Slow Wired Connection Speed
Update1:
After running this command
sudo mhwd -i pci network-r8168
my wired connection is working when I set the Link Negotiation to Manual and speed to 1gbps and Half duplex
Previously, If I set it to 1gbps, my wired connection did not work at all
Yet, my connection speed is still showing 100mbps image
Well if you can live with that, then stick with the r8168 driver for now. You can wait for kernel patches to come through for the r8169 kernel module down the road. If you wish to test the r8169 module after a few kernel update cycles it can be done easily like this:
sudo modprobe -r r8168 && sudo modprobe r8169 && sudo systemctl restart NetworkManager
This is everything inside the /etc/default/grub file
GRUB_DEFAULT=saved
GRUB_TIMEOUT=3
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor resume=UUID=fbd43c9c-e54b-4490-a7ae-05733904fb76 udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
If you want to enable the save default function, uncomment the following
line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
Preload both GPT and MBR modules so that they are not missed
Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
The resolution used on graphical terminal
note that you can use only modes which your graphic card supports via VBE
you can see them in real GRUB with the command 'videoinfo'
GRUB_GFXMODE=auto
Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
Uncomment if you want GRUB to pass to the Linux kernel the old parameter
format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
Uncomment and set to the desired menu colors. Used by normal and wallpaper
modes only. Entries specified as foreground/background.
Uncomment one of them for the gfx desired, a image background or a gfxtheme
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
To view the grub advanced menu at startup repeatedly press either the ESC, SHIFT, or F8 key.
I GOT IT FINALLY. I went to the advanced options. What now?
You only have one kernel installed according to the grub menu.
Try installing alternate kernels from the terminal:
sudo mhwd-kernel -i linux414
sudo mhwd-kernel -i linux419
sudo mhwd-kernel -i linux54
Reboot
Which one should I choose? The one with fallback or without fallback?image
Choose the one without. The fallback image is a last resort.
No changes. Still showing 100mbps :frowning:
You can test out the r8169 module on different kernels via modprobing:
Rebooting will return the system to using the r8168 driver.
You could also test out installing one of the Real Time kernels if you want to do further testing.
Sometimes kernel regressions don't get back ported as quickly on the real time kernels. You could test one of the Real Time kernels to see if the same issue is present. That would only be a temporary fix at best as the RT kernels eventually see changes from the mainline kernels applied to them as well.
