I'm running Manjaro with Cinnamon on a laptop with a 4k display and have hooked up an external monitor with a lower resolution. As a result, everything looks way bigger on the external monitor. Is there any way to alleviate this in a simple way? (by 'simple' I mean: I've found some solutions that involved defining special commands to launch applications in a way that looks good only on the external monitor, which is not an option for me).
As i understand it, XORG is setting a single "Screen0", a single "Device0" and the monitors will abide that even if there is a metamodes
option there. Probably you can tweak and have Screen0 (for one monitor) and Screen1 (for the TV), but better description is here:
https://wiki.archlinux.org/index.php/Multihead
Please describe what is the expected result, in view and in simplicity.
It would help if you gave more objective info about your owned hardware.
When you connect the external monitor, issue these commands in terminal and post them here (in code blocks)
mhwd -li
inxi -SGxxz
cat /etc/X11/xorg.conf.d/*.conf
xrandr
[ahura@xps ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
[ahura@xps ~]$ inxi -SGxxz
System: Host: xps Kernel: 4.17.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.1.0 Desktop: Cinnamon 3.8.3
dm: lightdm Distro: Manjaro Linux 17.1.10 Hakoila
Graphics: Card-1: Intel UHD Graphics 620 driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Display: x11 server: X.Org 1.19.6 driver: intel unloaded: fbdev,modesetting,vesa
resolution: 3840x2160~60Hz, 1920x1200~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2) v: 4.5 Mesa 18.0.4 compat-v: 3.0
direct render: Yes
[ahura@xps ~]$ cat /etc/X11/xorg.conf.d/*.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
Option "XkbModel" "pc105"
EndSection
[ahura@xps ~]$ xrandr
Screen 0: minimum 8 x 8, current 5040 x 2160, maximum 32767 x 32767
eDP1 connected primary 3840x2160+0+0 (normal left inverted right x axis y axis) 290mm x 170mm
3840x2160 60.00*+ 59.97 48.00
3200x1800 59.96 60.00 59.94
2880x1620 60.00 59.96 59.97
2560x1600 59.99 59.97
2560x1440 59.96 60.00 59.95
2048x1536 60.00
1920x1440 60.00
1856x1392 60.01
1792x1344 60.01
2048x1152 60.00 59.90 59.91
1920x1200 59.88 59.95
1920x1080 59.96 60.00 59.93
1600x1200 60.00
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 60.00 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1368x768 60.00 59.88 59.85
1280x800 59.81 59.91
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
640x360 59.84 59.32 60.00
DP1 disconnected (normal left inverted right x axis y axis)
DP2 connected 1200x1920+3840+0 left (normal left inverted right x axis y axis) 520mm x 320mm
1920x1200 59.95*+
1920x1080 60.00
1600x1200 60.00
1680x1050 59.88
1280x1024 60.02
1280x960 60.00
1024x768 60.00
800x600 60.32
640x480 59.94
720x400 70.08
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
Nice report. Now go ahead with the rest. What do you want to achieve? What use?
I'm not sure how to put it differently than in the original post. Right now, if I drag a window from my laptop's monitor to the external monitor, the size of the window and everything in it doubles. I would like things to be the same size on both monitors.
If I set the resolution on both monitors to HD, things are the same size on both, but I'd like the laptop's monitor to be in 4k without the size difference.
@bogdancovaciu sorry if I'm missing something but I only see information in there on using specialized launch commands for differene monitors, and:
I was making sure on what special commands you refer too as "not an option" ... As described could mean some, a few more, or all of them ...
Now, why do you think there where just proposals that involved scripts or even vnc, and no proper solution for your case?
Maybe you can add the scaling factor to xrandr for each monitor
xrandr --output eDP1 --scale 1x1 --pos 3840x0 ;
xrandr --output DP2 --scale 2x2 --mode 1920x1080 --fb 7680x2160 --pos 0x0
maybe you have to add to your .Xresources
Xft.dpi: 185
Let us know what you have tried so we don't repeat or advice something you already tried ...
I haven't tried anything thus far, as I haven't found any solution that fit my needs.
Entering the suggested commands had the effect that on my external monitor (the low-resolution one) that only about one fourth of it was used for display, i.e. the main part of the monitor went black and only a corner of it displayed a shrunk-down version of what it showed before.
Adding Xft.dpi: 185 to ~/.Xresources and rebooting didn't change anything.
If you install arandr
, you can make better settings for xrandr
, maybe there is something missing in that config.
