restart and lid-close problem with optimus-manager
Hi all! hope you are doing well.
I am facing this problem since about 3 months hoping it would correct itself with an update(which is not the case at the time of writing this) before creating a thread on this forum.
So I set up my laptop with optimus-manager using this guide.
Sometimes, when I cold boot my laptop, It shows login screen and when I pass it, It just shows a blank screen with a cursor on top left. But sometimes it just works when I restart and shows nVidia icon in the argos gnome extension.
Also, when I close and open the lid, It shows same blank screen with a cursor on top left. But as before, it just works when I restart.
I am attaching Xorg log files when it works and when it doesn't.
I always want to run nvidia dedicated gpu and I have done the setting with optimus-manager.
Please bear with me, I am new here :slight_smile:
Hardware:
Laptop: Asus Vivobook S15 X510UNR
Processor: Intel® Core™ i5-8250U CPU @ 1.60GHz
GPU(optimus): nVidia Geforce MX150
Ram : 8gb ddr4
System info:
Manjaro Linux x86_64 Gnome edition version 20.0(Lysia)
GNOME version : 3.36.1
Kernel: 5.4.34-1-MANJARO
Xorg log when boot is successful:
[    73.953] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[    73.954] _XSERVTransMakeAllCOTSServerListeners: server already running
[    73.957] (--) Log file renamed from "/home/rd/.local/share/xorg/Xorg.pid-1584.log" to "/home/rd/.local/share/xorg/Xorg.1.log"
[    73.958] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    73.958]
X.Org X Server 1.20.8
[    73.958] Build Operating System: Linux Manjaro Linux
[    73.958] Current Operating System: Linux rd-pc 5.4.34-1-MANJARO #1 SMP PREEMPT Tue Apr 21 08:35:40 UTC 2020 x86_64
[    73.958] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=aa8d3c0a-cfc7-4ba9-8fd6-ee5b73759aef rw apparmor=1 security=apparmor resume=UUID=4ebb15d4-ec93-4324-b9bb-67d715964d30 udev.log_priority=3
[    73.958] Build Date: 30 March 2020  06:33:12AM
[    73.958]
[    73.958] Current version of pixman: 0.38.4
[    73.958] 	Before reporting problems, check http://wiki.x.org
[    73.958] Markers: (--) probed, (**) from config file, (==) default setting,
[    73.959] (==) Log file: "/home/rd/.local/share/xorg/Xorg.1.log", Time: Wed Apr 22 23:28:09 2020
[    73.959] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    73.959] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    73.960] (==) ServerLayout "layout"
[    73.960] (**) |-->Screen "nvidia" (0)
[    73.960] (**) |   |-->Monitor "<default monitor>"
[    73.961] (**) |   |-->Device "nvidia"
[    73.961] (**) |   |-->GPUDevice "intel"
[    73.961] (**) |   |-->GPUDevice "Device0"
[    73.961] (==) No monitor specified for screen "nvidia".
[    73.961] (==) Automatically adding devices
[    73.961] (==) Automatically enabling devices
[    73.961] (==) Automatically adding GPU devices
[    73.961] (==) Automatically binding GPU devices
[    73.961] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    73.961] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    73.961] 	Entry deleted from font path.
[    73.961] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    73.961] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    73.961] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    73.961] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    73.961] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    73.961] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[    73.961] (==) ModulePath set to "/usr/lib/xorg/modules"
[    73.961] (**) Extension "COMPOSITE" is enabled
[    73.961] (II) The server relies on udev to provide the list of input devices.
[    73.961] (II) Module ABI versions:
[    73.961] 	X.Org ANSI C Emulation: 0.4
[    73.961] 	X.Org Video Driver: 24.1
[    73.961] 	X.Org XInput driver : 24.1
[    73.961] 	X.Org Server Extension : 10.0
[    73.963] (++) using VT number 2
[    73.968] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[    73.970] (II) xfree86: Adding drm device (/dev/dri/card0)
[    73.972] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[    73.973] (II) xfree86: Adding drm device (/dev/dri/card1)
[    73.975] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[    73.977] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    73.977] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    73.981] (--) PCI:*(0@0:2:0) 8086:5917:1043:163e rev 7, Mem @ 0xed000000/16777216, 0xc0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[    73.981] (--) PCI: (1@0:0:0) 10de:1d10:1043:163e rev 161, Mem @ 0xee000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[    73.982] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    73.982] (II) LoadModule: "glx"
[    73.983] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    73.989] (II) Module glx: vendor="X.Org Foundation"
[    73.989] 	compiled for 1.20.8, module version = 1.0.0
[    73.990] 	ABI class: X.Org Server Extension, version 10.0
[    73.990] (II) LoadModule: "nvidia"
[    73.990] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    73.992] (II) Module nvidia: vendor="NVIDIA Corporation"
[    73.992] 	compiled for 1.6.99.901, module version = 1.0.0
[    73.992] 	Module class: X.Org Video Driver
[    73.992] (II) LoadModule: "modesetting"
[    73.992] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    73.995] (II) Module modesetting: vendor="X.Org Foundation"
[    73.995] 	compiled for 1.20.8, module version = 1.20.8
[    73.995] 	Module class: X.Org Video Driver
[    73.995] 	ABI class: X.Org Video Driver, version 24.1
[    73.995] (II) NVIDIA dlloader X Driver  440.82  Wed Apr  1 19:50:17 UTC 2020
[    73.995] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    73.995] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    73.996] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[    73.996] (II) systemd-logind: releasing fd for 226:1
[    73.999] (II) Loading sub module "fb"
[    73.999] (II) LoadModule: "fb"
[    73.999] (II) Loading /usr/lib/xorg/modules/libfb.so
[    74.000] (II) Module fb: vendor="X.Org Foundation"
[    74.000] 	compiled for 1.20.8, module version = 1.0.0
[    74.000] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    74.000] (II) Loading sub module "wfb"
[    74.000] (II) LoadModule: "wfb"
[    74.001] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    74.001] (II) Module wfb: vendor="X.Org Foundation"
[    74.001] 	compiled for 1.20.8, module version = 1.0.0
[    74.002] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    74.002] (II) Loading sub module "ramdac"
[    74.002] (II) LoadModule: "ramdac"
[    74.002] (II) Module "ramdac" already built-in
[    74.003] (II) modeset(G0): using drv /dev/dri/card0
[    74.003] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    74.003] (II) NVIDIA(0): Creating default Display subsection in Screen section
	"nvidia" for depth/fbbpp 24/32
[    74.003] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    74.003] (==) NVIDIA(0): RGB weight 888
[    74.003] (==) NVIDIA(0): Default visual is TrueColor
[    74.003] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    74.003] (**) Option "AllowNVIDIAGpuScreens"
[    74.003] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[    74.003] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[    74.004] (**) NVIDIA(0): Option "Coolbits" "28"
[    74.004] (**) NVIDIA(0): Enabling 2D acceleration
[    74.004] (II) Loading sub module "glxserver_nvidia"
[    74.004] (II) LoadModule: "glxserver_nvidia"
[    74.004] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[    74.028] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    74.028] 	compiled for 1.6.99.901, module version = 1.0.0
[    74.028] 	Module class: X.Org Server Extension
[    74.028] (II) NVIDIA GLX Module  440.82  Wed Apr  1 19:47:36 UTC 2020
[    74.029] (II) NVIDIA: The X server supports PRIME Render Offload.
