Restore the default whisker menu
Hi, I just installed Manjaro 16.06.1, using an existing home partition.
I expected the default menu but instead I found the xfce menu. How to set the whisker menu?
I already tried copying the content of /etc/skel to my home but it didn't work...
Right click the panel, choose "Panel --> Add new elements". Find "Whisker menu" and add it. Later right click old menu button, choose "Delete" (or "Remove"?)
Ok that is where it was. Thanks. I wasn't guessing that it was a panel add item. That little rat is back in place!
