Hi
I just installed manjaro kde
Now I got some issues:
1- very slow shut down time(almost 7 minutes). I include all the images of my shutting down below
2- too slow update download speed (only with wifi, not when I hotspot my 4g network)
But the main one is number 1
It really annoys me
Thank you all in advance
First take a look at this so you can provide better info:
How to provide good information in your posts
The updates thing is probably mirrors.
oh right
this is the output of iinxi -Fxxxza --no-host
Kernel: 5.4.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.1
root=UUID=96a0b878-81c6-4185-a7dc-35203f8f78f0 rw quiet apparmor=1
security=apparmor resume=UUID=9455bd93-79ea-45ef-86ab-3398c5e8844e
udev.log_priority=3
Desktop: KDE Plasma 5.17.5 tk: Qt 5.14.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81DE v: Lenovo ideapad 330-15IKB
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 330-15IKB
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <filter> UEFI: LENOVO
v: 8TCN53WW date: 05/17/2019
ID-1: BAT0 charge: 12.9 Wh condition: 26.1/30.0 Wh (87%) volts: 7.5/7.6
model: LGC L17L2PF1 type: Li-poly serial: <filter> status: Discharging
Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: A (10)
microcode: CA L2 cache: 8192 KiB
bogomips: 32012
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800
3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes,
SMT vulnerable
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Lenovo driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:1d10
Display: x11 server: X.Org 1.20.7 driver: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa compositor: kwin_x11
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2)
v: 4.6 Mesa 19.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.4.23-1-MANJARO
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus ID: 02:00.0
chip ID: 10ec:8168
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel port: 3000 bus ID: 03:00.0
chip ID: 168c:0042
Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 1-7:3
chip ID: 0cf3:e500
Local Storage: total: 1.82 TiB used: 8.63 GiB (0.5%)
ID-1: /dev/sda vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: LDM2 scheme: GPT
ID-1: / raw size: 1.80 TiB size: 1.77 TiB (98.38%)
used: 8.63 GiB (0.5%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 17.11 GiB used: 0 KiB (0.0%) fs: swap
swappiness: 60 (default) cache pressure: 100 (default) dev: /dev/sda3
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 210 Uptime: 21m Memory: 15.55 GiB used: 1.45 GiB (9.3%)
Init: systemd v: 242 Compilers: gcc: 9.2.1 Shell: bash v: 5.0.16
running in: konsole inxi: 3.0.37
The output of $ sudo dmesg
was too long I can't copy it
So was the output of $ sudo journalctl
Doesn't look like you're up to date
sudo pacman -Syyu
It was getting stuck on sddm on shutdown so look for that.
sudo journalctl | grep sddm
Update first.
Yes you're right
I'm downloading the updates now
but it's too slow
20kib/s
Check your internet connection and update mirror list
sudo pacman-mirrors -f5 && sudo pacman -Syyu
If that is not your normal internet speed and you have not experienced not such a slow connection when you were surfing, you might wanna retry after rebuilding your mirror config.
You can rebuild the mirrors with
sudo pacman-mirrors --geoip
to use your country for geolocation or with
sudo pacman-mirrors --continent
to use your continent for it.
The you could try again.
Thank you
I ran it but nothing happened
It's still around 20kib/s
Thank you
Isn't there something like main server?
edit: I'm using my 4g network, so it's not normal
Mirrors all over the world.
You might have to sleep on it. Can't really do much until you're up to date. And the update might just fix the problem if you're lucky.
If you're using a mobile hotspot you could try USB tethering instead, or vice-versa.
I disconnect and reconnect my network and re run your command
Now it's ok
1 or 2mib/s
So I'm waiting until the update is done
by the way, sorry for my English I'm not native
Eventually the update completed
Now I should restart?
Or do something else to check if my issues are still there or not?
You should do a restart.
Because currently you are still running the old versions.
Then if the issue persists we will try to diagnose further. If it doesn't persist..... all is well?
Thank you so much:)
Ok I do a restart and reach you out if the issue persists
Unfortunately it still exists
first of all, it passed that A stop job is running for Simple Desktop Display Manager
faster than before
But it took the same time on the others
and finally I get a really WEIRD error
I get this:
The weird part is that I get this error everytime I restart/power on my laptop
For a more detailed explanation:
1- I turn on the laptop
2- I got this error
3- Laptop will be turned off
4- Laptop will be turned on automatically
5- No error anymore!!!!!
Ok i have to admit I'm really confused now
edit: I googled it and found out it was an issue in BIOS. So i guess it's ok now
But the very slow shutting down time exists
The issue is that using -f5
will just ping 5 mirrors at random .. they might all be slow or far etc.
Please see the wiki page I linked in the first response.
To for example scan and sort all mirrors globally (and do the required sync and update)
sudo pacman-mirrors -f && sudo pacman -Syyu