[    74.032] (II) NVIDIA(0): NVIDIA GPU GeForce MX150 (GP108-A) at PCI:1:0:0 (GPU-0)
[    74.032] (--) NVIDIA(0): Memory: 2097152 kBytes
[    74.032] (--) NVIDIA(0): VideoBIOS: 86.08.0e.00.55
[    74.032] (II) NVIDIA(0): Detected PCI Express Link width: 4X
[    74.032] (II) NVIDIA(0): Validated MetaModes:
[    74.032] (II) NVIDIA(0):     "NULL"
[    74.032] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[    74.032] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[    74.032] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[    74.032] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    74.032] (==) modeset(G0): RGB weight 888
[    74.032] (==) modeset(G0): Default visual is TrueColor
[    74.033] (II) Loading sub module "glamoregl"
[    74.033] (II) LoadModule: "glamoregl"
[    74.033] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    74.048] (II) Module glamoregl: vendor="X.Org Foundation"
[    74.048] 	compiled for 1.20.8, module version = 1.0.1
[    74.048] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    74.166] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 620 (KBL GT2)
[    74.166] (II) modeset(G0): glamor initialized
[    74.167] (II) modeset(G0): Output eDP-1-1 has no monitor section
[    74.172] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[    74.173] (II) modeset(G0): EDID for output eDP-1-1
[    74.173] (II) modeset(G0): Manufacturer: AUO  Model: 21ed  Serial#: 0
[    74.173] (II) modeset(G0): Year: 2016  Week: 0
[    74.173] (II) modeset(G0): EDID Version: 1.4
[    74.173] (II) modeset(G0): Digital Display Input
[    74.173] (II) modeset(G0): 6 bits per channel
[    74.173] (II) modeset(G0): Digital interface is DisplayPort
[    74.173] (II) modeset(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    74.173] (II) modeset(G0): Gamma: 2.20
[    74.173] (II) modeset(G0): No DPMS capabilities specified
[    74.173] (II) modeset(G0): Supported color encodings: RGB 4:4:4
[    74.173] (II) modeset(G0): First detailed timing is preferred mode
[    74.173] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[    74.173] (II) modeset(G0): redX: 0.580 redY: 0.347   greenX: 0.352 greenY: 0.570
[    74.173] (II) modeset(G0): blueX: 0.159 blueY: 0.131   whiteX: 0.313 whiteY: 0.329
[    74.173] (II) modeset(G0): Manufacturer's mask: 0
[    74.173] (II) modeset(G0): Supported detailed timing:
[    74.173] (II) modeset(G0): clock: 141.0 MHz   Image Size:  344 x 193 mm
[    74.173] (II) modeset(G0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2086 h_border: 0
[    74.173] (II) modeset(G0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1126 v_border: 0
[    74.173] (II) modeset(G0): Unknown vendor-specific block f
[    74.173] (II) modeset(G0):  AUO
[    74.173] (II) modeset(G0):  B156HAN02.1
[    74.173] (II) modeset(G0): EDID (in hex):
[    74.173] (II) modeset(G0): 	00ffffffffffff0006afed2100000000
[    74.173] (II) modeset(G0): 	001a01049522137802b0e594585a9228
[    74.173] (II) modeset(G0): 	21505400000001010101010101010101
[    74.173] (II) modeset(G0): 	010101010101143780a670382e406c30
[    74.173] (II) modeset(G0): 	aa0058c1100000180000000f00000000
[    74.173] (II) modeset(G0): 	00000000000000000020000000fe0041
[    74.173] (II) modeset(G0): 	554f0a202020202020202020000000fe
[    74.173] (II) modeset(G0): 	004231353648414e30322e31200a008e
[    74.174] (II) modeset(G0): Printing probed modes for output eDP-1-1
[    74.174] (II) modeset(G0): Modeline "1920x1080"x60.0  141.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[    74.174] (II) modeset(G0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[    74.174] (II) modeset(G0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[    74.174] (II) modeset(G0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[    74.174] (II) modeset(G0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    74.174] (II) modeset(G0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    74.174] (II) modeset(G0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[    74.174] (II) modeset(G0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[    74.174] (II) modeset(G0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[    74.174] (II) modeset(G0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[    74.174] (II) modeset(G0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    74.174] (II) modeset(G0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    74.174] (II) modeset(G0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[    74.174] (II) modeset(G0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[    74.174] (II) modeset(G0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[    74.174] (II) modeset(G0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[    74.174] (II) modeset(G0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    74.174] (II) modeset(G0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    74.174] (II) modeset(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    74.174] (II) modeset(G0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[    74.174] (II) modeset(G0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    74.174] (II) modeset(G0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[    74.174] (II) modeset(G0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    74.174] (II) modeset(G0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    74.174] (II) modeset(G0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    74.174] (II) modeset(G0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    74.174] (II) modeset(G0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    74.174] (II) modeset(G0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    74.174] (II) modeset(G0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    74.174] (II) modeset(G0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    74.174] (II) modeset(G0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    74.174] (II) modeset(G0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    74.174] (II) modeset(G0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    74.174] (II) modeset(G0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    74.179] (II) modeset(G0): EDID for output HDMI-1-1
[    74.179] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    74.179] (==) modeset(G0): DPI set to (96, 96)
[    74.179] (II) Loading sub module "fb"
[    74.179] (II) LoadModule: "fb"
[    74.180] (II) Loading /usr/lib/xorg/modules/libfb.so
[    74.180] (II) Module fb: vendor="X.Org Foundation"
[    74.180] 	compiled for 1.20.8, module version = 1.0.0
[    74.180] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    74.180] (WW) NVIDIA: Failed to bind sideband socket to
[    74.180] (WW) NVIDIA:     '/var/run/nvidia-xdriver-0b4b3382' Permission denied
[    74.180] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[    74.180] (II) NVIDIA:     access.
[    74.185] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    74.185] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    74.185] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    74.185] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    74.185] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    74.185] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    74.185] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    74.185] (II) NVIDIA(0):     Config Options in the README.
[    74.217] (II) NVIDIA(0): Setting mode "NULL"
[    74.221] (==) NVIDIA(0): Disabling shared memory pixmaps
[    74.221] (==) NVIDIA(0): Backing store enabled
[    74.221] (==) NVIDIA(0): Silken mouse disabled
[    74.221] (==) NVIDIA(0): DPMS enabled
[    74.221] (II) Loading sub module "dri2"
[    74.221] (II) LoadModule: "dri2"
[    74.221] (II) Module "dri2" already built-in
[    74.221] (II) NVIDIA(0): [DRI2] Setup complete
[    74.221] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    74.256] (==) modeset(G0): Backing store enabled
[    74.256] (==) modeset(G0): Silken mouse disabled
[    74.314] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[    74.314] (==) modeset(G0): DPMS enabled
[    74.314] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[    74.314] (II) modeset(G0): [DRI2] Setup complete
[    74.314] (II) modeset(G0): [DRI2]   DRI driver: iris
[    74.314] (II) modeset(G0): [DRI2]   VDPAU driver: va_gl
[    74.314] (II) Initializing extension Generic Event Extension
[    74.314] (II) Initializing extension SHAPE
[    74.314] (II) Initializing extension MIT-SHM
[    74.314] (II) Initializing extension XInputExtension
[    74.314] (II) Initializing extension XTEST
[    74.314] (II) Initializing extension BIG-REQUESTS
[    74.314] (II) Initializing extension SYNC
[    74.314] (II) Initializing extension XKEYBOARD
[    74.314] (II) Initializing extension XC-MISC
[    74.314] (II) Initializing extension SECURITY
[    74.314] (II) Initializing extension XFIXES
[    74.314] (II) Initializing extension RENDER
[    74.314] (II) Initializing extension RANDR
[    74.314] (II) Initializing extension COMPOSITE
[    74.314] (II) Initializing extension DAMAGE
[    74.314] (II) Initializing extension MIT-SCREEN-SAVER
[    74.314] (II) Initializing extension DOUBLE-BUFFER
[    74.314] (II) Initializing extension RECORD
[    74.314] (II) Initializing extension DPMS
[    74.314] (II) Initializing extension Present
[    74.314] (II) Initializing extension DRI3
[    74.314] (II) Initializing extension X-Resource
[    74.314] (II) Initializing extension XVideo
[    74.314] (II) Initializing extension XVideo-MotionCompensation
[    74.314] (II) Initializing extension GLX
[    74.314] (II) Indirect GLX disabled.
