[SOLVED]HP mfp printer will not scan
Hi,
I am a new Manjaro user.
I love it so far but have a scanning issue.
I have an HP Color LaserJet Pro MFP M277 Postscript printer
device `hpaio:/usb/HP_Color_LaserJet_MFP_M277dw?serial=VNB8HD7D20' is a Hewlett-Packard HP_Color_LaserJet_MFP_M277dw all-in-one
It prints fine.
My problem is that when I scan I get the following message:
Message: "Failed to start scanner: Invalid argument"
I have included
  • inxi -Fxxxza --no-host
  • dmesg
below.
Any idea on how to fix this?
Thanks!
**inxi -Fxxxza --no-host**
[philip@philip-pc ~]$ inxi -Fxxxza --no-host
  Kernel: 4.19.79-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64
  root=UUID=94029170-eb88-48fd-825f-fa5623ee8946 rw quiet
  resume=UUID=9b56e323-2ef2-44e3-915c-ab9e876e9374
  Desktop: Xfce 4.14.1 tk: Gtk 3.24.12 info: xfce4-panel wm: xfwm4
  dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Desktop System: System76 product: Meerkat v: meer2 serial: <filter>
  Chassis: type: 3 v: meer2 serial: <filter>
  Mobo: Intel model: NUC6i3SYB v: H81132-503 serial: <filter> UEFI: Intel
  v: SYSKLi35.86A.0063.2017.1115.1550 date: 11/15/2017
  Topology: Dual Core model: Intel Core i3-6100U bits: 64 type: MT MCP
  arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: CC
  L2 cache: 3072 KiB
  bogomips: 18436
  Speed: 2300 MHz min/max: 400/2300 MHz Core speeds (MHz): 1: 2300 2: 2300
  3: 2300 4: 2300
  Vulnerabilities: Type: l1tf
  Device-1: Intel Skylake GT2 [HD Graphics 520] driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:1916
  Display: x11 server: X.Org 1.20.5 driver: intel unloaded: modesetting
  alternate: fbdev,vesa resolution: 3840x2160~30Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2)
  v: 4.5 Mesa 19.2.1 compat-v: 3.0 direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
  bus ID: 00:1f.3 chip ID: 8086:9d70
  Sound Server: ALSA v: k4.19.79-1-MANJARO
  Device-1: Intel Ethernet I219-V driver: e1000e v: 3.2.6-k port: f040
  bus ID: 00:1f.6 chip ID: 8086:1570
  Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: f040
  bus ID: 01:00.0 chip ID: 8086:24f3
  IF: wlp1s0 state: down mac: <filter>
  Local Storage: total: 2.76 TiB used: 308.83 GiB (10.9%)
  ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB
  block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: 2B6Q scheme: GPT
  ID-2: /dev/sdb vendor: Transcend model: TS32GMTS800 size: 29.82 GiB
  serial: <filter> rev: 5G scheme: MBR
  ID-3: /dev/sdc type: USB vendor: Western Digital
  model: WD My Passport 0748 size: 1.82 TiB block size: physical: 512 B
  logical: 512 B serial: <filter> rev: 1019 scheme: MBR
  ID-1: / raw size: 896.78 GiB size: 881.71 GiB (98.32%)
  used: 146.76 GiB (16.6%) fs: ext4 dev: /dev/sda2
  ID-2: swap-1 size: 34.43 GiB used: 3.5 MiB (0.0%) fs: swap
  swappiness: 10 (default 60) cache pressure: 100 (default) dev: /dev/sda3
  System Temperatures: cpu: 63.0 C mobo: 29.8 C
  Processes: 329 Uptime: 17h 59m Memory: 31.30 GiB used: 9.54 GiB (30.5%)
  Init: systemd v: 242 Compilers: gcc: 9.2.0 Shell: bash v: 5.0.11
  running in: xfce4-terminal inxi: 3.0.36
DMESG
[philip@philip-pc ~]$ sudo dmesg
[sudo] password for philip:
[    0.000000] microcode: microcode updated early to revision 0xcc, date = 2019-04-01
[    0.000000] Linux version 4.19.79-1-MANJARO (builduser@lancaster) (gcc version 9.2.0 (GCC)) #1 SMP PREEMPT Fri Oct 11 19:57:09 UTC 2019
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=94029170-eb88-48fd-825f-fa5623ee8946 rw quiet resume=UUID=9b56e323-2ef2-44e3-915c-ab9e876e9374
[    0.000000] KERNEL supported cpus:
[    0.000000]   Intel GenuineIntel
[    0.000000]   AMD AuthenticAMD
[    0.000000]   Centaur CentaurHauls
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: xstate_offset[3]:  832, xstate_sizes[3]:   64
[    0.000000] x86/fpu: xstate_offset[4]:  896, xstate_sizes[4]:   64
[    0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[    0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000757d8fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000757d9000-0x00000000757d9fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000757da000-0x0000000075803fff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000075804000-0x000000007a244fff] usable
[    0.000000] BIOS-e820: [mem 0x000000007a245000-0x000000007a547fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007a548000-0x000000007a57ffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000007a580000-0x000000007ae71fff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x000000007ae72000-0x000000007b293fff] reserved
[    0.000000] BIOS-e820: [mem 0x000000007b294000-0x000000007b2fefff] type 20
[    0.000000] BIOS-e820: [mem 0x000000007b2ff000-0x000000007b2fffff] usable
[    0.000000] BIOS-e820: [mem 0x000000007b300000-0x000000007b3fffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000087effffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.40 by American Megatrends
[    0.000000] efi:  ACPI=0x7a553000  ACPI 2.0=0x7a553000  SMBIOS=0xf05e0  SMBIOS 3.0=0xf0600  ESRT=0x7b1d9798  MPS=0xfc9b0
[    0.000000] SMBIOS 3.0.0 present.
[    0.000000] DMI: System76 Meerkat/NUC6i3SYB, BIOS SYSKLi35.86A.0063.2017.1115.1550 11/15/2017
[    0.000000] tsc: Detected 2300.000 MHz processor
[    0.002103] tsc: Detected 2304.000 MHz TSC
[    0.002103] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.002106] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.002114] last_pfn = 0x87f000 max_arch_pfn = 0x400000000
[    0.002119] MTRR default type: write-back
[    0.002119] MTRR fixed ranges enabled:
[    0.002121]   00000-9FFFF write-back
[    0.002122]   A0000-BFFFF uncachable
[    0.002123]   C0000-FFFFF write-protect
[    0.002123] MTRR variable ranges enabled:
[    0.002125]   0 base 0080000000 mask 7F80000000 uncachable
[    0.002126]   1 base 007C000000 mask 7FFC000000 uncachable
[    0.002127]   2 base 007B800000 mask 7FFF800000 uncachable
[    0.002127]   3 disabled
[    0.002128]   4 disabled
[    0.002129]   5 disabled
[    0.002129]   6 disabled
[    0.002130]   7 disabled
[    0.002130]   8 disabled
[    0.002131]   9 disabled
[    0.003043] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.003248] last_pfn = 0x7b300 max_arch_pfn = 0x400000000
[    0.012315] found SMP MP-table at [mem 0x000fcba0-0x000fcbaf]
[    0.012329] esrt: Reserving ESRT space from 0x000000007b1d9798 to 0x000000007b1d97d0.
