Screen freezes after logging in from screen lock
This has been going on for a few months. I can hit ctl+Alt F1/2/3 and get a terminal and things respond normally, in the terminal, whilst the lightdm session remains frozen. The time varies.
After leaving the machine overnight it freezes for a few minutes. During the day it freezes for a few seconds to 10's of seconds depending on how long it is left.
I have upgraded kernal a few times during the period and and there was no effect.
I have taken journalctl dumps at the time, but nothing is being logged to journalctl while it is frozen.
inxi dump of my system - it is just this system my other 4 systems do not have this problem.
inxi --full --verbosity=7 --filter --no-host
Kernel: 4.19.126-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Desktop System: ASUS product: All Series v: N/A serial:
Mobo: ASUSTeK model: H81M-K v: Rev X.0x serial:
UEFI: American Megatrends v: 0304 date: 08/23/2013
RAM: total: 15.54 GiB used: 10.27 GiB (66.1%)
RAM Report:
Topology: Quad Core model: Intel Core i7-4770 bits: 64 type: MT MCP
arch: Haswell rev: 3 L2 cache: 8192 KiB bogomips: 54397
Speed: 1982 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 1550 2: 1656
3: 1726 4: 1707 5: 1652 6: 1828 7: 1535 8: 1654
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0412
Device-2: AMD Cedar [Radeon HD 5000/6000/7350/8350 Series]
vendor: Micro-Star MSI driver: radeon v: kernel bus ID: 01:00.0
chip ID: 1002:68f9
Display: x11 server: X.Org 1.20.8 driver: ati,intel,radeon
unloaded: modesetting alternate: fbdev,vesa
resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: AMD CEDAR (DRM 2.50.0 / 4.19.126-1-MANJARO LLVM 10.0.0)
v: 3.3 Mesa 20.0.7 compat-v: 3.1 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 1002:aa68
Device-3: C-Media Blue Snowball type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 2-1:2 chip ID: 0d8c:0005
serial:
Sound Server: ALSA v: k4.19.126-1-MANJARO
vendor: ASUSTeK driver: r8168 v: 8.048.03-NAPI port: d000 bus ID: 03:00.0
chip ID: 10ec:8168
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: global
IP v6: type: noprefixroute scope: link
WAN IP:
Local Storage: total: 1.14 TiB used: 750.64 GiB (64.2%)
ID-1: /dev/sda vendor: Intel model: SSDSC2CW240A3 size: 223.57 GiB
speed: 6.0 Gb/s serial: rev: 400i scheme: GPT
ID-2: /dev/sdb vendor: Western Digital model: WD10EFRX-68PJCN0
size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm serial:
rev: 1A01 scheme: GPT
ID-3: /dev/sdc type: USB vendor: SanDisk model: Cruzer Glide
size: 14.91 GiB serial: rev: 1.00 scheme: MBR
ID-1: / size: 201.94 GiB used: 83.27 GiB (41.2%) fs: ext4 dev: /dev/sda2
label: N/A uuid: 1b99541c-5d04-4daa-9057-9e6fcc4f255c
ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat
dev: /dev/sda1 label: N/A uuid: DFB4-41F9
ID-3: /mnt/data size: 915.89 GiB used: 661.46 GiB (72.2%) fs: ext4
dev: /dev/sdb1 label: N/A uuid: 65dab148-4bb0-45f2-94a9-e6f4d43841ee
ID-4: swap-1 size: 17.09 GiB used: 5.90 GiB (34.5%) fs: swap
dev: /dev/sda3 label: N/A uuid: 3b7b86d5-17e1-4965-9529-97fccb6cf412
ID-1: /dev/sdc1 size: 14.91 GiB fs: vfat label: ESD-USB uuid: 14D0-7BF3
Hub: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Hub: 1-1:2 info: Intel ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:8008
Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0
Device-1: 2-1:2 info: C-Media Blue Snowball type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s chip ID: 0d8c:0005 serial:
Device-2: 2-2:3 info: Chicony USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
chip ID: 04f2:0939
Device-3: 2-3:4 info: Microsoft Natural Ergonomic Keyboard 4000 V1.0
type: Keyboard,HID driver: microsoft,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s chip ID: 045e:00db
Device-4: 2-10:5 info: SanDisk Cruzer Glide type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
chip ID: 0781:5575 serial:
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 3-1:2 info: Intel ports: 6 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:8000
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: radeon temp: 56 C
Fan Speeds (RPM): cpu: 0
Processes: 246 Uptime: 27d 1h 52m Init: systemd v: 245 Compilers:
gcc: 10.1.0 Shell: bash v: 5.0.17 running in: xfce4-terminal inxi: 3.0.37
More info - There is nothing logged in journalctl whilst the screen is frozen.