[    74.314] (II) GLX: Another vendor is already registered for screen 0
[    74.314] (II) Initializing extension XFree86-VidModeExtension
[    74.315] (II) Initializing extension XFree86-DGA
[    74.315] (II) Initializing extension XFree86-DRI
[    74.315] (II) Initializing extension DRI2
[    74.315] (II) Initializing extension NV-GLX
[    74.315] (II) Initializing extension NV-CONTROL
[    74.587] (II) modeset(G0): Damage tracking initialized
[    74.693] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    74.693] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    74.693] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    74.693] (**) Power Button: Applying InputClass "system-keyboard"
[    74.693] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    74.693] (II) LoadModule: "libinput"
[    74.693] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    74.696] (II) Module libinput: vendor="X.Org Foundation"
[    74.696] 	compiled for 1.20.7, module version = 0.29.0
[    74.696] 	Module class: X.Org XInput Driver
[    74.696] 	ABI class: X.Org XInput driver, version 24.1
[    74.696] (II) Using input driver 'libinput' for 'Power Button'
[    74.697] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 34 paused 0
[    74.697] (**) Power Button: always reports core events
[    74.697] (**) Option "Device" "/dev/input/event3"
[    74.697] (**) Option "_source" "server/udev"
[    74.700] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    74.700] (II) event3  - Power Button: device is a keyboard
[    74.700] (II) event3  - Power Button: device removed
[    74.700] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    74.700] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    74.700] (**) Option "xkb_model" "pc105"
[    74.700] (**) Option "xkb_layout" "us"
[    74.700] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.724] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    74.725] (II) event3  - Power Button: device is a keyboard
[    74.725] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event5)
[    74.725] (**) Asus Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[    74.725] (**) Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[    74.725] (**) Asus Wireless Radio Control: Applying InputClass "system-keyboard"
[    74.725] (**) Asus Wireless Radio Control: Applying InputClass "Keyboard Defaults"
[    74.725] (II) Using input driver 'libinput' for 'Asus Wireless Radio Control'
[    74.726] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 37 paused 0
[    74.726] (**) Asus Wireless Radio Control: always reports core events
[    74.726] (**) Option "Device" "/dev/input/event5"
[    74.726] (**) Option "_source" "server/udev"
[    74.727] (II) event5  - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[    74.727] (II) event5  - Asus Wireless Radio Control: device is a keyboard
[    74.727] (II) event5  - Asus Wireless Radio Control: device removed
[    74.727] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input5/event5"
[    74.727] (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 7)
[    74.727] (**) Option "xkb_model" "pc105"
[    74.727] (**) Option "xkb_layout" "us"
[    74.727] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.729] (II) event5  - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[    74.729] (II) event5  - Asus Wireless Radio Control: device is a keyboard
[    74.729] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[    74.729] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    74.729] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    74.729] (**) Video Bus: Applying InputClass "system-keyboard"
[    74.729] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    74.729] (II) Using input driver 'libinput' for 'Video Bus'
[    74.730] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 38 paused 0
[    74.730] (**) Video Bus: always reports core events
[    74.730] (**) Option "Device" "/dev/input/event10"
[    74.730] (**) Option "_source" "server/udev"
[    74.731] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    74.731] (II) event10 - Video Bus: device is a keyboard
[    74.732] (II) event10 - Video Bus: device removed
[    74.732] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12/event10"
[    74.732] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    74.732] (**) Option "xkb_model" "pc105"
[    74.732] (**) Option "xkb_layout" "us"
[    74.732] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.733] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[    74.733] (II) event10 - Video Bus: device is a keyboard
[    74.734] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    74.734] (II) No input driver specified, ignoring this device.
[    74.734] (II) This device may have been added with another device file.
[    74.734] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[    74.734] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    74.734] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    74.734] (**) Video Bus: Applying InputClass "system-keyboard"
[    74.734] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    74.734] (II) Using input driver 'libinput' for 'Video Bus'
[    74.735] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 39 paused 0
[    74.735] (**) Video Bus: always reports core events
[    74.735] (**) Option "Device" "/dev/input/event11"
[    74.735] (**) Option "_source" "server/udev"
[    74.737] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[    74.737] (II) event11 - Video Bus: device is a keyboard
[    74.737] (II) event11 - Video Bus: device removed
[    74.737] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:24/LNXVIDEO:01/input/input13/event11"
[    74.737] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 9)
[    74.737] (**) Option "xkb_model" "pc105"
[    74.737] (**) Option "xkb_layout" "us"
[    74.737] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.738] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[    74.738] (II) event11 - Video Bus: device is a keyboard
[    74.739] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    74.739] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    74.739] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    74.739] (**) Power Button: Applying InputClass "system-keyboard"
[    74.739] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    74.739] (II) Using input driver 'libinput' for 'Power Button'
[    74.740] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 40 paused 0
[    74.740] (**) Power Button: always reports core events
[    74.740] (**) Option "Device" "/dev/input/event2"
[    74.740] (**) Option "_source" "server/udev"
[    74.741] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    74.741] (II) event2  - Power Button: device is a keyboard
[    74.741] (II) event2  - Power Button: device removed
[    74.741] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[    74.741] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 10)
[    74.741] (**) Option "xkb_model" "pc105"
[    74.741] (**) Option "xkb_layout" "us"
[    74.741] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.742] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    74.742] (II) event2  - Power Button: device is a keyboard
[    74.743] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    74.743] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    74.743] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    74.743] (**) Sleep Button: Applying InputClass "system-keyboard"
[    74.743] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    74.743] (II) Using input driver 'libinput' for 'Sleep Button'
[    74.744] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 41 paused 0
[    74.744] (**) Sleep Button: always reports core events
[    74.744] (**) Option "Device" "/dev/input/event1"
[    74.744] (**) Option "_source" "server/udev"
[    74.745] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    74.745] (II) event1  - Sleep Button: device is a keyboard
[    74.745] (II) event1  - Sleep Button: device removed
[    74.745] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    74.745] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 11)
[    74.745] (**) Option "xkb_model" "pc105"
[    74.745] (**) Option "xkb_layout" "us"
[    74.745] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.746] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    74.746] (II) event1  - Sleep Button: device is a keyboard
[    74.747] (II) config/udev: Adding input device USB2.0 VGA UVC WebCam: USB2.0 V (/dev/input/event19)
[    74.747] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "evdev keyboard catchall"
[    74.747] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "libinput keyboard catchall"
[    74.747] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "system-keyboard"
[    74.748] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "Keyboard Defaults"
[    74.748] (II) Using input driver 'libinput' for 'USB2.0 VGA UVC WebCam: USB2.0 V'
[    74.748] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 42 paused 0
[    74.748] (**) USB2.0 VGA UVC WebCam: USB2.0 V: always reports core events
[    74.748] (**) Option "Device" "/dev/input/event19"
[    74.748] (**) Option "_source" "server/udev"
[    74.750] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: is tagged by udev as: Keyboard
[    74.750] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: device is a keyboard
[    74.750] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: device removed
[    74.750] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input21/event19"
[    74.750] (II) XINPUT: Adding extended input device "USB2.0 VGA UVC WebCam: USB2.0 V" (type: KEYBOARD, id 12)
[    74.750] (**) Option "xkb_model" "pc105"
[    74.750] (**) Option "xkb_layout" "us"
[    74.750] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.752] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: is tagged by udev as: Keyboard
[    74.752] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: device is a keyboard
[    74.752] (II) config/udev: Adding input device ELAN1300:00 04F3:3057 Mouse (/dev/input/event8)
[    74.753] (**) ELAN1300:00 04F3:3057 Mouse: Applying InputClass "evdev pointer catchall"
[    74.753] (**) ELAN1300:00 04F3:3057 Mouse: Applying InputClass "libinput pointer catchall"
[    74.753] (II) Using input driver 'libinput' for 'ELAN1300:00 04F3:3057 Mouse'
[    74.753] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 43 paused 0
[    74.753] (**) ELAN1300:00 04F3:3057 Mouse: always reports core events
[    74.753] (**) Option "Device" "/dev/input/event8"
[    74.753] (**) Option "_source" "server/udev"
[    74.755] (II) event8  - ELAN1300:00 04F3:3057 Mouse: is tagged by udev as: Mouse
[    74.755] (II) event8  - ELAN1300:00 04F3:3057 Mouse: device is a pointer
[    74.756] (II) event8  - ELAN1300:00 04F3:3057 Mouse: device removed
[    74.756] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ELAN1300:00/0018:04F3:3057.0001/input/input10/event8"
[    74.756] (II) XINPUT: Adding extended input device "ELAN1300:00 04F3:3057 Mouse" (type: MOUSE, id 13)
[    74.756] (**) Option "AccelerationScheme" "none"
[    74.756] (**) ELAN1300:00 04F3:3057 Mouse: (accel) selected scheme none/0
[    74.756] (**) ELAN1300:00 04F3:3057 Mouse: (accel) acceleration factor: 2.000
[    74.756] (**) ELAN1300:00 04F3:3057 Mouse: (accel) acceleration threshold: 4
[    74.757] (II) event8  - ELAN1300:00 04F3:3057 Mouse: is tagged by udev as: Mouse
[    74.757] (II) event8  - ELAN1300:00 04F3:3057 Mouse: device is a pointer
[    74.758] (II) config/udev: Adding input device ELAN1300:00 04F3:3057 Mouse (/dev/input/mouse0)
[    74.758] (II) No input driver specified, ignoring this device.
[    74.758] (II) This device may have been added with another device file.
