasma and Gnome, using gnome-keyring for sddm ?
using gnome-keyring for Geary email client.
