hello all
i have read and attempted to follow the directions from the mar 10(i think) post about installing the proper drivers. i followed the directions and still wasnt able to get the wireless adapter working. i have followed the instructions on getting the log info requested and i shall now post it here and hopefully some one will be able to assist me. i am a step above a newbie, but not a huge step. i have searched for the answer and thought i finally found it here, until it didnt work...thank you in advance
btw it was 17 pages of output. if there was another way i was supposed to share it here please let me know.
lag
ac97_bus 16384 1 snd_ac97_codec
agpgart 49152 3 intel_agp,intel_gtt,drm
ata_generic 16384 0
ata_piix 36864 3
cdrom 65536 1 sr_mod
crc16 16384 1 ext4
crc32c_generic 16384 3
crypto_user 16384 0
dcdbas 16384 0
drm 512000 5 drm_kms_helper,i915
drm_kms_helper 208896 1 i915
ehci_hcd 94208 1 ehci_pci
ehci_pci 16384 0
evdev 24576 6
ext4 741376 2
fb_sys_fops 16384 1 drm_kms_helper
floppy 81920 0
fscrypto 32768 1 ext4
fuse 118784 16
hid 135168 4 usbhid,hid_generic,hid_logitech_dj,hid_logitech_hidpp
hid_generic 16384 0
hid_logitech_dj 24576 0
hid_logitech_hidpp 40960 0
i2c_algo_bit 16384 1 i915
i2c_i801 32768 0
i915 2101248 2
input_leds 16384 0
intel_agp 20480 0
intel_gtt 24576 2 intel_agp,i915
intel_powerclamp 16384 0
ip_tables 28672 0
irqbypass 16384 1 kvm
iTCO_vendor_support 16384 1 iTCO_wdt
iTCO_wdt 16384 0
jbd2 126976 1 ext4
joydev 24576 0
kvm 745472 1 kvmgt
kvmgt 28672 0
libata 270336 3 ata_piix,pata_acpi,ata_generic
libphy 81920 1 tg3
lpc_ich 28672 0
mac_hid 16384 0
mbcache 16384 1 ext4
mdev 20480 2 kvmgt,vfio_mdev
Module Size Used by
mousedev 24576 0
parport 57344 2 parport_pc,ppdev
parport_pc 49152 0
pata_acpi 16384 0
pcspkr 16384 0
ppdev 20480 0
rng_core 16384 0
scsi_mod 253952 5 sd_mod,usb_storage,uas,libata,sr_mod
sd_mod 61440 18
snd 106496 8 snd_intel8x0,snd_timer,snd_ac97_codec,snd_pcm
snd_ac97_codec 147456 1 snd_intel8x0
snd_intel8x0 45056 2
snd_pcm 131072 2 snd_intel8x0,snd_ac97_codec
snd_timer 36864 1 snd_pcm
soundcore 16384 1 snd
sr_mod 28672 0
syscopyarea 16384 1 drm_kms_helper
sysfillrect 16384 1 drm_kms_helper
sysimgblt 16384 1 drm_kms_helper
tg3 184320 0
uas 28672 0
uhci_hcd 49152 0
usbhid 57344 0
usb_storage 73728 8 uas
vfio 32768 3 kvmgt,vfio_mdev,vfio_iommu_type1
vfio_iommu_type1 28672 0
vfio_mdev 16384 0
x_tables 45056 1 ip_tables
rtl8812au, 5.2.20.2.r33.g30d47a0, 4.19.80-1-MANJARO, x86_64: installed
rfkill: cannot open /dev/rfkill: No such file or directory
rfkill: cannot read /dev/rfkill: Bad file descriptor
02:00.0 Ethernet controller [0200]: Broadcom Inc. and subsidiaries NetXtreme BCM5751 Gigabit Ethernet PCI Express [14e4:1677] (rev 01)