[    74.759] (II) config/udev: Adding input device ELAN1300:00 04F3:3057 Touchpad (/dev/input/event9)
[    74.759] (**) ELAN1300:00 04F3:3057 Touchpad: Applying InputClass "evdev touchpad catchall"
[    74.759] (**) ELAN1300:00 04F3:3057 Touchpad: Applying InputClass "libinput touchpad catchall"
[    74.759] (II) Using input driver 'libinput' for 'ELAN1300:00 04F3:3057 Touchpad'
[    74.760] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 44 paused 0
[    74.760] (**) ELAN1300:00 04F3:3057 Touchpad: always reports core events
[    74.760] (**) Option "Device" "/dev/input/event9"
[    74.760] (**) Option "_source" "server/udev"
[    74.761] (II) event9  - ELAN1300:00 04F3:3057 Touchpad: is tagged by udev as: Touchpad
[    74.763] (II) event9  - ELAN1300:00 04F3:3057 Touchpad: device is a touchpad
[    74.763] (II) event9  - ELAN1300:00 04F3:3057 Touchpad: device removed
[    74.763] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ELAN1300:00/0018:04F3:3057.0001/input/input11/event9"
[    74.763] (II) XINPUT: Adding extended input device "ELAN1300:00 04F3:3057 Touchpad" (type: TOUCHPAD, id 14)
[    74.765] (**) Option "AccelerationScheme" "none"
[    74.765] (**) ELAN1300:00 04F3:3057 Touchpad: (accel) selected scheme none/0
[    74.765] (**) ELAN1300:00 04F3:3057 Touchpad: (accel) acceleration factor: 2.000
[    74.765] (**) ELAN1300:00 04F3:3057 Touchpad: (accel) acceleration threshold: 4
[    74.766] (II) event9  - ELAN1300:00 04F3:3057 Touchpad: is tagged by udev as: Touchpad
[    74.768] (II) event9  - ELAN1300:00 04F3:3057 Touchpad: device is a touchpad
[    74.769] (II) config/udev: Adding input device ELAN1300:00 04F3:3057 Touchpad (/dev/input/mouse1)
[    74.769] (II) No input driver specified, ignoring this device.
[    74.769] (II) This device may have been added with another device file.
[    74.769] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event12)
[    74.770] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event13)
[    74.770] (II) No input driver specified, ignoring this device.
[    74.770] (II) This device may have been added with another device file.
[    74.770] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event14)
[    74.771] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event15)
[    74.771] (II) No input driver specified, ignoring this device.
[    74.771] (II) This device may have been added with another device file.
[    74.771] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event16)
[    74.771] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event17)
[    74.772] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event18)
[    74.772] (II) No input driver specified, ignoring this device.
[    74.772] (II) This device may have been added with another device file.
[    74.772] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event7)
[    74.772] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    74.772] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    74.772] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[    74.772] (**) Asus WMI hotkeys: Applying InputClass "Keyboard Defaults"
[    74.772] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[    74.773] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 45 paused 0
[    74.773] (**) Asus WMI hotkeys: always reports core events
[    74.773] (**) Option "Device" "/dev/input/event7"
[    74.773] (**) Option "_source" "server/udev"
[    74.774] (II) event7  - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    74.774] (II) event7  - Asus WMI hotkeys: device is a keyboard
[    74.774] (II) event7  - Asus WMI hotkeys: device removed
[    74.774] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input9/event7"
[    74.774] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 15)
[    74.774] (**) Option "xkb_model" "pc105"
[    74.774] (**) Option "xkb_layout" "us"
[    74.774] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.775] (II) event7  - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    74.775] (II) event7  - Asus WMI hotkeys: device is a keyboard
[    74.776] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    74.776] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    74.776] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    74.776] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    74.776] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[    74.776] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    74.777] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 46 paused 0
[    74.777] (**) AT Translated Set 2 keyboard: always reports core events
[    74.777] (**) Option "Device" "/dev/input/event4"
[    74.777] (**) Option "_source" "server/udev"
[    74.778] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    74.778] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    74.779] (II) event4  - AT Translated Set 2 keyboard: device removed
[    74.779] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    74.779] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[    74.779] (**) Option "xkb_model" "pc105"
[    74.779] (**) Option "xkb_layout" "us"
[    74.779] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    74.781] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    74.781] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    74.782] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[    74.782] (II) No input driver specified, ignoring this device.
[    74.782] (II) This device may have been added with another device file.
Xorg log when boot is not successful:
[    28.052] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[    28.052] _XSERVTransMakeAllCOTSServerListeners: server already running
[    28.058] (--) Log file renamed from "/home/rd/.local/share/xorg/Xorg.pid-1568.log" to "/home/rd/.local/share/xorg/Xorg.1.log"
[    28.059] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[    28.060]
[    28.060] Build Operating System: Linux Manjaro Linux
[    28.060] Current Operating System: Linux rd-pc 5.4.34-1-MANJARO #1 SMP PREEMPT Tue Apr 21 08:35:40 UTC 2020 x86_64
[    28.060] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=aa8d3c0a-cfc7-4ba9-8fd6-ee5b73759aef rw apparmor=1 security=apparmor resume=UUID=4ebb15d4-ec93-4324-b9bb-67d715964d30 udev.log_priority=3
[    28.060] Build Date: 30 March 2020  06:33:12AM
[    28.060]
[    28.060] Current version of pixman: 0.38.4
[    28.060] 	Before reporting problems, check http://wiki.x.org
[    28.060] Markers: (--) probed, (**) from config file, (==) default setting,
[    28.061] (==) Log file: "/home/rd/.local/share/xorg/Xorg.1.log", Time: Wed Apr 22 22:09:32 2020
[    28.061] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    28.061] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    28.063] (==) ServerLayout "layout"
[    28.063] (**) |-->Screen "nvidia" (0)
[    28.063] (**) |   |-->Monitor "<default monitor>"
[    28.065] (**) |   |-->Device "nvidia"
[    28.065] (**) |   |-->GPUDevice "intel"
[    28.065] (**) |   |-->GPUDevice "Device0"
[    28.065] (==) No monitor specified for screen "nvidia".
[    28.065] (==) Automatically adding devices
[    28.065] (==) Automatically enabling devices
[    28.065] (==) Automatically adding GPU devices
[    28.065] (==) Automatically binding GPU devices
[    28.065] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    28.065] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    28.065] 	Entry deleted from font path.
[    28.065] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    28.065] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    28.065] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    28.065] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    28.066] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    28.066] (==) FontPath set to:
[    28.066] (==) ModulePath set to "/usr/lib/xorg/modules"
[    28.066] (**) Extension "COMPOSITE" is enabled
[    28.066] (II) The server relies on udev to provide the list of input devices.
[    28.066] (II) Module ABI versions:
[    28.066] 	X.Org ANSI C Emulation: 0.4
[    28.066] 	X.Org Video Driver: 24.1
[    28.066] 	X.Org XInput driver : 24.1
[    28.066] 	X.Org Server Extension : 10.0
[    28.068] (++) using VT number 2
[    28.079] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_32
[    28.081] (II) xfree86: Adding drm device (/dev/dri/card0)
[    28.083] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[    28.083] (II) xfree86: Adding drm device (/dev/dri/card1)
[    28.085] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[    28.088] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    28.088] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[    28.091] (--) PCI:*(0@0:2:0) 8086:5917:1043:163e rev 7, Mem @ 0xed000000/16777216, 0xc0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[    28.092] (--) PCI: (1@0:0:0) 10de:1d10:1043:163e rev 161, Mem @ 0xee000000/16777216, 0xd0000000/268435456, 0xe0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[    28.092] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    28.092] (II) LoadModule: "glx"
[    28.093] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    28.099] (II) Module glx: vendor="X.Org Foundation"
[    28.099] 	compiled for 1.20.8, module version = 1.0.0
[    28.099] 	ABI class: X.Org Server Extension, version 10.0
[    28.099] (II) LoadModule: "nvidia"
[    28.099] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    28.100] (II) Module nvidia: vendor="NVIDIA Corporation"
[    28.101] 	compiled for 1.6.99.901, module version = 1.0.0
[    28.101] 	Module class: X.Org Video Driver
[    28.101] (II) LoadModule: "modesetting"
[    28.101] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[    28.103] (II) Module modesetting: vendor="X.Org Foundation"
[    28.104] 	compiled for 1.20.8, module version = 1.20.8
[    28.104] 	Module class: X.Org Video Driver
[    28.104] 	ABI class: X.Org Video Driver, version 24.1
[    28.104] (II) NVIDIA dlloader X Driver  440.82  Wed Apr  1 19:50:17 UTC 2020
[    28.104] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    28.104] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[    28.104] xf86EnableIOPorts: failed to set IOPL for I/O (Operation not permitted)
[    28.104] (II) systemd-logind: releasing fd for 226:1
[    28.106] (II) Loading sub module "fb"
[    28.106] (II) LoadModule: "fb"
[    28.106] (II) Loading /usr/lib/xorg/modules/libfb.so
[    28.107] (II) Module fb: vendor="X.Org Foundation"
[    28.107] 	compiled for 1.20.8, module version = 1.0.0
[    28.107] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    28.107] (II) Loading sub module "wfb"
[    28.107] (II) LoadModule: "wfb"
[    28.107] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    28.108] (II) Module wfb: vendor="X.Org Foundation"
[    28.108] 	compiled for 1.20.8, module version = 1.0.0
[    28.108] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    28.108] (II) Loading sub module "ramdac"
[    28.108] (II) LoadModule: "ramdac"
[    28.108] (II) Module "ramdac" already built-in
[    28.110] (II) modeset(G0): using drv /dev/dri/card0
[    28.110] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    28.110] (II) NVIDIA(0): Creating default Display subsection in Screen section
[    28.110] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[    28.110] (==) NVIDIA(0): RGB weight 888
[    28.111] (==) NVIDIA(0): Default visual is TrueColor
[    28.111] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[    28.111] (**) Option "AllowNVIDIAGpuScreens"
[    28.111] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[    28.111] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[    28.111] (**) NVIDIA(0): Option "Coolbits" "28"
[    28.111] (**) NVIDIA(0): Enabling 2D acceleration
[    28.111] (II) Loading sub module "glxserver_nvidia"
[    28.111] (II) LoadModule: "glxserver_nvidia"
[    28.112] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[    28.134] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[    28.134] 	compiled for 1.6.99.901, module version = 1.0.0
[    28.134] 	Module class: X.Org Server Extension
[    28.134] (II) NVIDIA GLX Module  440.82  Wed Apr  1 19:47:36 UTC 2020
[    28.134] (II) NVIDIA: The X server supports PRIME Render Offload.
