Slow shutdown - any help will be much appreciated.
Ever since I've upgraded my PC, Manjaro has been having slow shutdowns. They normally take 2 minutes. I'm a little stuck on what's causing the problem. Any ideas?
Here's the journal log from last shutdown using the command 'journalctl -b -1 | tail -100'
Jan 08 14:27:32 PC-chan systemd[1]: Stopped D-Bus System Message Bus.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target Basic System.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target Slices.
Jan 08 14:27:32 PC-chan systemd[1]: Removed slice User and Session Slice.
Jan 08 14:27:32 PC-chan systemd[1]: Removed slice Virtual Machine and Container Slice.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target Paths.
Jan 08 14:27:32 PC-chan systemd[1]: org.cups.cupsd.path: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped CUPS Scheduler.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target Sockets.
Jan 08 14:27:32 PC-chan systemd[1]: org.cups.cupsd.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed CUPS Scheduler.
Jan 08 14:27:32 PC-chan systemd[1]: snapd.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed Socket activation for snappy daemon.
Jan 08 14:27:32 PC-chan systemd[1]: libvirtd-admin.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed Libvirt admin socket.
Jan 08 14:27:32 PC-chan systemd[1]: avahi-daemon.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Jan 08 14:27:32 PC-chan systemd[1]: virtlockd.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed Virtual machine lock manager socket.
Jan 08 14:27:32 PC-chan systemd[1]: virtlogd.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed Virtual machine log manager socket.
Jan 08 14:27:32 PC-chan systemd[1]: libvirtd-ro.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed Libvirt local read-only socket.
Jan 08 14:27:32 PC-chan systemd[1]: libvirtd.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed Libvirt local socket.
Jan 08 14:27:32 PC-chan systemd[1]: dbus.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed D-Bus System Message Bus Socket.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target System Initialization.
Jan 08 14:27:32 PC-chan systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Jan 08 14:27:32 PC-chan systemd[1]: systemd-binfmt.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Set Up Additional Binary Formats.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Stopping Load/Save Random Seed...
Jan 08 14:27:32 PC-chan systemd[1]: Stopping Network Time Synchronization...
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target Local Encrypted Volumes.
Jan 08 14:27:32 PC-chan systemd[1]: systemd-ask-password-console.path: Succeeded.
Jan 08 14:27:32 PC-chan audit[6481]: SYSTEM_SHUTDOWN pid=6481 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Jan 08 14:27:32 PC-chan systemd[1]: systemd-ask-password-wall.path: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jan 08 14:27:32 PC-chan systemd[1]: systemd-sysctl.service: Succeeded.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Apply Kernel Variables.
Jan 08 14:27:32 PC-chan systemd[1]: systemd-modules-load.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Load Kernel Modules.
Jan 08 14:27:32 PC-chan systemd[1]: systemd-timesyncd.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Network Time Synchronization.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: systemd-random-seed.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Load/Save Random Seed.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: systemd-update-utmp.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Create Volatile Files and Directories.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target Local File Systems.
Jan 08 14:27:32 PC-chan systemd[1]: Unmounting /tmp...
Jan 08 14:27:32 PC-chan systemd[1]: tmp.mount: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Unmounted /tmp.
Jan 08 14:27:32 PC-chan systemd[1]: Reached target Unmount All Filesystems.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target Local File Systems (Pre).
Jan 08 14:27:32 PC-chan systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Jan 08 14:27:32 PC-chan systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Create Static Device Nodes in /dev.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: systemd-remount-fs.service: Succeeded.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Remount Root and Kernel File Systems.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped target Swap.
Jan 08 14:27:32 PC-chan systemd[1]: lvm2-monitor.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Stopping LVM2 metadata daemon...
Jan 08 14:27:32 PC-chan systemd[1]: lvm2-lvmetad.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Stopped LVM2 metadata daemon.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Reached target Shutdown.
Jan 08 14:27:32 PC-chan systemd[1]: Reached target Final Step.
Jan 08 14:27:32 PC-chan systemd[1]: systemd-poweroff.service: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Started Power-Off.
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-poweroff comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-poweroff comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 08 14:27:32 PC-chan systemd[1]: Reached target Power-Off.
Jan 08 14:27:32 PC-chan systemd[1]: lvm2-lvmetad.socket: Succeeded.
Jan 08 14:27:32 PC-chan systemd[1]: Closed LVM2 metadata daemon socket.
Jan 08 14:27:32 PC-chan systemd[1]: Shutting down.
Jan 08 14:27:32 PC-chan kernel: printk: systemd-shutdow: 63 output lines suppressed due to ratelimiting
Jan 08 14:27:32 PC-chan kernel: fbcon: Taking over console
Jan 08 14:27:32 PC-chan systemd-shutdown[1]: Syncing filesystems and block devices.
