Problem
Intermittently no internet on newly installed single boot manjaro. Here's my inxi -Fx
System: Host: strange-potato Kernel: 5.4.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: Xfce 4.14.2
Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: H61M-K v: Rev X.0x serial: 161190399802651 BIOS: American Megatrends v: 0801
date: 07/21/2014
CPU: Topology: Dual Core model: Intel Core i3-2100 bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24754
Speed: 1597 MHz min/max: 1600/3100 MHz Core speeds (MHz): 1: 1597 2: 1596 3: 1596 4: 1601
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0
Display: x11 server: X.Org 1.20.7 driver: intel unloaded: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel Sandybridge Desktop v: 3.3 Mesa 19.3.4 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Sound Server: ALSA v: k5.4.18-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK P8 series driver: r8169 v: kernel
port: e000 bus ID: 03:00.0
IF: enp3s0 state: down mac: 2c:4d:54:4e:7d:1f
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u bus ID: 2-1.5:5
IF: wlp0s29u1u5 state: up mac: c8:3a:35:c8:60:3e
Drives: Local Storage: total: 931.51 GiB used: 135.98 GiB (14.6%)
ID-1: /dev/sda vendor: Western Digital model: WD10EZEX-22MFCA0 size: 931.51 GiB
Partition: ID-1: / size: 72.83 GiB used: 9.19 GiB (12.6%) fs: ext4 dev: /dev/sda11
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C
Info: Processes: 181 Uptime: 31m Memory: 3.72 GiB used: 1.45 GiB (38.9%) Init: systemd Compilers: gcc: 9.2.1 Shell: bash
v: 5.0.16 inxi: 3.0.37
- For the most part, after startup, link light is off.
dmesg
just saysLink is Down
. - If link light is ON and IPV4 is set to
Automatic
thendmesg | grep r81
shows this-
[ 1416.109545] RTL8211E Gigabit Ethernet r8169-300:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
[ 1416.266288] r8169 0000:03:00.0 enp3s0: Link is Down
[ 1786.094803] RTL8211E Gigabit Ethernet r8169-300:00: attached PHY driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-300:00, irq=IGNORE)
[ 1786.265999] r8169 0000:03:00.0 enp3s0: Link is Down
Manual
(manual setting is correctly done, I have used manual previously on Linux Mint) thendmesg | grep r81
shows Link is Down and Link is Up in a loop, as in it connects and disconnects frequently. Forgot to copy the output ofjournalctl -f
at that time. I faced this problem in Linux Mint too. Couldn't solve it either then.
EDIT Here's the snippet ofjournalctl -f
while connection is in loop.
Apr 14 18:22:25 strange-potato kernel: audit: type=1130 audit(1586866945.068:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 14 18:22:25 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Apr 14 18:22:27 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
Apr 14 18:22:28 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Apr 14 18:22:30 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0058] device (enp3s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0074] policy: auto-activating connection 'wired' (a43d0459-5932-45a8-85e1-96d118e7d4d2)
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0088] device (enp3s0): Activation: starting connection 'wired' (a43d0459-5932-45a8-85e1-96d118e7d4d2)
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0091] device (enp3s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0099] manager: NetworkManager state is now CONNECTING
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0112] device (enp3s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0122] device (enp3s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Apr 14 18:22:30 strange-potato avahi-daemon[597]: Joining mDNS multicast group on interface enp3s0.IPv4 with address 192.168.1.26.
Apr 14 18:22:30 strange-potato avahi-daemon[597]: New relevant interface enp3s0.IPv4 for mDNS.
Apr 14 18:22:30 strange-potato avahi-daemon[597]: Registering new address record for 192.168.1.26 on enp3s0.IPv4.
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0147] device (enp3s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0462] device (enp3s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0466] device (enp3s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0474] manager: NetworkManager state is now CONNECTED_LOCAL
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0490] manager: NetworkManager state is now CONNECTED_SITE
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0492] policy: set 'wired' (enp3s0) as default for IPv4 routing and DNS
Apr 14 18:22:30 strange-potato NetworkManager[600]: <info> [1586866950.0717] device (enp3s0): Activation: successful, device activated.
Apr 14 18:22:30 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Apr 14 18:22:32 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
Apr 14 18:22:33 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Apr 14 18:22:34 strange-potato systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Apr 14 18:22:34 strange-potato audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 14 18:22:34 strange-potato kernel: audit: type=1131 audit(1586866954.872:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 14 18:22:35 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
Apr 14 18:22:36 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Apr 14 18:22:37 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
Apr 14 18:22:38 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Apr 14 18:22:40 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
Apr 14 18:22:41 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Down
Apr 14 18:22:42 strange-potato kernel: r8169 0000:03:00.0 enp3s0: Link is Up - 100Mbps/Full - flow control rx/tx
- Sometimes, everything works after boot and internet is available, but after some random time of usage like 30, 50, 2/3hr, connection drops suddenly.
Steps I followed from other forums posts
- Restarting router - did not work
- Unplugging and plugging Ethernet - worked once or twice
- disabled ipv6 in nm-applet.
- deleting the ethernet profile and creating a new one in nm-applet - never worked, this triggered frequent connects and disconnects situation mentioned above
- installed r8168 from
pacman -S r8168
. blacklisted r8169. Butmodprobe r8168
showed -
modprobe: FATAL: Module r8168 not found in directory /lib/modules/5.4.18-1-MANJARO
- Tried to build r8168 from https://aur.archlinux.org/packages/r8168-dkms/, couldn't implement the patches. Error:
Unable to install module r8168/8.048.02 for kernel 5.4.18-1-MANJARO: Missing kernel headers.
- Tried to install network-r8168 from Manjaro Settings Manajer > Hardware Configuration. Error message-
Waiting for user input...
Starting
> Installing network-r8168...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG
Processing classid: 0200
error: target not found: linux54-r8168
core is up to date
extra is up to date
community is up to date
multilib is up to date
Error: pacman failed!
Error: script failed!
Done ...
I am desperate for help now. Thanks in advance.