[    0.012337] Scanning 1 areas for low memory corruption
[    0.012341] Using GB pages for direct mapping
[    0.012343] BRK [0x44401000, 0x44401fff] PGTABLE
[    0.012345] BRK [0x44402000, 0x44402fff] PGTABLE
[    0.012346] BRK [0x44403000, 0x44403fff] PGTABLE
[    0.012378] BRK [0x44404000, 0x44404fff] PGTABLE
[    0.012380] BRK [0x44405000, 0x44405fff] PGTABLE
[    0.012551] BRK [0x44406000, 0x44406fff] PGTABLE
[    0.012591] BRK [0x44407000, 0x44407fff] PGTABLE
[    0.012640] BRK [0x44408000, 0x44408fff] PGTABLE
[    0.012691] Secure boot could not be determined
[    0.012692] RAMDISK: [mem 0x36a5b000-0x37524fff]
[    0.012703] ACPI: Early table checksum verification disabled
[    0.012706] ACPI: RSDP 0x000000007A553000 000024 (v02 INTEL )
[    0.012710] ACPI: XSDT 0x000000007A5530A0 0000BC (v01 INTEL  NUC6i3SY 0000003F AMI  00010013)
[    0.012715] ACPI: FACP 0x000000007A574F00 00010C (v05 INTEL  NUC6i3SY 0000003F AMI  00010013)
[    0.012721] ACPI: DSDT 0x000000007A5531E8 021D12 (v02 INTEL  NUC6i3SY 0000003F INTL 20120913)
[    0.012725] ACPI: FACS 0x000000007AE71F80 000040
[    0.012728] ACPI: APIC 0x000000007A575010 000084 (v03 INTEL  NUC6i3SY 0000003F AMI  00010013)
[    0.012731] ACPI: FPDT 0x000000007A575098 000044 (v01 INTEL  NUC6i3SY 0000003F AMI  00010013)
[    0.012734] ACPI: FIDT 0x000000007A5750E0 00009C (v01 INTEL  NUC6i3SY 0000003F AMI  00010013)
[    0.012737] ACPI: MCFG 0x000000007A575180 00003C (v01 INTEL  NUC6i3SY 0000003F MSFT 00000097)
[    0.012740] ACPI: HPET 0x000000007A5751C0 000038 (v01 INTEL  NUC6i3SY 0000003F AMI. 0005000B)
[    0.012743] ACPI: LPIT 0x000000007A5751F8 000094 (v01 INTEL  NUC6i3SY 0000003F MSFT 0000005F)
[    0.012747] ACPI: SSDT 0x000000007A575290 000248 (v02 INTEL  NUC6i3SY 0000003F INTL 20120913)
[    0.012750] ACPI: SSDT 0x000000007A5754D8 002BAE (v02 INTEL  NUC6i3SY 0000003F INTL 20120913)
[    0.012753] ACPI: SSDT 0x000000007A578088 000BE3 (v02 INTEL  NUC6i3SY 0000003F INTL 20120913)
[    0.012756] ACPI: SSDT 0x000000007A578C70 0004A3 (v02 INTEL  NUC6i3SY 0000003F INTL 20120913)
[    0.012759] ACPI: DBGP 0x000000007A579118 000034 (v01 INTEL  NUC6i3SY 0000003F MSFT 0000005F)
[    0.012762] ACPI: DBG2 0x000000007A579150 000054 (v00 INTEL  NUC6i3SY 0000003F MSFT 0000005F)
[    0.012765] ACPI: SSDT 0x000000007A5791A8 00046E (v02 INTEL  NUC6i3SY 0000003F INTL 20120913)
[    0.012769] ACPI: SSDT 0x000000007A579618 00546C (v02 INTEL  NUC6i3SY 0000003F INTL 20120913)
[    0.012772] ACPI: UEFI 0x000000007A57EA88 000042 (v01 INTEL  NUC6i3SY 0000003F      00000000)
[    0.012775] ACPI: SSDT 0x000000007A57EAD0 000E73 (v02 INTEL  NUC6i3SY 0000003F INTL 20120913)
[    0.012778] ACPI: BGRT 0x000000007A57F948 000038 (v01 INTEL  NUC6i3SY 0000003F AMI  00010013)
[    0.012781] ACPI: DMAR 0x000000007A57F980 0000CC (v01 INTEL  NUC6i3SY 0000003F INTL 00000001)
[    0.012789] ACPI: Local APIC address 0xfee00000
[    0.012986] No NUMA configuration found
[    0.012987] Faking a node at [mem 0x0000000000000000-0x000000087effffff]
[    0.012991] NODE_DATA(0) allocated [mem 0x87effa000-0x87effdfff]
[    0.013028] Zone ranges:
[    0.013029]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.013031]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.013032]   Normal   [mem 0x0000000100000000-0x000000087effffff]
[    0.013033]   Device   empty
[    0.013034] Movable zone start for each node
[    0.013035] Early memory node ranges
[    0.013036]   node   0: [mem 0x0000000000001000-0x0000000000057fff]
[    0.013037]   node   0: [mem 0x0000000000059000-0x000000000009efff]
[    0.013037]   node   0: [mem 0x0000000000100000-0x00000000757d8fff]
[    0.013038]   node   0: [mem 0x0000000075804000-0x000000007a244fff]
[    0.013039]   node   0: [mem 0x000000007b2ff000-0x000000007b2fffff]
[    0.013039]   node   0: [mem 0x0000000100000000-0x000000087effffff]
[    0.013043] Reserved but unavailable: 98 pages
[    0.013044] Initmem setup node 0 [mem 0x0000000000001000-0x000000087effffff]
[    0.013045] On node 0 totalpages: 8360376
[    0.013047]   DMA zone: 64 pages used for memmap
[    0.013047]   DMA zone: 26 pages reserved
[    0.013048]   DMA zone: 3997 pages, LIFO batch:0
[    0.013137]   DMA32 zone: 7753 pages used for memmap
[    0.013138]   DMA32 zone: 496155 pages, LIFO batch:63
[    0.025541]   Normal zone: 122816 pages used for memmap
[    0.025542]   Normal zone: 7860224 pages, LIFO batch:63
[    0.188244] Reserving Intel graphics memory at [mem 0x7c000000-0x7fffffff]
[    0.188558] ACPI: PM-Timer IO Port: 0x1808
[    0.188560] ACPI: Local APIC address 0xfee00000
[    0.188565] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.188566] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.188567] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.188568] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.188600] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.188602] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.188603] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.188605] ACPI: IRQ0 used by override.
[    0.188606] ACPI: IRQ9 used by override.
[    0.188608] Using ACPI (MADT) for SMP configuration information
[    0.188609] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.188617] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.188636] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.188638] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.188639] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.188640] PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.188642] PM: Registered nosave memory: [mem 0x757d9000-0x757d9fff]
[    0.188642] PM: Registered nosave memory: [mem 0x757da000-0x75803fff]
[    0.188644] PM: Registered nosave memory: [mem 0x7a245000-0x7a547fff]
[    0.188644] PM: Registered nosave memory: [mem 0x7a548000-0x7a57ffff]
[    0.188645] PM: Registered nosave memory: [mem 0x7a580000-0x7ae71fff]
[    0.188646] PM: Registered nosave memory: [mem 0x7ae72000-0x7b293fff]
[    0.188646] PM: Registered nosave memory: [mem 0x7b294000-0x7b2fefff]
[    0.188648] PM: Registered nosave memory: [mem 0x7b300000-0x7b3fffff]
[    0.188648] PM: Registered nosave memory: [mem 0x7b400000-0x7bffffff]
[    0.188649] PM: Registered nosave memory: [mem 0x7c000000-0x7fffffff]
[    0.188650] PM: Registered nosave memory: [mem 0x80000000-0xdfffffff]
[    0.188650] PM: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.188651] PM: Registered nosave memory: [mem 0xf0000000-0xfdffffff]
[    0.188651] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.188652] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.188652] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.188653] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[    0.188654] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.188654] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.188655] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.188657] [mem 0x80000000-0xdfffffff] available for PCI devices
[    0.188658] Booting paravirtualized kernel on bare hardware
[    0.188660] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.308653] random: get_random_bytes called from start_kernel+0x93/0x53f with crng_init=0
[    0.308661] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.308816] percpu: Embedded 46 pages/cpu s151552 r8192 d28672 u524288
[    0.308823] pcpu-alloc: s151552 r8192 d28672 u524288 alloc=1*2097152
[    0.308825] pcpu-alloc: [0] 0 1 2 3
[    0.308844] Built 1 zonelists, mobility grouping on.  Total pages: 8229717
[    0.308845] Policy zone: Normal
[    0.308847] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=94029170-eb88-48fd-825f-fa5623ee8946 rw quiet resume=UUID=9b56e323-2ef2-44e3-915c-ab9e876e9374
[    0.312282] Calgary: detecting Calgary via BIOS EBDA area
[    0.312284] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.376384] Memory: 32734404K/33441504K available (12300K kernel code, 1387K rwdata, 3624K rodata, 1552K init, 3744K bss, 707100K reserved, 0K cma-reserved)
[    0.376485] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.376490] Kernel/User page tables isolation: enabled
[    0.376543] ftrace: allocating 36241 entries in 142 pages
[    0.392211] rcu: Preemptible hierarchical RCU implementation.
[    0.392212] rcu: 	CONFIG_RCU_FANOUT set to non-default value of 32.
[    0.392212] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.392213] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.392214] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.392215] 	Tasks RCU enabled.
[    0.392216] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.393933] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[    0.394133] rcu: 	Offload RCU callbacks from CPUs: (none).
[    0.394272] spurious 8259A interrupt: IRQ7.
[    0.394298] Console: colour dummy device 80x25
[    0.394301] console [tty0] enabled
[    0.394317] ACPI: Core revision 20180810
[    0.394673] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.394704] hpet clockevent registered
[    0.394785] APIC: Switch to symmetric I/O mode setup
[    0.394787] DMAR: Host address width 39
[    0.394788] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.394793] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e3ff0505e
[    0.394794] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.394797] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.394798] DMAR: RMRR base: 0x0000007a2ea000 end: 0x0000007a309fff
[    0.394800] DMAR: RMRR base: 0x0000007b800000 end: 0x0000007fffffff
[    0.394801] DMAR: ANDD device: 9 name: \_SB.PCI0.UA00
[    0.394802] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.394803] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.394804] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.396313] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.396314] x2apic enabled
[    0.396327] Switched APIC routing to cluster x2apic.
[    0.400266] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.414720] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2135f7c97c8, max_idle_ns: 440795273205 ns
[    0.414733] Calibrating delay loop (skipped), value calculated using timer frequency.. 4609.00 BogoMIPS (lpj=7680000)
[    0.414735] pid_max: default: 32768 minimum: 301
[    0.415333] Security Framework initialized
[    0.415334] Yama: becoming mindful.