Model: "Dell OptiPlex GX620"
Driver: "tg3"
Device File: enp2s0
Link detected: no
Driver Status: tg3 is active
Driver Activation Cmd: "modprobe tg3"
Host: Buffalo Kernel: 4.19.80-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 9.2.0 Desktop: Cinnamon 4.2.4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: Dell product: OptiPlex GX520 v: N/A serial: <filter>
Chassis: type: 15 serial: <filter>
Mobo: Dell model: 0XG309 serial: <filter> BIOS: Dell v: A11
date: 11/30/2006
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
status: Discharging
Topology: Single Core model: Intel Pentium 4 bits: 64 type: MT
arch: Netburst Smithfield rev: 3 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 bogomips: 11975
Speed: 2993 MHz min/max: N/A Core speeds (MHz): 1: 2993 2: 2993
Device-1: Intel 82945G/GZ Integrated Graphics vendor: Dell driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:2772
Display: x11 server: X.Org 1.20.5 driver: intel unloaded: modesetting
alternate: fbdev,vesa tty: N/A
OpenGL: renderer: Mesa DRI Intel 945G v: 1.4 Mesa 19.2.2
direct render: Yes
Device-1: Intel 82801G AC97 Audio vendor: Dell OptiPlex GX620
driver: snd_intel8x0 v: kernel bus ID: 00:1e.2 chip ID: 8086:27de
Sound Server: ALSA v: k4.19.80-1-MANJARO
Device-1: Broadcom and subsidiaries NetXtreme BCM5751 Gigabit Ethernet PCI
Express
vendor: Dell OptiPlex GX620 driver: tg3 v: 3.137 port: e8a0
bus ID: 02:00.0 chip ID: 14e4:1677
Device-2: NetGear A6100 AC600 DB Wireless Adapter [Realtek RTL8811AU]
type: USB driver: usb-network bus ID: 1-2:2 chip ID: 0846:9052
serial: <filter>
Local Storage: total: 25.76 TiB used: 12.11 TiB (47.0%)
ID-1: /dev/sda vendor: Seagate model: ST3320820AS size: 298.09 GiB
speed: <unknown> serial: <filter> rev: G scheme: MBR
ID-2: /dev/sdb type: USB vendor: Western Digital model: WD40 EZRX-00SPEB0
size: 3.64 TiB serial: <filter> rev: 0125 scheme: GPT
ID-3: /dev/sdc type: USB vendor: Western Digital model: WD40 EZRX-00SPEB0
ID-4: /dev/sdd type: USB vendor: Western Digital model: WD40 EZRZ-00WN9B0
ID-5: /dev/sde type: USB vendor: Western Digital model: WD40 EZRX-00SPEB0
ID-6: /dev/sdf type: USB vendor: Western Digital model: WD40 EZRZ-00GXCB0
ID-7: /dev/sdg type: USB vendor: Western Digital model: WD40 EZRZ-00WN9B0
ID-8: /dev/sdh type: USB vendor: Western Digital model: WD40 EZRX-00SPEB0
ID-1: / size: 45.18 GiB used: 8.61 GiB (19.1%) fs: ext2 dev: /dev/sda1
ID-2: /home size: 245.79 GiB used: 2.43 GiB (1.0%) fs: ext4 dev: /dev/sda3
ID-3: swap-1 size: 1.46 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Message: No sensors data was found. Is sensors configured?
