Hi!
I'm experiencing some strange behaviour with my QCA6174:
My ping latency progressively rises.
Consider the following scenario:
I start my laptop, connect to wireless network, and, say, ping 1.1.1.1
At first, i get something like 20 ms.
fast forward maybe 20 mins and ping time pattern looks like this:
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=5 ttl=47 time=20.4 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=6 ttl=47 time=21.7 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=7 ttl=47 time=23.5 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=8 ttl=47 time=36.2 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=9 ttl=47 time=58.6 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=10 ttl=47 time=155 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=11 ttl=47 time=175 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=12 ttl=47 time=20.7 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=13 ttl=47 time=38.2 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=14 ttl=47 time=62.3 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=15 ttl=47 time=20.8 ms
64 bytes from lg-in-f113.1e100.net (64.233.165.113): icmp_seq=16 ttl=47 time=21.6 ms
fast forward an hour, start ping
again and latency becomes 300 ms, and sometimes even 900 ms. Moreover, packet drop rate may rise up to 12%.
I tried:
- at least three different networks; (so, it looks like the router is not the case)
- reloading firmware (
modprobe -r ath10k_*
and so on) - swapping NetworkManager with connmand
- adding
pcie_aspm=off
as kernel boot parameter - pinging router's IP instead of 1.1.1.1 (and experience same problems)
iwconfig wlp107s0 power off
Restarting network services does not help in any way, but reboot seems to "refresh" the pattern.
It's reproducible at least on these kernels: 4.14, 5.4, 5.5, 5.6.
My laptop's Lenovo Yoga 920 (manjaro/win10 dual boot):
$ inxi -Fxxxz
System: Host: Sun2 Kernel: 5.6.0-2-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.1 Desktop: KDE Plasma 5.18.3 tk: Qt 5.14.1
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Convertible System: LENOVO product: 80Y8 v: Lenovo YOGA 920-13IKB Glass serial: <filter> Chassis: type: 31
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter> UEFI: LENOVO v: 5NCN41WW date: 09/12/2018
Battery: ID-1: BAT1 charge: 55.7 Wh condition: 55.7/70.0 Wh (80%) volts: 8.5/7.7 model: Celxpert BASE-BAT type: Li-poly
serial: <filter> status: Full
CPU: Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32012
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Display: x11 server: X.Org 1.20.7 driver: intel unloaded: modesetting,vesa alternate: fbdev compositor: kwin_x11
resolution: 3840x2160~60Hz
OpenGL: renderer: Mesa DRI Intel UHD Graphics 620 (Kabylake GT2) v: 4.6 Mesa 19.3.5 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.6.0-2-MANJARO
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lenovo driver: ath10k_pci v: kernel
port: 3040 bus ID: 6b:00.0 chip ID: 168c:003e
IF: wlp107s0 state: up mac: <filter>
Device-2: Qualcomm Atheros type: USB driver: btusb bus ID: 1-8:4 chip ID: 0cf3:e300
Drives: Local Storage: total: 476.94 GiB used: 255.43 GiB (53.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-000L2 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 2L1QEXA7 scheme: GPT
Partition: ID-1: / size: 344.19 GiB used: 255.40 GiB (74.2%) fs: ext4 dev: /dev/nvme0n1p4
Sensors: System Temperatures: cpu: 42.0 C mobo: 29.8 C
Info: Processes: 299 Uptime: 1h 18m Memory: 15.39 GiB used: 4.13 GiB (26.9%) Init: systemd v: 244 Compilers: gcc: 9.2.1
clang: 9.0.1 Shell: bash v: 5.0.16 running in: konsole inxi: 3.0.37
Wireless:
2.4GHz/5Ghz + WPA2
Firmware and dmesg logs:
[ 3.567849] ath10k_pci 0000:6b:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[ 3.814961] ath10k_pci 0000:6b:00.0: qca6174 hw3.2 target 0x05030000 chip_id 0x00340aff sub 17aa:0827
[ 3.814964] ath10k_pci 0000:6b:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[ 3.815389] ath10k_pci 0000:6b:00.0: firmware ver WLAN.RM.4.4.1-00140-QCARMSWPZ-1 api 6 features wowlan,ignore-otp,mfp crc32 29eb8ca1
[ 3.879548] ath10k_pci 0000:6b:00.0: board_file api 2 bmi_id N/A crc32 4ac0889b
[ 3.970994] ath10k_pci 0000:6b:00.0: htt-ver 3.60 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[ 4.045537] ath: EEPROM regdomain: 0x6c
[ 4.045538] ath: EEPROM indicates we should expect a direct regpair map
[ 4.045539] ath: Country alpha2 being used: 00
[ 4.045540] ath: Regpair used: 0x6c
[ 4.050044] ath10k_pci 0000:6b:00.0 wlp107s0: renamed from wlan0
[ 1556.759356] ath: EEPROM regdomain: 0x8283
[ 1556.759361] ath: EEPROM indicates we should expect a country code
[ 1556.759364] ath: doing EEPROM country->regdmn map search
[ 1556.759368] ath: country maps to regdmn code: 0x3d
[ 1556.759371] ath: Country alpha2 being used: RU
[ 1556.759374] ath: Regpair used: 0x3d
[ 1556.759379] ath: regdomain 0x8283 dynamically updated by country element
Any ideas on fixing/debugging this are greatly appreciated!
Thanks,
Mike.
