Should you move your home-directory to a new partition on the same drive?
I was just wondering if it is a good idea to create a new partition on my 1 TB SSD (the only drive in my PC) for my /home-direcory? If yes, how big should the partition for the root directory ("/") and how big should the home partition ("~") be?
if possible install in UEFI ( see and check all options in Bios )
  • /boot/efi in fat32 with flag boot & esp (33Mo)
  • / for 50Go
  • /home for the rest ( 949Go )
Is there a way to make these changes while I am in my normal Manjaro (booted from SSD) or do I have to make these changes from a USB drive? Because I can't unmount the partition I booted from.
I don't know if it helps, but here is the output of lsblk:
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sr0          11:0    1  1024M  0 rom
nvme0n1     259:0    0 931,5G  0 disk
├─nvme0n1p1 259:1    0   300M  0 part /boot/efi
├─nvme0n1p2 259:2    0 914,1G  0 part /run/timeshift/backup
└─nvme0n1p3 259:3    0  17,1G  0 part [SWAP]
can boot on USB iso manjaro
open a terminal and a browser on this topic
and returns
inxi -Fxxxza
sudo parted -l
  Host: manjaro-gnome Kernel: 5.6.15-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 10.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
  driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  misobasedir=manjaro misolabel=MANJARO_GNOME_2003 quiet
  systemd.show_status=1 apparmor=1 security=apparmor
  Desktop: Gnome 3.36.2 wm: gnome-shell dm: GDM 3.34.1 Distro: Manjaro Linux
  Type: Desktop Mobo: ASRock model: B450 Pro4 serial: <filter>
  UEFI: American Megatrends v: P3.90 date: 12/12/2019
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Topology: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen
  family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701013
  L2 cache: 3072 KiB
  bogomips: 86279
  Speed: 2387 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
  1: 2794 2: 2794 3: 2192 4: 2196 5: 1863 6: 2194 7: 2196 8: 2192 9: 2794
  10: 2786 11: 1862 12: 2191
  conditional, RSB filling
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
  vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 0a:00.0
  chip ID: 1002:67df
  Display: x11 server: X.org 1.20.8 driver: amdgpu compositor: gnome-shell
  resolution: <xdpyinfo missing>
  OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.36.0
  5.6.15-1-MANJARO LLVM 10.0.0)
  v: 4.6 Mesa 20.0.7 direct render: Yes
  Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus ID: 0a:00.1
  chip ID: 1002:aaf0
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
  driver: snd_hda_intel v: kernel bus ID: 0c:00.4 chip ID: 1022:1487
  Device-3: Focusrite-Novation Scarlett Solo USB type: USB
  driver: snd-usb-audio bus ID: 3-1:2 chip ID: 1235:8205
  Sound Server: ALSA v: k5.6.15-1-MANJARO
  Device-1: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
  vendor: D-Link System driver: rtl8821ae v: kernel port: e000
  bus ID: 06:00.0 chip ID: 10ec:8812
  IF: wlp6s0 state: up mac: <filter>
  vendor: ASRock driver: r8169 v: kernel port: c000 bus ID: 09:00.0
  chip ID: 10ec:8168
  IF: enp9s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 946.36 GiB used: 112.0 MiB (0.0%)
  ID-1: /dev/nvme0n1 vendor: Crucial model: CT1000P1SSD8 size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: P3CR013 scheme: GPT
  ID-2: /dev/sde type: USB vendor: Innostor model: Innostor size: 14.84 GiB
  block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00
  scheme: MBR
  ID-1: / raw size: N/A size: 11.68 GiB used: 112.0 MiB (0.9%) fs: overlay
  source: ERR-102
  System Temperatures: cpu: 51.5 C mobo: N/A gpu: amdgpu temp: 36 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 906
  Processes: 334 Uptime: 3m Memory: 15.57 GiB used: 1.28 GiB (8.2%)
  Init: systemd v: 245 Compilers: gcc: N/A Shell: zsh v: 5.8
  running in: gnome-terminal inxi: 3.0.37
Model: Innostor Innostor (scsi)
Disk /dev/sde: 15.9GB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 2      2773MB  2777MB  4194kB  primary               esp
Model: CT1000P1SSD8 (nvme)
Disk /dev/nvme0n1: 1000GB
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name  Flags
 1      2097kB  317MB   315MB   fat32                 boot, esp
 2      317MB   982GB   981GB   ext4
 3      982GB   1000GB  18.4GB  linux-swap(v1)        swap
you can use before Gparted ,
and then install with manual option
redo installation
1 reduce to 33Mo , not forget to add flag boot&esp when add mountpoint
2 / with 50go ext4
3/home the rest
4 no need for swap , you have enough memory
This is fine as long as you are not dual booting in the future. If you want to be prepared for that better consider 100 MiB, if a dual boot with Windoze could be a future option I would recommend 260 MiB.
https://wiki.manjaro.org/index.php?title=UEFI_-_Install_Guide
