[SOLVED] Customize kde application dashboard
First time caller here. Semi new to linux in general. Just made the switch from Ubuntu to Manjaro KDE. What I'm trying to do, is rearrange the application launcher a bit. I want to move the list of categories from the right side to the left side. See attached image to see what I mean. I haven't found much info about customizing the dashboard itself. Any help would be appreciated. Is this kind of thing possible? youd think there would be some simple edit i could make in some file? Thanks
You can change some things (icon size, font size, etc.) by editing the file
/usr/share/plasma/plasmoids/org.kde.plasma.kicker/contents/ui/DashboardRepresentation.qml
This requires qml knowledge.Take a look at here.I don't know if it's possible to rearrange it, though.
Thanks, I'll check it out
And you can switch away from dashboard alltogether toward something more usable by right clicking the Manjaro button (start button) and selecting Alternatives. Unless you like Dashboard, which often appeals to Ubuntu users.
Thanks to @rgnr for pointing out
I was able to make the change i wanted by using the following code. However I dont think it really looks right, it doesnt improve the dashboard as well as I thought it would.. Atleast now I know what to edit to make changes though. So i'm gonna have to learn a little more about QML and see if I can make it a little better.
 *   Copyright (C) 2015 by Eike Hein <hein@kde.org>                        *
 *   This program is free software; you can redistribute it and/or modify  *
 *   it under the terms of the GNU General Public License as published by  *
 *   the Free Software Foundation; either version 2 of the License, or     *
 *   (at your option) any later version.                                   *
 *   This program is distributed in the hope that it will be useful,       *
 *   but WITHOUT ANY WARRANTY; without even the implied warranty of        *
 *   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the         *
 *   GNU General Public License for more details.                          *
 *   You should have received a copy of the GNU General Public License     *
 *   along with this program; if not, write to the                         *
 *   Free Software Foundation, Inc.,                                       *
 *   51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA .        *
import QtQuick 2.4
import QtGraphicalEffects 1.0
import org.kde.plasma.core 2.1 as PlasmaCore
import org.kde.plasma.components 2.0 as PlasmaComponents
import org.kde.plasma.extras 2.0 as PlasmaExtras
import org.kde.kquickcontrolsaddons 2.0
import org.kde.kwindowsystem 1.0
import org.kde.plasma.private.shell 2.0
import org.kde.plasma.private.kicker 0.1 as Kicker
import "../code/tools.js" as Tools
/* TODO
 * Reverse middleRow layout + keyboard nav + filter list text alignment in rtl locales.
 * Keep cursor column when arrow'ing down past non-full trailing rows into a lower grid.
 * Make DND transitions cleaner by performing an item swap instead of index reinsertion.
Kicker.DashboardWindow {
    property bool smallScreen: ((Math.floor(width / units.iconSizes.huge) <= 22) || (Math.floor(height / units.iconSizes.huge) <= 14))
    property int iconSize: smallScreen ? units.iconSizes.large : units.iconSizes.huge
    property int cellSize: iconSize + theme.mSize(theme.defaultFont).height
        + (2 * units.smallSpacing)
        + (2 * Math.max(highlightItemSvg.margins.top + highlightItemSvg.margins.bottom,
                        highlightItemSvg.margins.left + highlightItemSvg.margins.right))
    property int columns: Math.floor(((smallScreen ? 85 : 80)/100) * Math.ceil(width / cellSize))
    property bool searching: (searchField.text != "")
    property var widgetExplorer: null
    keyEventProxy: searchField
    backgroundColor: Qt.rgba(0, 0, 0, 0.737)
    onKeyEscapePressed: {
        if (searching) {
            searchField.clear();
        } else {
            root.toggle();
    onVisibleChanged: {
        tabBar.activeTab = 0;
        reset();
        if (visible) {
            preloadAllAppsTimer.restart();
    onSearchingChanged: {
        if (!searching) {
            reset();
        } else {
            filterList.currentIndex = -1;
            if (tabBar.activeTab == 1) {
                widgetExplorer.widgetsModel.filterQuery = "";
                widgetExplorer.widgetsModel.filterType = "";
    function reset() {
        globalFavoritesGrid.currentIndex = -1;
        systemFavoritesGrid.currentIndex = -1;