Jan 08 14:27:32 PC-chan kernel: Console: switching to colour frame buffer device 240x67
Jan 08 14:27:32 PC-chan systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Jan 08 14:27:32 PC-chan haveged[430]: haveged: Stopping due to signal 15
Jan 08 14:27:32 PC-chan haveged[430]: haveged starting up
Jan 08 14:27:32 PC-chan systemd-udevd[5998]: Process '/usr/lib/systemd/systemd-vconsole-setup' terminated by signal TERM.
Jan 08 14:27:32 PC-chan systemd-udevd[5998]: Failed to wait for spawned command '/usr/lib/systemd/systemd-vconsole-setup': Input/output error
Jan 08 14:27:32 PC-chan systemd-journald[433]: Journal stopped
You might want to see/show a bit more than the last 100 lines.
Try this: journalctl -b -1 -n400
The n option defines the last x lines to be shown.
Thanks for suggestion. Here's the whole log from powering down.
Jan 09 01:21:58 PC-chan systemd-logind[766]: System is powering down.
Jan 09 01:21:58 PC-chan systemd[1]: Starting Generate shutdown-ramfs...
Jan 09 01:21:58 PC-chan systemd[1]: Stopping TLP system startup/shutdown...
Jan 09 01:21:58 PC-chan systemd[1]: Removed slice system-systemd\x2dcoredump.slice.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Jan 09 01:21:58 PC-chan systemd[1]: systemd-rfkill.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Jan 09 01:21:58 PC-chan systemd[1]: lvm2-lvmpolld.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Closed LVM2 poll daemon socket.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Disk Manager...
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target Timers.
Jan 09 01:21:58 PC-chan systemd[1]: shadow.timer: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Daily verification of password and group files.
Jan 09 01:21:58 PC-chan systemd[1]: pamac-cleancache.timer: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Monthly clean packages cache.
Jan 09 01:21:58 PC-chan systemd[1]: Removed slice system-getty.slice.
Jan 09 01:21:58 PC-chan systemd[1]: session-2.scope: Killing process 1413 (ssh-agent) with signal SIGTERM.
Jan 09 01:21:58 PC-chan systemd[1]: session-2.scope: Killing process 1486 (tracker-miner-r) with signal SIGTERM.
Jan 09 01:21:58 PC-chan systemd[1]: session-2.scope: Killing process 1489 (tracker-miner-f) with signal SIGTERM.
Jan 09 01:21:58 PC-chan systemd[1]: session-2.scope: Killing process 1511 (agent) with signal SIGTERM.
Jan 09 01:21:58 PC-chan systemd[1]: session-2.scope: Killing process 1546 (applet.py) with signal SIGTERM.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Session 2 of user louie.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounting /mnt/internal...
Jan 09 01:21:58 PC-chan systemd[1]: Unmounting /mnt/ssd_drive...
Jan 09 01:21:58 PC-chan systemd[1]: Unmounting /mnt/M2...
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target Graphical Interface.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Light Display Manager...
Jan 09 01:21:58 PC-chan udisksd[1543]: udisks daemon version 2.8.4 exiting
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Daemon for power management...
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Accounts Service...
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target Sound Card.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping CUPS Scheduler...
Jan 09 01:21:58 PC-chan systemd[1]: logrotate.timer: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Daily rotation of log files.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Session c2 of user lightdm.
Jan 09 01:21:58 PC-chan systemd[1347]: mnt-ssd_drive.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounting /mnt/game...
Jan 09 01:21:58 PC-chan systemd[1]: Unmounting /mnt/external_drive...
Jan 09 01:21:58 PC-chan systemd[1]: pamac-mirrorlist.timer: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Generate mirrorlist weekly.
Jan 09 01:21:58 PC-chan systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Jan 09 01:21:58 PC-chan systemd[1347]: mnt-internal.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: mnt-M2.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: mnt-internal.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: mnt-ssd_drive.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: mnt-external_drive.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: mnt-M2.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: mnt-game.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: mnt-game.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: mnt-external_drive.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: org.cups.cupsd.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped CUPS Scheduler.
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.187:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: accounts-daemon.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Accounts Service.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.187:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: rtkit-daemon.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: udisks2.service: Succeeded.
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.187:114): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Disk Manager.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan lightdm[23676]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.187:115): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: mnt-internal.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /mnt/internal.
Jan 09 01:21:58 PC-chan systemd[1]: mnt-ssd_drive.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /mnt/ssd_drive.
Jan 09 01:21:58 PC-chan systemd[1]: mnt-M2.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /mnt/M2.
Jan 09 01:21:58 PC-chan systemd[1]: mnt-external_drive.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /mnt/external_drive.
