Hello,
I'm having this strange issue where when I either un-dock and re-dock, or wake my laptop from sleep, my dock network adapter becomes disabled. WiFi interfaces are not impacted, and neither are other hardware dongles (USB Ethernet adapters, etc).
Restarting NetworkManager.service unfortunately does not resolve the issue either. So far my only working remedy is to reboot while docked, and then everything works normally.
System Info:
Laptop - ThinkPad X1 Extreme Gen2
Dock - ThinkPad Thunderbolt 3 Workstation Dock Gen2
Majnaro Info
inxi -Fxxxza --no-host
type or paste codSystem: Kernel: 5.4.36-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=c650d837-89a7-4a22-9761-97b05f63f77c rw quiet apparmor=1
security=apparmor resume=UUID=408b2d48-d58b-4a0f-958c-6818740b0a4e udev.log_priority=3
Desktop: KDE Plasma 5.18.4 tk: Qt 5.14.2 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20QVCTO1WW v: ThinkPad X1 Extreme 2nd serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: LENOVO model: 20QVCTO1WW v: SDK0J40697 WIN serial: <filter> UEFI: LENOVO v: N2OET41W (1.28 ) date: 11/25/2019
Battery: ID-1: BAT0 charge: 81.3 Wh condition: 81.3/80.4 Wh (101%) volts: 17.4/15.4 model: SMP 01YU911 type: Li-poly
serial: <filter> status: Full cycles: 19
CPU: Topology: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: A (10) microcode: CA L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
Speed: 2168 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 2993 2: 3583 3: 3171 4: 3246 5: 3261 6: 3093 7: 3232
8: 3740 9: 3332 10: 3284 11: 3102 12: 3281
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo driver: nvidia v: 435.21 bus ID: 01:00.0
chip ID: 10de:1f91
Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia compositor: kwin_x11
resolution: 1920x1200~60Hz, 1920x1200~60Hz, 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 435.21 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus ID: 3-2.3.3:11
chip ID: 046d:082d serial: <filter>
Device-3: Lenovo USB2.0 Hub type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-2.1.1.2:10
chip ID: 17ef:3083 serial: <filter>
Device-4: N/A type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-2.3.4:12 chip ID: 2f96:0100
Sound Server: ALSA v: k5.4.36-1-MANJARO
Network: Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: 3.2.6-k port: efa0 bus ID: 00:1f.6
chip ID: 8086:15bc
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus ID: 52:00.0 chip ID: 8086:2723
IF: wlp82s0 state: up mac: <filter>
Device-3: Lenovo USB3.1 Hub type: USB driver: cdc_ether bus ID: 4-2.1.2:5 chip ID: 17ef:3082 serial: <filter>
IF: enp9s0u2u1u2c2 state: up speed: N/A duplex: N/A mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 331.31 GiB (35.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB256HBHQ-000L7 size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 4M2QEXH7 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXE7 scheme: GPT
Partition: ID-1: / raw size: 897.10 GiB size: 882.02 GiB (98.32%) used: 330.75 GiB (37.5%) fs: ext4 dev: /dev/nvme1n1p2
ID-2: swap-1 size: 34.12 GiB used: 566.0 MiB (1.6%) fs: swap swappiness: 60 (default) cache pressure: 100 (default)
dev: /dev/nvme1n1p3
Sensors: System Temperatures: cpu: 71.0 C mobo: 48.0 C gpu: nvidia temp: 49 C
Fan Speeds (RPM): cpu: 3269 fan-2: 2958
Info: Processes: 338 Uptime: 8h 27m Memory: 31.02 GiB used: 6.85 GiB (22.1%) Init: systemd v: 244 Compilers: gcc: 9.3.0
alt: 8 Shell: bash v: 5.0.16 running in: yakuake inxi: 3.0.37
lspci -k
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
Subsystem: Lenovo 8th Gen Core Processor Host Bridge/DRAM Registers
Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07)
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630 (Mobile)
Subsystem: Lenovo UHD Graphics 630 (Mobile)
Kernel driver in use: i915
Kernel modules: i915
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 07)
Subsystem: Lenovo Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
Kernel driver in use: proc_thermal
Kernel modules: processor_thermal_device
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
Subsystem: Lenovo Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
Subsystem: Lenovo Cannon Lake PCH Thermal Controller
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
Subsystem: Lenovo Cannon Lake PCH USB 3.1 xHCI Host Controller
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
Subsystem: Lenovo Cannon Lake PCH Shared SRAM
00:15.0 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
Subsystem: Lenovo Cannon Lake PCH Serial IO I2C Controller
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
Subsystem: Lenovo Cannon Lake PCH HECI Controller
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #17 (rev f0)
00:1b.4 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 (rev f0)
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #1 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1d.6 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #15 (rev f0)
00:1e.0 Communication controller: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller (rev 10)
Subsystem: Lenovo Cannon Lake PCH Serial IO UART Host Controller
00:1f.0 ISA bridge: Intel Corporation Device a30e (rev 10)
Subsystem: Lenovo Device 229f
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
Subsystem: Lenovo Cannon Lake PCH cAVS
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
Subsystem: Lenovo Cannon Lake PCH SMBus Controller
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
Subsystem: Lenovo Cannon Lake PCH SPI Controller
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-V (rev 10)
Subsystem: Lenovo Ethernet Connection (7) I219-V
Kernel driver in use: e1000e
Kernel modules: e1000e
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q] (rev a1)
Subsystem: Lenovo TU117M [GeForce GTX 1650 Mobile / Max-Q]
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
Kernel driver in use: nvme
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
04:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
06:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
Subsystem: Lenovo JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018]
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
07:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
08:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
08:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge DD 2018] (rev 06)
09:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge DD 2018] (rev 06)
Subsystem: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge DD 2018]
52:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
53:00.0 SD Host controller: Genesys Logic, Inc Device 9755
Kernel driver in use: sdhci-pci
Kernel modules: sdhci_pci
Any help would be greatly appreciated!
Theo