Processes: 170 Uptime: 12m Memory: 1.94 GiB used: 949.1 MiB (47.9%)
Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
running in: gnome-terminal inxi: 3.0.36
cinnamon2d.desktop cinnamon.desktop kodi.desktop
2019-10-26
[ 0.723382] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 1.587515] ehci-pci 0000:00:1d.7: debug port 1
[ 2.084096] usb 1-2: Product: 802.11ac WLAN Adapter
[ 7.010697] EXT4-fs (sda1): warning: mounting unchecked fs, running e2fsck is recommended
[ 15.340600] intel_rng: Firmware space is locked read-only. If you can't or
intel_rng: don't want to disable this in firmware setup, and if
[ 16.205413] tg3 0000:02:00.0 eth0: Tigon3 [partno(BCM5751PKFBG) rev 4001] (PCI Express) MAC address 00:12:3f:c4:6a:01
[ 16.205419] tg3 0000:02:00.0 eth0: attached PHY is 5750 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 16.205423] tg3 0000:02:00.0 eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 16.205427] tg3 0000:02:00.0 eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 17.255604] tg3 0000:02:00.0 enp2s0: renamed from eth0
[ 29.561553] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
[ 29.599234] IPv6: ADDRCONF(NETDEV_UP): enp2s0: link is not ready
/usr/lib/modprobe.d/bluetooth-usb.conf:options btusb reset=1
/usr/lib/modprobe.d/systemd.conf:options bonding max_bonds=0
/usr/lib/modprobe.d/systemd.conf:options dummy numdummies=0
/usr/lib/modprobe.d/uvesafb.conf:# options uvesafb mode=<xres>x<yres>[-<bpp>][@<refresh>] scroll=<ywrap|ypan|redraw> ...
/usr/lib/modprobe.d/uvesafb.conf:options uvesafb mode_option=1024x768-32 scroll=ywrap
/usr/lib/modprobe.d/nvdimm-security.conf:install libnvdimm /usr/bin/ndctl load-keys ; /sbin/modprobe --ignore-install libnvdimm $CMDLINE_OPTS
linux419
linux419-headers
Running Kernel 4.19.80-1-MANJARO
Oct 30 20:55:28 Buffalo NetworkManager[296]: <info> [1572483328.6172] device (wlan0): driver supports Access Point (AP) mode
Oct 30 20:55:28 Buffalo NetworkManager[296]: <info> [1572483328.6356] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/5)
Oct 30 20:55:28 Buffalo NetworkManager[296]: <info> [1572483328.7143] rfkill1: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1d.7/usb1/1-8/1-8:1.0/ieee80211/phy1/rfkill1) (driver rtl8192cu)
Oct 30 20:55:28 Buffalo NetworkManager[296]: <info> [1572483328.8325] device (wlan0): interface index 4 renamed iface from 'wlan0' to 'wlp0s29f7u8'
Oct 30 20:55:28 Buffalo NetworkManager[296]: <info> [1572483328.9628] device (wlp0s29f7u8): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 20:55:29 Buffalo NetworkManager[296]: <info> [1572483329.7044] device (wlp0s29f7u8): set-hw-addr: set MAC address to 9E:2D:AD:1D:30:B5 (scanning)
Oct 30 20:55:30 Buffalo NetworkManager[296]: <info> [1572483330.5351] sup-iface[0x563634384200,wlp0s29f7u8]: supports 4 scan SSIDs
Oct 30 20:55:30 Buffalo NetworkManager[296]: <info> [1572483330.5390] device (wlp0s29f7u8): supplicant interface state: starting -> ready
Oct 30 20:55:30 Buffalo NetworkManager[296]: <info> [1572483330.5397] Wi-Fi P2P device controlled by interface wlp0s29f7u8 created
Oct 30 20:55:30 Buffalo NetworkManager[296]: <info> [1572483330.5412] manager: (p2p-dev-wlp0s29f7u8): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/6)
Oct 30 20:55:30 Buffalo NetworkManager[296]: <info> [1572483330.5622] device (p2p-dev-wlp0s29f7u8): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 20:55:30 Buffalo NetworkManager[296]: <info> [1572483330.5672] device (p2p-dev-wlp0s29f7u8): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:30 Buffalo NetworkManager[296]: <info> [1572483330.5736] device (wlp0s29f7u8): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 30 20:55:30 Buffalo NetworkManager[296]: <warn> [1572483330.5801] sup-iface: failed to cancel p2p connect: P2P cancel failed
Oct 30 20:55:31 Buffalo NetworkManager[296]: <info> [1572483331.8706] device (wlp0s29f7u8): Activation: starting connection 'Auto Greenhouse' (ec7c6435-1780-44c9-8a3e-09e14b3f3084)
Oct 30 20:55:31 Buffalo NetworkManager[296]: <info> [1572483331.8725] device (wlp0s29f7u8): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:31 Buffalo NetworkManager[296]: <info> [1572483331.9348] device (wlp0s29f7u8): set-hw-addr: reset MAC address to C4:3D:C7:7F:1D:F8 (preserve)
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.5801] device (wlp0s29f7u8): supplicant interface state: ready -> disabled
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.5802] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: ready -> disabled
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.5806] device (wlp0s29f7u8): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.5834] device (wlp0s29f7u8): Activation: (wifi) access point 'Auto Greenhouse' has security, but secrets are required.