This morning it was frozen for 7 minutes, and I dumped the journalctl to disk after I logged into a virtual terminal and then again when the lightdm session started working again. Nothing was logged to journalctl for the entire 7 minutes.
Jul 16 07:39:24 ronald-pc lightdm[803313]: gkr-pam: unable to locate daemon control file
Jul 16 07:39:24 ronald-pc kernel: audit: type=1100 audit(1594881564.708:4355): pid=803313 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_tally2,pam_shells,
pam_unix,pam_permit,pam_gnome_keyring acct="rjd" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 16 07:39:24 ronald-pc kernel: audit: type=1101 audit(1594881564.708:4356): pid=803313 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_
unix,pam_permit,pam_time acct="rjd" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 16 07:39:24 ronald-pc audit[803313]: USER_AUTH pid=803313 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnom
Jul 16 07:39:24 ronald-pc audit[803313]: USER_ACCT pid=803313 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acc
Jul 16 07:39:24 ronald-pc lightdm[803313]: gkr-pam: stashed password to try later in open session
Jul 16 07:39:24 ronald-pc audit[803313]: CRED_REFR pid=803313 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyri
Jul 16 07:39:24 ronald-pc kernel: audit: type=1110 audit(1594881564.738:4357): pid=803313 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_uni
Jul 16 07:39:25 ronald-pc systemd[1]: Stopping Session c167 of user lightdm.
Jul 16 07:39:25 ronald-pc lightdm[803263]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jul 16 07:39:25 ronald-pc audit[803263]: USER_END pid=803263 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/li
Jul 16 07:39:25 ronald-pc audit[803263]: CRED_DISP pid=803263 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm"
Jul 16 07:39:25 ronald-pc systemd[1]: session-c167.scope: Succeeded.
Jul 16 07:39:25 ronald-pc systemd[1]: Stopped Session c167 of user lightdm.
Jul 16 07:39:25 ronald-pc systemd-logind[625]: Removed session c167.
Jul 16 07:39:25 ronald-pc kernel: audit: type=1106 audit(1594881565.338:4358): pid=803263 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd ac
ct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Jul 16 07:39:25 ronald-pc kernel: audit: type=1104 audit(1594881565.338:4359): pid=803263 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="ligh
Jul 16 07:39:35 ronald-pc systemd[1]: Stopping User Manager for UID 620...
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopped target Main User Target.
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopping Accessibility services bus...
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopping D-Bus User Message Bus...
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopping Virtual filesystem service...
Jul 16 07:39:35 ronald-pc systemd[803267]: at-spi-dbus-bus.service: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopped Accessibility services bus.
Jul 16 07:39:35 ronald-pc systemd[803267]: dbus.service: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopped D-Bus User Message Bus.
Jul 16 07:39:35 ronald-pc systemd[803267]: run-user-620-gvfs.mount: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[1]: run-user-620-gvfs.mount: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[866]: run-user-620-gvfs.mount: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: gvfs-daemon.service: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopped Virtual filesystem service.
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopped target Basic System.
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopped target Paths.
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopped target Sockets.
Jul 16 07:39:35 ronald-pc systemd[803267]: Stopped target Timers.
Jul 16 07:39:35 ronald-pc systemd[803267]: dbus.socket: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Closed D-Bus User Message Bus Socket.
Jul 16 07:39:35 ronald-pc systemd[803267]: dirmngr.socket: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Closed GnuPG network certificate management daemon.
Jul 16 07:39:35 ronald-pc systemd[803267]: gpg-agent-browser.socket: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jul 16 07:39:35 ronald-pc systemd[803267]: gpg-agent-ssh.socket: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jul 16 07:39:35 ronald-pc systemd[803267]: gpg-agent.socket: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Closed GnuPG cryptographic agent and passphrase cache.
Jul 16 07:39:35 ronald-pc systemd[803267]: p11-kit-server.socket: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Closed p11-kit server.
Jul 16 07:39:35 ronald-pc systemd[803267]: pipewire.socket: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Closed Multimedia System.
Jul 16 07:39:35 ronald-pc systemd[803267]: pulseaudio.socket: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Closed Sound System.
Jul 16 07:39:35 ronald-pc systemd[803267]: Reached target Shutdown.
Jul 16 07:39:35 ronald-pc systemd[803267]: systemd-exit.service: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[803267]: Finished Exit the Session.
Jul 16 07:39:35 ronald-pc systemd[803267]: Reached target Exit the Session.