[    0.415339] AppArmor: AppArmor disabled by boot time parameter
[    0.419178] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[    0.421101] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.421178] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.421238] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.421448] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.421448] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.421461] CPU0: Thermal monitoring enabled (TM1)
[    0.421477] process: using mwait in idle threads
[    0.421479] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.421480] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.421481] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.421482] Spectre V2 : Mitigation: Full generic retpoline
[    0.421483] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.421484] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.421490] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.421491] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.421492] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.421519] MDS: Mitigation: Clear CPU buffers
[    0.421822] Freeing SMP alternatives memory: 28K
[    0.426736] TSC deadline timer enabled
[    0.426740] smpboot: CPU0: Intel(R) Core(TM) i3-6100U CPU @ 2.30GHz (family: 0x6, model: 0x4e, stepping: 0x3)
[    0.444768] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.444802] ... version:                4
[    0.444803] ... bit width:              48
[    0.444803] ... generic registers:      4
[    0.444804] ... value mask:             0000ffffffffffff
[    0.444805] ... max period:             00007fffffffffff
[    0.444805] ... fixed-purpose events:   3
[    0.444806] ... event mask:             000000070000000f
[    0.451404] rcu: Hierarchical SRCU implementation.
[    0.474864] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.481437] smp: Bringing up secondary CPUs ...
[    0.521440] x86: Booting SMP configuration:
[    0.521441] .... node  #0, CPUs:      #1 #2
[    0.561863] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.601441]  #3
[    0.601844] smp: Brought up 1 node, 4 CPUs
[    0.601844] smpboot: Max logical packages: 1
[    0.601844] smpboot: Total of 4 processors activated (18439.00 BogoMIPS)
[    0.605311] devtmpfs: initialized
[    0.605311] x86/mm: Memory block size: 128MB
[    0.606936] PM: Registering ACPI NVS region [mem 0x757d9000-0x757d9fff] (4096 bytes)
[    0.606936] PM: Registering ACPI NVS region [mem 0x7a580000-0x7ae71fff] (9379840 bytes)
[    0.606936] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.606936] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.606936] pinctrl core: initialized pinctrl subsystem
[    0.608059] RTC time: 19:37:13, date: 10/17/19
[    0.608187] NET: Registered protocol family 16
[    0.608264] audit: initializing netlink subsys (disabled)
[    0.608269] audit: type=2000 audit(1571341033.213:1): state=initialized audit_enabled=0 res=1
[    0.608269] cpuidle: using governor ladder
[    0.608269] cpuidle: using governor menu
[    0.608269] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.608269] ACPI: bus type PCI registered
[    0.608269] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.608269] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.608269] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[    0.608269] PCI: Using configuration type 1 for base access
[    0.609291] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.609291] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.609291] ACPI: Added _OSI(Module Device)
[    0.609291] ACPI: Added _OSI(Processor Device)
[    0.609291] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.609291] ACPI: Added _OSI(Processor Aggregator Device)
[    0.609291] ACPI: Added _OSI(Linux-Dell-Video)
[    0.609291] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.654050] ACPI: 8 ACPI AML tables successfully acquired and loaded
[    0.662650] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.667023] ACPI: Dynamic OEM Table Load:
[    0.667029] ACPI: SSDT 0xFFFF91D01AF14000 0005FD (v02 PmRef  Cpu0Ist  00003000 INTL 20120913)
[    0.667714] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[    0.669671] ACPI: Dynamic OEM Table Load:
[    0.669677] ACPI: SSDT 0xFFFF91D01AB39800 00037F (v02 PmRef  Cpu0Cst  00003001 INTL 20120913)
[    0.670246] ACPI: Dynamic OEM Table Load:
[    0.670250] ACPI: SSDT 0xFFFF91D01AF20540 00008E (v02 PmRef  Cpu0Hwp  00003000 INTL 20120913)
[    0.670668] ACPI: Dynamic OEM Table Load:
[    0.670671] ACPI: SSDT 0xFFFF91D01AB78600 000130 (v02 PmRef  HwpLvt   00003000 INTL 20120913)
[    0.671739] ACPI: Dynamic OEM Table Load:
[    0.671745] ACPI: SSDT 0xFFFF91D01AF11800 0005AA (v02 PmRef  ApIst    00003000 INTL 20120913)
[    0.672663] ACPI: Dynamic OEM Table Load:
[    0.672667] ACPI: SSDT 0xFFFF91D01AB78200 000119 (v02 PmRef  ApHwp    00003000 INTL 20120913)
[    0.673190] ACPI: Dynamic OEM Table Load:
[    0.673194] ACPI: SSDT 0xFFFF91D01AB79800 000119 (v02 PmRef  ApCst    00003000 INTL 20120913)
[    0.677226] ACPI: Interpreter enabled
[    0.677270] ACPI: (supports S0 S3 S4 S5)
[    0.677271] ACPI: Using IOAPIC for interrupt routing
[    0.677314] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.678572] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.681850] ACPI: Power Resource [PG00] (on)
[    0.682319] ACPI: Power Resource [PG01] (on)
[    0.682765] ACPI: Power Resource [PG02] (on)
[    0.685475] ACPI: Power Resource [WRST] (on)
[    0.685954] ACPI: Power Resource [WRST] (on)
[    0.686422] ACPI: Power Resource [WRST] (on)
[    0.686885] ACPI: Power Resource [WRST] (on)
[    0.687348] ACPI: Power Resource [WRST] (on)
[    0.687812] ACPI: Power Resource [WRST] (on)
[    0.688279] ACPI: Power Resource [WRST] (on)
[    0.688745] ACPI: Power Resource [WRST] (on)
[    0.689207] ACPI: Power Resource [WRST] (on)
[    0.689863] ACPI: Power Resource [WRST] (on)
[    0.690325] ACPI: Power Resource [WRST] (on)
[    0.690801] ACPI: Power Resource [WRST] (on)
[    0.691282] ACPI: Power Resource [WRST] (on)
[    0.691751] ACPI: Power Resource [WRST] (on)
[    0.692215] ACPI: Power Resource [WRST] (on)
[    0.692677] ACPI: Power Resource [WRST] (on)
[    0.693138] ACPI: Power Resource [WRST] (on)
[    0.693600] ACPI: Power Resource [WRST] (on)
[    0.694062] ACPI: Power Resource [WRST] (on)
[    0.694523] ACPI: Power Resource [WRST] (on)
[    0.709314] ACPI: Power Resource [FN00] (off)
[    0.709437] ACPI: Power Resource [FN01] (off)
[    0.709556] ACPI: Power Resource [FN02] (off)
[    0.709675] ACPI: Power Resource [FN03] (off)
[    0.709793] ACPI: Power Resource [FN04] (off)
[    0.711481] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.711487] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
[    0.711538] acpi PNP0A08:00: _OSC failed (AE_ERROR); disabling ASPM
[    0.712619] PCI host bridge to bus 0000:00
[    0.712621] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.712622] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.712623] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.712624] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[    0.712625] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.712627] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.712636] pci 0000:00:00.0: [8086:1904] type 00 class 0x060000
[    0.713088] pci 0000:00:02.0: [8086:1916] type 00 class 0x030000
[    0.713100] pci 0000:00:02.0: reg 0x10: [mem 0xde000000-0xdeffffff 64bit]
[    0.713106] pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.713111] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.713131] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.713368] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[    0.713393] pci 0000:00:14.0: reg 0x10: [mem 0xdf130000-0xdf13ffff 64bit]
[    0.713472] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.713744] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[    0.713765] pci 0000:00:14.2: reg 0x10: [mem 0xdf150000-0xdf150fff 64bit]
[    0.713980] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[    0.713999] pci 0000:00:16.0: reg 0x10: [mem 0xdf14f000-0xdf14ffff 64bit]
[    0.714056] pci 0000:00:16.0: PME# supported from D3hot
[    0.714253] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601
[    0.714271] pci 0000:00:17.0: reg 0x10: [mem 0xdf148000-0xdf149fff]
[    0.714278] pci 0000:00:17.0: reg 0x14: [mem 0xdf14e000-0xdf14e0ff]
[    0.714285] pci 0000:00:17.0: reg 0x18: [io  0xf090-0xf097]
[    0.714292] pci 0000:00:17.0: reg 0x1c: [io  0xf080-0xf083]
[    0.714299] pci 0000:00:17.0: reg 0x20: [io  0xf060-0xf07f]
[    0.714307] pci 0000:00:17.0: reg 0x24: [mem 0xdf14d000-0xdf14d7ff]
[    0.714349] pci 0000:00:17.0: PME# supported from D3hot
[    0.714556] pci 0000:00:1c.0: [8086:9d14] type 01 class 0x060400
[    0.714653] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.715016] pci 0000:00:1e.0: [8086:9d27] type 00 class 0x118000
[    0.715280] pci 0000:00:1e.0: reg 0x10: [mem 0xdf14c000-0xdf14cfff 64bit]
[    0.716292] pci 0000:00:1e.6: [8086:9d2d] type 00 class 0x080501
[    0.716317] pci 0000:00:1e.6: reg 0x10: [mem 0xdf14b000-0xdf14bfff 64bit]
[    0.716590] pci 0000:00:1f.0: [8086:9d48] type 00 class 0x060100
[    0.716882] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[    0.716899] pci 0000:00:1f.2: reg 0x10: [mem 0xdf144000-0xdf147fff]
[    0.717141] pci 0000:00:1f.3: [8086:9d70] type 00 class 0x040300
[    0.717171] pci 0000:00:1f.3: reg 0x10: [mem 0xdf140000-0xdf143fff 64bit]
[    0.717205] pci 0000:00:1f.3: reg 0x20: [mem 0xdf120000-0xdf12ffff 64bit]
[    0.717260] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.717531] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[    0.717591] pci 0000:00:1f.4: reg 0x10: [mem 0xdf14a000-0xdf14a0ff 64bit]
[    0.717660] pci 0000:00:1f.4: reg 0x20: [io  0xf040-0xf05f]
[    0.717920] pci 0000:00:1f.6: [8086:1570] type 00 class 0x020000
[    0.717945] pci 0000:00:1f.6: reg 0x10: [mem 0xdf100000-0xdf11ffff]
[    0.718049] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold