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.5835] device (wlp0s29f7u8): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.5842] sup-iface[0x563634384200,wlp0s29f7u8]: wps: type pbc start...
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.6015] device (wlp0s29f7u8): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.6034] device (wlp0s29f7u8): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.6065] device (wlp0s29f7u8): Activation: (wifi) connection 'Auto Greenhouse' has security, and secrets exist. No new secrets needed.
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.6155] device (wlp0s29f7u8): supplicant interface state: disabled -> inactive
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.6156] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: disabled -> inactive
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.7414] device (wlp0s29f7u8): supplicant interface state: inactive -> scanning
Oct 30 20:55:32 Buffalo NetworkManager[296]: <info> [1572483332.7415] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: inactive -> scanning
Oct 30 20:55:33 Buffalo NetworkManager[296]: <info> [1572483333.8456] device (wlp0s29f7u8): supplicant interface state: scanning -> authenticating
Oct 30 20:55:33 Buffalo NetworkManager[296]: <info> [1572483333.8457] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: scanning -> authenticating
Oct 30 20:55:34 Buffalo NetworkManager[296]: <info> [1572483334.1833] device (wlp0s29f7u8): supplicant interface state: authenticating -> disconnected
Oct 30 20:55:34 Buffalo NetworkManager[296]: <info> [1572483334.1834] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: authenticating -> disconnected
Oct 30 20:55:34 Buffalo NetworkManager[296]: <info> [1572483334.2832] device (wlp0s29f7u8): supplicant interface state: disconnected -> scanning
Oct 30 20:55:34 Buffalo NetworkManager[296]: <info> [1572483334.2833] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: disconnected -> scanning
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.3665] device (wlp0s29f7u8): supplicant interface state: scanning -> authenticating
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.3666] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: scanning -> authenticating
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.5096] device (wlp0s29f7u8): supplicant interface state: authenticating -> associating
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.5097] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: authenticating -> associating
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7029] device (wlp0s29f7u8): supplicant interface state: associating -> associated
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7030] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: associating -> associated
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7149] device (wlp0s29f7u8): supplicant interface state: associated -> 4-way handshake
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7150] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: associated -> 4-way handshake
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7651] device (wlp0s29f7u8): supplicant interface state: 4-way handshake -> completed
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7669] device (wlp0s29f7u8): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Greenhouse"
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7673] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: 4-way handshake -> completed
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7708] device (wlp0s29f7u8): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:35 Buffalo NetworkManager[296]: <info> [1572483335.7758] dhcp4 (wlp0s29f7u8): activation: beginning transaction (timeout in 45 seconds)
Oct 30 20:55:38 Buffalo NetworkManager[296]: <info> [1572483338.0610] dhcp4 (wlp0s29f7u8): state changed unknown -> bound
Oct 30 20:55:38 Buffalo NetworkManager[296]: <info> [1572483338.0663] device (wlp0s29f7u8): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:38 Buffalo NetworkManager[296]: <info> [1572483338.0948] device (wlp0s29f7u8): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:38 Buffalo NetworkManager[296]: <info> [1572483338.0965] device (wlp0s29f7u8): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oct 30 20:55:38 Buffalo NetworkManager[296]: <info> [1572483338.1269] policy: set 'Auto Greenhouse' (wlp0s29f7u8) as default for IPv4 routing and DNS
Oct 30 20:55:38 Buffalo NetworkManager[296]: <info> [1572483338.1953] device (wlp0s29f7u8): Activation: successful, device activated.
