Show total network usage in ksysguard
Gnome-system-monitor have an option that shows total network usage. I can't find this option in ksysguard. Is this option exists in ksysguard?
Thanks in advance
You can create new tabs. If your system has the sensors, you can create a display for it. :wink:
Another question plz, how to display custom names for sensors like this image
Right-click the sensor display and choose "Properties". You'll get a dialog with four tabs. You can set a custom name in the first of those tabs, labeled "General". :wink:
I'm not sure if he talk about graphic tittle.. in this case your answer is correct.
or if he talk about the sensors name itself, in this case it's not possible to change the sensors name displayed.
yeah, sensors
sorry for trouble