[    0.718537] pci 0000:01:00.0: [8086:24f3] type 00 class 0x028000
[    0.718637] pci 0000:01:00.0: reg 0x10: [mem 0xdf000000-0xdf001fff 64bit]
[    0.718911] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[    0.719463] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.719467] pci 0000:00:1c.0:   bridge window [mem 0xdf000000-0xdf0fffff]
[    0.722274] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.722358] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.722436] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.722521] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.722605] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.722691] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.722766] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.722843] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.723610] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.723610] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.723610] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.723610] vgaarb: loaded
[    0.723610] ACPI: bus type USB registered
[    0.723610] usbcore: registered new interface driver usbfs
[    0.723610] usbcore: registered new interface driver hub
[    0.723610] usbcore: registered new device driver usb
[    0.723610] pps_core: LinuxPPS API ver. 1 registered
[    0.723610] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.723610] PTP clock support registered
[    0.723610] EDAC MC: Ver: 3.0.0
[    0.723610] Registered efivars operations
[    0.734837] PCI: Using ACPI for IRQ routing
[    0.763093] PCI: pci_cache_line_size set to 64 bytes
[    0.763356] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.763357] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[    0.763358] e820: reserve RAM buffer [mem 0x757d9000-0x77ffffff]
[    0.763359] e820: reserve RAM buffer [mem 0x7a245000-0x7bffffff]
[    0.763360] e820: reserve RAM buffer [mem 0x7b300000-0x7bffffff]
[    0.763361] e820: reserve RAM buffer [mem 0x87f000000-0x87fffffff]
[    0.763452] NetLabel: Initializing
[    0.763452] NetLabel:  domain hash size = 128
[    0.763453] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.763468] NetLabel:  unlabeled traffic allowed by default
[    0.763472] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.763472] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.765751] clocksource: Switched to clocksource tsc-early
[    0.775162] VFS: Disk quotas dquot_6.6.0
[    0.775176] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.775237] pnp: PnP ACPI init
[    0.775627] system 00:00: [io  0x0a00-0x0a2f] has been reserved
[    0.775628] system 00:00: [io  0x0a30-0x0a3f] has been reserved
[    0.775630] system 00:00: [io  0x0a40-0x0a4f] has been reserved
[    0.775634] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.776109] pnp 00:01: [dma 0 disabled]
[    0.776137] pnp 00:01: Plug and Play ACPI device, IDs ITE8713 (active)
[    0.776302] system 00:02: [io  0x0680-0x069f] has been reserved
[    0.776304] system 00:02: [io  0xffff] has been reserved
[    0.776305] system 00:02: [io  0xffff] has been reserved
[    0.776306] system 00:02: [io  0xffff] has been reserved
[    0.776307] system 00:02: [io  0x1800-0x18fe] has been reserved
[    0.776308] system 00:02: [io  0x164e-0x164f] has been reserved
[    0.776312] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.776423] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.776466] system 00:04: [io  0x1854-0x1857] has been reserved
[    0.776469] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.776766] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.776767] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.776769] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.776770] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[    0.776771] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.776772] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.776774] system 00:05: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.776775] system 00:05: [mem 0xff000000-0xffffffff] has been reserved
[    0.776776] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.776778] system 00:05: [mem 0xdffe0000-0xdfffffff] has been reserved
[    0.776781] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.776829] system 00:06: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.776830] system 00:06: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.776831] system 00:06: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.776833] system 00:06: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.776834] system 00:06: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.776835] system 00:06: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.776837] system 00:06: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.776839] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.777209] system 00:07: [io  0xff00-0xfffe] has been reserved
[    0.777212] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.778615] system 00:08: [mem 0xfe029000-0xfe029fff] has been reserved
[    0.778617] system 00:08: [mem 0xfe028000-0xfe028fff] has been reserved
[    0.778620] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.779792] pnp: PnP ACPI: found 9 devices
[    0.785485] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.785501] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.785506] pci 0000:00:1c.0:   bridge window [mem 0xdf000000-0xdf0fffff]
[    0.785513] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.785514] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.785516] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.785517] pci_bus 0000:00: resource 7 [mem 0x80000000-0xdfffffff window]
[    0.785518] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7fffff window]
[    0.785519] pci_bus 0000:01: resource 1 [mem 0xdf000000-0xdf0fffff]
[    0.785704] NET: Registered protocol family 2
[    0.785842] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes)
[    0.785946] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.786236] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    0.786327] TCP: Hash tables configured (established 262144 bind 65536)
[    0.786365] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[    0.786442] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[    0.786533] NET: Registered protocol family 1
[    0.786537] NET: Registered protocol family 44
[    0.786547] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.786982] PCI: CLS 0 bytes, default 64
[    0.787015] Unpacking initramfs...
[    0.923930] Freeing initrd memory: 11048K
[    0.923963] DMAR: ACPI device "device:67" under DMAR at fed91000 as 00:1e.0
[    0.923981] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.923983] software IO TLB: mapped [mem 0x700a4000-0x740a4000] (64MB)
[    0.924008] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2135f7c97c8, max_idle_ns: 440795273205 ns
[    0.924031] clocksource: Switched to clocksource tsc
[    0.924119] Scanning for low memory corruption every 60 seconds
[    0.924643] Initialise system trusted keyrings
[    0.924652] Key type blacklist registered
[    0.924690] workingset: timestamp_bits=41 max_order=23 bucket_order=0
[    0.925842] zbud: loaded
[    0.927251] Key type asymmetric registered
[    0.927252] Asymmetric key parser 'x509' registered
[    0.927260] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[    0.927292] io scheduler noop registered
[    0.927293] io scheduler deadline registered
[    0.927325] io scheduler cfq registered
[    0.927326] io scheduler mq-deadline registered
[    0.927327] io scheduler kyber registered
[    0.927348] io scheduler bfq registered
[    0.927368] io scheduler bfq-sq registered (default)
[    0.927369] BFQ I/O-scheduler: v10 (with cgroups support)
[    0.927387] io scheduler bfq-mq registered
[    0.927388] BFQ I/O-scheduler: v10 (with cgroups support)
[    0.927791] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.927857] efifb: probing for efifb
[    0.927871] efifb: showing boot graphics
[    0.933320] efifb: framebuffer at 0xc0000000, using 8128k, total 8128k
[    0.933321] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[    0.933321] efifb: scrolling: redraw
[    0.933323] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.933372] fbcon: Deferring console take-over
[    0.933373] fb0: EFI VGA frame buffer device
[    0.933381] intel_idle: MWAIT substates: 0x11142120
[    0.933382] intel_idle: v0.4.1 model 0x4E
[    0.933573] intel_idle: lapic_timer_reliable_states 0xffffffff
[    0.933657] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0
[    0.933665] ACPI: Sleep Button [SLPB]
[    0.933695] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.933700] ACPI: Power Button [PWRB]
[    0.933729] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.933738] ACPI: Power Button [PWRF]
[    1.031804] thermal LNXTHERM:00: registered as thermal_zone0
[    1.031806] ACPI: Thermal Zone [TZ00] (28 C)
[    1.032036] thermal LNXTHERM:01: registered as thermal_zone1
[    1.032037] ACPI: Thermal Zone [TZ01] (30 C)
[    1.032305] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.032869] AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    1.032870] AMD IOMMUv2 functionality not available on this system
[    1.033497] usbcore: registered new interface driver usbserial_generic
[    1.033501] usbserial: USB Serial support registered for generic
[    1.033527] rtc_cmos 00:03: RTC can wake from S4
[    1.033989] rtc_cmos 00:03: registered as rtc0
[    1.034004] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    1.034056] intel_pstate: Intel P-state driver initializing
[    1.034299] intel_pstate: HWP enabled
[    1.034338] ledtrig-cpu: registered to indicate activity on CPUs
[    1.034381] intel_pmc_core:  initialized
[    1.034607] NET: Registered protocol family 10
[    1.041336] Segment Routing with IPv6
[    1.041369] NET: Registered protocol family 17
[    1.041943] mce: Using 8 MCE banks
[    1.041963] RAS: Correctable Errors collector initialized.