Oct 30 21:30:53 Buffalo NetworkManager[296]: <info> [1572485453.0850] dhcp4 (wlp0s29f7u8): canceled DHCP transaction
Oct 30 21:30:53 Buffalo NetworkManager[296]: <info> [1572485453.0850] dhcp4 (wlp0s29f7u8): state changed bound -> done
Oct 30 21:30:53 Buffalo NetworkManager[296]: <info> [1572485453.0851] device (wlp0s29f7u8): DHCPv4: 480 seconds grace period started
Oct 30 21:30:53 Buffalo NetworkManager[296]: <info> [1572485453.0901] device (p2p-dev-wlp0s29f7u8): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Oct 30 21:31:33 Buffalo NetworkManager[315]: <info> [1572485493.2636] hostname: hostname changed from (none) to "Buffalo"
Oct 30 21:31:33 Buffalo NetworkManager[315]: <info> [1572485493.2675] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1d.7/usb1/1-8/1-8:1.0/ieee80211/phy0/rfkill0) (driver rtl8192cu)
Oct 30 21:31:36 Buffalo NetworkManager[315]: <info> [1572485496.2725] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 21:31:36 Buffalo NetworkManager[315]: <info> [1572485496.3394] device (wlp0s29f7u8): driver supports Access Point (AP) mode
Oct 30 21:31:36 Buffalo NetworkManager[315]: <info> [1572485496.3412] manager: (wlp0s29f7u8): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Oct 30 21:31:36 Buffalo NetworkManager[315]: <info> [1572485496.3446] device (wlp0s29f7u8): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 21:31:37 Buffalo NetworkManager[315]: <info> [1572485497.4412] device (wlp0s29f7u8): set-hw-addr: set MAC address to 3A:B5:43:11:48:F1 (scanning)
Oct 30 21:31:38 Buffalo NetworkManager[315]: <info> [1572485498.9007] device (wlp0s29f7u8): supplicant interface state: init -> starting
Oct 30 21:31:39 Buffalo NetworkManager[315]: <info> [1572485499.1313] sup-iface[0x55fb4f84e120,wlp0s29f7u8]: supports 4 scan SSIDs
Oct 30 21:31:39 Buffalo NetworkManager[315]: <info> [1572485499.1337] device (wlp0s29f7u8): supplicant interface state: starting -> ready
Oct 30 21:31:39 Buffalo NetworkManager[315]: <info> [1572485499.1342] Wi-Fi P2P device controlled by interface wlp0s29f7u8 created
Oct 30 21:31:39 Buffalo NetworkManager[315]: <info> [1572485499.1349] manager: (p2p-dev-wlp0s29f7u8): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Oct 30 21:31:39 Buffalo NetworkManager[315]: <info> [1572485499.1359] device (p2p-dev-wlp0s29f7u8): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 21:31:39 Buffalo NetworkManager[315]: <info> [1572485499.1381] device (p2p-dev-wlp0s29f7u8): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:39 Buffalo NetworkManager[315]: <info> [1572485499.1391] device (wlp0s29f7u8): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 30 21:31:39 Buffalo NetworkManager[315]: <warn> [1572485499.1436] sup-iface: failed to cancel p2p connect: P2P cancel failed
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.2216] device (wlp0s29f7u8): Activation: starting connection 'Auto Greenhouse' (ec7c6435-1780-44c9-8a3e-09e14b3f3084)
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.2220] device (wlp0s29f7u8): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.2528] device (wlp0s29f7u8): set-hw-addr: reset MAC address to C4:3D:C7:7F:1D:F8 (preserve)
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8312] device (wlp0s29f7u8): supplicant interface state: ready -> disabled
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8313] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: ready -> disabled
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8317] device (wlp0s29f7u8): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8327] device (wlp0s29f7u8): Activation: (wifi) access point 'Auto Greenhouse' has security, but secrets are required.
