Read only usb stick
So, I have a USB stick for my old laptop and I need to copy-paste there my EFI script but I can't do it, how can I fix it?
Seems to be an USB Flash Drive which has a livecd flashed on it. So obviously this drive is read-only and therefore permissions can't be changed.
You need to change it on the extracted iso and rebuild it.
Btw why do you want copy paste an "EFI script" there? I am just curious. :upside_down_face:
That is sad... So I have an old PC which has x32 EFI but x64 system and no one Linux distro has it by default so I thought I can just copy-paste it. Maybe you have any idea how do I do it? Can I use Manjaro?
Hey! I guess your old PC has then x86/32bit CPU? Then you need to install the 32bit version. But Manjaro doesn't support 32bit anymore. There only some older releases from April 2019 with xfce desktop: https://osdn.net/projects/manjaro32/storage/xfce/18.0.4/
Could you open a terminal and enter lscpu and post the output here in a codeblock like this?
code
There are a few threads on these monstrosities ..