[    28.137] (II) NVIDIA(0): NVIDIA GPU GeForce MX150 (GP108-A) at PCI:1:0:0 (GPU-0)
[    28.137] (--) NVIDIA(0): Memory: 2097152 kBytes
[    28.137] (--) NVIDIA(0): VideoBIOS: 86.08.0e.00.55
[    28.137] (II) NVIDIA(0): Detected PCI Express Link width: 4X
[    28.137] (II) NVIDIA(0): Validated MetaModes:
[    28.137] (II) NVIDIA(0):     "NULL"
[    28.137] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[    28.137] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[    28.137] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[    28.138] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[    28.138] (==) modeset(G0): RGB weight 888
[    28.138] (==) modeset(G0): Default visual is TrueColor
[    28.138] (II) Loading sub module "glamoregl"
[    28.138] (II) LoadModule: "glamoregl"
[    28.138] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[    28.151] (II) Module glamoregl: vendor="X.Org Foundation"
[    28.151] 	compiled for 1.20.8, module version = 1.0.1
[    28.151] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    28.290] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 620 (KBL GT2)
[    28.290] (II) modeset(G0): glamor initialized
[    28.291] (II) modeset(G0): Output eDP-1-1 has no monitor section
[    28.295] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[    28.296] (II) modeset(G0): EDID for output eDP-1-1
[    28.296] (II) modeset(G0): Manufacturer: AUO  Model: 21ed  Serial#: 0
[    28.296] (II) modeset(G0): Year: 2016  Week: 0
[    28.296] (II) modeset(G0): EDID Version: 1.4
[    28.296] (II) modeset(G0): Digital Display Input
[    28.296] (II) modeset(G0): 6 bits per channel
[    28.296] (II) modeset(G0): Digital interface is DisplayPort
[    28.296] (II) modeset(G0): Max Image Size [cm]: horiz.: 34  vert.: 19
[    28.296] (II) modeset(G0): Gamma: 2.20
[    28.296] (II) modeset(G0): No DPMS capabilities specified
[    28.296] (II) modeset(G0): Supported color encodings: RGB 4:4:4
[    28.296] (II) modeset(G0): First detailed timing is preferred mode
[    28.296] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[    28.296] (II) modeset(G0): redX: 0.580 redY: 0.347   greenX: 0.352 greenY: 0.570
[    28.296] (II) modeset(G0): blueX: 0.159 blueY: 0.131   whiteX: 0.313 whiteY: 0.329
[    28.296] (II) modeset(G0): Manufacturer's mask: 0
[    28.296] (II) modeset(G0): Supported detailed timing:
[    28.296] (II) modeset(G0): clock: 141.0 MHz   Image Size:  344 x 193 mm
[    28.296] (II) modeset(G0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2086 h_border: 0
[    28.296] (II) modeset(G0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1126 v_border: 0
[    28.296] (II) modeset(G0): Unknown vendor-specific block f
[    28.296] (II) modeset(G0):  AUO
[    28.296] (II) modeset(G0):  B156HAN02.1
[    28.296] (II) modeset(G0): EDID (in hex):
[    28.297] (II) modeset(G0): 	00ffffffffffff0006afed2100000000
[    28.297] (II) modeset(G0): 	001a01049522137802b0e594585a9228
[    28.297] (II) modeset(G0): 	21505400000001010101010101010101
[    28.297] (II) modeset(G0): 	010101010101143780a670382e406c30
[    28.297] (II) modeset(G0): 	aa0058c1100000180000000f00000000
[    28.297] (II) modeset(G0): 	00000000000000000020000000fe0041
[    28.297] (II) modeset(G0): 	554f0a202020202020202020000000fe
[    28.297] (II) modeset(G0): 	004231353648414e30322e31200a008e
[    28.297] (II) modeset(G0): Printing probed modes for output eDP-1-1
[    28.297] (II) modeset(G0): Modeline "1920x1080"x60.0  141.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[    28.297] (II) modeset(G0): Modeline "1920x1080"x120.0  356.38  1920 2080 2288 2656  1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[    28.297] (II) modeset(G0): Modeline "1920x1080"x119.9  266.50  1920 1944 1960 2000  1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[    28.297] (II) modeset(G0): Modeline "1920x1080"x60.0  173.00  1920 2048 2248 2576  1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[    28.297] (II) modeset(G0): Modeline "1920x1080"x59.9  138.50  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[    28.297] (II) modeset(G0): Modeline "1680x1050"x60.0  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[    28.297] (II) modeset(G0): Modeline "1400x1050"x60.0  122.00  1400 1488 1640 1880  1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[    28.297] (II) modeset(G0): Modeline "1600x900"x120.0  246.00  1600 1728 1900 2200  900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[    28.297] (II) modeset(G0): Modeline "1600x900"x119.9  186.50  1600 1624 1640 1680  900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "1600x900"x59.9  118.25  1600 1696 1856 2112  900 903 908 934 -hsync +vsync (56.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "1600x900"x59.8   97.50  1600 1648 1680 1760  900 903 908 926 +hsync -vsync (55.4 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "1400x900"x60.0  103.50  1400 1480 1624 1848  900 903 913 934 -hsync +vsync (56.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "1400x900"x59.9   86.50  1400 1448 1480 1560  900 903 913 926 +hsync -vsync (55.4 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "1440x810"x120.0  198.12  1440 1548 1704 1968  810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[    28.297] (II) modeset(G0): Modeline "1440x810"x119.9  151.88  1440 1464 1480 1520  810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[    28.297] (II) modeset(G0): Modeline "1368x768"x59.9   85.25  1368 1440 1576 1784  768 771 781 798 -hsync +vsync (47.8 kHz d)
[    28.297] (II) modeset(G0): Modeline "1368x768"x59.9   72.25  1368 1416 1448 1528  768 771 781 790 +hsync -vsync (47.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x800"x120.0  174.25  1280 1380 1516 1752  800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x800"x119.9  134.25  1280 1304 1320 1360  800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x800"x59.8   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x800"x59.9   71.00  1280 1328 1360 1440  800 803 809 823 +hsync -vsync (49.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x720"x120.0  156.12  1280 1376 1512 1744  720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x720"x120.0  120.75  1280 1304 1320 1360  720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x720"x59.9   74.50  1280 1344 1472 1664  720 723 728 748 -hsync +vsync (44.8 kHz d)
[    28.297] (II) modeset(G0): Modeline "1280x720"x59.7   63.75  1280 1328 1360 1440  720 723 728 741 +hsync -vsync (44.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "1024x768"x120.1  133.47  1024 1100 1212 1400  768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz d)
[    28.297] (II) modeset(G0): Modeline "960x720"x120.0  117.00  960 1024 1128 1300  720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "928x696"x120.1  109.15  928 976 1088 1264  696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[    28.297] (II) modeset(G0): Modeline "896x672"x120.0  102.40  896 960 1060 1224  672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[    28.297] (II) modeset(G0): Modeline "1024x576"x119.9   98.50  1024 1092 1200 1376  576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[    28.297] (II) modeset(G0): Modeline "1024x576"x119.9   78.38  1024 1048 1064 1104  576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "1024x576"x59.9   46.50  1024 1064 1160 1296  576 579 584 599 -hsync +vsync (35.9 kHz d)
[    28.297] (II) modeset(G0): Modeline "1024x576"x59.8   42.00  1024 1072 1104 1184  576 579 584 593 +hsync -vsync (35.5 kHz d)
[    28.297] (II) modeset(G0): Modeline "960x600"x119.9   96.62  960 1028 1128 1296  600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[    28.297] (II) modeset(G0): Modeline "960x600"x120.0   77.00  960 984 1000 1040  600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "960x540"x119.9   86.50  960 1024 1124 1288  540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[    28.297] (II) modeset(G0): Modeline "960x540"x120.0   69.25  960 984 1000 1040  540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[    28.297] (II) modeset(G0): Modeline "960x540"x59.6   40.75  960 992 1088 1216  540 543 548 562 -hsync +vsync (33.5 kHz d)
[    28.297] (II) modeset(G0): Modeline "960x540"x59.8   37.25  960 1008 1040 1120  540 543 548 556 +hsync -vsync (33.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "800x600"x120.0   81.00  800 832 928 1080  600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz d)
[    28.297] (II) modeset(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz d)
[    28.297] (II) modeset(G0): Modeline "840x525"x120.0   73.12  840 892 980 1120  525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "840x525"x119.8   59.50  840 864 880 920  525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[    28.297] (II) modeset(G0): Modeline "864x486"x59.9   32.50  864 888 968 1072  486 489 494 506 -hsync +vsync (30.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "864x486"x59.6   30.50  864 912 944 1024  486 489 494 500 +hsync -vsync (29.8 kHz d)
[    28.297] (II) modeset(G0): Modeline "700x525"x120.0   61.00  700 744 820 940  525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[    28.297] (II) modeset(G0): Modeline "800x450"x119.9   59.12  800 848 928 1056  450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "800x450"x119.6   48.75  800 824 840 880  450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x512"x120.0   54.00  640 664 720 844  512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "700x450"x119.9   51.75  700 740 812 924  450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "700x450"x119.8   43.25  700 724 740 780  450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x480"x120.0   54.00  640 688 744 900  480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz d)