Jan 09 01:21:58 PC-chan systemd[1]: session-2.scope: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Session 2 of user louie.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping User Manager for UID 1000...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping Virtual filesystem service - digital camera monitor...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping GnuPG cryptographic agent and passphrase cache...
Jan 09 01:21:58 PC-chan gpg-agent[1416]: SIGTERM received - shutting down ...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping Virtual filesystem service - Apple File Conduit monitor...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping Accessibility services bus...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping Virtual filesystem service...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping Virtual filesystem service - disk device monitor...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped target Main User Target.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping D-Bus User Message Bus...
Jan 09 01:21:58 PC-chan systemd[1347]: Stopping Virtual filesystem metadata service...
Jan 09 01:21:58 PC-chan systemd[1347]: run-user-1000-gvfs.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: run-user-1000-gvfs.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /run/user/1000/gvfs.
Jan 09 01:21:58 PC-chan systemd[1347]: gvfs-mtp-volume-monitor.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Jan 09 01:21:58 PC-chan systemd[1347]: gvfs-metadata.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped Virtual filesystem metadata service.
Jan 09 01:21:58 PC-chan systemd[1347]: gvfs-gphoto2-volume-monitor.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped Virtual filesystem service - digital camera monitor.
Jan 09 01:21:58 PC-chan systemd[23680]: run-user-1000-gvfs.mount: Succeeded.
Jan 09 01:21:58 PC-chan mkinitcpio[23760]: ==> Starting build: none
Jan 09 01:21:58 PC-chan mkinitcpio[23760]: -> Running build hook: [sd-shutdown]
Jan 09 01:21:58 PC-chan systemd-logind[766]: Removed session 2.
Jan 09 01:21:58 PC-chan systemd[1]: session-c2.scope: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Session c2 of user lightdm.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping User Manager for UID 970...
Jan 09 01:21:58 PC-chan systemd[23680]: Stopping Virtual filesystem service...
Jan 09 01:21:58 PC-chan systemd[23680]: Stopping Accessibility services bus...
Jan 09 01:21:58 PC-chan systemd[23680]: Stopped target Main User Target.
Jan 09 01:21:58 PC-chan systemd[23680]: Stopping D-Bus User Message Bus...
Jan 09 01:21:58 PC-chan systemd-logind[766]: Removed session c2.
Jan 09 01:21:58 PC-chan systemd[23680]: at-spi-dbus-bus.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Stopped Accessibility services bus.
Jan 09 01:21:58 PC-chan systemd[1347]: run-user-970-gvfs.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: run-user-970-gvfs.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: gvfs-daemon.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: run-user-970-gvfs.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /run/user/970/gvfs.
Jan 09 01:21:58 PC-chan systemd[23680]: Stopped Virtual filesystem service.
Jan 09 01:21:58 PC-chan systemd[23680]: dbus.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Stopped D-Bus User Message Bus.
Jan 09 01:21:58 PC-chan systemd[23680]: Stopped target Basic System.
Jan 09 01:21:58 PC-chan systemd[23680]: Stopped target Timers.
Jan 09 01:21:58 PC-chan systemd[23680]: Stopped target Sockets.
Jan 09 01:21:58 PC-chan systemd[23680]: p11-kit-server.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed p11-kit server.
Jan 09 01:21:58 PC-chan systemd[23680]: gpg-agent.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: dbus.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 09 01:21:58 PC-chan systemd[23680]: dirmngr.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped D-Bus User Message Bus.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed GnuPG network certificate management daemon.
Jan 09 01:21:58 PC-chan systemd[23680]: pipewire.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed Multimedia System.
Jan 09 01:21:58 PC-chan systemd[23680]: gpg-agent-extra.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 09 01:21:58 PC-chan systemd[1347]: gvfs-udisks2-volume-monitor.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: gpg-agent-browser.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped Virtual filesystem service - disk device monitor.
Jan 09 01:21:58 PC-chan systemd[23680]: gpg-agent-ssh.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 09 01:21:58 PC-chan systemd[23680]: pulseaudio.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: gvfs-afc-volume-monitor.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed Sound System.
Jan 09 01:21:58 PC-chan systemd[23680]: Stopped target Paths.
Jan 09 01:21:58 PC-chan systemd[23680]: dbus.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped Virtual filesystem service - Apple File Conduit monitor.
Jan 09 01:21:58 PC-chan systemd[1347]: gvfs-daemon.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Closed D-Bus User Message Bus Socket.
Jan 09 01:21:58 PC-chan systemd[23680]: Reached target Shutdown.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped Virtual filesystem service.
Jan 09 01:21:58 PC-chan systemd[23680]: systemd-exit.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[23680]: Started Exit the Session.