Jul 16 07:39:35 ronald-pc systemd[803268]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[] rhost=[]
Jul 16 07:39:35 ronald-pc systemd[1]: user@620.service: Succeeded.
Jul 16 07:39:35 ronald-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 16 07:39:35 ronald-pc systemd[1]: Stopped User Manager for UID 620.
Jul 16 07:39:35 ronald-pc systemd[1]: Stopping User Runtime Directory /run/user/620...
Jul 16 07:39:35 ronald-pc kernel: audit: type=1131 audit(1594881575.518:4360): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 16 07:39:35 ronald-pc systemd[866]: run-user-620.mount: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[1]: run-user-620.mount: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[1]: user-runtime-dir@620.service: Succeeded.
Jul 16 07:39:35 ronald-pc systemd[1]: Stopped User Runtime Directory /run/user/620.
Jul 16 07:39:35 ronald-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jul 16 07:39:35 ronald-pc systemd[1]: Removed slice User Slice of UID 620.
Jul 16 07:39:35 ronald-pc kernel: audit: type=1131 audit(1594881575.588:4361): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
(END)
Had a look for errors in Xorg.0.log file. Timer evernt3 debounce: lots of errors as follows just showed the start rather than the 85 lines in the current log.
$ cat /var/log/Xorg.0.log | grep EE | wc -l
85
[ 11.929] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 11.929] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 12.283] (II) Initializing extension MIT-SCREEN-SAVER
[162358.486] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-11ms), your system is too slow
[162358.589] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-6ms), your system is too slow
[162600.066] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-6ms), your system is too slow
[162600.066] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-19ms), your system is too slow
[162675.813] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-0ms), your system is too slow
[162710.774] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-26ms), your system is too slow
[162710.901] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-17ms), your system is too slow
[162710.901] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-30ms), your system is too slow
One factor in the length of the delay is the amount of swap usage. I think it is less when there is less swap usage.
I reduced swap with vm.swappiness=10, but did not make this permanent, and after a reboot the freezes got longer and I had about 8 gig swapped. However after the morning freeze the system would be fine for the rest of the day.
So I did not bother clearing the swap.
I cleared the swap, yesterday so this morning there was only 10 meg in swap, and there was still a long delay.
Going upgrade to the 5.4 kernel since this has zswap by default, and have already made the swappines changes permanent going forward.
I am using direct rendering
glxinfo | grep "direct rendering"
direct rendering: Yes
One thing I noticed in the output of glxinfo
There are quite a lot of Slow entries (312) in the caveat column, for both 504 GLX Visuals and 1104 GLXFBConfigs
504 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x022 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x505 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x506 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 16 16 16 16 0 0 Slow
1104 GLXFBConfigs:
0x0b5 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 0 0 0 0 0 0 None
0x0b6 0 tc 0 32 0 r . . 10 10 10 2 . . 0 0 0 16 16 16 16 0 0 Slow
glxinfo |grep Slow | wc -l
312
Now on 5.4 kernel see if the issue is still around tomorrow morning.
5.4 Kernel was a big improvement on memory management for my machine. Now been running for a few days with out going near the 16 gig physical memory limit. I was using swap with the previous kernel.
Had first overnight freeze this morning and it was different in that it only lasted 10 secs and was logged into journalctl.
The following is the journalctl log
Jul 22 04:46:57 ronald-pc lightdm[91651]: gkr-pam: unable to locate daemon control file
Jul 22 04:46:57 ronald-pc audit[91651]: USER_AUTH pid=91651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome>
Jul 22 04:46:57 ronald-pc audit[91651]: USER_ACCT pid=91651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_unix,pam_permit,pam_time acct>
Jul 22 04:46:57 ronald-pc lightdm[91651]: gkr-pam: stashed password to try later in open session
Jul 22 04:46:57 ronald-pc kernel: audit: type=1100 audit(1595389617.248:797): pid=91651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_tally2,pam_shells,p>
Jul 22 04:46:57 ronald-pc kernel: audit: type=1101 audit(1595389617.248:798): pid=91651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_tally2,pam_access,pam_u>
Jul 22 04:46:57 ronald-pc audit[91651]: CRED_REFR pid=91651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix,pam_permit,pam_gnome_keyrin>
Jul 22 04:46:57 ronald-pc kernel: audit: type=1110 audit(1595389617.284:799): pid=91651 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_tally2,pam_shells,pam_unix>
Jul 22 04:46:57 ronald-pc systemd[1]: Stopping Session c33 of user lightdm.
