I have gotten closer to figuring this out. I use Mullvad commercial VPN service on all my machines and I figured out that if I disconnect from the VPN the connectivity issue goes away in about a minute. The question is whether or not my ISP is throttling my traffic when connected to the VPN or if it is just limited connectivity due to the VPN.
I did a test with traceroute to try and figure this out:
Traceroute connected to VPN:
traceroute to google.com (74.125.136.102), 30 hops max, 60 byte packets 1 10.15.0.1 (10.15.0.1) 27.952 ms 27.913 ms 27.891 ms 2 208.84.153.141 (208.84.153.141) 27.923 ms 28.049 ms 28.183 ms 3 vl82.br02.atl02.as46562.net (199.229.255.28) 27.724 ms 27.757 ms 27.737 ms 4 aix.pr1.atl.google.com (198.32.132.41) 27.719 ms 27.761 ms 27.651 ms 5 108.170.249.35 (108.170.249.35) 27.913 ms 108.170.249.44 (108.170.249.44) 27.677 ms 108.170.249.162 (108.170.249.162) 27.656 ms 6 72.14.233.145 (72.14.233.145) 28.141 ms 209.85.248.247 (209.85.248.247) 21.011 ms 209.85.250.68 (209.85.250.68) 21.908 ms 7 216.239.50.104 (216.239.50.104) 20.954 ms 209.85.240.202 (209.85.240.202) 28.469 ms 108.170.236.123 (108.170.236.123) 20.960 ms 8 209.85.247.91 (209.85.247.91) 22.792 ms 209.85.247.95 (209.85.247.95) 23.219 ms 108.170.231.157 (108.170.231.157) 21.853 ms 9 * * * 10 * * * 11 * * * 12 * * * 13 * * * 14 * * * 15 * * * 16 * * * 17 * * * 18 74.125.136.102 (74.125.136.102) 21.610 ms 21.606 ms 21.652 ms
Traceroute disconnected from VPN:
traceroute to google.com (74.125.21.113), 30 hops max, 60 byte packets 1 _gateway (192.168.1.1) 0.263 ms 0.261 ms 0.335 ms 2 * * * 3 96-34-95-2.static.unas.la.charter.com (96.34.95.2) 17.000 ms 17.498 ms 17.564 ms 4 crr01spbgsc-bue-202.spbg.sc.charter.com (96.34.64.8) 22.478 ms 22.465 ms 21.463 ms 5 bbr01spbgsc-bue-3.spbg.sc.charter.com (96.34.2.48) 27.375 ms 23.437 ms 24.369 ms 6 bbr02slidla-tge-0-1-0-4.slid.la.charter.com (96.34.0.133) 26.384 ms 29.802 ms 32.944 ms 7 prr01snjsca-tge-0-0-0-1.snjs.ca.charter.com (96.34.3.35) 32.016 ms 23.033 ms 22.904 ms 8 96-34-150-71.static.unas.mo.charter.com (96.34.150.71) 22.426 ms 28.423 ms 72.14.220.17 (72.14.220.17) 25.003 ms 9 108.170.249.163 (108.170.249.163) 31.106 ms 108.170.249.44 (108.170.249.44) 28.321 ms 108.170.249.162 (108.170.249.162) 28.466 ms 10 209.85.246.223 (209.85.246.223) 26.018 ms 216.239.63.88 (216.239.63.88) 32.080 ms 108.170.236.128 (108.170.236.128) 31.922 ms 11 209.85.240.202 (209.85.240.202) 28.337 ms 209.85.243.2 (209.85.243.2) 28.410 ms 108.170.228.161 (108.170.228.161) 27.498 ms 12 209.85.247.93 (209.85.247.93) 22.979 ms 108.170.228.163 (108.170.228.163) 28.309 ms 209.85.247.89 (209.85.247.89) 26.121 ms 13 * * * 14 * * * 15 * * * 16 * * * 17 * * * 18 * * * 19 * * * 20 * * * 21 * * * 22 yv-in-f113.1e100.net (74.125.21.113) 28.410 ms * 25.002 ms
I called my ISP and they said they do not throttle VPN traffic but some users online say that Charter Spectrum is untruthful about this.
inxi -Fxxxz
System: Host: 2600x Kernel: 4.19.66-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: KDE Plasma 5.16.4
tk: Qt 5.13.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop System: Gigabyte product: B450 I AORUS PRO WIFI v: N/A serial: <filter>
Mobo: Gigabyte model: B450 I AORUS PRO WIFI-CF v: x.x serial: <filter> UEFI: American Megatrends v: F40
date: 05/16/2019
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360 serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: Discharging
CPU: Topology: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ rev: 2 L2 cache: 3072 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86257
Speed: 2512 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 2512 2: 2027 3: 2135 4: 2974 5: 2897
6: 2681 7: 2041 8: 2172 9: 2820 10: 2005 11: 2393 12: 2477
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: eVga.com. driver: nvidia v: 430.40 bus ID: 0a:00.0
chip ID: 10de:1c82
Display: x11 server: X.Org 1.20.5 driver: nvidia compositor: kwin_x11 resolution: 1920x1200~60Hz
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 430.40 direct render: Yes
Audio: Device-1: NVIDIA GP107GL High Definition Audio vendor: eVga.com. driver: snd_hda_intel v: kernel bus ID: 0a:00.1
chip ID: 10de:0fb9
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus ID: 0c:00.3 chip ID: 1022:1457
Device-3: Logitech Headset H390 type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 3-2.2:5
chip ID: 046d:0a44
Sound Server: ALSA v: k4.19.66-1-MANJARO
Network: Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus ID: 07:00.0 chip ID: 8086:2526
IF: wlp7s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: 5.4.0-k port: f000 bus ID: 09:00.0
chip ID: 8086:1539
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 953.87 GiB used: 118.46 GiB (12.4%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
rev: 002C scheme: GPT
Partition: ID-1: / size: 920.63 GiB used: 74.57 GiB (8.1%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: swap-1 size: 17.24 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 43.6 C mobo: 27.0 C gpu: nvidia temp: 28 C
Fan Speeds (RPM): cpu: 0 fan-1: 0 fan-3: 0 gpu: nvidia fan: 30%
Voltages: 12v: N/A 5v: N/A 3.3v: 1.68 vbat: 1.59
Info: Processes: 275 Uptime: 14m Memory: 15.67 GiB used: 2.53 GiB (16.2%) Init: systemd v: 242 Compilers: gcc: 9.1.0
Shell: bash v: 5.0.7 running in: yakuake inxi: 3.0.35
cat /etc/resolv.conf
# Generated by NetworkManager
nameserver 10.15.0.1
The above commands are done with me connected through the VPN service.
Do you understand the traceroute output? If we can figure out if it is ISP throttling vs. the VPN service this issue will be solved. Thanks for all your help @tbg !!!