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8328] device (wlp0s29f7u8): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8335] sup-iface[0x55fb4f84e120,wlp0s29f7u8]: wps: type pbc start...
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8423] device (wlp0s29f7u8): supplicant interface state: disabled -> inactive
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8424] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: disabled -> inactive
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8426] device (wlp0s29f7u8): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8444] device (wlp0s29f7u8): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8454] device (wlp0s29f7u8): Activation: (wifi) connection 'Auto Greenhouse' has security, and secrets exist. No new secrets needed.
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8821] device (wlp0s29f7u8): supplicant interface state: inactive -> scanning
Oct 30 21:31:40 Buffalo NetworkManager[315]: <info> [1572485500.8822] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: inactive -> scanning
Oct 30 21:31:47 Buffalo NetworkManager[315]: <info> [1572485507.9364] device (wlp0s29f7u8): supplicant interface state: scanning -> authenticating
Oct 30 21:31:47 Buffalo NetworkManager[315]: <info> [1572485507.9365] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: scanning -> authenticating
Oct 30 21:31:47 Buffalo NetworkManager[315]: <info> [1572485507.9563] device (wlp0s29f7u8): supplicant interface state: authenticating -> associating
Oct 30 21:31:47 Buffalo NetworkManager[315]: <info> [1572485507.9563] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: authenticating -> associating
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.0519] device (wlp0s29f7u8): supplicant interface state: associating -> associated
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.0523] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: associating -> associated
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.0743] device (wlp0s29f7u8): supplicant interface state: associated -> 4-way handshake
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.0748] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: associated -> 4-way handshake
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.1512] device (wlp0s29f7u8): supplicant interface state: 4-way handshake -> completed
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.1516] device (wlp0s29f7u8): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Greenhouse"
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.1519] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: 4-way handshake -> completed
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.1549] device (wlp0s29f7u8): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:48 Buffalo NetworkManager[315]: <info> [1572485508.1572] dhcp4 (wlp0s29f7u8): activation: beginning transaction (timeout in 45 seconds)
Oct 30 21:31:51 Buffalo NetworkManager[315]: <info> [1572485511.8173] dhcp4 (wlp0s29f7u8): state changed unknown -> bound
Oct 30 21:31:51 Buffalo NetworkManager[315]: <info> [1572485511.8278] device (wlp0s29f7u8): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:51 Buffalo NetworkManager[315]: <info> [1572485511.9458] device (wlp0s29f7u8): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:51 Buffalo NetworkManager[315]: <info> [1572485511.9478] device (wlp0s29f7u8): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oct 30 21:31:51 Buffalo NetworkManager[315]: <info> [1572485511.9708] policy: set 'Auto Greenhouse' (wlp0s29f7u8) as default for IPv4 routing and DNS
Oct 30 21:31:51 Buffalo NetworkManager[315]: <info> [1572485511.9959] device (wlp0s29f7u8): Activation: successful, device activated.