Jul 22 04:46:57 ronald-pc lightdm[91600]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jul 22 04:46:57 ronald-pc audit[91600]: USER_END pid=91600 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lig>
Jul 22 04:46:57 ronald-pc audit[91600]: CRED_DISP pid=91600 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" h>
Jul 22 04:46:57 ronald-pc systemd[1]: session-c33.scope: Succeeded.
Jul 22 04:46:57 ronald-pc systemd[1]: Stopped Session c33 of user lightdm.
Jul 22 04:46:57 ronald-pc kernel: audit: type=1106 audit(1595389617.571:800): pid=91600 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acc>
Jul 22 04:46:57 ronald-pc kernel: audit: type=1104 audit(1595389617.571:801): pid=91600 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="light>
Jul 22 04:46:57 ronald-pc systemd-logind[518]: Removed session c33.
Jul 22 04:47:07 ronald-pc systemd[1]: Stopping User Manager for UID 620...
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopped target Main User Target.
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopping Accessibility services bus...
Jul 22 04:47:07 ronald-pc gvfsd[91632]: A connection to the bus can't be made
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopping D-Bus User Message Bus...
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopping Virtual filesystem service...
Jul 22 04:47:07 ronald-pc systemd[91604]: dbus.service: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopped D-Bus User Message Bus.
Jul 22 04:47:07 ronald-pc systemd[91604]: at-spi-dbus-bus.service: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopped Accessibility services bus.
Jul 22 04:47:07 ronald-pc systemd[91604]: run-user-620-gvfs.mount: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[1]: run-user-620-gvfs.mount: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[934]: run-user-620-gvfs.mount: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: gvfs-daemon.service: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopped Virtual filesystem service.
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopped target Basic System.
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopped target Paths.
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopped target Sockets.
Jul 22 04:47:07 ronald-pc systemd[91604]: Stopped target Timers.
Jul 22 04:47:07 ronald-pc systemd[91604]: dbus.socket: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Closed D-Bus User Message Bus Socket.
Jul 22 04:47:07 ronald-pc systemd[91604]: dirmngr.socket: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Closed GnuPG network certificate management daemon.
Jul 22 04:47:07 ronald-pc systemd[91604]: gpg-agent-browser.socket: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jul 22 04:47:07 ronald-pc systemd[91604]: gpg-agent-extra.socket: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jul 22 04:47:07 ronald-pc systemd[91604]: gpg-agent-ssh.socket: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jul 22 04:47:07 ronald-pc systemd[91604]: gpg-agent.socket: Succeeded.
Jul 22 04:47:07 ronald-pc systemd[91604]: Closed GnuPG cryptographic agent and passphrase cache.
Looking at my
less Xorg.0.log
Shows a couple of
[291733.169] (EE) client bug: timer event3 debounce: scheduled expiry is in the past (-24ms), your system is too slow
[291733.169] (EE) client bug: timer event3 debounce short: scheduled expiry is in the past (-37ms), your system is too slow
Which I think may have been when I tried using some sites that hogged memory and got the system into swap. It was not when I logged in this morning.
The log for this morning was as follows and takes about 1/10th of a second
[302319.332] (II) AIGLX: Suspending AIGLX clients for VT switch
[324390.813] (II) AIGLX: Resuming AIGLX clients after VT switch
[324390.844] (II) RADEON(0): EDID vendor "BNQ", prod id 30891
[324390.845] (II) RADEON(0): Using hsync ranges from config file
[324390.845] (II) RADEON(0): Using vrefresh ranges from config file
[324390.845] (II) RADEON(0): Printing DDC gathered Modelines:
[324390.845] (II) RADEON(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[324390.845] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[324390.845] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[324390.845] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[324390.845] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[324390.845] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[324390.845] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[324390.845] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[324390.845] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[324390.845] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[324390.845] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[324390.845] (II) RADEON(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[324390.845] (II) RADEON(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[324390.845] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[324390.845] (II) RADEON(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[324390.845] (II) RADEON(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[324390.881] (II) event1 - Power Button: is tagged by udev as: Keyboard