[    1.042022] microcode: sig=0x406e3, pf=0x80, revision=0xcc
[    1.042166] microcode: Microcode Update Driver: v2.2.
[    1.042181] sched_clock: Marking stable (1041667554, 490398)->(1065281563, -23123611)
[    1.042549] registered taskstats version 1
[    1.042560] Loading compiled-in X.509 certificates
[    1.048160] Loaded X.509 cert 'Build time autogenerated kernel key: 613b968e1b846b8c58f9e4aafb587af40252c757'
[    1.048197] zswap: loaded using pool lzo/zbud
[    1.057095] Key type big_key registered
[    1.059240]   Magic number: 7:898:647
[    1.059309] acpi LNXCPU:00: hash matches
[    1.059467] rtc_cmos 00:03: setting system clock to 2019-10-17 19:37:14 UTC (1571341034)
[    1.062713] Freeing unused decrypted memory: 2040K
[    1.064329] Freeing unused kernel image memory: 1552K
[    1.064402] Write protecting the kernel read-only data: 18432k
[    1.065434] Freeing unused kernel image memory: 2008K
[    1.065702] Freeing unused kernel image memory: 472K
[    1.086332] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.086333] x86/mm: Checking user space page tables
[    1.098233] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    1.098234] Run /init as init process
[    1.227872] SCSI subsystem initialized
[    1.232807] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.232815] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    1.233926] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[    1.233937] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    1.234276] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.234279] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.234281] usb usb1: Product: xHCI Host Controller
[    1.234282] usb usb1: Manufacturer: Linux 4.19.79-1-MANJARO xhci-hcd
[    1.234284] usb usb1: SerialNumber: 0000:00:14.0
[    1.234514] hub 1-0:1.0: USB hub found
[    1.234611] hub 1-0:1.0: 12 ports detected
[    1.237404] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.237409] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.237413] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    1.237478] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.237480] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.237482] usb usb2: Product: xHCI Host Controller
[    1.237484] usb usb2: Manufacturer: Linux 4.19.79-1-MANJARO xhci-hcd
[    1.237485] usb usb2: SerialNumber: 0000:00:14.0
[    1.237650] sdhci: Secure Digital Host Controller Interface driver
[    1.237650] sdhci: Copyright(c) Pierre Ossman
[    1.237729] libata version 3.00 loaded.
[    1.237846] hub 2-0:1.0: USB hub found
[    1.237867] hub 2-0:1.0: 6 ports detected
[    1.243059] ahci 0000:00:17.0: version 3.0
[    1.243378] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x5 impl SATA mode
[    1.243381] ahci 0000:00:17.0: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[    1.243399] sdhci-pci 0000:00:1e.6: SDHCI controller found [8086:9d2d] (rev 21)
[    1.243785] sdhci-pci 0000:00:1e.6: failed to setup card detect gpio
[    1.244077] mmc0: SDHCI controller on PCI [0000:00:1e.6] using ADMA 64-bit
[    1.244225] scsi host0: ahci
[    1.244382] scsi host1: ahci
[    1.244473] scsi host2: ahci
[    1.244679] ata1: SATA max UDMA/133 abar m2048@0xdf14d000 port 0xdf14d100 irq 123
[    1.244680] ata2: DUMMY
[    1.244682] ata3: SATA max UDMA/133 abar m2048@0xdf14d000 port 0xdf14d200 irq 123
[    1.559798] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.559832] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    1.560306] ata1.00: supports DRM functions and may not be fully accessible
[    1.561216] ata3.00: ATA-9: TS32GMTS800, O1225G, max UDMA/133
[    1.561220] ata3.00: 62533296 sectors, multi 2: LBA48 NCQ (depth 32), AA
[    1.561268] ata1.00: disabling queued TRIM support
[    1.561271] ata1.00: ATA-9: Samsung SSD 850 EVO 1TB, EMT02B6Q, max UDMA/133
[    1.561273] ata1.00: 1953525168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    1.562448] ata3.00: configured for UDMA/133
[    1.562462] ahci 0000:00:17.0: port does not support device sleep
[    1.563623] ata1.00: supports DRM functions and may not be fully accessible
[    1.564570] ata1.00: disabling queued TRIM support
[    1.564775] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[    1.566440] ata1.00: configured for UDMA/133
[    1.576631] ahci 0000:00:17.0: port does not support device sleep
[    1.577085] scsi 0:0:0:0: Direct-Access     ATA      Samsung SSD 850  2B6Q PQ: 0 ANSI: 5
[    1.577763] scsi 2:0:0:0: Direct-Access     ATA      TS32GMTS800      5G   PQ: 0 ANSI: 5
[    1.592191] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    1.592212] sd 0:0:0:0: [sda] Write Protect is off
[    1.592217] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    1.592241] sd 2:0:0:0: [sdb] 62533296 512-byte logical blocks: (32.0 GB/29.8 GiB)
[    1.592243] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.592255] sd 2:0:0:0: [sdb] Write Protect is off
[    1.592259] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    1.592285] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.594845]  sda: sda1 sda2 sda3
[    1.595797] sd 0:0:0:0: [sda] supports TCG Opal
[    1.595800] sd 0:0:0:0: [sda] Attached SCSI disk
[    1.596485]  sdb: sdb1
[    1.597097] sd 2:0:0:0: [sdb] Attached SCSI disk
[    1.657791] PM: Image not found (code -22)
[    1.668148] random: fast init done
[    1.706547] usb 1-3: New USB device found, idVendor=2109, idProduct=2813, bcdDevice= 2.21
[    1.706550] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.706552] usb 1-3: Product: USB2.0 Hub
[    1.706554] usb 1-3: Manufacturer: VIA Labs, Inc.
[    1.707473] hub 1-3:1.0: USB hub found
[    1.707673] hub 1-3:1.0: 4 ports detected
[    1.729697] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    1.828124] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[    1.841258] systemd[1]: systemd 242.135-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[    1.845814] usb 2-1: New USB device found, idVendor=1058, idProduct=0748, bcdDevice=10.19
[    1.845816] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[    1.845818] usb 2-1: Product: My Passport 0748
[    1.845819] usb 2-1: Manufacturer: Western Digital
[    1.845820] usb 2-1: SerialNumber: 57584B314537325A454D3936
[    1.854914] systemd[1]: Detected architecture x86-64.
[    1.862415] systemd[1]: Set hostname to <philip-pc>.
[    1.968086] usb 1-4: new high-speed USB device number 3 using xhci_hcd
[    2.044374] systemd[1]: Listening on udev Control Socket.
[    2.047597] systemd[1]: Listening on Process Core Dump Socket.
[    2.047832] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    2.047844] systemd[1]: Reached target Login Prompts.
[    2.047900] systemd[1]: Listening on udev Kernel Socket.
[    2.047947] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[    2.048031] systemd[1]: Listening on Journal Socket (/dev/log).
[    2.065118] EXT4-fs (sda2): re-mounted. Opts: discard
[    2.080371] random: systemd-random-: uninitialized urandom read (512 bytes read)
[    2.082461] random: lvm: uninitialized urandom read (4 bytes read)
[    2.108607] usb 1-4: New USB device found, idVendor=03f0, idProduct=3b2a, bcdDevice= 1.00
[    2.108610] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.108612] usb 1-4: Product: HP Color LaserJet MFP M277dw
[    2.108614] usb 1-4: Manufacturer: Hewlett-Packard
[    2.108616] usb 1-4: SerialNumber: VNB8HD7D20
[    2.295361] usb 2-3: new SuperSpeed Gen 1 USB device number 3 using xhci_hcd
[    2.381697] audit: type=1130 audit(1571341035.820:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.391087] systemd-journald[217]: Received request to flush runtime journal from PID 1
[    2.435986] usb 2-3: New USB device found, idVendor=2109, idProduct=0813, bcdDevice= 2.21
[    2.435989] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.435991] usb 2-3: Product: USB3.0 Hub
[    2.435992] usb 2-3: Manufacturer: VIA Labs, Inc.
[    2.438490] hub 2-3:1.0: USB hub found
[    2.438780] hub 2-3:1.0: 4 ports detected
[    2.466514] audit: type=1130 audit(1571341035.903:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.502541] audit: type=1130 audit(1571341035.939:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.521412] usb 1-3.1: new high-speed USB device number 4 using xhci_hcd
[    2.623092] usb 1-3.1: New USB device found, idVendor=2109, idProduct=2813, bcdDevice= 2.21
[    2.623095] usb 1-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.623097] usb 1-3.1: Product: USB2.0 Hub
[    2.623099] usb 1-3.1: Manufacturer: VIA Labs, Inc.
