SOLVED:Manjaro Gnome 3.28.2: how to make Trash Can visible in Favorites or Desktop?
Tips for posting
Use a "keyword search" to make sure your question has not already been asked. For example "failed to verify key" or "sound is muted".
Make sure you include enough detail so people know what you are running. A useful command is inxi -Fxz; copy and paste the text and format as "code" (e.g. use the </> button above).
If possible, paste text rather than upload a photo. Text is easier to read, searchable, and takes up less space on the server. Please don't upload high-resolution photos.
For more information read this post: How to provide good information in your posts
Remember to remove all of this help text before you post.
Hi,
I am using Manjaro 17 Gnome 3.28.2 and would like to see the Trash Can not only in "Files" but also in "Favorites" or on the Desktop. How can I do that, please?
Thanks, manjacub
P.S. I do not know how to correct my spelling error in the subject line. It should be "3.28.2".
Look for a shell extension(s) for one for the desktop. For the others, I dunno.
regards
I will go a bit off topic - it seems that in all the posts you created, you let the default text in place (a text meant to help you how to use it). That's why is called Tips for posting.
Have a look how is formatted, delete it after that, and place your comment instead.
Use the Edit icon at the end of the title
Read this to get some context to @c00ter's post above:
OK, perhaps the above link is to a pretty heated discussion.
Try this:
Thanks, I had read this before. But how about putting the Trash icon into Favorites?
I mean, it is easy to put an App into Favorites, just start an App and "add to favorites".
Why not with the trash can?
No idea. Have you searched for a gnome shell extension that does that?
In terminal, try
gsettings set org.gnome.nautilus.desktop trash-icon-visible true
No shell extension for that and
$ gsettings set org.gnome.nautilus.desktop trash-icon-visible true
No such schema “org.gnome.nautilus.desktop”
Have you tried a google search for "gnome trash can extension"?
Some things pop up that might help.
Yes, seems to be impossible right now with this new Gnome version. I test installed now Manjaro KDE, there is a Trash folder on the Desktop :slight_smile: This was not the only reason I installed KDE, just curious about it.
Just curious why not tried nautilus-legacy is the same is shipped with ubuntu :laughing:
Hi, here is the quick and dirty way :slightly_smiling_face:
-In your home directory open /.local/share/applications/
-Right click in this folder and create a empty desktop file
-Open this file with gedit and paste this content:
[Desktop Entry]
Type=Application
Icon=user-trash
Name=Trash
Name[de]=Papierkorb
Comment=open trash
Categories=FileManager;Utility;Core;GTK;
Exec=nautilus trash:///
StartupNotify=true
Terminal=false
MimeType=x-directory/normal;inode/directory;
Name[de_DE]=Papierkorb
-Rename the file to trash.desktop
-Restart the GNOME shell with Alt+F2+r
-Type trash in the search and pin it to your Dock.
Enjoy :wink:
It does not work :sob:
This works, Trash Can opens with full functionality
...and pin it to your Dock
How? It does not appear in the Favorites when open (like other programs I start)
P.S. I am back on Manjaro 17 Gnome 3.28.2. What is your version?
Search it, right click on it, add it to Favorites
It looks completely different with my system:
trashDesktop
What could be the problem?
Not much of a problem, but you are using the Menu, while i was using the Dash (Show Applications)
Sorry, I am a Manjaro newbie and do not understand what you mean. I now the Dash from Ubuntuversions prior to 18.04, and could do Dash searches to my heart's extent. But my Manjaro Gnome Desktop has only the Favorites tool bar as seen here:
WholeDesktop
Please direct me to Manjara Gnome's Dash, thank you!
Your lower left corner, the icon with 9 dots ... :slight_smile:
Thank you very much :thumbsup:
Now I have a beautiful and working Trashcan in my Favorites :slight_smile:
