[SOLVED] Input not supported after installing NVIDIA drivers
So I installed NVIDIA drivers after i installed Manjaro and when I rebooted and it showed input not supported but then i switched my VGA cable to the motherboard and it worked but whenever i connect back to my GPU it doesn't work (I'm using a VGA to display port to connect to my GPU)
running inxi -Fxz showed me this
System: Host: hamzailer Kernel: 5.7.9-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.1.0 Desktop: KDE Plasma 5.19.3 Distro: Manjaro Linux
Machine: Type: Desktop System: HP product: HP Pavilion Desktop 590-p0xxx v: N/A
serial:
Mobo: HP model: 8433 v: 11 serial: UEFI: AMI v: F.40
date: 10/31/2019
CPU: Topology: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics
bits: 64 type: MCP arch: Zen L2 cache: 2048 KiB
bogomips: 27956
Speed: 1477 MHz min/max: 1600/3500 MHz Core speeds (MHz): 1: 1476 2: 1475
3: 1477 4: 3674
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: Hewlett-Packard
driver: nvidia v: 440.100 bus ID: 10:00.0
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 38:00.0
Display: x11 server: X.Org 1.20.8 driver: amdgpu,nvidia FAILED: ati
unloaded: modesetting,nouveau resolution: 1440x900~60Hz
OpenGL: renderer: AMD RAVEN (DRM 3.37.0 5.7.9-1-MANJARO LLVM 10.0.0)
v: 4.6 Mesa 20.1.3 direct render: Yes
Audio: Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 38:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: N/A bus ID: 38:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 38:00.6
Sound Server: ALSA v: k5.7.9-1-MANJARO
Network: Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A port: e000 bus ID: 17:00.0
vendor: Hewlett-Packard driver: r8168 v: 8.048.03-NAPI port: d000
bus ID: 2e:00.0
IF: enp46s0 state: up speed: 100 Mbps duplex: full mac:
Drives: Local Storage: total: 1.03 TiB used: 77.94 GiB (7.4%)
ID-1: /dev/sda vendor: Samsung model: MZ7PD128HCFV-000H1 size: 119.24 GiB
ID-2: /dev/sdb vendor: Seagate model: ST91000640NS size: 931.51 GiB
Partition: ID-1: / size: 116.38 GiB used: 23.09 GiB (19.8%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 915.89 GiB used: 54.85 GiB (6.0%) fs: ext4 dev: /dev/sdb1
Sensors: System Temperatures: cpu: 47.8 C mobo: N/A gpu: amdgpu temp: 48 C
Info: Processes: 228 Uptime: 28m Memory: 6.76 GiB used: 2.32 GiB (34.2%)
Init: systemd Compilers: gcc: 10.1.0 clang: 10.0.0 Shell: bash v: 5.0.18
inxi: 3.0.37
Also if it helps I'm using video hybrid amd nvidia 440x prime driver
Ok so it turned it just showed me it at the login screen all I had to do was type in my password I couldnt see the login screen but when I finished typing it and pressed enter my display worked again