Oct 30 21:36:31 Buffalo NetworkManager[315]: <info> [1572485791.7278] dhcp4 (wlp0s29f7u8): canceled DHCP transaction
Oct 30 21:36:31 Buffalo NetworkManager[315]: <info> [1572485791.7278] dhcp4 (wlp0s29f7u8): state changed bound -> done
Oct 30 21:36:31 Buffalo NetworkManager[315]: <info> [1572485791.7279] device (wlp0s29f7u8): DHCPv4: 480 seconds grace period started
Oct 30 21:36:31 Buffalo NetworkManager[315]: <info> [1572485791.7311] device (p2p-dev-wlp0s29f7u8): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Oct 30 21:37:15 Buffalo NetworkManager[310]: <info> [1572485835.4733] hostname: hostname changed from (none) to "Buffalo"
Oct 30 21:37:15 Buffalo NetworkManager[310]: <info> [1572485835.4770] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1d.7/usb1/1-8/1-8:1.0/ieee80211/phy0/rfkill0) (driver rtl8192cu)
Oct 30 21:37:18 Buffalo NetworkManager[310]: <info> [1572485838.3494] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 21:37:18 Buffalo NetworkManager[310]: <info> [1572485838.4049] device (wlp0s29f7u8): driver supports Access Point (AP) mode
Oct 30 21:37:18 Buffalo NetworkManager[310]: <info> [1572485838.4062] manager: (wlp0s29f7u8): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Oct 30 21:37:18 Buffalo NetworkManager[310]: <info> [1572485838.4092] device (wlp0s29f7u8): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 21:37:18 Buffalo NetworkManager[310]: <info> [1572485838.9942] device (wlp0s29f7u8): set-hw-addr: set MAC address to FA:5D:C9:36:71:89 (scanning)
Oct 30 21:37:20 Buffalo NetworkManager[310]: <info> [1572485840.6621] device (wlp0s29f7u8): supplicant interface state: init -> starting
Oct 30 21:37:21 Buffalo NetworkManager[310]: <info> [1572485841.0418] sup-iface[0x56230aaf9130,wlp0s29f7u8]: supports 4 scan SSIDs
Oct 30 21:37:21 Buffalo NetworkManager[310]: <info> [1572485841.0443] device (wlp0s29f7u8): supplicant interface state: starting -> ready
Oct 30 21:37:21 Buffalo NetworkManager[310]: <info> [1572485841.0445] Wi-Fi P2P device controlled by interface wlp0s29f7u8 created
Oct 30 21:37:21 Buffalo NetworkManager[310]: <info> [1572485841.0452] manager: (p2p-dev-wlp0s29f7u8): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
Oct 30 21:37:21 Buffalo NetworkManager[310]: <info> [1572485841.0463] device (p2p-dev-wlp0s29f7u8): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 21:37:21 Buffalo NetworkManager[310]: <info> [1572485841.0485] device (p2p-dev-wlp0s29f7u8): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:21 Buffalo NetworkManager[310]: <info> [1572485841.0519] device (wlp0s29f7u8): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 30 21:37:21 Buffalo NetworkManager[310]: <warn> [1572485841.0576] sup-iface: failed to cancel p2p connect: P2P cancel failed
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.1220] device (wlp0s29f7u8): Activation: starting connection 'Auto Greenhouse' (ec7c6435-1780-44c9-8a3e-09e14b3f3084)
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.1225] device (wlp0s29f7u8): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.1539] device (wlp0s29f7u8): set-hw-addr: reset MAC address to C4:3D:C7:7F:1D:F8 (preserve)
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7319] device (wlp0s29f7u8): supplicant interface state: ready -> disabled
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7320] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: ready -> disabled
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7323] device (wlp0s29f7u8): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7332] device (wlp0s29f7u8): Activation: (wifi) access point 'Auto Greenhouse' has security, but secrets are required.
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7332] device (wlp0s29f7u8): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7384] sup-iface[0x56230aaf9130,wlp0s29f7u8]: wps: type pbc start...
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7464] device (wlp0s29f7u8): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7483] device (wlp0s29f7u8): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7493] device (wlp0s29f7u8): Activation: (wifi) connection 'Auto Greenhouse' has security, and secrets exist. No new secrets needed.
