[SOLVED] R8168 Wired network connection not working
it is, in manjaro settings Manager, network-r9168 is not installed, there doesnt appear to be any other controller for it available. I installed it before but then uninstalled it again to check if the driver 169 would click, it hasnt.
Turn your wifi off via the function key, airplane mode etc.
Reboot with the wifi turned off.
Save the instructions below and run them after you reboot with no wifi on.
Run the set of commands below to see if your connection can be properly initiated.
Please do not cut and paste all the commands together at once.
Enter and run each command separately with a few seconds between each command.
Please post all inputs, and all outputs of that sequence of commands once they are finished being run.
Please do not give me a summary, such as "there were no outputs".
It is very important that you post each input and output for troubleshooting purposes.
nmcli networking off
sudo systemctl stop NetworkManager
sudo ip link set enp59s0 down
sudo modprobe -r r8168
sudo modprobe -r r8169
sudo modprobe r8169
sudo ip link set enp59s0 mode default
sudo ip link set enp59s0 up
sudo systemctl start NetworkManager
nmcli networking on
nmcli r wifi off
nmcli r wifi on
Turn your wifi back on if the LAN connection is not working, then post all the outputs from those commands.
[gabriel@Amroth-pc modprobe.d]$ sudo systemctl stop NetworkManager
[sudo] password for gabriel:
[gabriel@Amroth-pc modprobe.d]$ sudo ip link set enp59s0 down
[gabriel@Amroth-pc modprobe.d]$ sudo modprobe -r r8168
modprobe: FATAL: Module r8168 not found.
[gabriel@Amroth-pc modprobe.d]$ sudo modprobe -r r8169
[gabriel@Amroth-pc modprobe.d]$ sudo modprobe r8169
[gabriel@Amroth-pc modprobe.d]$ sudo ip link set enp59s0 mode default
[gabriel@Amroth-pc modprobe.d]$ sudo ip link set enp59s0 up
[gabriel@Amroth-pc modprobe.d]$ sudo systemctl start NetworkManager
[gabriel@Amroth-pc modprobe.d]$ nmcli networking on
[gabriel@Amroth-pc modprobe.d]$ nmcli r wifi on
[gabriel@Amroth-pc modprobe.d]$ nmcli r wifi off
And was there any change in the network status?
Please post the output of the following command:
hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
Still no signal from the wired connection.
Model: "Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
Driver: "r8169"
Device File: enp59s0
Link detected: no
Driver Status: r8169 is active
Driver Activation Cmd: "modprobe r8169"
Model: "Intel Wireless 8265 / 8275"
Driver: "iwlwifi"
Device File: wlp60s0
Link detected: yes
Driver Status: iwlwifi is active
Driver Activation Cmd: "modprobe iwlwifi"
Model: "Intel Bluetooth Device"
Driver: "btusb"
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
I would install and test kenel 5.0.
if not working
then install kernel 5.1
Install kernels through Manjaro Settings Manager, and always have at least two kernels installed at all times for safety.
It works now, I disconnected from the wifi again just to be sure and now it's working again, thank you very much. Visually the wired connection doesnt show in the network window, so it just connects to the wired one. In system settings module it does appear and it connecting so all good.
Thank you.
Have you swapped in alternate cables and tested other ports on the router. Are the lights on-the back of the LAN connection on the back of the computer lit.
Glad to hear it's working now. You had me worried there for a bit.
Me two, not sure what to check as to solved, swapping drivers?
Hard to say, because a lot of things were tested out. Take your pick. You want to check that you have different IP addresses being assigned to both adapters. They could be conflicting and causing problems. I would suggest disabling WiFi if using LAN, and vice versa.
Yep, I'm gonna keep doing that and get a second kernel.