        filterList.currentIndex = 0;
        funnelModel.sourceModel = rootModel.modelForRow(0);
        mainGrid.model = (tabBar.activeTab == 0) ? funnelModel : root.widgetExplorer.widgetsModel;
        mainGrid.currentIndex = -1;
        filterListScrollArea.focus = true;
        filterList.model = (tabBar.activeTab == 0) ? rootModel : root.widgetExplorer.filterModel;
    function updateWidgetExplorer() {
        if (tabBar.activeTab == 1 /* Widgets */ || tabBar.hoveredTab == 1) {
            if (!root.widgetExplorer) {
                root.widgetExplorer = widgetExplorerComponent.createObject(root, {
                    containment: containmentInterface.screenContainment(plasmoid)
        } else if (root.widgetExplorer) {
            root.widgetExplorer.destroy();
            root.widgetExplorer = null;
    mainItem: MouseArea {
        anchors.fill: parent
        acceptedButtons: Qt.LeftButton | Qt.RightButton
        LayoutMirroring.enabled: Qt.application.layoutDirection == Qt.RightToLeft
        LayoutMirroring.childrenInherit: true
        Connections {
            target: kicker
            onReset: {
                if (!searching) {
                    filterList.applyFilter();
                    if (tabBar.activeTab == 0) {
                        funnelModel.reset();
            onDragSourceChanged: {
                if (!dragSource) {
                    // FIXME TODO HACK: Reset all views post-DND to work around
                    // mouse grab bug despite QQuickWindow::mouseGrabberItem==0x0.
                    // Needs a more involved hunt through Qt Quick sources later since
                    // it's not happening with near-identical code in the menu repr.
                    rootModel.refresh();
                } else if (tabBar.activeTab == 1) {
                    root.toggle();
                    containmentInterface.ensureMutable(containmentInterface.screenContainment(plasmoid));
                    kwindowsystem.showingDesktop = true;
        KWindowSystem {
        Component {
            WidgetExplorer { showSpecialFilters: false }
        Connections {
            target: plasmoid
            onUserConfiguringChanged: {
                if (plasmoid.userConfiguring) {
                    root.hide()
        PlasmaComponents.Menu {
            PlasmaComponents.MenuItem {
                action: plasmoid.action("configure")
        PlasmaExtras.Heading {
            visible: false
            width: 0
            level: 1
        TextMetrics {
            font: dummyHeading.font
        Kicker.FunnelModel {
            onSourceModelChanged: {
                if (mainColumn.visible) {
                    mainGrid.forceLayout();
        Timer {
            property bool done: false
            interval: 1000
            repeat: false
            onTriggered: {
                if (done || searching) {
                    return;
                for (var i = 0; i < rootModel.count; ++i) {
                    var model = rootModel.modelForRow(i);
                    if (model.description == "KICKER_ALL_MODEL") {
                        allAppsGrid.model = model;
                        done = true;
                        break;
            function defer() {
                if (running && !done) {
                    restart();
        Kicker.ContainmentInterface {
        DashboardTabBar {
            y: 0
            anchors.horizontalCenter: parent.horizontalCenter
            visible: (plasmoid.immutability !== PlasmaCore.Types.SystemImmutable)
            onActiveTabChanged: {
                updateWidgetExplorer();
                reset();
            onHoveredTabChanged: updateWidgetExplorer()
            Keys.onDownPressed: {
                mainColumn.tryActivate(0, 0);
        PlasmaComponents.TextField {
            width: 0
            height: 0
            visible: false
            onTextChanged: {
                    runnerModel.query = searchField.text;
                } else {
                    widgetExplorer.widgetsModel.searchTerm = searchField.text;
            function clear() {
                text = "";
            anchors {
            y: (middleRow.anchors.topMargin / 2) - (smallScreen ? (height/10) : 0)
            font.pointSize: dummyHeading.font.pointSize * 1.5
            elide: Text.ElideRight
            wrapMode: Text.NoWrap
            opacity: 1.0
            color: "white"
            level: 1
            text: searching ? i18n("Searching for '%1'", searchField.text) : i18n("Type to search.")
