RapidMiner shortcut
How can I add Rapidminer's shortcut to favourites or desktop? There is no option when I run its 'sh' on favourites bar. Some other programs allow on right click for "Add to Favourites" option; while they re running but Rapidminer doesnt.. How can i fix that?
Is it this AUR package: https://aur.archlinux.org/packages/rapidminer-studio ?
If so, report the issue to the package maintainer. The PKGBUILD has a .desktop file so it should work.
on building level I have these errors
==> ERROR: Cannot find the strip binary required for object file stripping.
==> ERROR: An unknown error has occurred. Exiting...
==> ERROR: Makepkg was unable to build rapidminer-studio.
So I downloaded and extracted from its own offical page. I use that :confused:
It's telling you specifically which application is missing. To get all software needed for building packages you should install base-devel. https://wiki.archlinux.org/index.php/Arch_User_Repository#Getting_started
If you want to use that version you'll need to create a desktop launcher which can then be used to launch the software and which can be added to your Favourites (etc.).
