Read missed notifications?
I am running Manjaro in a VM to try it out, when I logged in there was a notification in the top right corner but it disappeared before I could read it. How can I view missed notifications?
Manjaro-i3 uses "dunst" for the notifications (not sure about other DE's - possibly the same). If you look at your ~/.config/dunst/dunstrc you will find the "history" keyboard shortcut. Mine is ctrl+Mod4+h - type that shortcut and your history of notifications will appear.
I should have said that I am using Mate. I had a look for the file you specified but it doesn't exist so I guess dunst isn't used.
FWIW
$ inxi -b
  Host: pc Kernel: 4.19.16-1-MANJARO x86_64 bits: 64
  Desktop: MATE 1.20.4 Distro: Manjaro Linux
  Type: Virtualbox System: innotek product: VirtualBox v: 1.2
  serial: <root required>
  Mobo: Oracle model: VirtualBox v: 1.2 serial: <root required>
  BIOS: innotek v: VirtualBox date: 12/01/2006
  Dual Core: Intel Core i3-4000M type: MCP speed: 2394 MHz
  Device-1: InnoTek Systemberatung VirtualBox Graphics Adapter
  driver: vboxvideo v: kernel
  Display: x11 server: X.org 1.20.3 driver: modesetting
  resolution: <xdpyinfo missing>
  OpenGL: renderer: llvmpipe (LLVM 7.0 256 bits) v: 3.3 Mesa 18.3.2
  Device-1: Intel 82540EM Gigabit Ethernet driver: e1000
  Device-2: Intel 82371AB/EB/MB PIIX4 ACPI type: network bridge
  driver: piix4_smbus
  Local Storage: total: 20.13 GiB used: 7.74 GiB (38.5%)
  Processes: 144 Uptime: 38m Memory: 3.85 GiB used: 494.8 MiB (12.5%)
  Shell: bash inxi: 3.0.30
You can't. This is not a feature of MATE.
Huh, well that is inconvenient. But if I can't I can't. I appreciate the assistance!
