[solved]Not able swtich input method in some applications
Hi,
I am switching from Ubuntu18.04 to Manjaro Gnome18.
I normally need to input Chinese and English. so I installed the sogou Chinese input method with following commands:
sudo pacman -S fcitx-im
sudo pacman -S fcitx-configtool
sudo pacman -S fcitx-sogoupinyin
and add the sogoupin in the fcitx configuration tool then after a reboot the system, it works well in most applications, I can easily switch between English and Chinese by pressing "CTRL"+"SPACE"
However, in some applications like "WPS", I am not able to toggle the input method
Does anyone know why?
Thanks.
BRs
TQ
I find the way to fix this.
add following lines to ~/.xprofile
export GTK_IM_MODULE=fcitx
export QT_IM_MODULE=fcitx
export XMODIFIERS="@im=fcitx"
BRs
TQ
