Hello! I have searched and am not finding an issue quite like the one I am experiencing. Wifi speeds are slow, ethernet is snappy and quick. I am running a mid 2012 Macbook Pro. macos, windows, and KDE Neon do not have the wifi problems.
I assumed this was due to the broadcom wifi drivers which have proven to be a headache in the past, but I have a USB wifi adapter (Alfa AWUS036NEH) which has worked perfectly - plug & play - with every distro I've tried. However, I get the slow wifi speeds on the Alfa as well as with the internal wifi.
inxi -Fxz outputs the following:
Host: heisenberg Kernel: 4.19.28-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 8.2.1 Desktop: KDE Plasma 5.15.2 Distro: Manjaro Linux
Type: Laptop System: Apple product: MacBookPro9,1 v: 1.0 serial: <filter>
Mobo: Apple model: Mac-4B7AC7E43945597E v: MacBookPro9,1 serial: <filter>
UEFI: Apple v: 222.0.0.0.0 date: 09/21/2018
ID-1: BAT0 charge: 30.0 Wh condition: 44.3/75.2 Wh (59%)
model: SMP bq20z451 status: Charging
Topology: Quad Core model: Intel Core i7-3615QM bits: 64 type: MT MCP
arch: Ivy Bridge rev: 9 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36728
Speed: 1197 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1197 2: 1197
3: 1198 4: 1197 5: 1197 6: 1197 7: 1197 8: 1197
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
v: kernel bus ID: 00:02.0
Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple
driver: nvidia v: 390.116 bus ID: 01:00.0
Display: x11 server: X.Org 1.20.4 driver: nvidia resolution: 1440x900~60Hz
OpenGL: renderer: GeForce GT 650M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.116
direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k4.19.28-1-MANJARO
Device-1: Broadcom and subsidiaries NetXtreme BCM57765 Gigabit Ethernet
PCIe
driver: tg3 v: 3.137 port: 2000 bus ID: 02:00.0
IF: enp2s0f0 state: down mac: <filter>
Device-2: Broadcom and subsidiaries BCM4331 802.11a/b/g/n
driver: bcma-pci-bridge v: N/A port: 2000 bus ID: 03:00.0
IF-ID-1: wlp3s0b1 state: up mac: <filter>
Local Storage: total: 931.51 GiB used: 27.04 GiB (2.9%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB
ID-1: / size: 159.42 GiB used: 27.02 GiB (16.9%) fs: ext4 dev: /dev/dm-0
System Temperatures: cpu: 71.0 C mobo: N/A gpu: nvidia temp: 60 C
Processes: 241 Uptime: 12m Memory: 7.73 GiB used: 2.85 GiB (36.9%)
Init: systemd Compilers: gcc: 8.2.1 Shell: bash v: 5.0.0 inxi: 3.0.32
lscpi -v gives me this (obv I've cut out a lot of irrelevant stuff):
03:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4331 802.11a/b/g/n (rev 02)
Subsystem: Broadcom Inc. and subsidiaries BCM4331 802.11a/b/g/n
Flags: bus master, fast devsel, latency 0, IRQ 17
Memory at c1a00000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Capabilities: [58] Vendor Specific Information: Len=78 <?>
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [d0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [13c] Virtual Channel
Capabilities: [160] Device Serial Number 00-00-00-ff-ff-00-00-00
Capabilities: [16c] Power Budgeting <?>
Kernel driver in use: bcma-pci-bridge
Kernel modules: bcma
iwconfig gives me this:
enp2s0f0 no wireless extensions.
wlp3s0b1 IEEE 802.11 ESSID:"milksteak"
Mode:Managed Frequency:2.462 GHz Access Point: DC:FE:07:9C:D7:58
Bit Rate=36 Mb/s Tx-Power=30 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=63/70 Signal level=-47 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:321 Invalid misc:1758 Missed beacon:0
lo no wireless extensions.
All of that is without the Alfa USB adapter plugged in. I assume some of that will be irrelevant given the fact this happens with either device, but I hope that's enough information. I appreciate any assistance.