Jan 09 01:21:58 PC-chan systemd[23680]: Reached target Exit the Session.
Jan 09 01:21:58 PC-chan gpg-agent[1416]: gpg-agent (GnuPG) 2.2.19 stopped
Jan 09 01:21:58 PC-chan systemd[1347]: gpg-agent.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped GnuPG cryptographic agent and passphrase cache.
Jan 09 01:21:58 PC-chan systemd[23681]: pam_unix(systemd-user:session): session closed for user lightdm
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.224:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: user@970.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped User Manager for UID 970.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping User Runtime Directory /run/user/970...
Jan 09 01:21:58 PC-chan systemd[1347]: run-user-970.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: run-user-970.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /run/user/970.
Jan 09 01:21:58 PC-chan systemd[1]: user-runtime-dir@970.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped User Runtime Directory /run/user/970.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Removed slice User Slice of UID 970.
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.230:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@970 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan mkinitcpio[23760]: ==> Build complete.
Jan 09 01:21:58 PC-chan systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Started Generate shutdown-ramfs.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan kernel: audit: type=1130 audit(1578532918.264:118): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.264:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan tlp[23761]: Applying power save settings...done.
Jan 09 01:21:58 PC-chan systemd[1]: tlp.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped TLP system startup/shutdown.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target Multi-User System.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping amdgpu-fancontrol...
Jan 09 01:21:58 PC-chan amdgpu-fancontrol[1745]: Terminated
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Virtualization daemon...
Jan 09 01:21:58 PC-chan amdgpu-fancontrol[1745]: exiting, resetting fan to auto control...
Jan 09 01:21:58 PC-chan amdgpu-fancontrol[1745]: setting fan mode to 2
Jan 09 01:21:58 PC-chan systemd[1]: man-db.timer: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Daily man-db regeneration.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Jan 09 01:21:58 PC-chan systemd[1]: updatedb.timer: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Daily locate database update.
Jan 09 01:21:58 PC-chan avahi-daemon[763]: Got SIGTERM, quitting.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target System Time Synchronized.
Jan 09 01:21:58 PC-chan avahi-daemon[763]: Leaving mDNS multicast group on interface enp9s0.IPv6 with address fd18:d276:acb:f00:85e3:48fb:f9f5:a51f.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target System Time Set.
Jan 09 01:21:58 PC-chan avahi-daemon[763]: Leaving mDNS multicast group on interface enp9s0.IPv4 with address 192.168.1.29.
Jan 09 01:21:58 PC-chan fancontrol[804]: Aborting, restoring fans...
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Start fan control, if configured...
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target Login Prompts.
Jan 09 01:21:58 PC-chan ModemManager[930]: Caught signal, shutting down...
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Modem Manager...
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Periodic Command Scheduler...
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.344:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: amdgpufan.service: Main process exited, code=exited, status=1/FAILURE
Jan 09 01:21:58 PC-chan systemd[1]: amdgpufan.service: Failed with result 'exit-code'.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped amdgpu-fancontrol.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=amdgpufan comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jan 09 01:21:58 PC-chan NetworkManager[767]: [1578532918.3485] modem-manager: ModemManager no longer available
Jan 09 01:21:58 PC-chan ModemManager[930]: ModemManager is shut down
Jan 09 01:21:58 PC-chan kernel: audit: type=1131 audit(1578532918.347:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=amdgpufan comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jan 09 01:21:58 PC-chan fancontrol[804]: Verify fans have returned to full speed
Jan 09 01:21:58 PC-chan systemd[1]: ModemManager.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Modem Manager.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Authorization Manager...
Jan 09 01:21:58 PC-chan systemd[1]: fancontrol.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Start fan control, if configured.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=fancontrol comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Initialize hardware monitoring sensors...
Jan 09 01:21:58 PC-chan systemd[1]: libvirtd.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Virtualization daemon.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=libvirtd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Login Service...
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Virtual Machine and Container Registration Service...
Jan 09 01:21:58 PC-chan systemd[1]: systemd-machined.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Virtual Machine and Container Registration Service.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-machined comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan avahi-daemon[763]: avahi-daemon 0.7 exiting.
Jan 09 01:21:58 PC-chan crond[762]: (CRON) INFO (Shutting down)
Jan 09 01:21:58 PC-chan systemd[1]: polkit.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Authorization Manager.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: cronie.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Periodic Command Scheduler.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: avahi-daemon.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: lm_sensors.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Initialize hardware monitoring sensors.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lm_sensors comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: mnt-game.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /mnt/game.
Jan 09 01:21:58 PC-chan systemd[1347]: at-spi-dbus-bus.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped Accessibility services bus.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped target Basic System.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped target Paths.