[    28.297] (II) modeset(G0): Modeline "720x405"x59.5   22.50  720 744 808 896  405 408 413 422 -hsync +vsync (25.1 kHz d)
[    28.297] (II) modeset(G0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    28.297] (II) modeset(G0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    28.297] (II) modeset(G0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    28.297] (II) modeset(G0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    28.297] (II) modeset(G0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    28.297] (II) modeset(G0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    28.298] (II) modeset(G0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    28.298] (II) modeset(G0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    28.298] (II) modeset(G0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    28.298] (II) modeset(G0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    28.298] (II) modeset(G0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    28.298] (II) modeset(G0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    28.298] (II) modeset(G0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    28.298] (II) modeset(G0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    28.298] (II) modeset(G0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    28.298] (II) modeset(G0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    28.298] (II) modeset(G0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    28.298] (II) modeset(G0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    28.303] (II) modeset(G0): EDID for output HDMI-1-1
[    28.303] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[    28.303] (==) modeset(G0): DPI set to (96, 96)
[    28.303] (II) Loading sub module "fb"
[    28.303] (II) LoadModule: "fb"
[    28.303] (II) Loading /usr/lib/xorg/modules/libfb.so
[    28.303] (II) Module fb: vendor="X.Org Foundation"
[    28.303] 	compiled for 1.20.8, module version = 1.0.0
[    28.303] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    28.303] (WW) NVIDIA: Failed to bind sideband socket to
[    28.303] (WW) NVIDIA:     '/var/run/nvidia-xdriver-6ac94fa7' Permission denied
[    28.303] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[    28.303] (II) NVIDIA:     access.
[    28.308] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    28.308] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    28.308] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    28.308] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    28.308] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    28.308] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    28.308] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    28.308] (II) NVIDIA(0):     Config Options in the README.
[    28.342] (II) NVIDIA(0): Setting mode "NULL"
[    28.346] (==) NVIDIA(0): Disabling shared memory pixmaps
[    28.346] (==) NVIDIA(0): Backing store enabled
[    28.346] (==) NVIDIA(0): Silken mouse disabled
[    28.346] (==) NVIDIA(0): DPMS enabled
[    28.346] (II) Loading sub module "dri2"
[    28.346] (II) LoadModule: "dri2"
[    28.346] (II) Module "dri2" already built-in
[    28.346] (II) NVIDIA(0): [DRI2] Setup complete
[    28.346] (II) NVIDIA(0): [DRI2]   VDPAU driver: nvidia
[    28.380] (==) modeset(G0): Backing store enabled
[    28.380] (==) modeset(G0): Silken mouse disabled
[    28.441] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[    28.441] (==) modeset(G0): DPMS enabled
[    28.441] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[    28.441] (II) modeset(G0): [DRI2] Setup complete
[    28.441] (II) modeset(G0): [DRI2]   DRI driver: iris
[    28.441] (II) modeset(G0): [DRI2]   VDPAU driver: va_gl
[    28.441] (II) Initializing extension Generic Event Extension
[    28.441] (II) Initializing extension SHAPE
[    28.441] (II) Initializing extension MIT-SHM
[    28.441] (II) Initializing extension XInputExtension
[    28.441] (II) Initializing extension XTEST
[    28.441] (II) Initializing extension BIG-REQUESTS
[    28.441] (II) Initializing extension SYNC
[    28.441] (II) Initializing extension XKEYBOARD
[    28.441] (II) Initializing extension XC-MISC
[    28.441] (II) Initializing extension SECURITY
[    28.441] (II) Initializing extension XFIXES
[    28.441] (II) Initializing extension RENDER
[    28.441] (II) Initializing extension RANDR
[    28.441] (II) Initializing extension COMPOSITE
[    28.441] (II) Initializing extension DAMAGE
[    28.441] (II) Initializing extension MIT-SCREEN-SAVER
[    28.441] (II) Initializing extension DOUBLE-BUFFER
[    28.441] (II) Initializing extension RECORD
[    28.441] (II) Initializing extension DPMS
[    28.441] (II) Initializing extension Present
[    28.441] (II) Initializing extension DRI3
[    28.441] (II) Initializing extension X-Resource
[    28.441] (II) Initializing extension XVideo
[    28.441] (II) Initializing extension XVideo-MotionCompensation
[    28.441] (II) Initializing extension GLX
[    28.441] (II) Indirect GLX disabled.
[    28.441] (II) GLX: Another vendor is already registered for screen 0
[    28.441] (II) Initializing extension XFree86-VidModeExtension
[    28.441] (II) Initializing extension XFree86-DGA
[    28.441] (II) Initializing extension XFree86-DRI
[    28.441] (II) Initializing extension DRI2
[    28.441] (II) Initializing extension NV-GLX
[    28.442] (II) Initializing extension NV-CONTROL
[    28.713] (II) modeset(G0): Damage tracking initialized
[    28.808] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[    28.808] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    28.808] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    28.808] (**) Power Button: Applying InputClass "system-keyboard"
[    28.808] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    28.808] (II) LoadModule: "libinput"
[    28.808] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    28.812] (II) Module libinput: vendor="X.Org Foundation"
[    28.812] 	compiled for 1.20.7, module version = 0.29.0
[    28.812] 	Module class: X.Org XInput Driver
[    28.812] 	ABI class: X.Org XInput driver, version 24.1
[    28.812] (II) Using input driver 'libinput' for 'Power Button'
[    28.814] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 34 paused 0
[    28.814] (**) Power Button: always reports core events
[    28.814] (**) Option "Device" "/dev/input/event3"
[    28.814] (**) Option "_source" "server/udev"
[    28.817] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    28.817] (II) event3  - Power Button: device is a keyboard
[    28.818] (II) event3  - Power Button: device removed
[    28.818] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[    28.818] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[    28.818] (**) Option "xkb_model" "pc105"
[    28.818] (**) Option "xkb_layout" "us"
[    28.818] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.844] (II) event3  - Power Button: is tagged by udev as: Keyboard
[    28.844] (II) event3  - Power Button: device is a keyboard
[    28.845] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event5)
[    28.845] (**) Asus Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[    28.845] (**) Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[    28.845] (**) Asus Wireless Radio Control: Applying InputClass "system-keyboard"
[    28.845] (**) Asus Wireless Radio Control: Applying InputClass "Keyboard Defaults"
[    28.845] (II) Using input driver 'libinput' for 'Asus Wireless Radio Control'
[    28.846] (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 37 paused 0
[    28.846] (**) Asus Wireless Radio Control: always reports core events
[    28.846] (**) Option "Device" "/dev/input/event5"
[    28.846] (**) Option "_source" "server/udev"
[    28.847] (II) event5  - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[    28.847] (II) event5  - Asus Wireless Radio Control: device is a keyboard
[    28.847] (II) event5  - Asus Wireless Radio Control: device removed
[    28.847] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input5/event5"
[    28.847] (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 7)
[    28.847] (**) Option "xkb_model" "pc105"
[    28.847] (**) Option "xkb_layout" "us"
[    28.847] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.848] (II) event5  - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[    28.848] (II) event5  - Asus Wireless Radio Control: device is a keyboard
[    28.849] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[    28.849] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    28.849] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    28.849] (**) Video Bus: Applying InputClass "system-keyboard"
[    28.849] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    28.849] (II) Using input driver 'libinput' for 'Video Bus'
[    28.850] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 38 paused 0
[    28.850] (**) Video Bus: always reports core events
[    28.850] (**) Option "Device" "/dev/input/event8"
[    28.850] (**) Option "_source" "server/udev"
[    28.851] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[    28.851] (II) event8  - Video Bus: device is a keyboard
[    28.851] (II) event8  - Video Bus: device removed
[    28.851] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10/event8"
[    28.851] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[    28.851] (**) Option "xkb_model" "pc105"
[    28.851] (**) Option "xkb_layout" "us"
[    28.851] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.853] (II) event8  - Video Bus: is tagged by udev as: Keyboard
[    28.853] (II) event8  - Video Bus: device is a keyboard
[    28.853] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[    28.854] (II) No input driver specified, ignoring this device.