        PlasmaComponents.ToolButton {
            anchors {
                left: searchHeading.right
                leftMargin: units.largeSpacing
                verticalCenter: searchHeading.verticalCenter
            width: units.iconSizes.large
            height: width
            visible: (searchField.text != "")
            iconName: "dialog-close"
            flat: false
            onClicked: searchField.clear();
        Row {
            anchors {
                top: parent.top
                topMargin: units.gridUnit * (smallScreen ? 8 : 10)
                bottom: parent.bottom
                bottomMargin: (units.gridUnit * 2)
            width: (root.columns * cellSize) + (2 * spacing)
            spacing: units.gridUnit * 2
            Item {
                anchors {
                    top: parent.top
                width: (columns * cellSize) + units.gridUnit
                property int columns: 3
                    enabled: (tabBar.activeTab == 0)
                    anchors {
                        top: parent.top
                    x: units.smallSpacing
                    width: parent.width - x
                    color: "white"
                    level: 1
                    text: i18n("Favorites")
                    opacity: (enabled ? 1.0 : 0.3)
                    Behavior on opacity { SmoothedAnimation { duration: units.longDuration; velocity: 0.01 } }
                PlasmaCore.SvgItem {
                    anchors {
                        top: favoritesColumnLabel.bottom
                    width: parent.width - units.gridUnit
                    height: lineSvg.horLineHeight
                    svg: lineSvg
                    elementId: "horizontal-line"
                ItemGridView {
                    anchors {
                        top: favoritesColumnLabelUnderline.bottom
                        topMargin: units.largeSpacing
                    property int rows: (Math.floor((parent.height - favoritesColumnLabel.height
                        - favoritesColumnLabelUnderline.height - units.largeSpacing) / cellSize)
                        - systemFavoritesGrid.rows)
                    width: parent.width
                    height: rows * cellSize
                    cellWidth: cellSize
                    cellHeight: cellSize
                    iconSize: root.iconSize
                    model: globalFavorites
                    dropEnabled: true
                    usesPlasmaTheme: false
                    onCurrentIndexChanged: {
                        preloadAllAppsTimer.defer();
                    onKeyNavRight: {
                        mainColumn.tryActivate(currentRow(), 0);
                    onKeyNavDown: {
                        systemFavoritesGrid.tryActivate(0, currentCol());
                    Binding {
                        target: globalFavorites
                        property: "iconSize"
                        value: root.iconSize
                ItemGridView {
                    anchors {
                        top: globalFavoritesGrid.bottom
                    property int rows: Math.ceil(count / Math.floor(width / cellSize))
                    width: parent.width
                    cellWidth: cellSize
                    model: systemFavorites
                    dropEnabled: true
                    usesPlasmaTheme: true
                    onKeyNavRight: {
                        mainColumn.tryActivate(globalFavoritesGrid.rows + currentRow(), 0);
                    onKeyNavUp: {
                        globalFavoritesGrid.tryActivate(globalFavoritesGrid.rows - 1, currentCol());
            Item {
                anchors.top: parent.top
                height: Math.floor(parent.height / cellSize) * cellSize + mainGridContainer.headerHeight
                property int columns: root.columns - favoritesColumn.columns - filterListColumn.columns
                property Item visibleGrid: mainGrid
                function tryActivate(row, col) {
                    if (visibleGrid) {
                        visibleGrid.tryActivate(row, col);
                Item {
                    z: (opacity == 1.0) ? 1 : 0
                    enabled: (opacity == 1.0) ? 1 : 0
                    property int headerHeight: mainColumnLabel.height + mainColumnLabelUnderline.height + units.largeSpacing
                    opacity: {
                        if (tabBar.activeTab == 0 && searching) {
                            return 0.0;
                        if (filterList.allApps) {
                            return 0.0;
                        return 1.0;
                    onOpacityChanged: {
                        if (opacity == 1.0) {
                            mainColumn.visibleGrid = mainGrid;
                        anchors {
                            top: parent.top
                        opacity: 1.0
                        color: "white"
                        level: 1
                        text: (tabBar.activeTab == 0) ? funnelModel.description : i18n("Widgets")
                        visible: mainGrid.count
                        anchors {
                            top: mainColumnLabel.bottom
                        svg: lineSvg
                    ItemGridView {
                        anchors {
                            top: mainColumnLabelUnderline.bottom