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7604] device (wlp0s29f7u8): supplicant interface state: disabled -> inactive
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7604] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: disabled -> inactive
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7920] device (wlp0s29f7u8): supplicant interface state: inactive -> scanning
Oct 30 21:37:22 Buffalo NetworkManager[310]: <info> [1572485842.7921] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: inactive -> scanning
Oct 30 21:37:23 Buffalo NetworkManager[310]: <info> [1572485843.8238] device (wlp0s29f7u8): supplicant interface state: scanning -> authenticating
Oct 30 21:37:23 Buffalo NetworkManager[310]: <info> [1572485843.8239] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: scanning -> authenticating
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.0320] device (wlp0s29f7u8): supplicant interface state: authenticating -> associating
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.0321] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: authenticating -> associating
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.2008] device (wlp0s29f7u8): supplicant interface state: associating -> associated
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.2008] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: associating -> associated
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.2182] device (wlp0s29f7u8): supplicant interface state: associated -> 4-way handshake
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.2183] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: associated -> 4-way handshake
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.3386] device (wlp0s29f7u8): supplicant interface state: 4-way handshake -> completed
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.3387] device (wlp0s29f7u8): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Greenhouse"
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.3388] device (p2p-dev-wlp0s29f7u8): supplicant management interface state: 4-way handshake -> completed
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.3393] device (wlp0s29f7u8): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:24 Buffalo NetworkManager[310]: <info> [1572485844.3427] dhcp4 (wlp0s29f7u8): activation: beginning transaction (timeout in 45 seconds)
Oct 30 21:37:27 Buffalo NetworkManager[310]: <info> [1572485847.5374] dhcp4 (wlp0s29f7u8): state changed unknown -> bound
Oct 30 21:37:27 Buffalo NetworkManager[310]: <info> [1572485847.5412] device (wlp0s29f7u8): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:27 Buffalo NetworkManager[310]: <info> [1572485847.5750] device (wlp0s29f7u8): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:27 Buffalo NetworkManager[310]: <info> [1572485847.5773] device (wlp0s29f7u8): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oct 30 21:37:27 Buffalo NetworkManager[310]: <info> [1572485847.5875] policy: set 'Auto Greenhouse' (wlp0s29f7u8) as default for IPv4 routing and DNS
Oct 30 21:37:27 Buffalo NetworkManager[310]: <info> [1572485847.6260] device (wlp0s29f7u8): Activation: successful, device activated.
Oct 30 21:47:56 Buffalo NetworkManager[310]: <info> [1572486476.7448] dhcp4 (wlp0s29f7u8): canceled DHCP transaction
Oct 30 21:47:56 Buffalo NetworkManager[310]: <info> [1572486476.7448] dhcp4 (wlp0s29f7u8): state changed bound -> done
Oct 30 21:47:56 Buffalo NetworkManager[310]: <info> [1572486476.7449] device (wlp0s29f7u8): DHCPv4: 480 seconds grace period started
Oct 30 21:47:56 Buffalo NetworkManager[310]: <info> [1572486476.7476] device (p2p-dev-wlp0s29f7u8): state change: disconnected -> unmanaged (reason 'unmanaged', sys-iface-state: 'managed')
Oct 30 21:48:42 Buffalo NetworkManager[298]: <info> [1572486522.7818] hostname: hostname changed from (none) to "Buffalo"
Oct 30 21:48:45 Buffalo NetworkManager[298]: <info> [1572486525.5434] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 21:55:23 Buffalo NetworkManager[1572]: <info> [1572486923.0038] hostname: hostname changed from (none) to "Buffalo"
Oct 30 21:55:23 Buffalo NetworkManager[1572]: <info> [1572486923.0597] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 30 22:03:40 Buffalo NetworkManager[292]: <info> [1572487420.7856] hostname: hostname changed from (none) to "Buffalo"
Oct 30 22:03:43 Buffalo NetworkManager[292]: <info> [1572487423.7571] device (enp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
