Hey dudes, I love bspwm edition. Is there an open repo to post issues? I had an issue that was solved on Arch forums under this link
https://bbs.archlinux.org/viewtopic.php?id=229095
Has anyone had the same problem? Is there an option to implement the solution to the distro?
Hello! I moved your question to a separte topic.
Please, explain the issue in you own words, edit your post, even if it is "exactly" the same as the linked post.
Alright, thanks!
So after booting Manjaro it would freeze for 30 seconds or more when rofi was first used. Couldn't change working space, run anything, only the mouse moved and hover on toolbar worked (tooltips showed, hover effects were visible). I logged onto another tty and saw a rofind
process with find
command ran which had around 10% CPU usage. I found the solution and edited /usr/bin/rofind adding coproc
which ran it asynchronously and it rofi now shows without delay.
Nice improvement. You can send the pull request in this repo:
Alright, this is embarassing. I haven't checked if the script works - it did for me, as it loaded fast, but actually rofind
was just crashing. This script uses dash
shell which has no coproc
implemented. I committed new code that kinda works, but needs some improvement.
@Chrysostomus please take a look https://github.com/fraunos/rofi-scripts/commit/3fb26f7e171fdb49653dc2ffa88cbd982bc2c0c0
Well, good thing I didn't build the package yet
Thus is my laziness rewarded