[    28.854] (II) This device may have been added with another device file.
[    28.854] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[    28.854] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[    28.854] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[    28.854] (**) Video Bus: Applying InputClass "system-keyboard"
[    28.854] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[    28.854] (II) Using input driver 'libinput' for 'Video Bus'
[    28.855] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 39 paused 0
[    28.855] (**) Video Bus: always reports core events
[    28.855] (**) Option "Device" "/dev/input/event9"
[    28.855] (**) Option "_source" "server/udev"
[    28.856] (II) event9  - Video Bus: is tagged by udev as: Keyboard
[    28.856] (II) event9  - Video Bus: device is a keyboard
[    28.857] (II) event9  - Video Bus: device removed
[    28.857] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:24/LNXVIDEO:01/input/input11/event9"
[    28.857] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 9)
[    28.857] (**) Option "xkb_model" "pc105"
[    28.857] (**) Option "xkb_layout" "us"
[    28.857] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.858] (II) event9  - Video Bus: is tagged by udev as: Keyboard
[    28.858] (II) event9  - Video Bus: device is a keyboard
[    28.859] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[    28.859] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[    28.859] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[    28.859] (**) Power Button: Applying InputClass "system-keyboard"
[    28.859] (**) Power Button: Applying InputClass "Keyboard Defaults"
[    28.859] (II) Using input driver 'libinput' for 'Power Button'
[    28.860] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 40 paused 0
[    28.860] (**) Power Button: always reports core events
[    28.860] (**) Option "Device" "/dev/input/event2"
[    28.860] (**) Option "_source" "server/udev"
[    28.861] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    28.861] (II) event2  - Power Button: device is a keyboard
[    28.861] (II) event2  - Power Button: device removed
[    28.861] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[    28.861] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 10)
[    28.861] (**) Option "xkb_model" "pc105"
[    28.861] (**) Option "xkb_layout" "us"
[    28.861] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.862] (II) event2  - Power Button: is tagged by udev as: Keyboard
[    28.862] (II) event2  - Power Button: device is a keyboard
[    28.863] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[    28.863] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[    28.863] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[    28.863] (**) Sleep Button: Applying InputClass "system-keyboard"
[    28.863] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[    28.863] (II) Using input driver 'libinput' for 'Sleep Button'
[    28.864] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 41 paused 0
[    28.864] (**) Sleep Button: always reports core events
[    28.864] (**) Option "Device" "/dev/input/event1"
[    28.864] (**) Option "_source" "server/udev"
[    28.865] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    28.865] (II) event1  - Sleep Button: device is a keyboard
[    28.865] (II) event1  - Sleep Button: device removed
[    28.865] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[    28.865] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 11)
[    28.865] (**) Option "xkb_model" "pc105"
[    28.865] (**) Option "xkb_layout" "us"
[    28.865] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.866] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[    28.867] (II) event1  - Sleep Button: device is a keyboard
[    28.868] (II) config/udev: Adding input device USB2.0 VGA UVC WebCam: USB2.0 V (/dev/input/event19)
[    28.868] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "evdev keyboard catchall"
[    28.868] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "libinput keyboard catchall"
[    28.868] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "system-keyboard"
[    28.868] (**) USB2.0 VGA UVC WebCam: USB2.0 V: Applying InputClass "Keyboard Defaults"
[    28.868] (II) Using input driver 'libinput' for 'USB2.0 VGA UVC WebCam: USB2.0 V'
[    28.868] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 42 paused 0
[    28.868] (**) USB2.0 VGA UVC WebCam: USB2.0 V: always reports core events
[    28.868] (**) Option "Device" "/dev/input/event19"
[    28.868] (**) Option "_source" "server/udev"
[    28.870] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: is tagged by udev as: Keyboard
[    28.870] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: device is a keyboard
[    28.870] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: device removed
[    28.870] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input21/event19"
[    28.870] (II) XINPUT: Adding extended input device "USB2.0 VGA UVC WebCam: USB2.0 V" (type: KEYBOARD, id 12)
[    28.870] (**) Option "xkb_model" "pc105"
[    28.870] (**) Option "xkb_layout" "us"
[    28.870] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.872] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: is tagged by udev as: Keyboard
[    28.872] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: device is a keyboard
[    28.873] (II) config/udev: Adding input device ELAN1300:00 04F3:3057 Mouse (/dev/input/event10)
[    28.873] (**) ELAN1300:00 04F3:3057 Mouse: Applying InputClass "evdev pointer catchall"
[    28.873] (**) ELAN1300:00 04F3:3057 Mouse: Applying InputClass "libinput pointer catchall"
[    28.873] (II) Using input driver 'libinput' for 'ELAN1300:00 04F3:3057 Mouse'
[    28.874] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 43 paused 0
[    28.874] (**) ELAN1300:00 04F3:3057 Mouse: always reports core events
[    28.874] (**) Option "Device" "/dev/input/event10"
[    28.874] (**) Option "_source" "server/udev"
[    28.875] (II) event10 - ELAN1300:00 04F3:3057 Mouse: is tagged by udev as: Mouse
[    28.875] (II) event10 - ELAN1300:00 04F3:3057 Mouse: device is a pointer
[    28.876] (II) event10 - ELAN1300:00 04F3:3057 Mouse: device removed
[    28.876] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-ELAN1300:00/0018:04F3:3057.0001/input/input12/event10"
[    28.876] (II) XINPUT: Adding extended input device "ELAN1300:00 04F3:3057 Mouse" (type: MOUSE, id 13)
[    28.876] (**) Option "AccelerationScheme" "none"
[    28.876] (**) ELAN1300:00 04F3:3057 Mouse: (accel) selected scheme none/0
[    28.876] (**) ELAN1300:00 04F3:3057 Mouse: (accel) acceleration factor: 2.000
[    28.876] (**) ELAN1300:00 04F3:3057 Mouse: (accel) acceleration threshold: 4
[    28.877] (II) event10 - ELAN1300:00 04F3:3057 Mouse: is tagged by udev as: Mouse
[    28.878] (II) event10 - ELAN1300:00 04F3:3057 Mouse: device is a pointer
[    28.879] (II) config/udev: Adding input device ELAN1300:00 04F3:3057 Mouse (/dev/input/mouse0)
[    28.879] (II) No input driver specified, ignoring this device.
[    28.879] (II) This device may have been added with another device file.
[    28.879] (II) config/udev: Adding input device ELAN1300:00 04F3:3057 Touchpad (/dev/input/event11)
[    28.879] (**) ELAN1300:00 04F3:3057 Touchpad: Applying InputClass "evdev touchpad catchall"
[    28.879] (**) ELAN1300:00 04F3:3057 Touchpad: Applying InputClass "libinput touchpad catchall"
[    28.879] (II) Using input driver 'libinput' for 'ELAN1300:00 04F3:3057 Touchpad'
[    28.880] (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 44 paused 0
[    28.880] (**) ELAN1300:00 04F3:3057 Touchpad: always reports core events
[    28.880] (**) Option "Device" "/dev/input/event11"
[    28.880] (**) Option "_source" "server/udev"
[    28.882] (II) event11 - ELAN1300:00 04F3:3057 Touchpad: is tagged by udev as: Touchpad
[    28.883] (II) event11 - ELAN1300:00 04F3:3057 Touchpad: device is a touchpad
[    28.883] (II) event11 - ELAN1300:00 04F3:3057 Touchpad: device removed
[    28.884] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-ELAN1300:00/0018:04F3:3057.0001/input/input13/event11"
[    28.884] (II) XINPUT: Adding extended input device "ELAN1300:00 04F3:3057 Touchpad" (type: TOUCHPAD, id 14)
[    28.885] (**) Option "AccelerationScheme" "none"
[    28.885] (**) ELAN1300:00 04F3:3057 Touchpad: (accel) selected scheme none/0
[    28.885] (**) ELAN1300:00 04F3:3057 Touchpad: (accel) acceleration factor: 2.000
[    28.885] (**) ELAN1300:00 04F3:3057 Touchpad: (accel) acceleration threshold: 4
[    28.887] (II) event11 - ELAN1300:00 04F3:3057 Touchpad: is tagged by udev as: Touchpad
[    28.888] (II) event11 - ELAN1300:00 04F3:3057 Touchpad: device is a touchpad
[    28.889] (II) config/udev: Adding input device ELAN1300:00 04F3:3057 Touchpad (/dev/input/mouse1)
[    28.889] (II) No input driver specified, ignoring this device.