[    2.624062] hub 1-3.1:1.0: USB hub found
[    2.624243] hub 1-3.1:1.0: 4 ports detected
[    2.633630] ite_cir: Auto-detected model: ITE8713 CIR transceiver
[    2.633631] ite_cir: Using model: ITE8713 CIR transceiver
[    2.633633] ite_cir: TX-capable: 1
[    2.633634] ite_cir: Sample period (ns): 8680
[    2.633635] ite_cir: TX carrier frequency (Hz): 38000
[    2.633636] ite_cir: TX duty cycle (%): 33
[    2.633637] ite_cir: RX low carrier frequency (Hz): 0
[    2.633638] ite_cir: RX high carrier frequency (Hz): 0
[    2.680864] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    2.684772] Registered IR keymap rc-rc6-mce
[    2.691641] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0002)
[    2.692460] IR RC6 protocol handler initialized
[    2.692524] input: PC Speaker as /devices/platform/pcspkr/input/input4
[    2.718108] rc rc0: ITE8713 CIR transceiver as /devices/virtual/rc/rc0
[    2.718171] input: ITE8713 CIR transceiver as /devices/virtual/rc/rc0/input3
[    2.718304] rc rc0: lirc_dev: driver ite-cir registered at minor = 0, raw IR receiver, raw IR transmitter
[    2.721378] ite_cir: driver has been successfully loaded
[    2.745174] usb 1-7: new full-speed USB device number 5 using xhci_hcd
[    2.747561] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    2.747563] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.747846] e1000e 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[    2.748688] idma64 idma64.0: Found Intel integrated DMA 64-bit
[    2.755321] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[    2.755323] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    2.755324] RAPL PMU: hw unit of domain package 2^-14 Joules
[    2.755325] RAPL PMU: hw unit of domain dram 2^-14 Joules
[    2.755326] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[    2.755327] RAPL PMU: hw unit of domain psys 2^-14 Joules
[    2.772333] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[    2.811718] Linux agpgart interface v0.103
[    2.855065] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    2.859117] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    2.889213] usb 1-7: New USB device found, idVendor=8087, idProduct=0a2b, bcdDevice= 0.01
[    2.889221] usb 1-7: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.927072] Adding 36103664k swap on /dev/sda3.  Priority:-2 extents:1 across:36103664k SSDscFS
[    2.966137] iTCO_vendor_support: vendor-support=0
[    2.971446] usb 1-3.4: new full-speed USB device number 6 using xhci_hcd
[    2.988972] audit: type=1130 audit(1571341036.426:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    2.993884] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    2.994014] random: python: uninitialized urandom read (24 bytes read)
[    2.994170] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[    2.994612] dw-apb-uart.0: ttyS0 at MMIO 0xdf14c000 (irq = 20, base_baud = 115200) is a 16550A
[    3.001367] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    3.008226] cryptd: max_cpu_qlen set to 1000
[    3.022654] loop: module loaded
[    3.069434] e1000e 0000:00:1f.6 0000:00:1f.6 (uninitialized): registered PHC clock
[    3.073113] usb 1-3.4: New USB device found, idVendor=1050, idProduct=0116, bcdDevice= 3.49
[    3.073116] usb 1-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.073118] usb 1-3.4: Product: Yubikey NEO OTP+U2F+CCID
[    3.073120] usb 1-3.4: Manufacturer: Yubico
[    3.073853] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.080916] audit: type=1130 audit(1571341036.516:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-3F51\x2d8E0E comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.092862] Intel(R) Wireless WiFi driver for Linux
[    3.092863] Copyright(c) 2003- 2015 Intel Corporation
[    3.093095] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[    3.094093] AVX2 version of gcm_enc/dec engaged.
[    3.094095] AES CTR mode by8 optimization enabled
[    3.103684] iwlwifi 0000:01:00.0: Found debug destination: EXTERNAL_DRAM
[    3.103687] iwlwifi 0000:01:00.0: Found debug configuration: 0
[    3.104415] iwlwifi 0000:01:00.0: loaded firmware version 36.77d01142.0 op_mode iwlmvm
[    3.183134] e1000e 0000:00:1f.6 eth0: (PCI Express:2.5GT/s:Width x1) b8:ae:ed:eb:d9:83
[    3.183145] e1000e 0000:00:1f.6 eth0: Intel(R) PRO/1000 Network Connection
[    3.183213] e1000e 0000:00:1f.6 eth0: MAC: 12, PHY: 12, PBA No: FFFFFF-0FF
[    3.186397] e1000e 0000:00:1f.6 eno1: renamed from eth0
[    3.208788] usb 2-3.1: new SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[    3.295988] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8260, REV=0x208
[    3.303005] iwlwifi 0000:01:00.0: Applying debug destination EXTERNAL_DRAM
[    3.303006] VFIO - User Level meta-driver version: 0.3
[    3.303323] iwlwifi 0000:01:00.0: Allocated 0x00400000 bytes (order 10) for firmware monitor.
[    3.355893] usb 2-3.1: New USB device found, idVendor=2109, idProduct=0813, bcdDevice= 2.21
[    3.355896] usb 2-3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.355898] usb 2-3.1: Product: USB3.0 Hub
[    3.355900] usb 2-3.1: Manufacturer: VIA Labs, Inc.
[    3.358869] hub 2-3.1:1.0: USB hub found
[    3.359176] hub 2-3.1:1.0: 4 ports detected
[    3.378635] iwlwifi 0000:01:00.0: base HW address: 00:c2:c6:c9:d7:3b
[    3.384260] random: crng init done
[    3.400181] audit: type=1130 audit(1571341036.836:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.411188] audit: type=1127 audit(1571341036.846:8): pid=383 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[    3.415630] audit: type=1130 audit(1571341036.853:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.425532] audit: type=1130 audit(1571341036.863:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    3.438083] usb 1-3.1.1: new full-speed USB device number 7 using xhci_hcd
[    3.485273] intel_rapl: Found RAPL domain package
[    3.485276] intel_rapl: Found RAPL domain core
[    3.485277] intel_rapl: Found RAPL domain uncore
[    3.485278] intel_rapl: Found RAPL domain dram
[    3.501748] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[    3.502105] thermal thermal_zone4: failed to read out thermal zone (-61)
[    3.508852] iwlwifi 0000:01:00.0 wlp1s0: renamed from wlan0
[    3.543358] usb 1-3.1.1: New USB device found, idVendor=062a, idProduct=4102, bcdDevice= 3.21
[    3.543361] usb 1-3.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.543363] usb 1-3.1.1: Product: 2.4G Wireless Mouse
[    3.543365] usb 1-3.1.1: Manufacturer: MOSART Semi.
[    3.598357] checking generic (c0000000 7f0000) vs hw (c0000000 10000000)
[    3.598360] fb: switching to inteldrmfb from EFI VGA
[    3.598442] [drm] Replacing VGA console driver
[    3.599486] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.599487] [drm] Driver supports precise vblank timestamp query.