[324390.881] (II) event1 - Power Button: device is a keyboard
[324390.884] (II) event2 - Video Bus: is tagged by udev as: Keyboard
[324390.884] (II) event2 - Video Bus: device is a keyboard
[324390.886] (II) event0 - Power Button: is tagged by udev as: Keyboard
[324390.886] (II) event0 - Power Button: device is a keyboard
[324390.887] (II) event5 - Eee PC WMI hotkeys: is tagged by udev as: Keyboard
[324390.887] (II) event5 - Eee PC WMI hotkeys: device is a keyboard
[324390.888] (II) event12 - Microsoft Natural® Ergonomic Keyboard 4000: is tagged by udev as: Keyboard
[324390.888] (II) event12 - Microsoft Natural® Ergonomic Keyboard 4000: device is a keyboard
[324390.889] (II) event13 - Microsoft Natural® Ergonomic Keyboard 4000: is tagged by udev as: Keyboard
[324390.890] (II) event13 - Microsoft Natural® Ergonomic Keyboard 4000: device is a keyboard
[324390.891] (II) event3 - USB Optical Mouse: is tagged by udev as: Mouse
[324390.891] (II) event3 - USB Optical Mouse: device is a pointer
G
Lightdm log again 0.34 sec
[+302311.15s] DEBUG: Prompt greeter with 1 message(s)
[+324381.00s] DEBUG: Continue authentication
[+324381.01s] DEBUG: Session pid=91651: Authentication complete with return value 0: Success
[+324381.01s] DEBUG: Authenticate result for user rjd: Success
[+324381.01s] DEBUG: User rjd authorized
[+324381.01s] DEBUG: Greeter sets language en_GB.utf8
[+324381.04s] DEBUG: Greeter requests session xfce
[+324381.04s] DEBUG: Seat seat0: Returning to existing user session rjd
[+324381.04s] DEBUG: Unlocking login1 session 2
[+324381.04s] DEBUG: Activating VT 7
[+324381.29s] DEBUG: Seat seat0: Stopping greeter
[+324381.29s] DEBUG: Terminating login1 session c33
[+324381.30s] DEBUG: Session pid=91600: Sending SIGTERM
[+324381.30s] DEBUG: Activating login1 session 2
[+324381.31s] DEBUG: Session pid=91651: Exited with return value 0
[+324381.31s] DEBUG: Seat seat0: Session stopped
[+324381.31s] DEBUG: Seat seat0 changes active session to 2
[+324381.31s] DEBUG: Session 2 is already active
[+324381.33s] DEBUG: Greeter closed communication channel
[+324381.33s] DEBUG: Session pid=91600: Exited with return value 0
[+324381.33s] DEBUG: Seat seat0: Session stopped
[+324381.33s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+324381.33s] DEBUG: Sending signal 15 to process 91586
[+324381.34s] DEBUG: Process 91586 exited with return value 0
[+324381.34s] DEBUG: XServer 1: X server stopped
[+324381.34s] DEBUG: Releasing VT 8
[+324381.34s] DEBUG: XServer 1: Removing X server authority /run/lightdm/root/:1
[+324381.34s] DEBUG: Seat seat0: Display server stopped
less Xorg.1.log - again l about 0.3 sec similar time to Xorg.0.log
[302319.906] (**) Option "xkb_layout" "gb"
[324390.563] (II) event1 - Power Button: device removed
[324390.581] (II) event2 - Video Bus: device removed
[324390.621] (II) event0 - Power Button: device removed
[324390.647] (II) event3 - USB Optical Mouse: device removed
[324390.707] (II) event12 - Microsoft Natural® Ergonomic Keyboard 4000: device removed
[324390.728] (II) event5 - Eee PC WMI hotkeys: device removed
[324390.789] (II) event13 - Microsoft Natural® Ergonomic Keyboard 4000: device removed
[324390.811] (II) AIGLX: Suspending AIGLX clients for VT switch
[324390.851] (II) UnloadModule: "libinput"
[324390.852] (II) Server terminated successfully (0). Closing log file.
Looks like moving to 5.4 kernel has solved the problem. The main difference is that system is using a lot less memory so there is still a large amount of free memory.
I run 2 screens and 4 workspaces, and usually have a dev environment in one workspace, an office environment in a couple of others and a primary environment with email, slack and other chats. and office apps running.
Spoke too soon.
It has continued freezing after being left over night. I tried killing off firefox at the end of the day which freed up about 8gig of memory, so there was plenty of free memory overnight and no swap usage, and it still frooze for about 5 minutes in the morning.
This morning the freeze looks to be perminent since it has been frozen for over 25 minutes. Just went back to it to check since I am posting on another machine and it has unfrozen after 30 minutes.
I am going to upgrade the kernel again to the same version as my other machines. So it will go from 5.4 to 5.6 going forward.
Has carried on with 5.6 kernel. Froze for 7 minutes this morning.
The only thing that is logged in journalctl during the freeze is my logging into multiple tty's as I use all the virtual terminals to look at the logs and sudo iotop etc.
Apart from the frozen desktop session everything else works fine.
Will try and tidy up all my work and then reboot into kernel 5.7 to see if it makes a difference. It does work fine for a couple of days after a reboot and then gets progressively worse.
