my system info
picture from teamviewer
can you help me?
I assume It's a problem with team viewer? You haven't given much information and nobody is going to want to 'download' your system info, it should be in the post.
See here
I solved this by myself
open menu, type manjaro settings manager enter
go to hardware -> hardware configuration
install video-modesetting and remove video-linux using right click
restart and screen will never tear when recording again
It shouldn't make a difference. video-linux detects and applies optimal drivers while modesetting is the default xorg drivers cooked into the kernel, for an AMD or Intel GPU I would expect both settings to result in the same drivers being used. For an Nvidia system you would need non-free drivers for anything more than desktop usage.
Glad you're up and running in any case.