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped target Sockets.
Jan 09 01:21:58 PC-chan systemd[1347]: gpg-agent-browser.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Jan 09 01:21:58 PC-chan systemd[1347]: pipewire.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed Multimedia System.
Jan 09 01:21:58 PC-chan systemd[1347]: gpg-agent.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed GnuPG cryptographic agent and passphrase cache.
Jan 09 01:21:58 PC-chan systemd[1347]: pulseaudio.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed Sound System.
Jan 09 01:21:58 PC-chan systemd[1347]: dirmngr.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed GnuPG network certificate management daemon.
Jan 09 01:21:58 PC-chan systemd[1347]: gpg-agent-ssh.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Jan 09 01:21:58 PC-chan systemd[1347]: p11-kit-server.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed p11-kit server.
Jan 09 01:21:58 PC-chan systemd[1347]: gpg-agent-extra.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Jan 09 01:21:58 PC-chan systemd[1347]: Stopped target Timers.
Jan 09 01:21:58 PC-chan systemd[1347]: dbus.socket: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Closed D-Bus User Message Bus Socket.
Jan 09 01:21:58 PC-chan systemd[1347]: Reached target Shutdown.
Jan 09 01:21:58 PC-chan systemd[1347]: systemd-exit.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1347]: Started Exit the Session.
Jan 09 01:21:58 PC-chan systemd[1347]: Reached target Exit the Session.
Jan 09 01:21:58 PC-chan systemd[1]: user@1000.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped User Manager for UID 1000.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopping User Runtime Directory /run/user/1000...
Jan 09 01:21:58 PC-chan systemd[1]: run-user-1000.mount: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Unmounted /run/user/1000.
Jan 09 01:21:58 PC-chan systemd[1]: lightdm.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Light Display Manager.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: user-runtime-dir@1000.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped User Runtime Directory /run/user/1000.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Removed slice User Slice of UID 1000.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Permit User Sessions...
Jan 09 01:21:58 PC-chan systemd[1]: systemd-user-sessions.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Permit User Sessions.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target Remote File Systems.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target Network.
Jan 09 01:21:58 PC-chan systemd[1]: Stopping Network Manager...
Jan 09 01:21:58 PC-chan NetworkManager[767]: [1578532918.7110] caught SIGTERM, shutting down normally.
Jan 09 01:21:58 PC-chan NetworkManager[767]: [1578532918.7114] dhcp4 (enp9s0): canceled DHCP transaction
Jan 09 01:21:58 PC-chan NetworkManager[767]: [1578532918.7114] dhcp4 (enp9s0): state changed bound -> done
Jan 09 01:21:58 PC-chan NetworkManager[767]: [1578532918.7114] device (enp9s0): DHCPv4: 480 seconds grace period started
Jan 09 01:21:58 PC-chan NetworkManager[767]: [1578532918.7117] manager: NetworkManager state is now CONNECTED_SITE
Jan 09 01:21:58 PC-chan dbus-daemon[765]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=767 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Jan 09 01:21:58 PC-chan dbus-daemon[765]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Jan 09 01:21:58 PC-chan NetworkManager[767]: [1578532918.7198] exiting (success)
Jan 09 01:21:58 PC-chan systemd[1]: NetworkManager.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Network Manager.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopping D-Bus System Message Bus...
Jan 09 01:21:58 PC-chan systemd[1]: dbus.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped D-Bus System Message Bus.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: systemd-logind.service: Succeeded.
Jan 09 01:21:58 PC-chan systemd[1]: Stopped Login Service.
Jan 09 01:21:58 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:58 PC-chan systemd[1]: Stopped target User and Group Name Lookups.
Jan 09 01:21:59 PC-chan systemd[1]: upower.service: Succeeded.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Daemon for power management.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target Basic System.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target Sockets.
Jan 09 01:21:59 PC-chan systemd[1]: libvirtd-ro.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed Libvirt local read-only socket.
Jan 09 01:21:59 PC-chan systemd[1]: snapd.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed Socket activation for snappy daemon.
Jan 09 01:21:59 PC-chan systemd[1]: virtlockd.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed Virtual machine lock manager socket.
Jan 09 01:21:59 PC-chan systemd[1]: avahi-daemon.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Jan 09 01:21:59 PC-chan systemd[1]: dbus.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed D-Bus System Message Bus Socket.
Jan 09 01:21:59 PC-chan systemd[1]: org.cups.cupsd.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed CUPS Scheduler.
Jan 09 01:21:59 PC-chan systemd[1]: libvirtd-admin.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed Libvirt admin socket.
Jan 09 01:21:59 PC-chan systemd[1]: libvirtd.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed Libvirt local socket.
