read-only file system (Manjaro OpenBox), why?
dear all,
I'm working with an usb external hd (FAT32).
This morning I can't do anything... from creating a new folder, emptying the rubbish bin (where most, or all the files are from the usb hd) etc.
Why?
Yesterday I developed some raw files from this hd using a Windows application (Sigma Photo Pro) via Vine and deleted some using the application, something I don't usually do, could it be that? [I realize mine is a very uneducated guess].
Or is it a sign of a soon to fail hd?
Thanks, have a nice day & stay safe :slight_smile:
It would seem like the filesystem may have been damaged.
You know that a Windows application run through wine does not require a Windows based filesystem?
yes, I can't remember if that hd was already formatted like that when I bought it, or if I used FAT32 as I sometimes plug it to Windows machines.
How do I fix the file system (provided there's a way different from formatting)?
thanks!
You can use fsck on the unmounted device
$ lsblk
Then as root run fsck on the partition
# fsck /dev/sdy1
thanks!
