Dear Manjaro mates,
I' can't see any wifi network from my fresh Manjaro 19 System on Lenovo 340 laptop, I installed it from a live USB flash mem disc over LAN connection some days ago.
Yesterday I tried to activate the wifi from Panel and via
Manjaro Menu -> Settings -> Advanced Network Config
: nothing reminiscent of wifi only the VPN or ethernet stuff was visible, as if the installer had ignored the existence of the wifi hardware of my PC.
Actually only the LAN connects me.
Before getting into the longish kernel and system config described in [SOLVED] RTL8821CE Wi-Fi not working and hoping it would be overkill in my situation:
is there a simple way to use the wifi hardware in case it is already supported by my Manjaro system ? For example I tried also with
# nmcli dev wifi list
, unftly any output is missig.
Any suggestion for using the wifi support in case it has been installed ?
Thank you
Groen
PS I got
hwinfo --netcard --bluetooth
14: PCI 100.0: 0280 Network controller
[Created at pci.386]
Unique ID: VCu0.e_pxpmpLJP8
Parent ID: 1GTX.Ijneoxq_8yF
SysFS ID: /devices/pci0000:00/0000:00:1d.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: network
Model: "Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter"
Vendor: pci 0x10ec "Realtek Semiconductor Co., Ltd."
Device: pci 0xc821 "RTL8821CE 802.11ac PCIe Wireless Network Adapter"
SubVendor: pci 0x17aa "Lenovo"
SubDevice: pci 0xc024
I/O Ports: 0x4000-0x4fff (rw)
Memory Range: 0xa1200000-0xa120ffff (rw,non-prefetchable)
IRQ: 11 (no events)
Module Alias: "pci:v000010ECd0000C821sv000017AAsd0000C024bc02sc80i00"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #21 (PCI bridge)