                        width: parent.width
                        height: systemFavoritesGrid.y + systemFavoritesGrid.height - mainGridContainer.headerHeight
                        cellWidth: (tabBar.activeTab == 0 ? cellSize : cellSize * 2)
                        cellHeight: cellWidth
                        iconSize: (tabBar.activeTab == 0 ? root.iconSize : cellWidth - (units.largeSpacing * 2))
                        model: funnelModel
                        onKeyNavLeft: {
                                var row = currentRow();
                                var target = row + 1 > globalFavoritesGrid.rows ? systemFavoritesGrid : globalFavoritesGrid;
                                var targetRow = row + 1 > globalFavoritesGrid.rows ? row - globalFavoritesGrid.rows : row;
                                target.tryActivate(targetRow, favoritesColumn.columns - 1);
                        onKeyNavRight: {
                        onKeyNavUp: {
                            if (tabBar.visible) {
                                tabBar.focus = true;
                        onItemActivated: {
                                root.widgetExplorer.addApplet(currentItem.m.pluginName);
                                root.toggle();
                ItemMultiGridView {
                    anchors {
                        top: parent.top
                    width: parent.width
                    opacity: filterList.allApps ? 1.0 : 0.0
                    onOpacityChanged: {
                            allAppsGrid.flickableItem.contentY = 0;
                            mainColumn.visibleGrid = allAppsGrid;
                    onKeyNavLeft: {
                        var row = 0;
                        for (var i = 0; i < subGridIndex; i++) {
                            row += subGridAt(i).lastRow() + 2; // Header counts as one.
                        row += subGridAt(subGridIndex).currentRow();
                    onKeyNavRight: {
                ItemMultiGridView {
                    anchors {
                        top: parent.top
                    width: parent.width
                    model: runnerModel
                    grabFocus: true
                    opacity: (tabBar.activeTab == 0 && searching) ? 1.0 : 0.0
                    onOpacityChanged: {
                            mainColumn.visibleGrid = runnerGrid;
                    onKeyNavLeft: {
                        var row = 0;
            Item {
                anchors {
                    top: parent.top
                    topMargin: mainColumnLabelUnderline.y + mainColumnLabelUnderline.height + units.largeSpacing
                width: columns * cellSize
                PlasmaExtras.ScrollArea {
                    x: root.visible ? 0 : units.gridUnit
                    Behavior on x { SmoothedAnimation { duration: units.longDuration; velocity: 0.01 } }
                    width: parent.width
                    height: mainGrid.height
                    enabled: !searching
                    property alias currentIndex: filterList.currentIndex
                    opacity: root.visible ? (searching ? 0.30 : 1.0) : 0.3
                    verticalScrollBarPolicy: (opacity == 1.0) ? Qt.ScrollBarAsNeeded : Qt.ScrollBarAlwaysOff
                    onEnabledChanged: {
                        if (!enabled) {
                        focus = (currentIndex != -1);
                    ListView {
                        focus: true
                        property bool allApps: false
                        property int eligibleWidth: width
                        property int hItemMargins: Math.max(highlightItemSvg.margins.left + highlightItemSvg.margins.right,
                            listItemSvg.margins.left + listItemSvg.margins.right)
                        model: rootModel
                        boundsBehavior: Flickable.StopAtBounds
                        snapMode: ListView.SnapToItem
                        spacing: 0
                        keyNavigationWraps: true
                        delegate: MouseArea {
                            signal actionTriggered(string actionId, variant actionArgument)
                            signal aboutToShowActionMenu(variant actionMenu)
                            property var m: model
                            property int textWidth: label.contentWidth
                            property int mouseCol
                            property bool hasActionList: ((model.favoriteId != null)
                                || (("hasActionList" in model) && (model.hasActionList == true)))
                            property Item menu: actionMenu
                            width: parent.width
                            height: Math.ceil((label.paintedHeight
                                + Math.max(highlightItemSvg.margins.top + highlightItemSvg.margins.bottom,
                                listItemSvg.margins.top + listItemSvg.margins.bottom)) / 2) * 2
                            Accessible.role: Accessible.MenuItem
                            Accessible.name: model.display
                            hoverEnabled: true
                            onContainsMouseChanged: {
                                if (!containsMouse) {
                                    updateCurrentItemTimer.stop();
                            onPositionChanged: { // Lazy menu implementation.
