Oftentimes I can't load the forum, I have a dark (but that might be my colors) page with written something along the lines of "Can't load application" after a bit of loading (not much, but it isn't instant). I don't know if this is a common problem, sorry if it is. The problem lasts for a certain time, trying to force and reload and reload doesn't solve the problem. This problem appears on various connections and both my OSs on my laptop, Manjaro and Windows, on Firefox for both.
Yes I have the same problem
As far as I know, this can happen when something changes on the Discourse backend. Forum software update, settings applied etc.
I'm getting this a couple of times a day but just load a new tab and all is OK.
Just mentioning that the forum relies on javascript. My browser has it disabled by default, so have to enable to use.
Discourse uses both client-side and server-side components. If your network goes down you'll get this message. If the server goes down you'll get this message. If you refresh the page fully you'll get the traditional time-out message from your browser. The simple answer is to try again later.
I'm on the forum almost 12/7 and this has very rarely - if ever - happened to me, so I suspect it's more likely a network issue. Or, of course, your browser...
I know that I have only be a member for 3 days now but have been reading on here for about a week now with java disabled.
To date I never came across that error or errors as of yet and usually login any where from 10 to 15 times a day.
Actually the site loads with in a few seconds. ( lucky me I guess )
I face this issue quite often. In Firefox, when I hit the url archived.forum.manjaro.org
, I get this error. But, when I do ctrl+F5
, the page loads fine.
possibly related thread
@jonathon this is getting worse i get the "can't open app" and the Manjaro forum will not load till i open another book mark then it opens fine for a few hours then the same again.
I still haven't noticed anything.
The total number of requests has risen over the last few months so I'll look into this server-side:
If this is a resource/rate limiting thing I may not have noticed because I'm an admin and Discourse wants to keep my account/session/etc. active.
that graph is starting to resemble manjaro
anyhow, is it a potential DNS resolution issue specific to the affected users as the number of comments about this seems too low for it to be a major issue with the server load handling aspect.
I use quad9 for primary DNS and connectsafe for secondary because my own ISP's DNS servers are about as much use as a chocolate fireguard and if used the browser regularly state pages are inaccessible or such cause partial loading errors.
try disabling e10s. ...not that that's a great long-term solution, but hopefully that'll lead discourse down the right path to fix it if it works for you too.
If this is "fixed" by a clean browser profile (or running in -safe-mode) then it's not a forum issue.
I continue to have this problem when I use Firefox Safe Mode.
When I open the Manjaro forums in a tab, load another site in the same tab, and then return to the Manjaro forums in the same tab (with Alt+Left), I see the error.
Also, when I close and reopen Firefox (which I have configured to save all my open tabs), I see the error on the page containing the Manjaro forums.
Also, when I close the tab containing the Manjaro forums and then select the Undo Close Tab option, I see the error.
Reloading the page always corrects the error.
Edit to add these observations:
I do not have this problem when I type the URL of the Manjaro forums in the Firefox address box myself. Rather, I have to perform one of the actions mentioned above which, apparently, fail to reinitialize the state of the forum page I had been viewing.
I have this problem in Firefox, in both Windows and Linux.
I do not have this problem in Opera or Vivaldi.
I also have this problem on other Discourse forums, not just on the Manjaro forums. For example, it happens on Discourse's own forums.
This problem is being discussed here:
The Discourse co-founder, Sam Saffron, claims the problem lies with Adblock Plus. However, the problem also happens in Firefox Safe Mode, with all add-ons disabled, so Adblock Plus cannot be the sole cause of the problem.
Well, I'm happy I started this post possibly rekindling the interest to the already known problem. I'm still having problems, some days more failing to load the forum than succeding to load it. There is not much more than I can add, other than that the failing occurs on both my OSs, so on different firefoxs, and on different internet connections, at home like at school.
And a clean browser profile?
Starting Firefox with a clean browser profile does indeed correct the problem:
firefox --profile ~/.mozilla/firefox/temp_profile --no-remote
However, without the clean profile, clearing the browser cache and the forum cookies is not enough to correct the problem.
The other question is why only Manjaro no other forum acts this way Void uses discourse no problem their so this site is not closing cleanly for some users or something
The problem doesn't happen on Void:
However, it does happen on Discourse:
