Hey folks,
I also get the warning when starting my Manjaro:
error: sparse file not allowed. - press any key to continue booting
I used the search-function and tried
sudo grub-editenv create
and edited /etc/default/grub like this:
**cat** /etc/default/grub
#GRUB_DEFAULT="saved"
GRUB_TIMEOUT="5"
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=e860eca5-9535-45e7-b109-27d415b36e2a"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
#GRUB_SAVEDEFAULT="true"
# Uncomment to enable Hidden Menu, and optionally hide the timeout count
#GRUB_HIDDEN_TIMEOUT="5"
#GRUB_HIDDEN_TIMEOUT_QUIET="true"
GRUB_TERMINAL_INPUT="console"
#GRUB_TERMINAL_OUTPUT="console"
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE="auto"
GRUB_GFXPAYLOAD_LINUX="keep"
#GRUB_DISABLE_LINUX_UUID="true"
GRUB_DISABLE_RECOVERY="true"
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
GRUB_BACKGROUND="/usr/share/grub/background.png"
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
I don't use UEFI.
Manjaro is booting (so same situation like the others having this issue). However, the warning massage still appears. What else could I try?
Seantum