Jan 09 01:21:59 PC-chan systemd[1]: virtlogd.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed Virtual machine log manager socket.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target Paths.
Jan 09 01:21:59 PC-chan systemd[1]: org.cups.cupsd.path: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped CUPS Scheduler.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target System Initialization.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: systemd-sysctl.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Apply Kernel Variables.
Jan 09 01:21:59 PC-chan systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target Local Encrypted Volumes.
Jan 09 01:21:59 PC-chan systemd[1]: systemd-ask-password-wall.path: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Jan 09 01:21:59 PC-chan systemd[1]: systemd-ask-password-console.path: Succeeded.
Jan 09 01:21:59 PC-chan audit[24072]: SYSTEM_SHUTDOWN pid=24072 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: systemd-modules-load.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Load Kernel Modules.
Jan 09 01:21:59 PC-chan systemd[1]: Stopping Network Time Synchronization...
Jan 09 01:21:59 PC-chan systemd[1]: systemd-binfmt.service: Succeeded.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Set Up Additional Binary Formats.
Jan 09 01:21:59 PC-chan systemd[1]: Stopping Load/Save Random Seed...
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target Slices.
Jan 09 01:21:59 PC-chan systemd[1]: Removed slice User and Session Slice.
Jan 09 01:21:59 PC-chan systemd[1]: Removed slice Virtual Machine and Container Slice.
Jan 09 01:21:59 PC-chan systemd[1]: systemd-update-utmp.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: systemd-random-seed.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Load/Save Random Seed.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: systemd-timesyncd.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Network Time Synchronization.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Create Volatile Files and Directories.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target Local File Systems.
Jan 09 01:21:59 PC-chan systemd[1]: Unmounting /tmp...
Jan 09 01:21:59 PC-chan systemd[1]: tmp.mount: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Unmounted /tmp.
Jan 09 01:21:59 PC-chan systemd[1]: Reached target Unmount All Filesystems.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target Local File Systems (Pre).
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: systemd-remount-fs.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Remount Root and Kernel File Systems.
Jan 09 01:21:59 PC-chan systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
Jan 09 01:21:59 PC-chan systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Create Static Device Nodes in /dev.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped target Swap.
Jan 09 01:21:59 PC-chan systemd[1]: lvm2-monitor.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: Stopping LVM2 metadata daemon...
Jan 09 01:21:59 PC-chan systemd[1]: lvm2-lvmetad.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Stopped LVM2 metadata daemon.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: Reached target Shutdown.
Jan 09 01:21:59 PC-chan systemd[1]: Reached target Final Step.
Jan 09 01:21:59 PC-chan systemd[1]: systemd-poweroff.service: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Started Power-Off.
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-poweroff comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-poweroff comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 09 01:21:59 PC-chan systemd[1]: Reached target Power-Off.
Jan 09 01:21:59 PC-chan systemd[1]: lvm2-lvmetad.socket: Succeeded.
Jan 09 01:21:59 PC-chan systemd[1]: Closed LVM2 metadata daemon socket.
Jan 09 01:21:59 PC-chan systemd[1]: Shutting down.
Jan 09 01:21:59 PC-chan kernel: printk: systemd-shutdow: 63 output lines suppressed due to ratelimiting
Jan 09 01:21:59 PC-chan kernel: fbcon: Taking over console
Jan 09 01:21:59 PC-chan systemd-shutdown[1]: Syncing filesystems and block devices.
Jan 09 01:21:59 PC-chan kernel: Console: switching to colour frame buffer device 240x67
Jan 09 01:21:59 PC-chan systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Jan 09 01:21:59 PC-chan haveged[438]: haveged: Stopping due to signal 15
Jan 09 01:21:59 PC-chan haveged[438]: haveged starting up
Jan 09 01:21:59 PC-chan systemd-journald[439]: Journal stopped
According to your log, it takes 2 seconds for the shutdown, not 2 minutes as per your original question.
Can you provide the output of the following command before you shut down?
for szFile in /proc/*/status ; do
  awk '/VmSwap|Name/{printf $2 "\t" $3}END{ print "" }' $szFile
done | sort --key 2 --numeric --reverse | head --lines=25
(that will give us an indication what is swapped out of RAM onto disk before you initiate your shutdown procedure)
Please use the </> button to enclose your terminal output for formatting and better readability. Simply highlight the text and click on the button.
I would suggest installing and testing at least three alternate kernels (both older and newer). Please list which kernels you have tested.
Please post:
inxi -Fxxxza --no-host
I'll try testing other Kernels now.
