rockpro64 usb port non-functional
I cannot get the USBc port on my rockpro 64 running a freshly installed and updated manjaro install. Displayport output on it doesn't work either. What am I missing?
Some Information would be nice :slight_smile:
Type journalctl --follow in a terminal and put an usb flash drive into the usb slot. Any output?
Hi,
Look here, you are not the first with this issue, I hope it will be helpful.
Is it the entire port function that is not working, or just Display/HDMI out?
That's a handy tool to know, thanks.
-- Logs begin at Fri 2013-01-18 03:50:23 EST. --
Aug 03 21:04:12 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:14 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:14 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:14 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:16 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:16 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:16 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:18 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:18 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:18 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:20 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:20 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:20 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:22 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:22 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:22 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/ti,davinci-mdio.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/ti,dp83867.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/ti,dp83869.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/ti,k3-am654-cpsw-nuss.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/ti-bluetooth.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/via-rhine.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/via-velocity.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/brcm,bcm43xx-fmac.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/esp,esp8089.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:23 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/ieee80211.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/marvell-8xxx.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/mediatek,mt76.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/qca,ath9k.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/qcom,ath10k.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/qcom,ath11k.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/ti,wl1251.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/ti,wlcore,spi.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wireless/ti,wlcore.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/wiznet,w5x00.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/xilinx_axienet.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/net/xilinx_gmii2rgmii.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nios2/nios2.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/numa.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/allwinner,sun4i-a10-sid.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/amlogic-efuse.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/amlogic-meson-mx-efuse.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/brcm,ocotp.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/imx-iim.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/imx-ocotp.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/ingenic,jz4780-efuse.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/lpc1850-otp.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/lpc1857-eeprom.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/mtk-efuse.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/mxs-ocotp.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/nvmem-consumer.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/nvmem.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/nvmem.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/qcom,spmi-sdam.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/qfprom.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/rockchip-efuse.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:24 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:24 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:24 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:27 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:27 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:27 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:29 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:29 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:29 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:30 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/sprd-efuse.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:30 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/st,stm32-romem.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:30 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/uniphier-efuse.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:30 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/vf610-ocotp.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/xlnx,zynqmp-nvmem.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/nvmem/zii,rave-sp-eeprom.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/openrisc/opencores/or1ksim.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/opp/allwinner,sun50i-h6-operating-points.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/opp/opp.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/opp/qcom-nvmem-cpufreq.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/opp/qcom-opp.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/opp/ti-omap5-opp-supply.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:31 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:31 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/83xx-512x-pci.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/aardvark-pci.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/altera-pcie-msi.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/altera-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/amlogic,meson-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/axis,artpec6-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/brcm,iproc-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/brcm,stb-pcie.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/cdns,cdns-pcie-ep.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/cdns,cdns-pcie-host.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/cdns-pcie-host.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/cdns-pcie.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/designware-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/faraday,ftpci100.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/fsl,imx6q-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/fsl,pci.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/hisilicon-histb-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/hisilicon-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/host-generic-pci.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/intel-gw-pcie.yaml" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/kirin-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/layerscape-pci.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/layerscape-pcie-gen4.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/mediatek-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/mobiveil-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/mvebu-pci.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/nvidia,tegra194-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:31 usb baloo_file_extractor[1128]: org.kde.baloo: "/home/sean/Downloads/pbp-tools/upstream/linux-5.7/Documentation/devicetree/bindings/pci/nvidia,tegra20-pcie.txt" id seems to have changed. Perhaps baloo was not running, and this file was deleted + re-created
Aug 03 21:04:33 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:33 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:33 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:35 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:35 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:35 usb kernel: busb vbus_attach rphy->chg_state = 5
Aug 03 21:04:37 usb kernel: busb rockchip_usb2phy_otg_sm_work b_idle otg sm work 1
Aug 03 21:04:37 usb kernel: busb HOST = 0,VBUS_EN=0,vbus_attached=1
Aug 03 21:04:37 usb kernel: busb vbus_attach rphy->chg_state = 5
Nothing changes when anything is connected to that port.
I saw that but it hasn't had any activity lately and I didn't was to piss anyone off with a necropost. It was locked anyway.
The entire port is dead to me. Neither Displayport nor USB-c work.
Funny ... the log is 7 years old? :smiley:
the date is set properly. weird.
I booted an lxde image from ayufan, ver 0.9.14. USBc and DP works. So we can rule out hardware.
When you mean USB-C, do you mean regular mass storage?
We know that DP and HMDI does not work. But mass storage should.
I tried plugging in a flash drive to that port and that doesn't work either.
Okay. That's indeed odd. Although I haven't actually tested the USB-C port on mine.
If you feel adventurous, you can try flashing the Pinebook Pro image. It's the same SoC, so it should boot just fine, and it has a working USB-C port.