                                mouseCol = mouse.x;
                                if (justOpenedTimer.running || ListView.view.currentIndex == 0 || index == ListView.view.currentIndex) {
                                    updateCurrentItem();
                                } else if ((index == ListView.view.currentIndex - 1) && mouse.y < (height - 6)
                                    || (index == ListView.view.currentIndex + 1) && mouse.y > 5) {
                                    if (mouse.x > ListView.view.eligibleWidth - 5) {
                                } else if (mouse.x > ListView.view.eligibleWidth) {
                                updateCurrentItemTimer.restart();
                            onPressed: {
                                if (mouse.buttons & Qt.RightButton) {
                                    if (hasActionList) {
                                        openActionMenu(item, mouse.x, mouse.y);
                            onAboutToShowActionMenu: {
                                var actionList = hasActionList ? model.actionList : [];
                                Tools.fillActionMenu(actionMenu, actionList, ListView.view.model.favoritesModel, model.favoriteId);
                            onActionTriggered: {
                                Tools.triggerAction(ListView.view.model, model.index, actionId, actionArgument);
                            function openActionMenu(visualParent, x, y) {
                                aboutToShowActionMenu(actionMenu);
                                actionMenu.visualParent = visualParent;
                                actionMenu.open(x, y);
                            function updateCurrentItem() {
                                ListView.view.currentIndex = index;
                                ListView.view.eligibleWidth = Math.min(width, mouseCol);
                            ActionMenu {
                                onActionClicked: {
                                    actionTriggered(actionId, actionArgument);
                            Timer {
                                interval: 50
                                repeat: false
                                onTriggered: parent.updateCurrentItem()
                                anchors {
                                    fill: parent
                                    leftMargin: highlightItemSvg.margins.left
                                    rightMargin: highlightItemSvg.margins.right
                                opacity: 1.0
                                color: "white"
                                level: 1
                                text: model.display
                        highlight: PlasmaComponents.Highlight {
                            anchors {
                                top: filterList.currentItem ? filterList.currentItem.top : undefined
                                left: filterList.currentItem ? filterList.currentItem.left : undefined
                                bottom: filterList.currentItem ? filterList.currentItem.bottom : undefined
                            opacity: filterListScrollArea.focus ? 1.0 : 0.7
                            width: (highlightItemSvg.margins.left
                                + filterList.currentItem.textWidth
                                + units.smallSpacing)
                            visible: filterList.currentItem
                        highlightFollowsCurrentItem: false
                        highlightMoveDuration: 0
                        highlightResizeDuration: 0
                        onCurrentIndexChanged: applyFilter()
                        onCountChanged: {
                            var width = 0;
                                headingMetrics.text = rootModel.labelForRow(i);
                                if (headingMetrics.width > width) {
                                    width = headingMetrics.width;
                            filterListColumn.columns = Math.ceil(width / cellSize);
                            filterListScrollArea.width = width + hItemMargins + (units.gridUnit * 2);
                        function applyFilter() {
                            if (!searching && currentIndex >= 0) {
                                    root.widgetExplorer.widgetsModel.filterQuery = currentItem.m.filterData;
                                    root.widgetExplorer.widgetsModel.filterType = currentItem.m.filterType;
                                    allApps = false;
                                    funnelModel.sourceModel = model;
                                    return;
                                if (preloadAllAppsTimer.running) {
                                    preloadAllAppsTimer.stop();
                                var model = rootModel.modelForRow(currentIndex);
                                    allApps = true;
                                    funnelModel.sourceModel = null;
                                    preloadAllAppsTimer.done = true;
                                } else {
                                    allApps = false;
                            } else {
                                allApps = false;
                        Keys.onPressed: {
                            if (event.key == Qt.Key_Left) {
                                event.accepted = true;
                                var currentRow = Math.max(0, Math.ceil(currentItem.y / mainGrid.cellHeight) - 1);
                                mainColumn.tryActivate(currentRow, mainColumn.columns - 1);
        onPressed: {
            if (mouse.button == Qt.RightButton) {
                contextMenu.open(mouse.x, mouse.y);
        onClicked: {
            if (mouse.button == Qt.LeftButton) {
                root.toggle();
In case anyone is wondering what it looks like
I won't see this ever
hasan5525
To be honest, me neither. Stepped away from Ubuntu when Unity was introduced, I will not go back to using a dash now. Sorry for all who are working on this, but this is not my cup of tea.
TBH I don't really like it either. I just thought if I messed around with it I could make it better.