  Kernel: 5.4.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
  root=UUID=227142aa-a889-4241-bac2-2ca1d84470d8 rw quiet apparmor=1
  Desktop: Xfce 4.14.1 tk: Gtk 3.24.12 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop Mobo: ASRock model: B450 Steel Legend serial: <filter>
  UEFI [Legacy]: American Megatrends v: P2.90 date: 09/11/2019
  Topology: 6-Core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen
  family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701013
  L2 cache: 3072 KiB
  bogomips: 91246
  Speed: 3998 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
  1: 3758 2: 2855 3: 4067 4: 3988 5: 4074 6: 4080 7: 4079 8: 3816 9: 3714
  10: 3190 11: 4091 12: 4077
  always-on, RSB filling
  Device-1: AMD Vega 10 XL/XT [Radeon RX Vega 56/64]
  vendor: Sapphire Limited driver: amdgpu v: kernel bus ID: 0c:00.0
  chip ID: 1002:687f
  Display: x11 server: X.Org 1.20.6 driver: ati,modesetting
  alternate: amdgpu,fbdev,vesa tty: N/A
  OpenGL:
  renderer: Radeon RX Vega (VEGA10 DRM 3.35.0 5.4.6-2-MANJARO LLVM 9.0.0)
  v: 4.5 Mesa 19.3.1 direct render: Yes
  Device-1: AMD Vega 10 HDMI Audio [Radeon Vega 56/64] driver: snd_hda_intel
  v: kernel bus ID: 0c:00.1 chip ID: 1002:aaf8
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
  driver: snd_hda_intel v: kernel bus ID: 0e:00.4 chip ID: 1022:1487
  Device-3: Kingston HyperX 7.1 Audio type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-3:2 chip ID: 0951:16a4
  serial: <filter>
  Sound Server: ALSA v: k5.4.6-2-MANJARO
  vendor: ASRock driver: r8169 v: kernel port: d000 bus ID: 09:00.0
  chip ID: 10ec:8168
  IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 6.59 TiB used: 2.75 TiB (41.8%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
  serial: <filter> rev: 2B2QEXE7
  ID-2: /dev/sda vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 00RL scheme: MBR
  ID-3: /dev/sdb type: USB vendor: Seagate model: BUP Slim BL
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B
  serial: <filter> rev: 0302 scheme: MBR
  ID-4: /dev/sdc vendor: Seagate model: ST4000DM005-2DP166 size: 3.64 TiB
  block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5980 rpm serial: <filter> rev: 0001 scheme: GPT
  ID-5: /dev/sdd vendor: Western Digital model: WD10EZEX-00BN5A0
  speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
  ID-6: /dev/sdi vendor: SanDisk model: SDSSDHII120G size: 111.79 GiB
  ID-1: / raw size: 111.79 GiB size: 109.53 GiB (97.98%)
  used: 70.63 GiB (64.5%) fs: ext4 dev: /dev/sdi1
  System Temperatures: cpu: 81.1 C mobo: 44.0 C gpu: amdgpu temp: 66 C
  Fan Speeds (RPM): fan-1: 505 fan-2: 1387 fan-3: 0 fan-4: 484 fan-5: 502
  gpu: amdgpu fan: 1689
  Voltages: 12v: N/A 5v: N/A 3.3v: 3.28 vbat: 3.28
  Processes: 332 Uptime: 10m Memory: 62.75 GiB used: 5.27 GiB (8.4%)
  Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
  running in: xfce4-terminal inxi: 3.0.37 ```
I'll try take a picture of the log as it shutdown. Might be something the Journal doesn't pick up on.
Xorg	0	kB
xfwm4	0	kB
xfsettingsd	0	kB
xflux	0	kB
xfdesktop	0	kB
xfconfd	0	kB
xfce4-terminal	0	kB
xfce4-session	0	kB
xfce4-power-man	0	kB
xfce4-panel	0	kB
xfce4-notifyd	0	kB
xfce4-clipman	0	kB
writeback
watchdogd
vce2
vce1
vce0
uvd_enc_0.1
uvd_enc_0.0
uvd_0
usb-storage
upowerd	0	kB
udisksd	0	kB
ttm_swap
tracker-miner-r	0	kB
I suspected a swap issue but I was wrong. Thanks for the input. No further ideas...