[    3.600071] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    3.601564] [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[    3.674742] usb 1-3.1.2: new low-speed USB device number 8 using xhci_hcd
[    3.830538] usb 1-3.1.2: New USB device found, idVendor=060b, idProduct=0595, bcdDevice= 1.30
[    3.830541] usb 1-3.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    3.830543] usb 1-3.1.2: Product: USB Keyboard
[    3.872886] [drm] Initialized i915 1.6.0 20180719 for 0000:00:02.0 on minor 0
[    3.875753] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    3.876365] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[    3.876579] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.907826] fbcon: inteldrmfb (fb0) is primary device
[    3.907828] fbcon: Deferring console take-over
[    3.907831] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[    3.911027] WARNING! power/level is deprecated; use power/control instead
[    3.922872] usblp 1-4:1.1: usblp0: USB Bidirectional printer dev 3 if 1 alt 0 proto 2 vid 0x03F0 pid 0x3B2A
[    3.923611] usbcore: registered new interface driver usblp
[    4.022496] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC283: line_outs=1 (0x21/0x0/0x0/0x0/0x0) type:hp
[    4.022499] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.022500] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    4.022501] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[    4.022502] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[    4.022503] snd_hda_codec_realtek hdaudioC0D0:      Mic=0x19
[    4.110502] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1f.3/sound/card0/input6
[    4.118321] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input7
[    4.118403] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input8
[    4.118485] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input9
[    4.118569] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input10
[    4.118645] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[    4.118722] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[    4.118796] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[    4.748848] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[    4.964980] IPv6: ADDRCONF(NETDEV_UP): eno1: link is not ready
[    4.973377] IPv6: ADDRCONF(NETDEV_UP): wlp1s0: link is not ready
[    5.528126] fuse init (API version 7.27)
[    5.664757] kauditd_printk_skb: 32 callbacks suppressed
[    5.664759] audit: type=1130 audit(1571341039.100:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snap.hplip-printer-application.run-server comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.664763] audit: type=1131 audit(1571341039.100:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snap.hplip-printer-application.run-server comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.665712] audit: type=1130 audit(1571341039.103:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snap.hplip-printer-application.run-server comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    5.700642] audit: type=1326 audit(1571341039.136:45): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=738 comm="server" exe="/snap/hplip-printer-application/3/bin/server" sig=0 arch=c000003e syscall=41 compat=0 ip=0x7f305efb2ec7 code=0x50000
[    5.700852] server[758]: segfault at 1a0 ip 00007f305f284ab0 sp 00007f305afcdc28 error 4 in libudev.so.1.6.9[7f305f281000+1d000]
[    5.700858] Code: 66 2e 0f 1f 84 00 00 00 00 00 45 85 c9 74 0c 4c 8d 57 01 4c 89 c5 e9 7a ff ff ff 48 8b 41 08 48 01 d8 5b 5d c3 0f 1f 44 00 00 <48> 8b 47 08 48 83 c7 08 ba 00 00 00 00 48 39 f8 48 0f 44 c2 c3 90
[    5.700880] audit: type=1701 audit(1571341039.136:46): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=738 comm="server" exe="/snap/hplip-printer-application/3/bin/server" sig=11 res=1
[    5.712706] audit: type=1130 audit(1571341039.150:47): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-760-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.280015] audit: type=1131 audit(1571341039.716:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snap.hplip-printer-application.run-server comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[    6.312503] audit: type=1131 audit(1571341039.750:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@1-760-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    6.630316] audit: type=1130 audit(1571341040.066:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snap.hplip-printer-application.run-server comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[    7.937517] e1000e: eno1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx
[    7.937576] IPv6: ADDRCONF(NETDEV_CHANGE): eno1: link becomes ready
[    9.166254] usblp0: removed
[   11.141084] kauditd_printk_skb: 29 callbacks suppressed
[   11.141086] audit: type=1131 audit(1571341044.576:77): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=configure-printer@usb-001-003 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.010833] audit: type=1131 audit(1571341048.446:78): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   19.424732] audit: type=1326 audit(1571341052.860:79): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=935 comm=506C65782054756E65722053657276 exe=2F736E61702F706C65786D656469617365727665722F33332F506C65782054756E65722053657276696365 sig=0 arch=c000003e syscall=41 compat=0 ip=0x7fdfdd05d5a7 code=0x50000
[   19.424791] audit: type=1326 audit(1571341052.863:80): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=935 comm=506C65782054756E65722053657276 exe=2F736E61702F706C65786D656469617365727665722F33332F506C65782054756E65722053657276696365 sig=0 arch=c000003e syscall=41 compat=0 ip=0x7fdfdd05d5a7 code=0x50000
[   24.227301] usb-storage 2-1:1.0: USB Mass Storage device detected
[   24.238086] scsi host3: usb-storage 2-1:1.0
[   24.238435] usbcore: registered new interface driver usb-storage
[   24.245836] usbcore: registered new interface driver uas
[   24.262710] Bluetooth: Core ver 2.22
[   24.262813] NET: Registered protocol family 31
[   24.262814] Bluetooth: HCI device and connection manager initialized
[   24.262818] Bluetooth: HCI socket layer initialized
[   24.262821] Bluetooth: L2CAP socket layer initialized
[   24.262829] Bluetooth: SCO socket layer initialized
[   24.275156] hidraw: raw HID events driver (C) Jiri Kosina
[   24.289427] usbcore: registered new interface driver btusb
[   24.292082] usbcore: registered new interface driver usbhid
[   24.292083] usbhid: USB HID core driver
[   24.295065] Bluetooth: hci0: Firmware revision 0.0 build 10 week 41 2018
[   24.309032] input: Yubico Yubikey NEO OTP+U2F+CCID as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.4/1-3.4:1.0/0003:1050:0116.0001/input/input14
[   24.310614] audit: type=1130 audit(1571341057.746:81): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.350355] audit: type=1130 audit(1571341057.786:82): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.357373] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   24.357375] Bluetooth: BNEP filters: protocol multicast
[   24.357379] Bluetooth: BNEP socket layer initialized
[   24.363371] NET: Registered protocol family 38
[   24.364892] hid-generic 0003:1050:0116.0001: input,hidraw0: USB HID v1.10 Keyboard [Yubico Yubikey NEO OTP+U2F+CCID] on usb-0000:00:14.0-3.4/input0
[   24.365099] hid-generic 0003:1050:0116.0002: hiddev0,hidraw1: USB HID v1.10 Device [Yubico Yubikey NEO OTP+U2F+CCID] on usb-0000:00:14.0-3.4/input1
[   24.365272] input: MOSART Semi. 2.4G Wireless Mouse Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1.1/1-3.1.1:1.0/0003:062A:4102.0003/input/input15
[   24.365351] input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1.1/1-3.1.1:1.0/0003:062A:4102.0003/input/input16
[   24.365456] hid-generic 0003:062A:4102.0003: input,hiddev1,hidraw2: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wireless Mouse] on usb-0000:00:14.0-3.1.1/input0
[   24.365616] input: USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3.1/1-3.1.2/1-3.1.2:1.0/0003:060B:0595.0004/input/input17
[   24.421811] hid-generic 0003:060B:0595.0004: input,hidraw3: USB HID v1.11 Keyboard [USB Keyboard] on usb-0000:00:14.0-3.1.2/input0
[   24.443341] mousedev: PS/2 mouse device common for all mice
[   25.249339] scsi 3:0:0:0: Direct-Access     WD       My Passport 0748 1019 PQ: 0 ANSI: 6
[   25.249740] scsi 3:0:0:1: Enclosure         WD       SES Device       1019 PQ: 0 ANSI: 6
[   25.251129] sd 3:0:0:0: [sdc] 3906963456 512-byte logical blocks: (2.00 TB/1.82 TiB)
[   25.251437] sd 3:0:0:0: [sdc] Write Protect is off
[   25.251443] sd 3:0:0:0: [sdc] Mode Sense: 47 00 10 08
[   25.251712] sd 3:0:0:0: [sdc] No Caching mode page found
[   25.251717] sd 3:0:0:0: [sdc] Assuming drive cache: write through
[   25.256726]  sdc: sdc1
[   25.257727] sd 3:0:0:0: [sdc] Attached SCSI disk
[   25.271187] scsi 3:0:0:1: Wrong diagnostic page; asked for 1 got 8
[   25.271190] scsi 3:0:0:1: Failed to get diagnostic page 0x1
[   25.271191] scsi 3:0:0:1: Failed to bind enclosure -19
[   25.271208] ses 3:0:0:1: Attached Enclosure device
[   25.934295] audit: type=1130 audit(1571341059.370:83): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-fd29672f\x2d700e\x2d47db\x2d9784\x2dc3722447467c comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.051296] EXT4-fs (sdc1): mounting with "discard" option, but the device does not support discard
[   26.051299] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: discard
[   29.306474] audit: type=1131 audit(1571341062.743:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.737425] audit: type=1006 audit(1571341068.170:85): pid=763 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   34.761109] audit: type=1130 audit(1571341068.193:86): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.767716] audit: type=1006 audit(1571341068.199:87): pid=1106 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
[   34.835414] audit: type=1130 audit(1571341068.268:88): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   34.859267] audit: type=1112 audit(1571341068.290:89): pid=763 uid=0 auid=1000 ses=2 msg='op=login id=1000 exe="/usr/bin/lightdm" hostname=philip-pc addr=? terminal=/dev/tty7 res=success'
[   35.694288] audit: type=1130 audit(1571341069.110:90): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   36.012973] Bluetooth: RFCOMM TTY layer initialized
[   36.012979] Bluetooth: RFCOMM socket layer initialized
[   36.012986] Bluetooth: RFCOMM ver 1.11
[   36.892701] audit: type=1130 audit(1571341070.286:91): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.045529] audit: type=1130 audit(1571341071.422:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.057824] audit: type=1131 audit(1571341071.432:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.417664] audit: type=1130 audit(1571341071.791:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   45.141441] kauditd_printk_skb: 1 callbacks suppressed
[   45.141444] audit: type=1131 audit(1571341078.452:96): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   45.169185] audit: type=1131 audit(1571341078.478:97): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@620 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   54.589285] audit: type=1131 audit(1571341087.873:98): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   68.800450] audit: type=1131 audit(1571341102.073:99): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  134.739612] audit: type=1130 audit(1571341168.014:100): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  346.067978] Did not find alt setting 1 for intf 0, config 1
[  603.452038] Did not find alt setting 1 for intf 0, config 1
