Scrot Select leaving ghost lines on screenshots in i3wm
I am using i3wm and when I am taking screenshots with scrot -s I am getting some ghost selection lines, which make the saved screenshot not presentable. Like the one below:
2020-08-05-114259_1035x1179_scrot
Is there a way to fix this problem with scrot? Anyone else having the same issue?
My machine:
# inxi -Fxz        11:50:48 
System:    Host: xps Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           Desktop: i3 4.18.1 Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: XPS 15 9560 v: N/A serial: <filter>
           Mobo: Dell model: 05FFDN v: A00 serial: <filter> UEFI: Dell v: 1.18.0
           date: 11/17/2019
Battery:   ID-1: BAT0 charge: 17.7 Wh condition: 66.6/97.0 Wh (69%) model: SMP DELL GPM0365
           status: Discharging
CPU:       Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
           arch: Kaby Lake rev: 9 L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44817
           Speed: 800 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 800 2: 800 3: 801
           4: 800 5: 800 6: 801 7: 800 8: 800
Graphics:  Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
           bus ID: 00:02.0
           Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: nvidia
           v: 418.113 bus ID: 01:00.0
           Display: x11 server: X.Org 1.20.8 driver: modesetting resolution: 3840x2160~60Hz
           OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.3
           direct render: Yes
Audio:     Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3
           Sound Server: ALSA v: k5.7.9-1-MANJARO
Network:   Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
           vendor: Bigfoot Networks driver: ath10k_pci v: kernel port: e000 bus ID: 02:00.0
           Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-4:3
           IF-ID-1: virbr0 state: down mac: <filter>
           IF-ID-2: virbr0-nic state: down mac: <filter>
Drives:    Local Storage: total: 476.94 GiB used: 144.71 GiB (30.3%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: PM981 NVMe 512GB size: 476.94 GiB
Partition: ID-1: / size: 58.59 GiB used: 38.00 GiB (64.9%) fs: f2fs dev: /dev/nvme0n1p10
           ID-2: /home size: 120.59 GiB used: 106.71 GiB (88.5%) fs: f2fs
           dev: /dev/nvme0n1p11
           ID-3: swap-1 size: 15.63 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p8
Sensors:   System Temperatures: cpu: 44.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 0 fan-2: 0
Info:      Processes: 274 Uptime: 18h 16m Memory: 15.48 GiB used: 2.69 GiB (17.4%)
           Init: systemd Compilers: gcc: 10.1.0 Shell: zsh v: 5.8 inxi: 3.0.37
I read the Arch Wiki entry for screenshots and saw that they are recommending using different screenshot utility, I tried escrotum-git and it seems almost the same like scrot but more reliable when using to take a screenshot of a selection region.