:sob:
that is the trouble
stop pid1 thats means all should be down , except haveged
can you provide
sudo systemd-analyze blame
sudo systemctl status haveged.service
sudo systemd-analyze blame result
          3.566s updatedb.service
          1.079s systemd-logind.service
           947ms lightdm.service
           758ms man-db.service
           691ms snapd.service
           617ms lvm2-monitor.service
           426ms apparmor.service
           386ms dev-sdi1.device
           294ms upower.service
           241ms systemd-udevd.service
           235ms systemd-journal-flush.service
           235ms udisks2.service
           218ms tlp.service
           214ms polkit.service
           157ms systemd-journald.service
           155ms systemd-timesyncd.service
           148ms mnt-game.mount
           134ms avahi-daemon.service
           133ms systemd-machined.service
           127ms NetworkManager.service
           127ms lm_sensors.service
            97ms ldconfig.service
            93ms mnt-external_drive.mount
sudo systemctl status haveged.service result
● haveged.service - Entropy Daemon based on the HAVEGE algorithm
   Loaded: loaded (/usr/lib/systemd/system/haveged.service; enabled; vendor preset: disabled)
   Active: active (running) since Sat 2020-01-11 15:00:45 GMT; 11h ago
     Docs: man:haveged(8)
           http://www.issihosts.com/haveged/
 Main PID: 453 (haveged)
    Tasks: 1 (limit: 4915)
   Memory: 4.5M
   CGroup: /system.slice/haveged.service
           └─453 /usr/sbin/haveged -w 1024 -v 1 --Foreground
Jan 11 15:00:45 PC-chan haveged[453]: haveged: listening socket at 3
Jan 11 15:00:45 PC-chan haveged[453]: haveged: ver: 1.9.8; arch: x86; vend: ; build: (gcc 9.1.0 ITV); collect: 128K
Jan 11 15:00:45 PC-chan haveged[453]: haveged: cpu: (VC); data: 32K (V); inst: 32K (V); idx: 25/40; sz: 32671/52623
Jan 11 15:00:45 PC-chan haveged[453]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B):  last entropy estimate 8.00071
Jan 11 15:00:45 PC-chan haveged[453]: haveged: fills: 0, generated: 0
Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
Thanks for the ideas Fabby.
Took a picture of what it shows while shutting down. Don't think this shows up in Journal, but it's the main reason it takes so long. These 'UFW blocks'. Any ideas?
IMG_20200115_180649
Quit all your applications and save all your work and then try:
ufw disable
shutdown --halt now
and see if that speeds things up (or not)
If yes: check your firewall rules.
If no: It's something else, sorry!
Didn't work sadly. Was worth a try; thanks!
Maybe I missed it, but I never noticed any confirmation on which kernels you have tested. This should always be the first step taken before wasting time on other troubleshooting procedures. You should test at least 4.14, 4.19, 5.5 and at least one real time kernel.
Also is your bios up to date?
Try stopping the haveged service before shutdown:
sudo systemctl stop haveged
sudo systemctl daemon-reload
systemctl poweroff
If this improves things, then disable haveged:
sudo systemctl disable haveged --now
Sorry for late response. I tried multiple Kernals with no change sadly; one of the older Kernals didn't even boot properly. I tried disabling haveged service then shutting down, but that didn't change anything either.
Thanks for the help; really not sure what's going on with shutdown. It's these 'UFW' blocks that take up the most time.
Nope the firewall rules are not the problem: we've ruled that out already here: they're just the ones that inform you that the system is shutting down slowly, not the problem itself.
Here's another piece of information that might help to pinpoint what's going on:
last --system | grep system | head --lines=10
sudo journalctl --system --boot=all | grep --ignore-case "Journal stopped" | tail --lines=5
(will give information on the last 5 boots)
Here's the result; hope it helps.
reboot system boot 5.4.12-1-MANJARO Mon Jan 20 17:12 still running
shutdown system down 5.4.12-1-MANJARO Mon Jan 20 03:59 - 17:12 (13:13)
reboot system boot 5.4.12-1-MANJARO Sun Jan 19 17:45 - 03:59 (10:14)
shutdown system down 5.3.18-1-MANJARO Sun Jan 19 17:43 - 17:45 (00:02)
reboot system boot 5.3.18-1-MANJARO Sun Jan 19 17:41 - 17:43 (00:01)
shutdown system down 5.2.21-rt15-MANJ Sun Jan 19 17:35 - 17:41 (00:06)
reboot system boot 5.2.21-rt15-MANJ Sun Jan 19 17:31 - 17:35 (00:03)
shutdown system down 5.4.12-1-MANJARO Sun Jan 19 17:29 - 17:31 (00:02)
reboot system boot 5.4.12-1-MANJARO Sun Jan 19 17:26 - 17:29 (00:02)
shutdown system down 5.4.12-1-MANJARO Sun Jan 19 04:24 - 17:26 (13:02)
Jan 19 04:24:16 PC-chan systemd-journald[442]: Journal stopped
Jan 19 17:29:18 PC-chan systemd-journald[453]: Journal stopped
Jan 19 17:35:32 PC-chan systemd-journald[506]: Journal stopped
Jan 19 17:43:17 PC-chan systemd-journald[447]: Journal stopped
Jan 20 03:59:35 PC-chan systemd-journald[432]: Journal stopped
Updated to Linux Kernel 5.5 today and it seems to have fixed my problem. Thanks all! :relaxed:
