I am using xfce edition and installing it on X1 carbon 2016 with intel i7-6600U and integrated core graphic card.
When I boot from the USB disk and choose the "free" entry, my computer shows black screen after showing
:: running early hook [udev]
starting version 231
:: running hook [udev]
:: Triggering uevents ...
for less than a second. I cannot switch to tty, and it gives no reaction for any keyboard button. But if I choose "nonfree" entry it boots as expected. But if I install the system after that and reboot, I still get a black screen after grub and a flash of Manjaro booting screen. No tty accessible either.
I tried to use a different USB drive and it went still. I also tried i3 and deepin edition of Manjora and met the same problem. The Arch distro works fine. However, the net edition of Manjora can boot successfully. I didn't try to really install the net edition because it didn't recognize my PCI-e hard drive (/dev/nvme0n1px).
Similar reports can be seen here, and someone pointed out in this post that it may possibly be the skylake driver (here).
Thank you for any suggestion!