[    28.889] (II) This device may have been added with another device file.
[    28.890] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event12)
[    28.890] (II) No input driver specified, ignoring this device.
[    28.890] (II) This device may have been added with another device file.
[    28.890] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event13)
[    28.891] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event14)
[    28.891] (II) No input driver specified, ignoring this device.
[    28.891] (II) This device may have been added with another device file.
[    28.891] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event15)
[    28.892] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event16)
[    28.892] (II) No input driver specified, ignoring this device.
[    28.892] (II) This device may have been added with another device file.
[    28.892] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event17)
[    28.892] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event18)
[    28.893] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event7)
[    28.893] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[    28.893] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[    28.893] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[    28.893] (**) Asus WMI hotkeys: Applying InputClass "Keyboard Defaults"
[    28.893] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[    28.894] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 45 paused 0
[    28.894] (**) Asus WMI hotkeys: always reports core events
[    28.894] (**) Option "Device" "/dev/input/event7"
[    28.894] (**) Option "_source" "server/udev"
[    28.895] (II) event7  - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    28.895] (II) event7  - Asus WMI hotkeys: device is a keyboard
[    28.895] (II) event7  - Asus WMI hotkeys: device removed
[    28.895] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input7/event7"
[    28.895] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 15)
[    28.895] (**) Option "xkb_model" "pc105"
[    28.895] (**) Option "xkb_layout" "us"
[    28.895] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.896] (II) event7  - Asus WMI hotkeys: is tagged by udev as: Keyboard
[    28.896] (II) event7  - Asus WMI hotkeys: device is a keyboard
[    28.897] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[    28.897] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[    28.897] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[    28.897] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[    28.897] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[    28.897] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[    28.898] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 46 paused 0
[    28.898] (**) AT Translated Set 2 keyboard: always reports core events
[    28.898] (**) Option "Device" "/dev/input/event4"
[    28.898] (**) Option "_source" "server/udev"
[    28.899] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    28.899] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    28.900] (II) event4  - AT Translated Set 2 keyboard: device removed
[    28.900] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[    28.900] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[    28.900] (**) Option "xkb_model" "pc105"
[    28.900] (**) Option "xkb_layout" "us"
[    28.900] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[    28.901] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[    28.902] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[    28.903] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[    28.903] (II) No input driver specified, ignoring this device.
[    28.903] (II) This device may have been added with another device file.
[    66.121] (**) Option "fd" "34"
[    66.121] (II) event3  - Power Button: device removed
[    66.121] (**) Option "fd" "37"
[    66.121] (II) event5  - Asus Wireless Radio Control: device removed
[    66.122] (**) Option "fd" "38"
[    66.122] (II) event8  - Video Bus: device removed
[    66.122] (**) Option "fd" "39"
[    66.122] (II) event9  - Video Bus: device removed
[    66.123] (**) Option "fd" "40"
[    66.123] (II) event2  - Power Button: device removed
[    66.123] (**) Option "fd" "41"
[    66.123] (II) event1  - Sleep Button: device removed
[    66.124] (**) Option "fd" "42"
[    66.124] (II) event19 - USB2.0 VGA UVC WebCam: USB2.0 V: device removed
[    66.124] (**) Option "fd" "43"
[    66.124] (II) event10 - ELAN1300:00 04F3:3057 Mouse: device removed
[    66.125] (**) Option "fd" "44"
[    66.125] (II) event11 - ELAN1300:00 04F3:3057 Touchpad: device removed
[    66.125] (**) Option "fd" "45"
[    66.125] (II) event7  - Asus WMI hotkeys: device removed
[    66.126] (**) Option "fd" "46"
[    66.126] (II) event4  - AT Translated Set 2 keyboard: device removed
[    66.195] (II) systemd-logind: got pause for 13:73
[    66.195] (II) systemd-logind: got pause for 13:75
[    66.195] (II) systemd-logind: got pause for 226:0
[    66.195] (II) systemd-logind: got pause for 13:67
[    66.196] (II) systemd-logind: got pause for 13:74
[    66.196] (II) systemd-logind: got pause for 13:69
[    66.196] (II) systemd-logind: got pause for 13:72
[    66.196] (II) systemd-logind: got pause for 13:71
[    66.196] (II) systemd-logind: got pause for 13:66
[    66.196] (II) systemd-logind: got pause for 13:83
[    66.196] (II) systemd-logind: got pause for 13:68
[    66.196] (II) systemd-logind: got pause for 13:65
[    67.352] randr: failed to create shared pixmap
[    67.390] (II) systemd-logind: got resume for 13:73
[    67.420] (II) systemd-logind: got resume for 13:75
[    67.420] (II) systemd-logind: got resume for 226:0
[    67.432] (II) NVIDIA(0): Setting mode "NULL"
[    67.434] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    67.434] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    67.434] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    67.434] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    67.434] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    67.434] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    67.434] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    67.434] (II) NVIDIA(0):     Config Options in the README.
[    67.443] (EE) modeset(G0): failed to set mode: No space left on device
[    67.443] (EE)
Fatal server error:
[    67.443] (EE) EnterVT failed for gpu screen 0
[    67.443] (EE)
[    67.443] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[    67.443] (EE) Please also check the log file at "/home/rd/.local/share/xorg/Xorg.1.log" for additional information.
[    67.443] (EE)
[    67.660] (EE) Server terminated with error (1). Closing log file.
I'm not expert on this so I can't point directly the cause but there are many problems in the background.
Icon warnings are not the problem here, but you need to install or reinstall some icon packages, or purge them carefully so the system wouldn't look for them. This is a common problem. You install some icon pack, uninstall it and then everything complains about lacking them... This is topic on its own, but it's not the direct cause of the issue here.
[    28.060]
This sounds disturbing, but I can't recognize it, hopefully someone will.
The main issue seems to be here (but I may be wrong)
[    67.443] (EE)
Fatal server error:
[    67.443] (EE)
[    67.443] (EE)
This looks like ACPI problem. Please read and try this:
Also, in optimus-manager settings, try out other switching methods then ACPI call, because it seems to be problematic for you.
You have also
but this isn't a big issue, at least not for me, because I have the same warning and things work fine on my end. Or maybe this is because I don't use ACPI to switch the cards?
I would also check again:
/etc/X11/xorg.conf.d/
/etc/X11/
to see if everything is just like in the tutorial (graphical confs disabled). Maybe you run Nvidia settings and it added some confing?
With resume issue, just to be sure, I would also check fstab settings and hooks in /etc/mkinitcpio.conf
There should be resume somewhere in the end.
Maybe you could add to grub config this parameter:
resume=/dev/sda4 resume_offset=1363968 - of course, change the path and the number according to the fstab and don't forget to grub-update after the change or use grub-customizer.
Hi thanks for quick reply.
So I followed the ACPI guide which you provided.
after applying correct ACPI parameter, I cold booted 5-6 times and got the problem only once.
I believe it will still occur but less frequent, I would be happy if there would be a permanent fix though.
As far as resume is concerned, I added kernel parameters you provided and also followed this guide but got no luck.
The issue is more frequent when I close the lid rather than just pressing power button for sleep but it occurs anyway.
It feels like x server just fails to resume and restarts itself, that too with intel graphics. And also when I use that session, there is audio problems. Ultimately I have to just restart my laptop.
Resume issues are unfortunately a common thing in Linux. When I installed my OS 4 years ago, I couldn't use resume because it produced many errors and session was bugged. Then after a year it all fixed itself and I could use it for 3 years without a bigger problem. Recently something changed my wifi isn't working after suspend, so I had to switch lid closing to 'screen off' and suspend is no longer an option for me anymore... Very likely, on LTS systems that bug would not be there yet...
So like you see, those things are in constant flux and sometimes things go better with time, sometimes they get worse, but luckily this happens less frequently.
And oh, did I wrote about tlp settings? Study those and maybe changing some of tlp settings may fix your problem, because you can delay certain processes (thus ensuring some race conditions won't happen), disable, enable turning off/on certain hardware parts and so on. Experiment with it. It may not do anything or do everything.
