Raspberry pi 4 hangs at bootsplash after updating
Hi,
I installed Manjaro Arm for Raspberry Pi 4, the latest, 19.10 I believe. Everything works great. Until I update..
When I update and reboot, my system hangs at ‘Started TLP system startup/shutdown’ and
‘Started hide bootsplash after starting the system’.
I can get into the terminal and use it. Only the whole screen glitches and seeing things is really hard. So far, the only thing that worked is reinstalling de whole OS. But that’s not a long time solution.
Does anyone have the same issue? Or even better, a solution? I tried every google link I found on this subject but no luck.
Thanks in advance!
