Secure hard disk erasure
Hey, everybody,
I want to safely delete files from my hard drive.
Is there a graphical software that allows erasing like eraser under Windows with a method like dod 5220.22?
Thank you in advance!
P.S: for the command line method, I know (like shred) but I'm a slacker.
Tried this yet?
Please be aware that for HDDs any secure erase utility will do, but for SSDs you need your manufacturer's secure erase utility and as you're a slacker, you didn't give us any specifics, :grin: so we can't neither, but @jillswift's methodology will serve you best!
By any measure the most efficient way is shred and if a PnC exist - it will most likely be a frontend to shred.
Note: Disconnect any hard drives from your PC that you do not want to erase. DBAN will delete absolutely everything that is connected to it.
DBAN still exists on SourceForge, but dban.org now links to a commercial page blancco.com (And why I didn't link to it)
:sob:
Thank you very much but I would like to shred my files directly into Manjaro. It's simpler and faster.
Too bad I can't find a simple and intuitive GUI.
DBAN is really simple to use. Just burn it to a bootable media (USB stick), boot from it and type "autonuke". Everything on that computer will be wiped clean. Then plug in your Manjaro live ISO, reboot and install.
Use a honkin huge electro magnet. :grinning:
There is a plugin for Thunar - a wrapper for shred
Build and install from AUR
pamac build thunar-secure-delete
Install the dependencies
sudo pacman -S xdialog libnotify
Download two files from github repo
  • srm_guified.sh
Save the files a convenient place in your home e.g. ~/.local/thunar-srm.
Open Thunar -> Edit -> Configure custom actions... -> Add
Basic
  • Name: Secure Delete
  • Description: Securely Wipe Files Before Deletion
  • Command: /home/$USER/.local/thunar-srm/srm_guified.sh %F
  • Icon: Select the icon saved in above location
Appearance Conditions
  • File Pattern: *
  • Tick all boxes
Click OK
Navigate to a file -> rightclick -> Secure Delete
That doesn't work any more for SSDs and OP never specified a specific piece of hardware...
Though a ball wrecker still works on both SSDs and HDDs! :innocent:
Thank you very much, it's working perfectly. This is what I was looking for.