[  840.554220] audit: type=1131 audit(1571341873.840:101): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  843.356697] audit: type=1130 audit(1571341876.643:102): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  919.245854] audit: type=1130 audit(1571341952.534:103): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  919.245859] audit: type=1131 audit(1571341952.534:104): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1083.231904] traps: xfwm4[1178] trap int3 ip:7f8fca1291c6 sp:7fff9e8e5180 error:0 in libglib-2.0.so.0.6200.1[7f8fca0e1000+81000]
[ 1083.231938] audit: type=1701 audit(1571342116.524:105): auid=1000 uid=1000 gid=1000 ses=2 pid=1178 comm="xfwm4" exe="/usr/bin/xfwm4" sig=5 res=1
[ 1083.247888] audit: type=1130 audit(1571342116.541:106): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-5887-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1084.852756] audit: type=1131 audit(1571342118.144:107): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-5887-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1092.556056] Did not find alt setting 1 for intf 0, config 1
[ 1092.556403] Did not find alt setting 1 for intf 0, config 1
[ 1096.501980] Did not find alt setting 1 for intf 0, config 1
[ 1096.502303] Did not find alt setting 1 for intf 0, config 1
[ 1099.711099] audit: type=1131 audit(1571342133.004:108): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 1168.213070] Did not find alt setting 1 for intf 0, config 1
[ 1168.213434] Did not find alt setting 1 for intf 0, config 1
[ 1181.858504] Did not find alt setting 1 for intf 0, config 1
[ 1181.859633] Did not find alt setting 1 for intf 0, config 1
[ 1182.027680] Did not find alt setting 1 for intf 0, config 1
[ 5937.414730] Did not find alt setting 1 for intf 0, config 1
[ 6053.516601] Did not find alt setting 1 for intf 0, config 1
[ 6053.518363] Did not find alt setting 1 for intf 0, config 1
[ 6094.947164] audit: type=1130 audit(1571347128.340:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6103.311400] audit: type=1131 audit(1571347136.704:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6117.903812] Did not find alt setting 1 for intf 0, config 1
[ 6295.353416] Did not find alt setting 1 for intf 0, config 1
[ 6295.353741] Did not find alt setting 1 for intf 0, config 1
[ 6721.068284] audit: type=1130 audit(1571347754.474:111): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6781.605343] audit: type=1131 audit(1571347815.012:112): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6814.383221] audit: type=1130 audit(1571347847.789:113): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 7454.810517] audit: type=1131 audit(1571348488.228:114): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8320.381784] audit: type=1130 audit(1571349353.818:115): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8350.434275] audit: type=1131 audit(1571349383.872:116): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8353.082379] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
[ 8889.280092] audit: type=1130 audit(1571349922.730:117): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 8919.339169] audit: type=1131 audit(1571349952.788:118): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9064.958043] audit: type=1130 audit(1571350098.410:119): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9095.022240] audit: type=1131 audit(1571350128.474:120): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9785.385450] traps: Shift[17557] general protection ip:38a58c0 sp:7fff9f8bf528 error:0 in Shift[1bf2000+4e42000]
[ 9785.385483] audit: type=1701 audit(1571350818.851:121): auid=1000 uid=1000 gid=1000 ses=2 pid=17557 comm="Shift" exe="/run/media/philip/32GB/shift-linux-v3.9.0/Shift" sig=11 res=1
[ 9785.406054] audit: type=1130 audit(1571350818.871:122): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@6-19951-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9790.336851] audit: type=1131 audit(1571350823.801:123): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@6-19951-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9940.524600] audit: type=1130 audit(1571350973.991:124): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10081.066952] Did not find alt setting 1 for intf 0, config 1
[10149.893907] audit: type=1131 audit(1571351183.368:125): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10291.332819] audit: type=1130 audit(1571351324.808:126): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10321.408074] audit: type=1131 audit(1571351354.885:127): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10419.297666] audit: type=1130 audit(1571351452.777:128): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10449.362473] audit: type=1131 audit(1571351482.840:129): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10610.501342] Did not find alt setting 1 for intf 0, config 1
[10610.501729] Did not find alt setting 1 for intf 0, config 1
[10631.464611] audit: type=1130 audit(1571351664.944:130): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10781.519423] Did not find alt setting 1 for intf 0, config 1
[10850.599890] audit: type=1131 audit(1571351884.085:131): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[10856.454942] Did not find alt setting 1 for intf 0, config 1
[10889.937381] Did not find alt setting 1 for intf 0, config 1
[10916.130702] Did not find alt setting 1 for intf 0, config 1
[11064.898853] Did not find alt setting 1 for intf 0, config 1
[11064.900229] Did not find alt setting 1 for intf 0, config 1
[11077.475060] Did not find alt setting 1 for intf 0, config 1
[11087.622639] Did not find alt setting 1 for intf 0, config 1
[11087.623372] Did not find alt setting 1 for intf 0, config 1
[11496.799431] Did not find alt setting 1 for intf 0, config 1
[11496.799776] Did not find alt setting 1 for intf 0, config 1
[11549.116885] audit: type=1130 audit(1571352582.614:132): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11579.177631] audit: type=1131 audit(1571352612.678:133): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11603.339868] audit: type=1130 audit(1571352636.842:134): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11633.409883] audit: type=1131 audit(1571352666.913:135): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[11950.704883] Did not find alt setting 1 for intf 0, config 1
[11950.706198] Did not find alt setting 1 for intf 0, config 1
[11970.403764] Did not find alt setting 1 for intf 0, config 1
[11970.404105] Did not find alt setting 1 for intf 0, config 1
[12031.720138] Did not find alt setting 1 for intf 0, config 1
[12908.644043] audit: type=1130 audit(1571353942.171:136): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12938.716960] audit: type=1131 audit(1571353972.245:137): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12960.742281] audit: type=1130 audit(1571353994.269:138): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[12990.805972] audit: type=1131 audit(1571354024.336:139): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[13236.544305] Did not find alt setting 1 for intf 0, config 1
[37372.947272] audit: type=1130 audit(1571378406.964:140): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37372.980988] audit: type=1131 audit(1571378406.997:141): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[37373.150048] audit: type=1130 audit(1571378407.167:142): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37373.150052] audit: type=1131 audit(1571378407.167:143): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37376.056019] audit: type=1130 audit(1571378410.074:144): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[37376.056200] audit: type=1131 audit(1571378410.074:145): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=updatedb comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38047.523239] audit: type=1130 audit(1571379081.554:146): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[38047.523243] audit: type=1131 audit(1571379081.554:147): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[62017.385609] Did not find alt setting 1 for intf 0, config 1
[64572.058959] Did not find alt setting 1 for intf 0, config 1
Do you have HP Device Manager installed or hplip Minimal? Welcome to the community by the way.
you need to run hp-plugin from the terminal if you are using the scanner connected over USB as indicated by your output above. printer-network is a misleading tag
This, but you need the plugin also if you use the scanner over network.
i use my hp mfp scanner over the network without the plugin installed, i guess they improved the MFP function network support for newer devices in the main driver
I use a HP 4520
  • open the embedded webserver - (ip address or network name)
    -> click scan
    -> select output format (pdf/png)
    -> Start scan
    -> save either pdf or png to local storage.
Quite easy - even from a smartphone.
Thank you inkrypted, the help available in the community is amazing!
I have HP Device Manager installed.
The weird thing is my scanner is connected to the network. There is no USB connection.
When I run the command hp-plugin I get the message "Unable to receive key from keyserver
Thanks Phrosgone. I downloaded the plugin but still can't get hp-plugin to work. I keep getting the message "Unable to receive key from keyserver"
Thanks micsim35. For some reason or other I am not able to connect to the printer over my network. Maybe that's the problem here.
Thanks linux-aarhus.
I understand about the webserver. My problem is getting its IP address. I think I'll focus on that and see if I can solve the problem.
You could try using an ip scanner like Angry IP Scanner
https://angryip.org/
You can get from the repo
However if you cannot connect to it I doubt it would show up in a scan but everything is worth a try.
Thanks inkrypted,
I'll check out Angry IP Scanner. Sounds useful.
However I fixed the problem. YAY!!
I had to do two things.
First, I kept getting stuck on adding the hp-plugin. As I noted earlier I kept getting an error message. I then downloaded the plugin and manually installed. I had to ignore a warning message. That's what I messed up before. I kept exiting. When I said "OK install it anyway" it worked.
Second I ran hp-setup and then did a manual search for my printer. (10.0.0.77). It was found instantly and everything installed and worked.
Thanks for the help from all the wonderful people in the community. I increased my knowledge of Manjaro and got my problem solved --- AWESOME.
The error message you get is about that the key cannot be validated, if you still want to install the plugin. If you click on "yes" plugin will be installed anyway.
Or you can download the plugin from here: https://developers.hp.com/sites/default/files/hplip-3.19.8-plugin.run and select to install the plugin from a local copy and select the downloaded file.
Hey that's great. I had to install the HP Device Manager which also installed the simple scanner program and my printer had the ability to set up the network manually and print out a report with the IP address and all so it was really easy. But they are not all like that. Just glad you got yours figured out.
You can setup the scan to retrieve the MAC address and vendor which will help in identifiying the IPs.
The angry ip scanner - is available from the repo.
sudo pacman -Syu ipscan
Most Manjaro editions comes with AVAHI - and using that tool you can easily lookup services on your network and their addresses.
Install the commandline utility arp-scan
sudo pacman -Syu arpscan
When installed run
sudo arp-scan --local
Thanks Phrosgone, thats a great link!
Thanks!
