[Solved] Error: grub-file-filter not found. grub rescue>
I have just installed Manjaro kde on my hp elitebook 2560p. After rebooting, it shows error message:
Starting in rescue mode.
grub rescue>
I searched for it on the Internet and answers say that it has to do something with installing bootloader in UEFI mode, mounting it on /boot/efi.
It doesn't show me /boot/efi flag which means I am running it in BIOS mode, I think.
I am complete noob and I had Linux Mint installed before. It was working fine.
Hello and welcome to the forums.
Which ISO did you use to install Manjaro ?
I used this link to download.
So you used the calamares installer. Did you do an automated partition or changed it? Is it installed as dual boot with Windows ?
I did manual partitioning. I set /boot, /root and swap partitions which I used with Linux Mint.
I have also two NTFS partitions which have some important data I don't want to loose and I also don't have external drive to backup to. That's why I chose manual partitioning.
Single boot.
There is the problem. Grub needs a /boot/efi partition. /boot will not work. You can repeat the install by mounting the ESP partition on /boot/efi, or read the following guide to repair the install:
https://wiki.manjaro.org/index.php?title=Restore_the_GRUB_Bootloader
Why it doesn't show /boot/efi flag in installer?
And also, I tried to enable UEFI mode from BIOS menu but it said hp supports UEFI mode for development only.
I am confused.
Then your computer does not support UEFI. On BIOS Systems all you need is the root partition and swap.
It should look something like this:
With your 2 NTFS Partitions added.
I just followed the tutorial you gave me.
And it worked!
Thank you so much!
